Disable Kessy VW Beetle 2014
bittuning
C?ID=347418
Is there a coding for disabling Keyless entry for an VW Beetle 2014:)? If yes could anybody tell what the coding is. Thanks for reaction
TBAx
C?ID=287144
You can disable the door sensors in module 05's coding. They are located in Byte 00, Bits 0-3.
bittuning
C?ID=347418
Disabling the door sensors doesn't effect any other functionality during normal procedure? What I mean is the normal functionality for opening and closing with the key is still working
Spacewalker
C?ID=159607
Yes, if you disable door sensors , you can not close/ open by handle /touch (my 4 years old boy last time use nose to close car, I told him nose also working ;) )
only close by remote
but kessy still working inside a car - push button to start engine
this is what you are looking for ?
bittuning
C?ID=347418
Thanks for the fast reaction. Good to hear that opening and closing with the remote key is still working. What did you exactly mean with close/open by handle/touch? You mean the door lock/opening key? How could I open the car when this key isn't working and I'm inside the car and will get out.
Spacewalker
C?ID=159607
you female ?
Jef
HQ
The door will mechanically unlock and open when the interior door release is used. But if one wants to make it more exciting, open the sunroof and climb out like a boss.
bittuning
C?ID=347418
Thanks Jef, that's clear. We use the roof for emergency exit:thumbs:
