How to prime high pressure pump and other madness ...
timeforprunejuice
C?ID=357523
Hi Folks,
I replaced both of my fuel pumps and filter a month ago and bought VCDS and was able to prime both pumps and get the car going. I filled the tank twice and smelled gas both times. In an effort to fix the issue, i wanted to clean the o-ring and lube it with silicone, but it went wrong. I had too much gas in the tank and it leaked, I then just tightened the lid and cleaned up the mess ... I did not prime the pumps.
I drove to work the next day - 10 miles - all was well ... On the way home, I had a misfire. :(
Well, I can find where to prime to fuel pump in the tank in the rear, but I can't find the option to prime the high pressure fuel pump up front. Where is it!?! Where is this in the menus?
Also, I replaced the door lock with a new one from China and the alarm stopped working. I have a used OEM replacement, and that will fix that error. I also replaced a broken rear window and the glass break sensor is not connected.
Thanks ...
 Wednesday,20,February,2019,17:08:05:57978
Mileage: 160620km-99804mi   Repair Order:
Chassis Type: FL-AU48 (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 6C
          72
Mileage: 160620km-99804miles
Address 01: Engine (DL0MA-CAEB)       Labels:| 06H-907-115-CAB.clb
   Component: 2.0l R4/4V TF H15 0001
   Revision: E1H15---
   Coding: 010C010A190F0160
   Shop #: WSC 26110 444 11239
   VCID: 79AFEF640957756FD93-802C
4063 - Cylinder 4
          P0304 00 [237] - Misfire Detected
                    Mileage: 160607 km
                    Date: 2019.02.19
                    Time: 16:54:50
                    Engine speed: 4147.50 /min
                    Normed load value: 90.6 %
                    Vehicle speed: 61 km/h
                    Coolant temperature: 77 °C
                    Intake air temperature: 18 °C
                    Voltage terminal 30: 14.135 V
4057 - Cylinder 2
          P0302 00 [096] - Misfire Detected
7960 - Cylinder Disabling
          P130A 00 [044] - -
                    Mileage: 160619 km
                    Date: 2019.02.19
                    Time: 19:12:57
                    Engine speed: 795.00 /min
                    Normed load value: 14.9 %
                    Coolant temperature: 60 °C
                    Intake air temperature: 42 °C
                    Voltage terminal 30: 13.216 V
4051 - Random/Multiple Cylinder Misfire Detected
          P0300 00 [109] - -
                    Mileage: 160607 km
                    Date: 2019.02.19
                    Time: 16:54:50
Address 02: Auto Trans (J217)       Labels:| 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H05 0008
   Revision: --H05---
   Coding: 001012
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3D273B745DFF894FB5B-8068
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   VCID: 7AADF0680CD17E77D09-802E
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Fault Frequency: 11
                    Reset counter: 245
                    Mileage: 159906 km
                    Date: 2019.01.26
                    Time: 13:45:32
                    Hex Value: 0x5500
                    Hex Value: 0x4006
                    Hex Value: 0x1237
                    Hex Value: 0x1CB6
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 DG    HW: 8K0 907 064 DG
   Component: BCM2 1.1      H02 0324
   Coding: 090200
   VCID: 78A9EA6032DD6C67A6D-802C
   Serial number: 0509000048206006
   Serial number: 0209000057643010
   Part No SW: 8T1 820 043 AQ    HW: 8T1 820 043 AQ
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01230920090312
   Coding: 64102000
   VCID: 005982806A0D24A79ED-8054
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000469849
   Coding: 26001091063CAF010000080300003D0D0F1C460800010161000000
   VCID: 3C21367046658047825-8068
   Component: WWS 190909  H06 0070
   Serial number: SWF09090195930
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10603543
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000001109090958
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
Address 10: Park/Steer Assist (J446)       Labels:. 8K0-919-475.clb
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940927202021
   Coding: 200103
   VCID: 3E253C7850799257AC1-806A
   Part No SW: 8K0 959 655 H    HW: 8K0 959 655 H
   Component: AirbagVW-AU10 H37 0520
   Serial number: 003EGD02DCK7
   VCID: 42DD48882401F6B7C89-8016
   Serial number: 5810000R0900004F53
   Serial number: 6334MSME4B14563DK
   Serial number: 6344MSME4B743519I
   Serial number: 6352QSME633B5136F
   Serial number: 6362QSME3E3C062EW
   Serial number: 63732SME753C3F0EF
   Serial number: 63832SME753C1100T
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90319III000DA
   Coding: 000017
   VCID: 3D273B745D7F894FB5B-8068
00886 - Turn Signal Switch (E2)
                    Fault Status: 00101110
                    Fault Frequency: 55
                    Reset counter: 26
                    Mileage: 158034 km
                    Date: 2018.11.20
                    Time: 20:11:25
   Part No SW: 8K0 920 980 M    HW: 8K0 920 980 M
   Component: KOMBIINSTR.   H19 0253
   Revision: 00300000    Serial number: BXM21NY79
   Coding: 8B1611000300D705020000
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E099118355
   Coding: 00C303
   VCID: 52FD78C8F4E16637789-8006
   Component: J367-BDM  H06 0170
   Serial number: 1908EC98040909
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009309652
   Coding: 011C03204000410001
   VCID: 45D7539435AFC18FEDB-8010
            008 - Implausible Signal
                    Fault Status: 01101000
                    Reset counter: 56
                    Mileage: 145889 km
                    Date: 2018.01.25
                    Time: 12:02:32
   Revision: 00002001    Serial number: 0121668965
   Coding: 0126023A207A441400B0020000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000168357
   Subsystem 3 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J245 PS133  H06 0041
   Subsystem 4 - Part No SW: 8K0 959 591 A    HW: 8K0 959 591
   Component: J394 PS228  H06 0041
02615 - Fuel Tank Cap; Lock
                    Fault Status: 00101001
                    Fault Frequency: 42
                    Reset counter: 17
                    Mileage: 145889 km
                    Date: 2018.01.25
                    Time: 12:02:32
02616 - Fuel Tank Cap; Unlock
                    Fault Frequency: 8
                    Reset counter: 21
                    Mileage: 145889 km
                    Date: 2018.01.25
                    Time: 14:49:18
01403 - Glass-Break Sensors; Rear
                    Fault Status: 01101011
                    Reset counter: 201
                    Mileage: 159922 km
                    Date: 2009.04.28
                    Time: 00:00:00
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009323099
   VCID: 44D14E903E95F887FA5-8010
   Revision: 00000003    Serial number: 10000000325279
   VCID: 34311E506E3548074A5-8060
   Part No: 8K5 907 357
   Coding: 0000004
   Shop #: WSC 06334 000 00000
   VCID: 77ABE95C33C3631FAF7-8022
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335I/097529517
   Coding: 020000020100000001
   VCID: 1D67DBF4FDBFE94F95B-8048
02984 - Connection between Impedance Converter 2 and Window Antenna
                    Reset counter: 56
                    Mileage: 145888 km
                    Date: 2018.01.25
                    Time: 10:20:24
                    Voltage: 14.50 V
02788 - Internal Communications Error
            000 -  -
                    Reset counter: 188
                    Mileage: 159671 km
                    Date: 2019.01.15
                    Time: 20:15:05
                    Bin. Bits: 00000001
   Part No SW: 8T1 035 664 F    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0189
   Revision: --------    Serial number: 490I 097516760
   Coding: 010200010006A1EF01000B0E000000030000
   VCID: 3B23356C436B877F8BF-806E
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 4F0 919 604     HW: 4F0 919 604
   Component: DU7 High  H43 0306
   Serial number: 9356I$091072688
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000364660
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
            000 -  -
                    Reset counter: 242
                    Mileage: 160488 km
                    Date: 2019.02.16
                    Time: 12:43:12
                    Voltage: 14.80 V
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101933898
   Coding: 010C03204000210001
   VCID: 42DD48882481F6B7C89-8016
   Revision: --H03---    Serial number: 525PA8-J9890WE
   Coding: 1000007
   Shop #: WSC 06325 000 00000
   VCID: 38292A607E5DAC6766D-806C
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101933891
End----------(Elapsed Time: 01:49, VBatt start/end: 12.2V/12.2V)-----------
Hi Folks,
Thanks ...
Component: 2.0l R4/4V TF H15 0001 <<<<<<<<<<<<<<<<<<<<< Firmware update needed!
Hello and welcome OP
Can you clear all fault codes and then do a re-scan after car has idled for at least 1-5 minutes and also post the OBD2 DTC's + MODE 9 DATA too?
Have you changed the injectors too?
Did you read the RTFB on fuel system procedures?
http://wiki.ross-tech.com/wiki/index.php/Official_Factory_Repair_Information
JPPSG
When working with sealing o-rings on fuel systems use seal lube or equivalent never silicone!
https://www.aircraftspruce.com/catalog/cspages/ezturnlube.php
Z
timeforprunejuice
C?ID=357523
OK, so I ordered EZ-Turn and will have it by the weekend. I have not RTFM, but will try to do so ASAP.
1) How can I get the firmware upgrade for the car?
2) I'll post a new report tomorrow.
3) I think I paid a guy to replace the injectors in October, will check ...
4) Were is the option to prime the high pressure pump?
Thanks ...
