VW T5 7H
SlowikTM
C?ID=340593
Hello I have problem.
VW T5 7H had removed the all wheel drive (4motion) end than in brake electronics was a dtc "no conection with all wheel drive "
I changed the coding in engine and in brake electronics but now i have another dtc 01044
Saturday,26,January,2019,15:47:27:62095
VCDS Version: 18.2.1.5 (x64)  HEX-NET CB: 0.4436.4
VIN: WV1ZZZ7HZ8H035453   License Plate:
          57 6E 76 77 78 7D
VIN: WV1ZZZ7HZ8H035453   Mileage: 255020km-158462miles
Address 01: Engine        Labels: 070-906-016-BPC.clb
   Part No SW: 070 906 016 EC    HW: 070 906 016 DS
   Component: R5 2,5L EDC G001SG  2539
   Revision: --H05---    Serial number: VWZ7Z0G5743126
   Coding: 0000032
   Shop #: WSC 61152 001 104857
   VCID: D5E2F5B87DF359ECA7-5184
005213 - Exhaust Gas Temperature Sensor 3
               P145D - 000 - Short to Plus
                    Mileage: 255027 km
                    RPM: 777 /min
                    Voltage: 14.52 V
                    Temperature: 0.0°C
                    Temperature: 126.0°C
                    Temperature: 90.0°C
                    Temperature: 324.0°C
006400 - Coolant Fan Control 2
               P1900 - 000 - Open or Short to Ground - Intermittent
                    Mileage: 255027 km
                    RPM: 777 /min
                    Load: 0.0 %
                    Voltage: 14.52 V
                    Bin. Bits: 00001000
                    Temperature: 45.9°C
                    Duty Cycle: 9.7 %
Address 03: ABS Brakes        Labels: 7H0-907-37x-ESP.lbl
   Part No SW: 7H0 907 379 R    HW: 7H0 907 379 R
   Component: ESP MK25E1          0104
   Revision: 00H31001
   Coding: 0000555
   Shop #: WSC 02756 790 00000
   VCID: C4C438FC8669D064C0-5160
                    Fault Status: 00100101
                    Reset counter: 40
                    Mileage: 255027 km
                    Count: 128
                    Count: 13057
                    Count: 212
                    Count: 255
            003 - Mechanical Failure
                    Fault Status: 01100011
                    Reset counter: 40
                    Mileage: 255027 km
                    Count: 128
                    Count: 12545
                    Count: 199
                    Count: 2049
   Part No: 7H0 820 045 AM
   Component: CLIMA/AC            0303
   VCID: F0ACA42CE2511CC454-5160
   Part No: 7H0 937 049 AD
   Component: BORDNETZ SGVER 1.0  2101
   Coding: 0000038
   Shop #: WSC 75531 146 73995
   VCID: F4A4A83C964920E4B0-5160
01598 - Drive Battery Voltage
            002 - Lower Limit Exceeded
02092 - Enabling Heated Seat
00925 - Fuse (30) for Interior Lamps (S261)
            014 - Defective
00991 - Interior Lights
   Part No: 1C0 909 605 A
   Component: 3C AIRBAG VW51      0010
   Coding: 13123
   Shop #: WSC 02756
   VCID: A2089E642C3DFE5492-5160
00532 - Supply Voltage B+
   Part No: 7H0 920 851 R
   Coding: 00113
   Shop #: WSC 19208
   VCID: BA384604A4AD9694AA-5160
   WV1ZZZ7HZ8H035453     VWZ7Z0G5743126
Address 18: Aux. Heat        Labels: 7H0-819-008.lbl
   Part No: 7H0 819 008 R
   Component: Standheizung        0209
   VCID: BB364300FB97AF9CB1-5160
01408 - Under-Voltage Shut-Off (fixed Value)
00664 - Fuel gauge
   Part No: 6N0 909 901
   Coding: 00006
   Shop #: WSC 02756
   VCID: F0ACA42CB2511CC454-5160
   Part No: 7H0 959 433 B
   Component: C11 Komfortgerát     0004
   Coding: 00025
   Shop #: WSC 02756
   VCID: B2286E247CDD6ED462-4B1E
   Part No SW: 7H0 035 156     HW: 7H0 035 156
   Component: Radio         009 0019
   Revision: R0009000    Serial number: VWZAZ1G4634769
   Coding: 0000020001
   Shop #: WSC 07936 044 612843
   VCID: E386DB60E3A7B75CD9-5160
Address 6E: Ctrl Head Roof        Labels: 7H5-919-044-W1.clb
   Part No SW: 7H5 919 044 J    HW: 7H5 919 044 J
   Component: J702  Dachdisplay   0500
   Revision: 1010007S    Serial number: 00000000028806
   VCID: B93A5908F1AB9D8CA3-5160
                    Fault Frequency: 64
                    Reset counter: 23
                    Date: 2019.01.13
                    Time: 02:27:24
End----------(Elapsed Time: 06:02, VBatt start/end: 14.5V/14.4V)-----------
AIB Wolfgang
Hello
This coding don't matches with the mechanical coding by the wiring. You have to read the wiring diagram.
SlowikTM
C?ID=340593
So you think that pin-outs in esp pump are diffrent for 4motion and fwd?
AIB Wolfgang
YES!
:thumbs: That's what the wiring shows :thumbs:
