Gear indicator on dashboard fully illuminated, trying to track down issue.
artistic_gore
C?ID=343368
This is on 2004 Touareg TDI, I recently replaced my right tandem pump and the batteries went flat while it was sitting. I had the batteries checked at Interstate and they both checked out ok and took a charge, the car starts and I can drive it around a bit but it only shifts through 3 gears and there is no indication on the dash which gear it is in. I have found anything from a low battery to a pinched wire, a bad connector or even the electrical connector to the cam position sensor under the tandem pump itself (I really don't want to pull anything back apart if I can avoid it) so I am just trying to find a clear direction to go in. My scan log is below. Any help would be appreciated. Thanks.
Monday,17,December,2018,12:47:51:07474
VCDS Version: 18.9.0.4  HEX-V2 CB: 0.4436.4
VIN: WVGHH77L44D070857   License Plate:
Mileage: 275110km-170945mi   Repair Order:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGHH77L44D070857   Mileage: 275110km-170945miles
   Part No SW: 070 997 016 R    HW: 028 101 172 9
   Component: V10 5,0L EDCG000AGMª2813
   Revision: 5KO3        Serial number: VWZ3Z0D7174392
   Coding: 0060575
   Shop #: WSC 26069 444 82799
   VCID: 290FFEBE85E8F16FE95-5160
17082 - Sensor Reference Voltage C
            P0698 - 000 - Too Low
                    Torque: 0.0 Nm
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
                    Bin. Bits: 00100000
                    Bin. Bits: 00100000
                    Bin. Bits: 00000000
18060 - Please check DTC Memory of Transmission Controller
            P1652 - 000 -
                    Torque: 284.4 Nm
Readiness: 1 1 0 0 1
   Part No: 09D 927 750 BB
   Component: AL 600 6Q           0467
   Coding: 0004153
   Shop #: WSC 31414 000 00000
   VCID: 6FBBD0A67B8CDF5F771-5160
00777 - Accelerator Position Sensor (G79)
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 D
   Component: ESP ALLRAD MK25     0108
   Coding: 0022785
   Shop #: WSC 19230 444 61889
   VCID: 3A2D31F2704E4AF790F-5160
   Part No SW: 3D0 909 135 M    HW: 5WK 470 26
   Component:    Kessy            6400
   Coding: 0000232
   Shop #: WSC 26071 444 82799
   VCID: 2F3B10A6BB0C9F5F371-5160
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77ABE8C603DC979FAF1-5160
   Part No: 7L6 907 044 H
   Component: CLIMAtronic 2+2   X 3717
   Coding: 0000030
   VCID: 392F2EFE754841EF995-5160
   Subsystem 1 - Part No: 7L6 907 049 C
   Component: CLIMAtronic FOND  X 0306
Address 09: Cent. Elect.        Labels:. 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 L
   Component:                     2703
   Coding: 0087519
   VCID: 45D7520E09B0350FEDD-5160
01517 - Control Module for Trailer/Towing Sensor (J345)
            013 - Check DTC Memory
Address 11: Engine II        Labels: None
   Component: V10 5,0L EDCG000AGSª2813
   Coding: 0060575
   Part No: 3D0 909 601 C
   Component: 05 Airbag 8.4E++H01 0352
   Revision: BB36963     Serial number: 00012986
   Coding: 0012341
   VCID: 2313EC96E7C42B3FA39-5160
   Subsystem 1 - Part No: 7L0 959 339 B
   Component: BF-Gewichtsens. 005 0006
   Part No: 7L6 953 549 D
   Component: Lenksäulenmodul     3301
   Coding: 0000032
   VCID: 40D9431A16921027DEB-5160
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 980 P
   Component: KOMBIINSTRUMENT RB8 2935
   Coding: 0007231
02613 - Stabilizer Control Module (J736)
01304 - Radio
Address 18: Aux. Heat        Labels: 7L6-819-008.clb
   Part No: 7L6 819 008 B
   Component: Standheizung  E1MAC 0235
   Coding: 0000030
   VCID: 353722CE5950A58F7DD-5160
   Part No: 6N0 909 901
   Coding: 0000006
   VCID: 70B9D3DA66B2C0A76EB-5160
7 Faults Found:
00830 - Convertible Top Control Module (J256)
01327 - Control Module for Parking Aid (J446)
00459 - Control Module for Display and Input; Front (J523)
01304 - Radio
00467 - TV Tuner (R78)
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879
   Component: JCI PathPoint       1700
   VCID: 04518F0A420ACC07BA3-5160
   Part No: 0AD 927 755 BE
   Component: TRANSFERCASE        0122
   VCID: 7F5B00E62BECAFDFE71-5160
Address 29: Left Light        Labels: 3D0-909-157.lbl
   Part No: 3D0 909 157
   Component: EVG GDL+AutoLWR(l)  X012
   Coding: 0000003
   Shop #: WSC 26101 444 12484
   VCID: 6695B58254761E17047-5160
Address 32: Differential Locks        Labels: None
   Part No: 0AC 927 771 B
   Component: SG-Quersperre       5018
   VCID: 372B28C6435C579F6F1-5160
02053 - Control Module for Transfer Case (J646)
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 F
   Component: LUFTFDR.-CDC- 3C3P1 3081
   Coding: 0015521
   VCID: 363525C24456AE97747-5160
Address 37: Navigation        Labels: 7L6-919-887-CD.lbl
   Part No: 7L6 919 887 DX
   Component:      Navigation     0736
   Shop #: WSC 26069 444 85803
   VCID: 1F1BE066CBAC0FDF871-5160
   Part No: 3D0 909 158
   Coding: 0000003
   VCID: 678BB886537C071F3F1-513C
   Part No: 7L0 959 933 E
   Component: 2N HSG              0201
   Coding: 0000085
   Shop #: WSC 25155 444 52134
   VCID: 3E253DE26C6666D7AC7-4B00
   Subsystem 1 - Part No: 7L0 959 701 B
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 B
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 B
   Subsystem 4 - Part No: 7L0 959 704 B
00485 - Drivers Outside Door Handle Central Locking Button (E369)
            007 - Short to Ground
00488 - Rear Right Outside Door Handle Central Locking Button (E372)
Address 47: Sound System        Labels: 7Lx-035-4xx-47.lbl
   Part No: 7L6 035 466
   Component: 12K-AUDIOVERST      0108
   VCID: 71BFD6DE6DB8C9AF615-5160
00419 - Left Front DSP Midrange Speaker (R103)
Address 56: Radio        Labels: 7L6-035-186-CD.lbl
   Part No: 7L6 035 186 AX
   Component:        Radio        0736
   Coding: 0025077
   VCID: 094F9E3E6528916FC95-5160
Address 65: Tire Pressure        Labels:. 7L6-907-273.lbl
   Part No: 7L6 907 273 B
   Component: Reifendruckueberw.  0053
   Coding: 0110320
Address 68: Wiper Electr.        Labels: 7L0-955-119-V1.clb
   Part No: 7L0 955 119 F
   Component: Front Wiper         2416
   Coding: 0000004
   Shop #: WSC 19230 444 381377
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   VCID: 38292BFA4E4258E766B-5160
Address 6E: Ctrl Head Roof        Labels: None
   Part No: 7L6 919 044 G
   Component: DACHDISPLAY         0530
   Revision: 00600530    Serial number: 2009268.03
   VCID: 3B2334F67F7473FF8B9-5160
Address 75: Telematics        Labels: 3D0-035-617.lbl
   Part No SW: 3D0 035 617 A    HW: 3D0 035 617 A
   Component: Telematik NAR1      0106
   Coding: 0076510
   VCID: 1E65DD62CCA606D78C7-5160
End----------(Elapsed Time: 08:30, VBatt start/end: 13.8V/13.8V)-----------
PetrolDave
Westbury, UK
C?ID=1423
   Coding: 0004153
Try looking at G79 and the connections to it.
There may also be a message missing on the BUS for gear box stuff an diffs with cluster.
I'm sensing batteries are not good as told tested good .........
Fix gateway coding ...........or I demand pictures please of the top on this TDI! ;)
