just to share my experience with you. Some might benefit from it. On Christmas eve our VW E-UP! from 2014 did not want to drive anymore. Upon starting the error Electrical system failure: Stop! was shown on the display accompanied with 3 chimes. Towed the car home and used VCSD to scan for errors. This was the output:
I cleared the DTC's but the problem did not go away and charging was not possible either.
Not being very experienced with electric cars, the 400 VDC power system etc made me read a lot about it during the holidays. I read on various VW forums that this problem also occured on the e-Golf. Charging the 12V battery that was quite drained did not help. Nothing helped. In the end we got the car transported to a VW garage. After 3 days more waiting they did a diagnosis and came to the conclusion that the PTC Heater was the root cause of the problem. When I checked the initial scan indeed it shows under module 08 - Auto HVAC:
Control Module for High-Voltage PTC Heater; Internal Shut-Off Condition
Moreover it had: Fault Priority: 1
That should have been the giveaway but because I was not known to VW troubleshooting before I overlooked this initially. I would never have expected that an electric heater fault could stop the whole car.
VW wanted 2000 USD for replacing the part.
We took the E-UP back home on a trailer and I ordered the PTC heater from a wrecking yard for 250 USD.
Learned along the way that most electric cars have a PTC heater that rapidly supplies the interior with hot air if outside temperatures fall below a certain value.
Anyways replaced the heater last night. Learned myself first how to disable the High Voltage
Unfortunately the error was still there! I then expected that the new (used) heater needed coding with VCDS. I read for hours to find the security access code for 08 - HVAC but did not find it.
I went back to the car to find that the error condition was gone
Apparantly the process takes some time? Do the other ECU's update themselves by learning that the fault condition no longer exist? This is something I like to know. Does someone know the answer?
In any case happy that the car is on the road again.
Monday,24,December,2018,15:02:57:10081
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4437.4
VIN: WVWZZZAAZED901XXX License Plate:
Chassis Type: AA-VW12 (6N0)
Scan: 01 03 04 05 08 09 10 15 17 19 23 25 44 51 56 61 75 8C AD BD
C6
VIN: WVWZZZAAZED901XXX Mileage: 69410km-43129miles
04-Steering Angle -- Status: Not registered 0001
05-Acc/Start Auth. -- Status: Cannot be reached 1100
75-Telematics -- Status: Malfunction 1010
8C-Hybrid Battery -- Status: Malfunction 0010
AD-Brake Sensors -- Status: Malfunction 0010
BD-Hi Volt. Batt. Charg. -- Status: Malfunction 0010
C6-Batt. Chrg. -- Status: OK 0000
Address 01: Engine (J623-EABA) Labels:. 0EA-907-309-V1.clb
Part No SW: 0EA 906 016 B HW: 0EA 907 309 B
Component: E-Vehicle H21 8242
Revision: WLH21---
Coding: 000D0012000400000000
Shop #: WSC 47036 001 1048576
ASAM Dataset: EV_VCU00XXX0110EA906016B 001019
ROD: EV_VCU00XXX0110EA906016B.rod
VCID: 2E05F36EB09533673C9-807A
15494 - Please Check Fault Codes in Control Module for ABS Brakes
U1017 00 [036] - -
[ABS brake control moduleRead out DTC]
Mileage: 69408 km
Date: 2018.12.24
Time: 11:42:46
Engine speed: 16383.75 /min
Normed load value: 100.0 %
Vehicle speed: 43 km/h
Coolant temperature: 215 °C
Intake air temperature: 215 °C
Voltage terminal 30: 11.520 V
Outside air temperature via CAN: -6.8 °C
Part No SW: 12E 698 517 HW: 12E 614 517 B
Component: EBC 460 ESP H08 0004
Serial number: A00G5IF
Coding: 44BF247199AD00F2220124FC99B1004159B800
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_Brake1ESPTRWPQ12E 004014
ROD: EV_Brake1ESPTRWPQ12E_004.rod
VCID: 6C8139664609817752D-8038
0261 - ESP Operation
C1075 29 [008] - Signal Implausible
Reset counter: 41
Mileage: 69408 km
Date: 2018.12.24
Time: 11:42:46
DTC: 00 01 05
Address 05: Acc/Start Auth.
Part No SW: 12E 907 044 B HW: 12E 907 044 A
Component: Climatronic H05 0109
Revision: V0000000
VCID: 221D175EF4CD8707A81-8076
Subsystem 1 - Part No SW: 12E 963 231 B HW: 12E 963 231 B
Component: J848 HV-PTC H08 0202
Serial number: T132983003803000034
Subsystem 2 - Part No SW: 12E 820 803 B HW: 12E 820 803 B
Component: J842 eKK H01 0007
6 Faults Found:
04070 - Function Limitation for Blower Regulator 1
Reset counter: 41
Mileage: 60060 km
Date: 2018.04.15
Time: 17:26:42
Fault Status: 00101101
Reset counter: 40
Mileage: 67102 km
Date: 2018.10.18
Time: 23:35:18
Reset counter: 36
Mileage: 67333 km
Date: 2018.11.02
Time: 20:51:08
Reset counter: 36
Mileage: 67333 km
Date: 2018.11.02
Time: 20:51:08
04072 - High Voltage Supply for A/C Compressor
Fault Status: 00101011
Reset counter: 26
Mileage: 68936 km
Date: 2018.12.14
Time: 22:44:59
04110 - Control Module for High-Voltage PTC Heater; Internal Shut-Off Condition
Reset counter: 41
Mileage: 69403 km
Date: 2018.12.24
Time: 10:40:56
Address 09: Cent. Elect. (J519) Labels:. 7H0-937-08x-09.clb
Part No SW: 7H0 937 090 D HW: 7H0 937 090
Component: BCM PQ25 Max4 H74 0726
Revision: B9074001 Serial number: 0571 284133471
Coding: 62B82B0000010000202001F42E2820F03300424E60020440200000420110
VCID: 2F3BEE6AB71F3A6F37F-807A
00447 - Function Limitation due to Over-Voltage
Fault Status: 00100001
Fault Frequency: 7
Reset counter: 41
Mileage: 68176 km
Date: 2018.11.17
Time: 17:52:50
Reset counter: 3
Mileage: 60073 km
Date: 2018.04.17
Time: 16:04:19
Reset counter: 3
Mileage: 60073 km
Date: 2018.04.17
Time: 16:04:19
Address 10: Park/Steer Assist (J446) Labels:| 1Sx-919-475.clb
Part No SW: 1S0 919 475 A HW: 1Q0 919 475
Component: PARKHILFE 3K H03 0009
Revision: -------- Serial number: 32961623701445
Coding: 100103
ASAM Dataset: EV_EPHVA14VW1200000 001008
ROD: EV_EPHVA14VW1200000.rod
VCID: 3829D53642D1FDD7665-806C
Part No SW: 12E 959 655 HW: 12E 959 655
Component: VW10Airbag005 H04 0215
Revision: -------- Serial number: 003KV00022V3
Coding: 000000000000000000000000000000003035
ASAM Dataset: EV_AirbaVW10BPAVW12X 001001
VCID: 6FBB2E6A771F7A6F77F-803A
Serial number: 3495RRB4AD121B49573R
Serial number: 3505RRB499121B491516
Serial number: 3555NRB424282D4F574K
Address 17: Instruments (J285) Labels:| 1Sx-920-xxx-17.clb-SRI1
Part No SW: 12E 920 860 A HW: 12E 920 860 A
Component: KOMBI H09 0014
Revision: X0009001 Serial number: 00000000000000
Coding: 110A00
ASAM Dataset: EV_KombiUDSMM9RM10 A04752
ROD: EV_KombiUDSMM9RM10_A04_VW12.rod
VCID: 221D175EF44D8707A81-8076
Part No SW: 6N0 909 901 HW: 7H0 937 090
Component: GW-K-CAN TP20 H74 0726
Revision: B9074001
Coding: 002200
VCID: 70B92D166AA165976E5-8024
Mileage: 60309 km
Date: 2018.04.28
Time: 17:24:44
01302 - Control Module for Telematic (J499)
Fault Frequency: 7
Reset counter: 7
Mileage: 65533 km
Date: 2018.09.09
Time: 09:37:38
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Reset counter: 12
Mileage: 60309 km
Date: 2018.04.28
Time: 17:24:46
Address 23: Brake Booster (J539) Labels:* None
Part No SW: 12E 909 059 A HW: 12E 909 059
Component: EBKV H10 0123
Serial number: 085430010114
Coding: 00700134010101
ASAM Dataset: EV_BrakeBoostEBKVBosch 004025
ROD: EV_BrakeBoostEBKVBosch_VW12.rod
VCID: 290F0072897B545FE9B-807C
Brake Assistance Sub:
Subsystem 1 - Part No SW: 12E 614 307 B HW: 12E 614 307 A
Component: V545BrakeAssi H03 0115
Serial number: 05802861171013095456
Part No SW: 5K0 953 234 HW: 12E 920 860 A
Component: IMMO H09 0014
ASAM Dataset: EV_ImmoUDSMM9RM10 A01702
ROD: EV_ImmoUDSMM9RM10_VW12.rod
VCID: 6A8D3F7E4CFD9F47201-803E
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6R1 909 144 R HW: 6R1 909 144 E
Component: EPS_TRW_ALow 312 3111
Serial number: CE6H1068
Coding: 4007
Shop #: WSC 28893 002 104857
ASAM Dataset: EV_SteerAssisUDSTRW 011021
ROD: EV_SteerAssisUDSTRW_011.rod
VCID: 46D5ABCE38259B27E49-8012
1091584 - invalid data record
B2005 00 [009] - -
[DEM_INVALID_DATASET_FAULT]
Reset counter: 12
Mileage: 60309 km
Date: 2018.04.28
Time: 17:31:17
Address 51: Electric Drive (J841) Labels: None
Part No SW: 12E 907 080 C HW: 12E 907 080 C
Component: VW120E2313020 H03 2096
Revision: 00H03000 Serial number:
Coding: C0020000000000000000
ASAM Dataset: EV_DMCM070501112E907080C 001020
ROD: EV_DMCM070501112E907080C.rod
VCID: 2313125AEB578E0FA37-8076
Part No SW: 1S0 035 156 J HW: 1S0 035 156 J
Component: Radio H36 0063
Revision: R0000000 Serial number: VWZAZ1N0577264
Coding: 0000040802
VCID: 323DE71EA42D1787581-8066
Part No SW: 7H0 907 534 HW: 7H0 937 090
Component: Batt.regelung H74 0726
Coding: 1683005A
VCID: 6B833A7A4387864F5B7-803E
Subsystem 1 - Part No SW: 6Z3 915 181 HW: 6Z3 915 181
Component: J367-BDM H08 0223
Serial number: 61153N41294311328944
Address 75: Telematics (J949) Labels:| 12E-035-284.clb
Part No SW: 12E 035 284 HW: 12E 035 284
Component: OCULowEMobil 015 0107
Serial number: 000003560590501
Coding: 02217001101612F0007800000000
ROD: EV_OCULow_001.rod
VCID: 5EE563AE80B5E3E7CC9-800A
13639936 - Mobile Online services
B149A FE [009] - Display trip details
Fault Frequency: 18
Reset counter: 1
13640704 - Mobile Online Services
B149A FA [009] - Remote Control of HV Battery Charging
Reset counter: 0
13640960 - Mobile Online Services
B149A FB [009] - Remote Control of HVAC functions
Reset counter: 0
2103041 - Control Module
Fault Priority: 8
Reset counter: 12
Mileage: 60309 km
Date: 2018.04.28
Time: 17:26:09
Address 8C: Hybrid Battery (J840) Labels: 5QE-915-227.clb
Part No SW: 12E 915 227 Q HW: 12E 915 227 G
Component: HVSM M10 0816
Serial number: 288 VWACDKU00O
ASAM Dataset: EV_BECM102202112E915227Q 008010
ROD: EV_BECM102202112E915227G.rod
VCID: 3333E21A5BB71E8F537-8066
18408 - 14V Power System Voltage
P0A8D 00 [032] - too Low
Voltage terminal 30: 8.750 V
18375 - Hybrid/EV Battery System
P0C78 00 [038] - Precharge Time Too Long
Fault Frequency: 13
Mileage: 69405 km
Date: 2018.12.24
Time: 10:50:06
Current of H-V / hybrid battery: -5.250 A
H-V battery voltage: 401.000 V
Address AD: Brake Sensors (J939) Labels: 1S0-907-201.clb
Part No SW: 1S0 907 201 A HW: 1S0 907 201 A
Component: CV-SENSOR H06 0460
ASAM Dataset: EV_CVSen 001001
ROD: EV_CVSen.rod
VCID: 2809057692716D57F65-807C
12289 - Function limitation due to optical constraint
C10FD 00 [008] - -
Reset counter: 30
Mileage: 69014 km
Date: 2018.12.15
Time: 19:07:54
Address BD: Hi Volt. Batt. Charg. (J966) Labels:| 5QE-915-022-V1.clb
Part No SW: 12E 915 022 G HW: 12E 915 022 C
Component: LMSG H04 0073
Serial number: 00776034170139
Coding: CA0D03
ASAM Dataset: EV_HVChargManagVW 005005
ROD: EV_HVChargManagVW_005_VW12.rod
2097152 - Battery Management
P33EB 00 [008] - Read Event Memory
Reset counter: 41
Mileage: 69410 km
Date: 2018.12.24
Time: 11:55:56
2162688 - Equalization of Charge from HV Battery to discharged LV Battery
P30DF 00 [009] - -
Reset counter: 1
Mileage: 69407 km
Date: 2018.12.24
Time: 11:41:37
2162704 - Interruption of Equalization of Charge from HV Battery to discharged NV Battery
P30E0 00 [009] - -
Reset counter: 1
Mileage: 69410 km
Date: 2018.12.24
Time: 11:56:18
Address C6: Batt. Chrg. (J1050) Labels: 5QE-915-681.clb
Part No SW: 12E 915 682 Q HW: 12E 915 682 K
Component: OBC KOSTAL H40 0037
Revision: -------- Serial number: 2010130J700058
ASAM Dataset: EV_OBCSinglPhaseKLOVW120 004001
ROD: EV_OBCSinglPhaseKLOVW120_004.rod
End----(Elapsed Time: 01:39, VBatt start/end: 11.8V/11.8V. VIgn 11.8V)-----
