- Joined
- Feb 25, 2014
- Messages
- 2,782
- Reaction score
- 4,495
- Location
- Cincinnati, OH
- VCDS Serial number
- C?ID=25607
Interesting that you have no fuel flow when running pump #2. From many anecdotes, and direct personal experience on older Phaetons (non-FSI), you should be able to start and run the engine on either. A glance at PL24 shows your low pressure fuel pumps to look pretty much the same.Was driving my Phaeton on way home when i made a stop for about 15 minutes at a store. When i returned to car and tried to start, the engine turns over but not starting.
Below it what i have don so far and the results.
1. Listened for fuel pump action when door opens. Pump runs for a few seconds.
2. Test each pump individually by bridging at relay junction. both fuel pumps were activated.
3. open fuel ling at pressure sensor (G247) and run each fuel pump individually. Fuel sprays out through opening when pump #1 is active. no fuel seen t opening when pump #2 is active.
4. Tried starting car with fuel pump #1 active (bridged). No start.
Can you confirm how you identified pump #1 vs pump #2? The primary fuel pump should be on the right side of the car, facing forward.
If pump #2 is dead, you might have trouble starting and running if you're low on fuel (less than 1/4 tank) as the second pump scavenges the bottom left of the saddle tank.
Historically, on the 3D platform, KESSY won't crank the engine if the key isn't authorized. This should be something different. I suppose it's possible this changed with your FSI engine; modern engines exert finer control over the starting process for emissions reasons. But then you wouldn't have burned out your starter when you drowned your last KESSY.I thought about KESSY playing tricks hence i checked MVBs
