Byte 18 Canadian 2012 Tiguan Comfortline
madlac
Canada
C?ID=356689
Hi, all
Bought this car 2 months ago and with the cold weather, we tried to enable remote with ignition on so I can lock it while warming it up in the morning. Comfortline is probably the US SE model as we have Trendline, Comfortline and Highline up here.
Anyone knows the proper byte 18 for this car? The 09 was overwritten with a garbage code by a friends clone cable and has 00 in the original coding. Restored it with my new genuine Hex-V2 but not yet perfect.
Car has dual halogen in front and dual brake/position lights in the back, no rear fog. DRL was the low beam dimmed, Scandinavian???
Coding to 51 restored some functionality but still no DRL and outside brake/position hence the error code.
Seems the 2 codes (50, 51) are both for Xenon with LED DRL-s.
Also found AD and AE being used on some models?
Any help would be greatly appreciated, I've been searching for 3 days now for a definitive answer. But I learned a lot about these tweaks :).
Here is my full scan:
Wednesday,09,January,2019,20:17:56:04460
VCDS Version: 18.9.0.4 (x64)  HEX-V2 CB: 0.4437.4
VIN: WVGBV7AXXCW5xxxxxx   License Plate:
Mileage: 111230km-69115mi   Repair Order:
Chassis Type: AX-VW36 (7N0)
Scan: 01 02 03 08 09 15 16 17 19 22 25 2E 42 44 46 4C 4F 52 53 56
          62 72 77
VIN: WVGBV7AXXCW553377   Mileage: 111230km-69115miles
Address 01: Engine (CCT)       Labels:. 06J-906-026-CCT.clb
   Part No SW: 06J 997 029 P    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2    1519
   Revision: P3H07---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 44486 001 1048576
   VCID: 44D14E93829AC9E7FA3-8010
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 LR
   Component: AQ 250 6F           2248
   Revision: 00H90000    Serial number:
   Coding: 0000328
   Shop #: WSC 26875 001 1048576
   VCID: 074B999FF32C22FFDF1-8052
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AP    HW: 5N0 614 109 AP
   Component: J104   C6 450M VDAC 0005
   Revision: --H07---    Serial number: 00000005108059
   Coding: 0005161
   VCID: 79AFEF67B5D8440FD95-802C
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001016
   Coding: 0000004002
   VCID: 00598283DA8215C79EB-8054
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 0064
   Revision: BJ021001
   Coding: 6F180ABB88232EC4000800C1140085C448210086524D8D60648040000040
   VCID: 3FDB417FE77CAA3FA71-806A
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 08121  013 0203
   Serial number: N1955119   °203!
   Coding: 009795
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 172
                    Mileage: 111236 km
                    Date: 2013.06.01
                    Time: 20:12:59
                    Voltage: 11.70 V
                    Reset counter: 172
                    Mileage: 111236 km
                    Date: 2013.06.01
                    Time: 20:12:59
                    Voltage: 11.70 V
   Part No SW: 5N0 959 655 P    HW: 5N0 959 655 P
   Component: J234__204 VW10 HI   1918
   Revision: 23016000    Serial number: 003GJPPN8QW5
   Coding: 0012340
   VCID: 4ACD60ABA0BE1F9700F-801E
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 00000000007F9K
   Subsystem 3 - Serial number: 0029.10.110000300000630025ÿ†63
   Subsystem 4 - Serial number: 630025ÿ†6332MTS618093181 ÿ†63
   Subsystem 5 - Serial number: 93181 ÿ†6342MTS631033171 ÿ†63
   Subsystem 6 - Serial number: 33171 ÿ†6351HTS6MEHNV9KJ ÿ†63
   Subsystem 7 - Serial number: NV9KJ ÿ†6361HTS6TI69R9KR ÿ†63
   Subsystem 8 - Serial number: 9R9KR ÿ†63727TS6G4GMV9KJ ÿ†63
   Subsystem 9 - Serial number: MV9KJ ÿ†63827TS69QQ4U9KJ ÿ
   Subsystem 10 - Serial number: 4U9KJ ÿ
   Part No SW: 5K0 953 501 AT    HW: 5K0 953 569 H
   Revision: FF010040    Serial number: 20111202301303
   Coding: 198A100000
   VCID: 7CA1F673B66A7127C23-8028
   Coding: 820000
   Part No SW: 5N0 920 872 B    HW: 5N0 920 872 B
   Coding: 311F01
   VCID: 313F174721A84C4F215-8064
   Part No SW: 7N0 907 530 P    HW: 1K0 907 951
   Component: J533  Gateway H40 1623
   Revision:   H40       Serial number: 031211F2003873
   Coding: 356002
   VCID: 3D273B77ED70B82FB5D-8068
01304 - Radio
                    Reset counter: 212
                    Mileage: 105964 km
                    Date: 2012.10.04
                    Time: 19:01:08
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4DC76BB751D008AF25D-8018
   VCID: 6A8DC02BCCFEFF9720F-803E
   Revision: A1001003    Serial number: 7661426728
   VCID: 290FFF2709F8348FE95-807C
01304 - Radio
                    Reset counter: 193
                    Mileage: 110994 km
                    Date: 2013.04.22
                    Time: 20:13:31
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0003970693
   Coding: 0004F4
   VCID: 38292A63C2D29D0766B-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  007 1504
   Serial number: 00000006111212
   Coding: 000490
67074 - Motors for Central Locking
          B122B 01 [008] - Electrical Failure
                    Reset counter: 212
                    Mileage: 111215 km
                    Date: 2019.01.07
                    Time: 08:52:05
67330 - Switch for Central Locking
          B122D 29 [008] - Signal Implausible
                    Reset counter: 211
                    Mileage: 111215 km
                    Date: 2019.01.07
                    Time: 08:52:05
132610 - Motors for Rear Central Locking
          B122C 01 [008] - Electrical Failure
                    Reset counter: 212
                    Mileage: 111215 km
                    Date: 2019.01.07
                    Time: 08:52:05
132866 - Switch for Rear Central Locking
          B122E 29 [008] - Signal Implausible
                    Reset counter: 212
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.286 1002
   Revision: 1AH03836    Serial number: 00113370024901
   Coding: 0000258
   Shop #: WSC 00000 028 00001
   VCID: 3C213673FA6AB127823-8068
   Component: EZE_2         H40 1623
   Coding: 050B0500
   VCID: 6FBBD13FF79C1ABF771-803A
   Component: J245EE20SKB13  H03 0220
   Component: J394EE20SKB13  H03 0220
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0003959318
   Coding: 0004F4
   VCID: 392F2F67F9D8840F995-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  007 1504
   Serial number: 00000006223730
   Coding: 000490
                    Reset counter: 212
                    Mileage: 111215 km
                    Date: 2019.01.07
                    Time: 08:52:05
                    Fault Frequency: 7
                    Reset counter: 211
                    Mileage: 111215 km
                    Date: 2019.01.07
                    Time: 08:52:05
                    Reset counter: 212
                    Mileage: 111215 km
                    Date: 2019.01.07
                    Time: 08:52:05
                    Reset counter: 212
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000492814
   Coding: 0026156
   VCID: 35372357D940606F7DD-8060
Address 56: Radio
   Part No SW: 5K0 035 730 E    HW: 5K0 035 730 E
   Component: TELEFON       H09 2902
   Revision: 1B001001    Serial number: 00007661445861
   Coding: 0A10040000010100
   ASAM Dataset: EV_UHVNA A01719
   ROD: UHVNA.rod
   VCID: 270BF91F1F6C02FFFF1-8072
9457427 - Left audio channel for speech/telephone
          B104F 13 [009] - Short to GND
                    Reset counter: 211
                    Mileage: 108634 km
                    Date: 2018.07.23
                    Time: 20:00:27
9457171 - Right audio channel for speech/telephone
          B104E 13 [009] - Short to GND
                    Reset counter: 211
                    Mileage: 108634 km
                    Date: 2018.07.23
                    Time: 20:00:27
0022 - Radio
          U1066 00 [008] - No Communication
          [Steuergerät Radio (RNS): kein Signal/Kommunikation]
                    Reset counter: 193
                    Mileage: 110994 km
                    Date: 2018.11.30
                    Time: 20:13:26
End----(Elapsed Time: 01:24, VBatt start/end: 11.7V/11.8V. VIgn 11.8V)-----
Address 42: DTCs cleared
Address 52: DTCs cleared
madlac
Canada
C?ID=356689
Coding to AD did the trick, all back to normal. Remote also enabled. Great tool, thx Ross-tech!
