GOLF 6 16TDI STOP START ISSUE
audivwauto1
South Africa
C?ID=260881
GOLF 6 16TDI 2011
MANUAL 5 SPEED
NO TIRE MONITORING
original fault was P0601 00 (096)- Memory check sum error
Intermittent- not confirmed
i did a software update and never solved it ,tested the battery had measured low Ah like 20ah instead of 68ah.
Stop start only works if the car stalls on pull away ,the decrease the clutch it starts
no other function works besides that.
i did find readiness fault
Monday,25,February,2019,10:38:58:16946
VCDS Version: 18.9.1.0 (x64)  HEX-NET CB: 0.4436.4
Dealer/Shop Name: AUDI VW AUTO CLINIC
Workshop Code: 996 02232 000010
VIN: WVWZZZ1KZBW100085   License Plate:
Chassis Type: 1K-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 61 62 72
VIN: WVWZZZ1KZBW100085   Mileage: 100050km-62168miles
Address 01: Engine (J623-CAYC)       Labels:. 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 HM    HW: 03L 906 023 A
   Component: 1,6l R4 CR td H23 9970
   Revision: --H23---    Serial number: 00000000000000
   Coding: 00114014032501080000
   ASAM Dataset: EV_ECM16TDI02103L906023HM 003011
   ROD: EV_ECM16TDI02103L997557R.rod
   VCID: 78BC0D43C391798AE5-802C
Readiness: 0100 0000
   Part No SW: 1K0 907 379 BE    HW: 1K0 907 379 BE
   Component: ESP MK60EC1   H31 0108
   Revision: 00H31001
   Coding: 133B200D092200FAC80B04EC901E0091310000
   VCID: 76A0037BC1850FFAF7-8022
   Part No SW: 3C8 907 336 AB    HW: 3C8 907 336 AB
   Component: Climatic      H14 0305
   Revision: 00009001
   Coding: 0000001003
   ROD: EV_ClimaBasis_VW36.rod
   VCID: 6D922C17BCD3CC2206-8038
   Part No SW: 1K0 937 084 D    HW: 1K0 937 084 D
   Component: BCM PQ35  B   103 0615
   Revision: 00103 AD
   Coding: 48180A3A8025F1C040080080100000E441010088424D8160648087200041
   VCID: 2F2EF61F7E5F7E3274-807A
   Subsystem 1 - Part No: 1K2 955 119 F  Labels: 1KX-955-119.CLB
   Component: Wischer 15091  26  0512
   Coding: 009795
   Subsystem 2 - Part No: 1K8 951 171
   Subsystem 3 - Part No: 1K8 951 605 A
   Component: LIN BACKUP HO  H11 9004
   Part No SW: 5K0 959 655 D    HW: 5K0 959 655 D
   Component: AirbagVW10    037 0606
   Serial number: 003FKRACUL7G
   Coding: 00003133
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 3B36D24FB2279292C8-806E
   Serial number: 3572MSME20426354ZZZJ
   Serial number: 3582MSME630C6458ZZZ
   Serial number: 3512QSME36256D6CZZZ1
   Serial number: 3522QSME38176F22ZZZ-
   Part No SW: 5K0 953 507 BC    HW: 5K0 953 549 E
   Component: Lenks.Modul   007 0080
   Revision: --------    Serial number:  90422JI9000BS
   Coding: 1082140000
   ROD: EV_SMLSNGKUDS_A05.rod
   VCID: 72A83F6BA5ED13DADB-8026
   Serial number: 70000000000000069851
   Coding: E20000
   Part No SW: 5K0 920 871 A    HW: 5K0 920 871 A
   Component: KOMBI         H03 0406
   Coding: 170B00
   VCID: 2C14E1134749052A51-8078
Address 19: CAN Gateway        Labels:. 7N0-907-530-V1.clb
   Part No SW: 7N0 907 530 A    HW: 1K0 907 951
   Component: J533  Gateway   H25 5603
   Revision:   H25       Serial number: 160910F1001357
   Coding: E9807F0600020204000003
   VCID: 2E10EB1BB955773A7F-807A
   Component: IMMO          H03 0406
   VCID: 6A98270B8D3DDB1A63-803E
   Component: Tuer-SG         009 2120
   Coding: 0000692
   VCID: 312AF067A86B68C262-8064
   Part No: 1K0 909 144 J
   Revision: 00H17000
   Coding: 0131764
   VCID: 3228FF6BAD6D53DA1B-8066
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2K8296925
   Coding: 0500040004
   VCID: 658254376C23F4624E-8030
   Component: Batt.regelung H25 5603
   Coding: 030B185A
   VCID: 71AA3067A8EB28C222-8024
   Subsystem 1 - Part No SW: 1K0 915 181 C    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0125
   Serial number: 00000000002790369576
   Coding: 0131216
   Shop #: WSC 01357 011 1012552
   VCID: 3522C4775C0344E23E-8060
   Coding: 0131216
   VCID: 3620C37B41054FFA37-8062
End----------(Elapsed Time: 01:03, VBatt start/end: 12.9V/12.9V)-----------
readiness
oxygen sensor failed or incomplete(red)
Tiptop
C?ID=127746
If it’s the original battery and with the low reading I would suspect that a new one is required, start stop will only work with a battery fully charged and in good condition
audivwauto1
South Africa
C?ID=260881
i have fitted a new battery with correct amps as required (68ah),must i code the battery modual ?
Tiptop
C?ID=127746
Yes I think you have to let it know it’s a new battery
audivwauto1
South Africa
C?ID=260881
ok thanks i did use the vas but cant find the part number they asking for
PetrolDave
Westbury, UK
C?ID=1423
DOn't worry about the part number, just change the serial number to anything different from the current value - if the battery is the same capacity and type that's all you need to change.
audivwauto1
South Africa
C?ID=260881
ok will do it first thing in the morning
audivwauto1
South Africa
C?ID=260881
morning guys ,i never changed the part number ,,one thing ii noticed i took the car home last night .if i pump the clutch pedal a few times quickly..stop start function works .
i see there is a part called a hall sensor that fits on the clutch slave cylinder ,could be faulty part number on parts link 24 ..is 1K0 927 810D.
