I just picked up a 1999 VW Golf TDI 1.9L
had a slew of issues most of which I hope I figured out, one was needed a new alternator, that was a joy to replace in 25 degree weather. Also had a boost leak, which I hope I found I found one of the inter-cooler pipes not sealed with the clamp behind the passenger headlight. Had a Check engine light, and ABS light on. I also ran a 3rd gear WOT pull it was a short one but I just wanted to post it here and get some feed back on it. Any thought on the glowplug or abs codes please let me know.
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
76
Mileage: 464990km-288931miles
Address 01: Engine Labels: 038-906-018-AGR.lbl
Part No: 038 906 018 EB
Component: 1,9l R4 EDC G700SG 2143
Coding: 00002
Shop #: WSC 01317
VCID: 5AED91B5A506B457B01-4B3C
16764 - Glow Plug/Heater (Q6) Circuit
P0380 - 35-10 - Malfunction - Intermittent
Readiness: N/A
Address 03: ABS Brakes Labels: 1J0-907-37x-ABS.lbl
Part No: 1J0 907 379 G
Component: ABS 20 IE CAN 0001
Coding: 03504
Shop #: WSC 01317
VCID: 353722096C58BB2F7D3-4B1E
Address 15: Airbags Labels: 1J0-909-60x-VW3.lbl
Part No: 1J0 909 609
Component: C AIRBAG VW3 SG 0002
Coding: 00067
Shop #: WSC 01317
VCID: 6C81C76D7F923AE752D-4B7A
32-00 - Resistance Too High
00532 - Supply Voltage B+
Address 17: Instruments Labels: 1J0-919-xxx-17.lbl
Part No: 1J0 919 951
Component: A4-KOMBIINSTR. VDO V01
Coding: 06242
VCID: 6D87CA69448833EF453-5160
Address 35: Centr. Locks Labels: 1C0-962-258-II.lbl
Part No: 1C0 962 258 P
Component: 06 Zentr.Verriegel. 0001
Coding: 00256
Shop #: WSC 01317
VCID: 34311F0D6722A2274AD-4B7A
00949 - Central Locking Motor - tailgate (V53); LOCK
25-00 - Unknown Switch Condition
00953 - Interior Light Time limit
25-10 - Unknown Switch Condition - Intermittent
End----------(Elapsed Time: 05:08, VBatt start/end: 14.4V/14.4V)-----------
