- Dec 5, 2018
- 71
- 3
- Terrebonne, QC, Canada
- C?ID=353427
Working on my TREG today for a few issues, I decided to look after that one:
I dismounted that right rear door and tested for the switch. No issue there.
I found out if I remove the big plug from the window motor, it removes the code.
Seems like this plug connect to another controller made with the windows motor. What may I do next?
Tuesday,08,January,2019,16:34:00:55476
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64(VMWare)
VCDS Version 18.9.0.4 (x64) HEX-V2 CB: 0.4436.4
VIN: WVGMM67L75D055257 License Plate:
Mileage: 199200km-123777mi Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGMM67L75D055257 Mileage: 199200km-123777miles
Address 09: Cent. Elect. Labels:. 7Lx-937-049-V1.clb
Part No: 7L6 937 049 M
Component: 3001
Coding: 0105695
Shop #: WSC 31414 000 00000
VCID: 46D5543074BA6677E47-5161
01498 - Bulb for Parking Lamps; Right (M3)
00060 - Foglight Lamps
Address 32: Differential Locks Labels: None
Part No: 0AC 927 771 C
Component: SG-Quersperre 5020
VCID: 38292AC80E4E008766B-5161
02062 - Differential Lock
02412 - Differential Lock Rear
Address 46: Central Conv. Labels: 7L0-959-933.lbl
Part No: 7L0 959 933 E
Component: H6 HSG 0201
Coding: 0000085
Shop #: WSC 94713 999 59229
VCID: 3E253CD02C6A3EB7AC7-4B01
Subsystem 1 - Part No: 7L0 959 701 H
Subsystem 2 - Part No: 7L0 959 702 H
Subsystem 3 - Part No: 7L0 959 703 D
Subsystem 4 - Part No: 7L0 959 704 D
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
007 - Short to Ground
Address 76: Park Assist Labels: Redir Fail!
Part No: 7L0 919 283 F
Component: 0E Einparkhilfe 1107
VCID: 392F2FCC3544198F995-5161
7 Faults Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
00434 - Left Front Inner Parking Aid Sensor (G332)
00435 - Front Right Inner Parking Aid Sensor (G333)
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
01626 - Sensor for Parking-Aid; Front Right (G252)
006 - Short to Plus
End----(Elapsed Time: 09:39, VBatt start/end: 11.8V/11.9V. VIgn 11.9V)-----
