- Sep 13, 2018
- 8
- 1
- Poland
- HV21B04-00002B-CF53F1D-CC07B9-TJICAP-5B09
Hello.
i've got trouble with passat WVWZZZ3CZAE107992
Car was originaly from UK, and i made swap of all electrical for right hand drive.(Yes i know it was suicide).
Except few errors in connections (door modules) i got big trouble with ABS. in errors it says it's not proper coded.
Could someone send me proper coding? I added auto hold switch to parking brake. And im not sure if this abs comes from this vehicle (i wasn't doing the mechanical swap of parts, only electrical is on my head)
Wednesday,09,January,2019,09:11:04:16157
VIN: WVWZZZ3CZAE107992 License Plate:
Mileage: 230090km-142971mi Repair Order:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 53 56
VIN: WVWZZZ3CZAE107992 Mileage: 230090km-142971miles
Address 01: Engine (CBA) Labels: 03L-906-022-CBA.clb
Part No SW: 03L 906 022 QC HW: 03L 907 309
Component: R4 2.0l TDI G000SG 9977
Revision: 13H03--- Serial number: VWZCZ000000000
Coding: 0000072
Shop #: WSC 53078 002 1048576
VCID: 76B5E59304C4CC67B49-8022
001152 - Coolant Fan Control Circuit 1
P0480 - 000 - Electrical Malfunction
Mileage: 230099 km
Date: 2013.06.01
Time: 02:36:21
Temperature: 16.2°C
Temperature: 19.8°C
Temperature: 12.6°C
Lambda: 9.5 %
Lambda: 0.0 %
Address 03: ABS Brakes Labels: 3C0-614-109-C4.clb
Part No SW: 3C0 614 109 AF HW: 3C0 614 109 AF
Component: J104 C4 440 V2 0015
Revision: --025--- Serial number: 00000705112590
Coding: 0005395
Shop #: WSC 11111 551 00000
VCID: 629DA9C3B84C40C7E81-8036
02543 - Vacuum Sensor for Brake Booster (G483)
Fault Status: 00101100
Reset counter: 115
Mileage: 230099 km
Date: 2013.06.01
Time: 02:36:45
Hex Value: 0x0000
Voltage: 14.00 V
Bin. Bits: 00111110
Count: 132
Hex Value: 0x0000
Reset counter: 115
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 227
Hex Value: 0x0000
Reset counter: 115
Hex Value: 0x0000
Voltage: 0.00 V
Bin. Bits: 00011111
Count: 149
Hex Value: 0x0000
Reset counter: 115
Address 08: Auto HVAC Labels: 3C0-907-044.lbl
Part No SW: 3C0 907 044 BT HW: 3C0 907 044 BT
Component: ClimatronicPQ46 122 0707
Revision: 00122021 Serial number: 00000000000000
VCID: 74B1DF9B12B8DE778AD-8020
Address 09: Cent. Elect. Labels:. 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Revision: 00H54000 Serial number: 00000003626974
Coding: 00800F0700041A00470A00000F000000000859435C000120000000000000
Shop #: WSC 05124 000 00000
VCID: 323D1983A82C9047581-8066
Subsystem 1 - Part No: 3C1 955 419 A Labels: 1KX-955-119.CLB
Component: Wischer 030707 003 0205
Coding: 00046997
Shop #: WSC 05124
Part No SW: 5N0 959 655 J HW: 5N0 959 655 J
Component: J234__00J VW10 HI 1916
Revision: 20013000 Serial number: 003E2PC9163W
Coding: 0012362
Shop #: WSC 05311 000 00000
VCID: 44D14F5B02982EF7FAD-8010
Subsystem 1 - Serial number: 6332MTS608923419
Subsystem 2 - Serial number: 6342MTS671913449
Subsystem 3 - Serial number: 6351HTS6VDN386KJ
Subsystem 4 - Serial number: 6361HTS671A186KR
00532 - Supply Voltage B+
Reset counter: 155
Mileage: 230099 km
Date: 2013.06.01
Time: 18:29:21
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C5 953 501 BN HW: 5K0 953 569 AB
Component: LENKS.MODUL 009 0122
Revision: FF010035 Serial number: 20100203100980
Coding: 0182270002
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_VW360SteerWheelUDS A03002
VCID: 72BDD983642CD047981-8026
Component: E221__MFL-TK6 H06 0022
Coding: E20000
365080 - Controls in Steering Wheel
U108E 00 [008] - No Communications
Reset counter: 155
Mileage: 230099 km
Date: 2019.01.09
Time: 18:29:25
Part No SW: 3C0 920 972 J HW: 3C0 920 972 J
Component: KOMBI H03 0305
Coding: 060F00
Shop #: WSC 05314 115 12345
VCID: 2D070AFFBD92CFBF053-8078
Address 19: CAN Gateway Labels:. 3C0-907-530-V3.clb
Part No SW: 3C0 907 530 Q HW: 3C0 907 951
Component: J533 Gateway H13 0172
Revision: H13 Serial number: 3620P10205045D
Coding: F9801F06000202001002
Shop #: WSC 05314 123 12345
VCID: 2F3B10F7BB1EBDAF37F-807A
Fault Frequency: 11
Reset counter: 115
Mileage: 230099 km
01304 - Radio
Reset counter: 115
Mileage: 230099 km
Part No SW: 3C0 959 433 AQ HW: 3C0 959 433 AQ
Component: IMMO 044 0383
Revision: 00044000 Serial number: VWZCZ000000000
VCID: 79AFEEAF35DAA31FD9B-802C
Subsystem 1 - Part No: 3C0 905 861 H
Component: ELV 028 0380
3C0905861H ELV 028 0380
Part No SW: 3C0 959 701 HW: 3C0 959 793
Component: TUER-SG FT 002 0306
Revision: 13101005 Serial number: 0000368121
Coding: 000035
Shop #: WSC 05311 115 12345
ASAM Dataset: EV_DCU42BroseDriveSide A03004
ROD: EV_DCU42BroseDriveSide_VW36.rod
VCID: 6597B2DFA5E237FF0D3-8030
65537 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Front CAN TSG-BF]
Reset counter: 155
Mileage: 230099 km
Date: 2019.01.09
Time: 02:30:23
68098 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Front CAN KSG]
Reset counter: 155
Mileage: 230099 km
Date: 2019.01.09
Time: 02:29:49
68099 - Function Restricted due to Missing Message(s)
U1111 00 [008] - -
[Front CAN Clima]
Reset counter: 155
Mileage: 230099 km
Date: 2019.01.09
Time: 02:30:03
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.135 H08 1901
Shop #: WSC 02069 000 90108
VCID: 3537229F5942877F7D3-8060
Component: KSG PQ46 ELV 044 0612
Coding: 10910A0801860E763004941570085BCE403C01
Shop #: WSC 05311 123 12345
Component: Neigungssensor 004 0611
Part No SW: 3C0 959 702 HW: 3C0 959 792
Component: TUER-SG BT 002 0306
Revision: 15101005 Serial number: 0000377226
Coding: 000034
ASAM Dataset: EV_DCU52BrosePasseSide A03004
ROD: EV_DCU52BrosePasseSide_VW32.rod
VCID: 6695B5D358E43CE7049-8032
U1111 00 [008] - -
[Front CAN KSG]
Reset counter: 155
Mileage: 230099 km
Date: 2019.01.09
Time: 01:32:03
U1111 00 [008] - -
[Front CAN Clima]
Reset counter: 155
Mileage: 230099 km
Date: 2019.01.09
Time: 02:30:27
65793 - Supply voltage
U1011 00 [009] - Voltage too Low
[Front DCU undervoltage]
Reset counter: 115
Mileage: 230099 km
Date: 2019.01.09
Time: 01:09:30
Address 53: Parking Brake Labels: 5N0-907-801.clb
Part No SW: 3C8 907 801 E HW: 3C8 907 801 E
Component: J540 EPB3 VW-15417 0007
Revision: 010 Serial number: 00000000158619
Coding: 0000057
VCID: 2C0107FB8A08C6B712D-8078
Address 56: Radio
End----(Elapsed Time: 01:08, VBatt start/end: 10.2V/10.1V. VIgn 10.0V)-----
