I have another car that is driving me quietly mad!
2001 A3 (8P) UK model, with a battery drain of around 280mA.
The conditions to set the problem are an ignition on/off cycle. When the battery is freshly connected, no problem with around a 22mA drain. Cycle the ignition on and off and the drain increases to around 280mA and stays there whether its locked or not. if the battery is disconnected the fault goes away until the key is cycled again.
Removing fuse 15 in the passenger compartment fusebox drops the drain to around 8mA. That fuse is marked instrument cluster and autobox (this car is a manual).
I thought it might be the alarm horn H12, TPS (the VAG parts supply in UK) said the horn is in the windscreen scuttle but it isn't. Looking behind the sub-woofer in the boot I can't see one but there is a 3-pin connector there that is unused although the cable appears a little short.
There appear to be several references on the internet about a similar drain on fuse 15 but no definitive answers.
Any ideas?
Tuesday,05,March,2019,14:51:54:20505
VCDS -- Windows Based VAG/VAS Emulator Running on Windows Vista x86
VCDS Version: 18.9.1.0
Dealer/Shop Name: Response Diagnostics 01732 863344
VIN: WAUZZZ8L92A040216 License Plate: FG51XNX
Mileage: 135593 Repair Order:
Chassis Type: 8L (8L - Audi A3/S3 (1997 > 2005))
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 01: Engine Labels: None
Part No: 06A 906 032 EE
Component: 1.8L R4/5VS MOTR 0001
Coding: 10500
Shop #: WSC 06435
VCID: 65C58DC5FF31DF624E-5120
WAUZZZ8L92A040216 AUZ5Z0A8120083
18010 - Power Supply Terminal 30
P1602 - 35-10 - Voltage too Low - Intermittent
16711 - Knock Sensor 1 (G61)
P0327 - 35-10 - Signal too Low - Intermittent
17852 - Potentiometer for EGR (G212)
P1444 - 35-10 - Implausible Signal - Intermittent
16795 - Secondary Air Injection System
P0411 - 35-10 - Incorrect Flow Detected - Intermittent
17544 - Fuel Trim: Bank 1 (Add)
P1136 - 35-00 - System too Lean
Address 03: ABS Brakes Labels: 1C0-907-37x-ESP-F.lbl
Part No: 1C0 907 379 E
Component: ESP FRONT MK60 0104
Coding: 0011266
Shop #: WSC 06435 000 00000
VCID: 2C5338E18C5B2E2A51-513C
Address 08: Auto HVAC Labels: Redir Fail!
Part No: 8L0 820 043 H
Component: A3 KLIMAAUTOMAT 0105
Coding: 00041
Shop #: WSC 06435
VCID: 2D5535E5E741272246-2578
01582 - Signal for Coolant Temperature
30-00 - Open or Short to Plus
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 5008
Coding: 01104
Shop #: WSC 06435
VCID: 45856D455FF1FF62AE-515A
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 950 E
Component: KOMBI+WEGFAHRS. M73 D02
Coding: 00442
VCID: 326F2699FE7F78DA1B-4B00
53-10 - Supply Voltage Too Low - Intermittent
Address 35: Centr. Locks Labels:. 8D0-862-257.lbl
Part No: 8D0 862 257 E
Component: CV-Pump, Alarm, RC D17
Coding: 15178
Shop #: WSC 06435
VCID: 2F692FEDED4D553274-4F02
9 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
35-00 - -
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01366 - Opened Due to Crash Signal
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
01134 - Alarm Horn (H12)
49-00 - No Communications
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
VCID: 60CB9CD1E013BA4ABD-4B00
Address 56: Radio Labels: 8E0-035-1xx-56.lbl
Part No: 8E0 035 186 J
Component: concert II GRO 0008
Coding: 01001
Shop #: WSC 63251
VCID: 2E5732E9EA475C3A7F-4B00
36-00 - Open Circuit
End-------------------------(Elapsed Time: 03:57)--------------------------
