Maps Passat B8 2014 with TV tuner EU maps
Maps
matociso
Verified VCDS-User
Slovakia
C?ID=329999
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 22 2B 36 42 44 52 55
          57 5F 65 6C BB BC CA
VIN: WVWZZZ3CZFE435829   Mileage: 53242km-33083miles
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CUAA)       Labels:. 03N-906-026-CUA.clb
   Part No SW: 03N 906 026     HW: 03N 907 309
   Component: R4 2,0L EDC   H23 1100
   Revision: A1H23---
   Coding: 01250032036605083000
   Shop #: WSC 05311 115 00321
   ASAM Dataset: EV_ECM20BTD01103N906026 001009
   ROD: EV_ECM20BTD01103N906026.rod
   VCID: 6888487A32F34697366-803C
   Part No SW: 0DL 300 011     HW: 0BH 927 711 F
   Component: GSG DQ500     H10 4701
   Revision: 00H10V01
   ROD: EV_TCMDQ500021.rod
   VCID: 6596414EC5E15BFF0D0-8030
   Part No SW: 3Q0 907 379 N    HW: 3Q0 907 379 G
   Component: ESC           H42 0710
   Revision: 00000000    Serial number: 63274000000151
   Coding: 0FEC6B8F54230B71077F070241CC69F0D62AD0E0E08296F5386250884209
   Shop #: WSC 00015 115 08193
   ASAM Dataset: EV_Brake1UDSContiMK100IPB 034027
   VCID: 45D6A1CE65217BFFED0-8010
   Part No SW: 3Q0 959 435     HW: 3Q0 959 435
   Component: VWKESSYMQB    023 0522
   Revision: 00023000    Serial number: 0355098567
   Coding: 000F0F0703
   ASAM Dataset: EV_KessyHellaMQBAB 004027
   VCID: 77AA1B066F4DD96FAFC-8022
   Part No SW: 5G0 907 044 AL    HW: 5G0 907 044 AL
   Revision: 00001K10
   Coding: 12020124202100012015500000101802
   ROD: EV_ACClimaBHBVW37X_003_VW48.rod
   VCID: 71BE251E0129875F618-8024
   Part No SW: 5Q0 937 086 BD    HW: 5Q0 937 086 BD
   Component: BCM PQ37BOSCH 028 0146
   Revision: --------    Serial number: 86580512142079
   Coding: 00959A46C24102FF4BC44004001407281880000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 7DA6092E4D71F33FF50-8028
   Component: WWS    141115  042 0607
   Serial number:         141122000350
   Component: RLHS  037 0059
   Serial number: S4Y14M12D11H19M41S41
   Coding: 00A8DD
   Light switch:
   Serial number: 31 10 2014  00000832
   Sun Roof:
   Subsystem 6 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Component: SysNameFanLin  012 X025
   Serial number: ESE0006648
   Subsystem 7 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0005887
   Subsystem 8 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0006694
   Subsystem 9 - Part No SW: 3G0 963 345     HW: 3G0 963 345
   Serial number: ESE0005886
   Part No SW: 5Q0 919 298 C    HW: 5Q0 919 298 C
   Component: PLA 3.0 12KH08 0013
   Serial number: ATW-00105.12.14
   Coding: 0071161051
   Shop #: WSC 05311 115 00081
   ASAM Dataset: EV_EPHVA2CAU3700000 008017
   ROD: EV_EPHVA2CAU3700000_008_VW48.rod
   VCID: 3FDAB32607FD212FA7C-806A
   Part No SW: 3Q0 907 572 A    HW: 3Q0 907 572 A
   Component: ACC BOSCH MQB H04 0126
   Coding: 3260678318FFC428949C804C
   ASAM Dataset: EV_ACCBOSCHVW48X 001007
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 3332EF163BB5F54F534-8066
   Part No SW: 5Q0 907 376     HW: 5Q0 907 376
   Component: DAEMPFUNGS-SG H16 0115
   Serial number: 29111441350232
   ROD: EV_DRCONTITEMIC_VW37.rod
   VCID: 76B416026847A067B4A-8022
   Part No SW: 3Q0 959 655 AF    HW: 3Q0 959 655 AF
   Component: Airbag VW20   012 0195
   Revision: --------    Serial number: 003R2PRSC241
   Coding: 98CCC000008000005C5400CC000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 025C7AD2348F8CC7882-8056
   Subsystem 1 - Part No SW: -----------    HW: 454 000 712 14
   Serial number: 3576U0000009073D1211
   Subsystem 2 - Part No SW: -----------    HW: 454 000 612 14
   Serial number: 3586U000000A74618114
   Subsystem 3 - Part No SW: -----------    HW: 454 801 112 14
   Serial number: 3516R2FF163050000003
   Subsystem 4 - Part No SW: -----------    HW: 454 800 912 14
   Serial number: 3526RCA4865050000007
   Subsystem 5 - Part No SW: -----------    HW: 454 800 912 14
   Serial number: 3556V908E43050000007
   Part No SW: 3Q0 953 521 P    HW: 5Q0 953 569 A
   Revision: FF032032    Serial number: 20141206500541
   Coding: 0410
   Shop #: WSC 00015 115 00001
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3D26C92E0DF1333FB50-8068
   Part No SW: 3G0 920 798 A    HW: 3G0 920 798 A
   Component: KOMBI         019 0470
   Coding: 07A40898BE80000800886A041001000000000000
   ASAM Dataset: EV_DashBoardVDDMQBAB 009049
   VCID: 2E04FE62D097D8A73CA-807A
   Revision: --------    Serial number: 28111410800671
   Coding: 030300044F017300EF0002589C0F00010001070000000000000000000000
   ROD: EV_GatewConti_011_VW48.rod
   VCID: 72BC2A12042FBC47982-8026
   Component: E221__MFL-DC1  H16 0040
   Serial number: 27140003086400054497
   Coding: 2CFFFF
   Subsystem 3 - Part No SW: 3Q0 915 181 A    HW: 3Q0 915 181 A
   Serial number: 4060264703
   Analog clock:
   Component: Analoguhr  111 1004
   Serial number: 0612201400010006
   Serial number: HA1-00018.10.14
   Coding: 0301
   VCID: 46D4A6C2582770E7E4A-8012
   Serial number: 14000277551001
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   Part No SW: 3Q0 959 760 A    HW: 3Q0 959 760 A
   Component: Sitzmemory    H03 0011
   Serial number: Y0006NL510145
   Coding: 001000020000010081A080808080000000008181000000F4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_001.rod
   VCID: 392EDD3E19D90F1F998-806C
   Part No SW: 5Q0 959 593 D    HW: 5Q0 959 593 B
   Serial number: 041214BL307905
   Coding: 003F0B20D200020000001000
   VCID: 42DCBAD2740F4CC7C82-8016
   Part No SW: 5Q0 909 143 K    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    203 2033
   Revision: 00000000    Serial number: 0000097570
   Coding: 01010010005001
   Shop #: WSC 00015 115 00321
   ASAM Dataset: EV_SteerAssisVWBSMQBA 008027
   ROD: EV_SteerAssisVWBSMQBA_008.rod
   VCID: 3B22C73613E53D0F8B4-806E
   Part No SW: 5Q0 959 592 D    HW: 5Q0 959 592 B
   Serial number: 031214BL211841
   Coding: 003F0120DE00020200001000
   VCID: 41DEB5DE710957DFD18-8014
   Coding: 03E2020009010000
   Shop #: WSC 05311 000 08193
   VCID: 75B6110E7541AB7FBD0-8020
Address 57: TV Tuner (R78)       Labels:* None
   Part No SW: 8V0 919 191 E    HW: 8V0 919 191
   Component: DVB-DTV       H08 0900
   Coding: 0204020000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   Part No SW: 3G0 035 020 A    HW: 3G0 035 020
   Component: MU-H-ND-EU    H41 0199
   Serial number: A598C0GB009457
   Coding: 02840201FF00000011111201000808001F0100E401200000DE
   VCID: 1576318E55010B7F5D0-8040
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL00M50
   Subsystem 2 - Part No SW: V03 959 800 QL    HW: -----------
   Component: ECE 2015  --- 0105
   Component: Gracenote2  --- 1008
   Part No SW: 5Q0 907 273     HW: 5Q0 907 273
   Component: RDKBERU30     H04 0008
   Serial number: 30000000002367
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_005.rod
   Part No SW: 5Q0 980 556     HW: 5Q0 980 556
   Component: RVC Compact   H07 0100
   Coding: 0184020162002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB_005_VW37.rod
   Part No SW: 5Q0 959 595 D    HW: 5Q0 959 595 B
   Component: TSG HFS       020 0028
   Serial number: 081214BL80487C
   Coding: 000E01200100020000001000
   VCID: 44D0BCCA6E1B42F7FAE-8010
   Component: TSG HBFS      020 0028
   Serial number: 081214BL80481C
   Part No SW: 4M0 907 594 B    HW: 4M0 907 594
   Component: SAD_STG_1     009 0002
   Coding: 008040748202
   ASAM Dataset: EV_SunRoofCONTIAU736 004008
   ROD: EV_SunRoofCONTIAU736_004.rod
   VCID: 3536D10E35C1EB7F7D0-8060
End----(Elapsed Time: 02:38, VBatt start/end: 12.0V/12.0V. VIgn 12.0V)-----
;SW:3G0-035-020-A   HW:3G0-035-020 ---  Information Electr.
;Component:MU-H-ND-EU    H41 0199, Coding:02840201FF00000011111201000808001F0100E401200000DE
;EV_MUHig4CGen2HBAS,001001,EV_MUHig4CGen2HBAS_VW37.rod
;Thursday,04,October,2018,11:36:53:02525
;VCDS Version: Release 18.9.0  Data version: 20180927 DS296.0
;VCID: 1576318E55010B7F5D0-8040
IDE00346-Summertime-automatic,Europe ,1
IDE00768-Country identification: country of sale,-- ,2
IDE00769-Number 1 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00770-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE00845-Wheel circ.,0 mm,2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module,Yes ,3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner,Yes ,3
IDE01996-MAS00844-Installation list: specified installations-Radio,No ,3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module,No ,3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1,Yes ,3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2,No ,3
IDE01996-MAS04300-Installation list: specified installations-DVD changer,No ,3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module,No ,3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit,No ,3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8,No ,3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1,No ,3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2,No ,3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1,No ,3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2,No ,3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1,No ,3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2,No ,3
IDE02330-Number 2 for Info call,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02331-Number 2 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,22 ,49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,22 ,49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,22 ,49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,22 ,49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,22 ,49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,22 ,49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,22 ,49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,22 ,49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,22 ,49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,22 ,49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,22 ,49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,22 ,49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,22 ,49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,22 ,49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,22 ,49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,22 ,49
IDE02502-Confirmation of installation change,6F C0 ,2
IDE02506-MAS03229-Copy multimedia data-Data medium,On ,1
IDE02506-MAS03230-Copy multimedia data-Optical drive,On ,1
IDE02607-Wheel pulse,0 ,2
IDE02699-Number 1 for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE02701-Number 1 (roaming) for roadside assistance,FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF ,23
IDE03471-ENG142146-Vehicle configuration-allow_message_editing,OFF ,30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO,OFF ,30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless,OFF ,30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life,OFF ,30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios,OFF ,30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless,OFF ,30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless,OFF ,30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb,blocked ,30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant,0 ,30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support,OFF ,30
IDE03471-ENG185778-Vehicle configuration-FoD,SWaP ,30
IDE03471-ENG130248-Vehicle configuration-Google_GAL,OFF ,30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless,OFF ,30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts,On ,30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other,On ,30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data,not activated ,30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender,Deactivated ,30
IDE03471-ENG142142-Vehicle configuration-map_email_support,OFF ,30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support,OFF ,30
IDE03471-ENG142141-Vehicle configuration-map_sms_support,OFF ,30
IDE03471-ENG142152-Vehicle configuration-Map_Style,0 ,30
IDE03471-ENG152537-Vehicle configuration-media_control,not activated ,30
IDE03471-ENG138662-Vehicle configuration-Mirror_link,OFF ,30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code,MIB_EU ,30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference,RGB565 ,30
IDE03471-ENG117843-Vehicle configuration-my_audi,OFF ,30
IDE03471-ENG127495-Vehicle configuration-online_media,OFF ,30
IDE03471-ENG117840-Vehicle configuration-online_navigation,OFF ,30
IDE03471-ENG117837-Vehicle configuration-online_POI,OFF ,30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice,OFF ,30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services,OFF ,30
IDE03471-ENG152553-Vehicle configuration-online_radio,Deactivated ,30
IDE03471-ENG117841-Vehicle configuration-online_street_view,OFF ,30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold,00 ,30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis,00 ,30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy,0 ,30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode,only data service act. ,30
IDE03471-ENG117844-Vehicle configuration-picture_navi,On ,30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking,not activated ,30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use,not activated ,30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest,0 ,30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version,PSD_1.5 ,30
IDE03471-ENG117846-Vehicle configuration-remote_HMI,OFF ,30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component,activated ,30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open,not activated ,30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold,not activated ,30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe,not activated ,30
IDE03471-ENG152556-Vehicle configuration-scon_telephony,not activated ,30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag,no_region ,30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch,not activated ,30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch,present ,30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support,OFF ,30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode,0 ,30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling,OFF ,30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone,OFF ,30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location,OFF ,30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving,blocked ,30
IDE03471-ENG167532-Vehicle configuration-UOTA_2,OFF ,30
IDE03471-ENG117852-Vehicle configuration-UPnP,On ,30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound,not activated ,30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound,not activated ,30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte,not activated ,30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI,OFF ,30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot,On ,30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch,not activated ,30
IDE04298-MAS01779-Vehicle dimensions-Length,0 mm,6
IDE04298-MAS01780-Vehicle dimensions-Width,0 mm,6
IDE04298-MAS02230-Vehicle dimensions-Height,0 mm,6
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code,2 ,2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code,2 ,2
IDE05111-Fee-based traffic information (TMC),32768 ,2
IDE06697-Audio management mute function,Muting of audio sources ,1
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128 ,40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128 ,40
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated ,4
IDE10604-Menu entries for mobile online services,activated ,1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold,37 dBµV,3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation,32 dB,3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo,15.0 s,3
IDE11105-Brand-specific display of connect application, ,256
IDE11122-Country identification: country of sale HMI,IT ,2
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength,4294967295 ,330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle,65535 ,330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle,65535 ,330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos,32767 ,330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle,65535 ,330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos,32767 ,330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos,32767 ,330
MAS00951-Bluetooth,On ,1
MAS03782-WLAN,On ,1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off,On ,12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time,150.00 ms,12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off,OFF ,12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time,0.00 ms,12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off,OFF ,12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time,0.00 ms,12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off,On ,12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time,150.00 ms,12
ENG117920-Audio_Managment_Soundset_Menu,OFF ,1
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,activated ,60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated ,60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,not activated ,60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated ,60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,activated ,60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated ,60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated ,60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated ,60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated ,60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated ,60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated ,60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated ,60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated ,60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated ,60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,activated ,60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,activated ,60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated ,60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated ,60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated ,60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated ,60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated ,60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated ,60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated ,60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated ,60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated ,60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,activated ,60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated ,60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated ,60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated ,60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated ,60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated ,60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,activated ,60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated ,60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated ,60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated ,60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,activated ,64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended ,64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus ,64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9 ,64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus ,64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus ,64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,activated ,64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15 ,64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Databus drivetrain ,64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated ,64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment ,64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated ,64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus ,64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus ,64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment ,64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus ,64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus ,64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,activated ,64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus ,64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus ,64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment ,64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,activated ,64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus ,64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus ,64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Comfort data bus ,64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus ,64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus,Comfort data bus ,64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus ,64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus ,64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain ,64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus ,64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated ,64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended ,64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus ,64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,Databus Infotainment ,64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated ,64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus ,64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9 ,64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus ,64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended ,64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment ,64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus ,64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain ,64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus ,64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus ,64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus ,64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus ,64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9 ,64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Comfort data bus ,64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated ,64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment ,64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended ,64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Databus extended ,64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended ,64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Comfort data bus ,64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus ,64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15 ,64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus ,64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,activated ,64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment ,64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,activated ,64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment ,64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus ,64
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus ,8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Databus Infotainment ,8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain ,8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Suspension data bus ,8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1,Comfort data bus ,8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2,Comfort data bus ,8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus ,8
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture,On ,10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart,On ,10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode,H264 ,10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode,MOST_streaming ,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100 ,12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150 ,12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220 ,12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %,12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,8 %,12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %,12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %,12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay,0 ms,3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic,On ,3
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE ,40
ENG117808-p_HMI_Display,13 %,1
ENG117919-Startup_Screen_Sticker_HMI,00 00 ,2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN,0 ,3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit,0 km/h,3
;SW:3G0-920-798-A   HW:3G0-920-798-A ---  Instruments
;Component:KOMBI         019 0470, Coding:07A40898BE80000800886A041001000000000000
;EV_DashBoardVDDMQBAB,009049,EV_DashBoardVDDMQBAB_VW48.rod
;Thursday,04,October,2018,11:38:11:02525
;VCDS Version: Release 18.9.0  Data version: 20180927 DS296.0
;VCID: 2E04FE62D097D8A73CA-807A
Group,Description,Actual
IDE00019,Voltage terminal 30,11.7, V
IDE00021,Engine speed,0.00, /min
IDE00025,Coolant temperature,90.00, °C
IDE00075,Vehicle speed,0, km/h
IDE00191,Charge air pressure: actual value,0.00, %
IDE00196,Engine oil temperature,68, °C
IDE00301,Distance,53242, km
IDE00310,Outside air temperature,19.0, °C
IDE00316-IDE00500,Time-Hour,11, H
IDE00316-IDE00501,Time-Minute,39, min
IDE00316-MAS00111,Time-Seconds,57, s
IDE00317-IDE00502,Date-Year,2018, yr
IDE00317-IDE00503,Date-Month,10, mon
IDE00317-IDE00504,Date-Day,4, d
IDE00323,Security Access: Number of invalid keys,0,
IDE00510,ESI: distance driven from inspection,19369, km
IDE00511,ESI: time from inspection,534, d
IDE00512,ESI: minimum value km-driving distance/inspection,15000, km
IDE00513,ESI: maximum value km-driving distance/inspection,30000, km
IDE00514,ESI: maximum value of time between inspections,730, d
IDE00515,ESI: oil quality,good oil quality,
IDE00517,ESI: soot entry,34000, km
IDE00518,ESI: thermal load,11300, km
IDE00520,Phototransistor,146,
IDE00695,ESI: service exceedance in km,0, km
IDE00696,ESI: service exceedance in days,0, d
IDE00697,ESI: remaining distance,9040, km
IDE00698,ESI: remaining running time,157, d
IDE00787-IDE02689,Cause for cancellation-Complete tank calibration,not performed,
IDE00787-IDE02690,Cause for cancellation-Wet dry tank calibration,not performed,
IDE00819,Day counter,706, d
IDE00827,ESI: minimum value of time between inspections,365, d
IDE00843,Starting impulse recognized,No,
IDE00845-MAS03213,Wheel circ.-Average wheel circumference for trip distance,2056, mm
IDE00845-MAS03214,Wheel circ.-Maximum wheel circumference for speed,2138, mm
IDE00935,ESI: Theoretical service interval,28400, km
IDE01076,Time since ignition off,647, s
IDE01153,SIA: maximum value of distance to service,15000, km
IDE01154,SIA: maximum value of time to service,365, d
IDE01285,Counter of component protection malfunctions,0,
IDE01985-MAS06854,FAZIT identification test sum-Version,02,
IDE01985-MAS06855,FAZIT identification test sum-Test sum,EA D6 0B E0,
IDE02307,Parking brake status,not activated,
IDE02486,Data logger triggering,not active,
IDE02642,Outside temp.: displayed value,15.5, °C
IDE03193-MAS02352,Terminal 58 status-Display dimming terminal 58d,E8,
IDE03193-MAS02353,Terminal 58 status-Switch dimming terminal 58s,00,
IDE03193-MAS02916,Terminal 58 status-Dimmer: duty cycle terminal 58st,64,
IDE03193-MAS02917,Terminal 58 status-Sensor for detecting light in the instrument panel insert,3595,
IDE03349,FIX: Max. distance until next mileage-related inspection,30000, km
IDE03350,FIX: Maximum time until next time-dependent inspection,1095, d
IDE03351,FIX: Distance covered since last mileage-dependent inspection,19300, km
IDE03352,FIX: Time since last time-dependent inspection,534, d
IDE03471-IDE03640,Vehicle configuration-Dynamic AFS light,Correct coding,
IDE03471-IDE03726,Vehicle configuration-Parallel Parking Assistance,Correct coding,
IDE03471-IDE04525,Vehicle configuration-Wheel Dampening Electronics,Correct coding,
IDE03471-IDE04939,Vehicle configuration-Tire pressure monitoring display,Correct coding,
IDE03471-IDE07016,Vehicle configuration-Tire Pressure Monitoring,Correct coding,
IDE03471-MAS00809,Vehicle configuration-Electro-Mechanical Parking Brake Control Module,Correct coding,
IDE03471-MAS00811,Vehicle configuration-Active steering control module,Correct coding,
IDE03471-MAS00911,Vehicle configuration-All Wheel Drive (AWD),Correct coding,
IDE03471-MAS01091,Vehicle configuration-Automated manual transmission,Correct coding,
IDE03471-MAS01891,Vehicle configuration-Lane assistant,Correct coding,
IDE03471-MAS01938,Vehicle configuration-Road sign detection,Correct coding,
IDE03471-MAS02570,Vehicle configuration-Lock Electronics,Correct coding,
IDE03471-MAS03385,Vehicle configuration-Lane change assistance,Correct coding,
IDE03471-MAS04384,Vehicle configuration-Electrical steering column lock control module,Correct coding,
IDE03471-MAS05723,Vehicle configuration-Adaptive cruise control or reducing stopping distance,Correct coding,
IDE03471-MAS08201,Vehicle configuration-Trailer positioning assistant,Correct coding,
IDE03472-MAS03806,Volume after refueling-Last displayed quantity before refueling,8.0, l
IDE03472-MAS03807,Volume after refueling-Last displayed quantity after refueling,58.1, l
IDE03472-MAS03808,Volume after refueling-Last sensor final value at end of refueling,58.1, l
IDE03472-MAS03809,Volume after refueling-Last reference quantity,8.4, l
IDE03472-MAS03810,Volume after refueling-Penultimate displayed quantity before refueling,20.4, l
IDE03472-MAS03811,Volume after refueling-Penultimate displayed quantity after refueling,66.0, l
IDE03472-MAS03812,Volume after refueling-Penultimate sensor final value at end of refueling,70.0, l
IDE03472-MAS03813,Volume after refueling-Penultimate reference quantity,20.0, l
IDE03472-MAS03814,Volume after refueling-Third-last displayed volume before refueling,0.9, l
IDE03472-MAS03815,Volume after refueling-Third-last displayed volume after refueling,26.3, l
IDE03472-MAS03816,Volume after refueling-Third-last sensor final value at end of refueling,26.3, l
IDE03472-MAS03817,Volume after refueling-Third-last reference quantity,9.5, l
IDE03472-MAS03818,Volume after refueling-Fourth-last displayed volume before refueling,5.8, l
IDE03472-MAS03819,Volume after refueling-Fourth-last displayed volume after refueling,26.7, l
IDE03472-MAS03820,Volume after refueling-Fourth-last sensor final value at end of refueling,26.7, l
IDE03472-MAS03821,Volume after refueling-Fourth-last reference quantity,6.4, l
IDE03472-MAS03822,Volume after refueling-Last error status,0,
IDE03472-MAS03823,Volume after refueling-Penultimate error status,0,
IDE03472-MAS03824,Volume after refueling-Third-last error status,0,
IDE03472-MAS03825,Volume after refueling-Fourth-last error status,0,
IDE03472-MAS06153,Volume after refueling-Last distance,52600,
IDE03472-MAS06154,Volume after refueling-Penultimate distance,52100,
IDE03472-MAS06155,Volume after refueling-Third to last distance,52000,
IDE03472-MAS06156,Volume after refueling-Fourth to last distance,51700,
IDE03473-IDE00730,Fuel tank sens-Fuel level sensor 1 including soiling resistance,227, Ohm
IDE03473-IDE00731,Fuel tank sens-Fuel level sensor 2 including soiling resistance,285, Ohm
IDE03473-IDE00732,Fuel tank sens-Fuel level sensor 1 soiling resistance,7, Ohm
IDE03473-IDE00733,Fuel tank sens-Fuel level sensor 2 soiling resistance,6, Ohm
IDE03473-IDE03494,Fuel tank sens-Fuel level sensor 3 including soiling resistance,65535, Ohm
IDE03473-IDE03495,Fuel tank sens-Fuel level sensor 3 soiling resistance,-32768, Ohm
IDE03473-IDE03496,Fuel tank sens-Fuel level sensor 4 including soiling resistance,65535, Ohm
IDE03473-IDE03497,Fuel tank sens-Fuel level sensor 4 soiling resistance,-32768, Ohm
IDE03473-MAS03798,Fuel tank sens-Raw value sensor 1 resistor 1,2219,
IDE03473-MAS03799,Fuel tank sens-Raw value sensor 1 resistor 2,1629,
IDE03473-MAS03800,Fuel tank sens-Raw value sensor 2 resistor 1,2446,
IDE03473-MAS03801,Fuel tank sens-Raw value sensor 2 resistor 2,1070,
IDE03473-MAS03802,Fuel tank sens-Raw value sensor 3 resistor 1,65535,
IDE03473-MAS03803,Fuel tank sens-Raw value sensor 3 resistor 2,65535,
IDE03473-MAS03804,Fuel tank sens-Raw value sensor 4 resistor 1,65535,
IDE03473-MAS03805,Fuel tank sens-Raw value sensor 4 resistor 2,65535,
IDE03474-IDE00304,Calculated volume-Fuel level,8.1, l
IDE03474-IDE00306,Calculated volume-Fuel Level Sensor 1,220, Ohm
IDE03474-IDE00307,Calculated volume-Fuel Level Sensor 2,279, Ohm
IDE03474-IDE00308,Calculated volume-Fuel Level Sensor 3,65535, Ohm
IDE03474-IDE00309,Calculated volume-Fuel Level Sensor 4,65535, Ohm
IDE03474-IDE00312,Calculated volume-Fuel level from sensor 1,9.1, l
IDE03474-IDE00313,Calculated volume-Fuel level from sensor 2,0.0, l
IDE03474-IDE00314,Calculated volume-Fuel level from sensor 3,0.0, l
IDE03474-IDE00315,Calculated volume-Fuel level from sensor 4,0.0, l
IDE03474-MAS03826,Calculated volume-Quality sensor 1,10,
IDE03474-MAS03827,Calculated volume-Quality sensor 2,10,
IDE03474-MAS03828,Calculated volume-Quality sensor 3,not installed,
IDE03474-MAS03829,Calculated volume-Quality sensor 4,not installed,
IDE03474-MAS10338,Calculated volume-Non-calibrated volume: sensor 1,9.1, l
IDE03474-MAS10339,Calculated volume-Non-calibrated volume: sensor 2,-1.8, l
IDE03474-MAS10340,Calculated volume-Non-calibrated volume: sensor 3,-32768.0, l
IDE03474-MAS10341,Calculated volume-Non-calibrated volume: sensor 4,-32768.0, l
IDE03474-ENG103155,Calculated volume-accelerated_linking_x,1.0000000, m/s
IDE03474-ENG103517,Calculated volume-accelerated_linking_y,1.0000000, m/s
IDE03474-ENG102894,Calculated volume-averaged_volume,9.1, l
IDE03474-ENG99406,Calculated volume-averaged_volume_clipped,9.1, l
IDE03474-ENG101619,Calculated volume-calibrated_volume_total,9.1, l
IDE03474-ENG99553,Calculated volume-linking,0.0000000,
IDE03474-ENG101669,Calculated volume-prefiltered_acceleration_x,0.03125, m/s
IDE03474-ENG102339,Calculated volume-prefiltered_acceleration_y,0.03,
IDE03474-ENG101623,Calculated volume-reference_volume,8.9, l
IDE03474-ENG102479,Calculated volume-speed_based_linking,0.0000000, m/s
IDE03474-ENG99683,Calculated volume-version_of_application,209,
IDE03474-ENG102081,Calculated volume-volume_based_linking,0.0000000,
IDE03475-MAS00216,Control button in instrument cluster-External button for daily distance driven,not active,
IDE03475-MAS02915,Control button in instrument cluster-Button for auto check system,not active,
IDE03475-MAS03929,Control button in instrument cluster-Menu button,not active,
IDE03477-IDE00500,GPS time-Hour,10, H
IDE03477-IDE00501,GPS time-Minute,38, min
IDE03477-IDE00501,GPS time-Minute,29, min
IDE03477-IDE00502,GPS time-Year,2018, yr
IDE03477-IDE00503,GPS time-Month,10, mon
IDE03477-IDE00504,GPS time-Day,4, d
IDE03477-MAS00111,GPS time-Seconds,15, s
IDE03477-MAS00111,GPS time-Seconds,9, s
IDE03477-MAS03493,GPS time-last synchronization year,2018, yr
IDE03506,Distance: high resolution,03 2C 69 42,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,17,
IDE03880-MAS03425,MOST address-Physical address,04 02,
IDE03911-MAS01390,Service -interval- display: history 1-Block 1,8F F0 00 00,
IDE03911-MAS01391,Service -interval- display: history 1-Block 2,CF F0 00 AC,
IDE03911-MAS01392,Service -interval- display: history 1-Block 3,8F F0 84 51,
IDE03911-MAS01393,Service -interval- display: history 1-Block 4,4F F0 00 AC,
IDE03911-MAS01394,Service -interval- display: history 1-Block 5,0F F0 84 51,
IDE03911-MAS01395,Service -interval- display: history 1-Block 6,4F F0 00 AC,
IDE03911-MAS01396,Service -interval- display: history 1-Block 7,0F F0 84 51,
IDE03911-MAS01397,Service -interval- display: history 1-Block 8,FF FF FF FF,
IDE03911-MAS01398,Service -interval- display: history 1-Block 9,FF FF FF FF,
IDE03911-MAS01399,Service -interval- display: history 1-Block 10,FF FF FF FF,
IDE03911-MAS01400,Service -interval- display: history 1-Block 11,FF FF FF FF,
IDE03911-MAS01401,Service -interval- display: history 1-Block 12,FF FF FF FF,
IDE03911-MAS01402,Service -interval- display: history 1-Block 13,FF FF FF FF,
IDE03911-MAS01403,Service -interval- display: history 1-Block 14,FF FF FF FF,
IDE03911-MAS01404,Service -interval- display: history 1-Block 15,FF FF FF FF,
IDE03911-MAS01405,Service -interval- display: history 1-Block 16,FF FF FF FF,
IDE03912-MAS01390,Service -interval- display: history 2-Block 1,FF FF FF FF,
IDE03912-MAS01391,Service -interval- display: history 2-Block 2,FF FF FF FF,
IDE03912-MAS01392,Service -interval- display: history 2-Block 3,FF FF FF FF,
IDE03912-MAS01393,Service -interval- display: history 2-Block 4,FF FF FF FF,
IDE03912-MAS01394,Service -interval- display: history 2-Block 5,FF FF FF FF,
IDE03912-MAS01395,Service -interval- display: history 2-Block 6,FF FF FF FF,
IDE03912-MAS01396,Service -interval- display: history 2-Block 7,FF FF FF FF,
IDE03912-MAS01397,Service -interval- display: history 2-Block 8,FF FF FF FF,
IDE03912-MAS01398,Service -interval- display: history 2-Block 9,FF FF FF FF,
IDE03912-MAS01399,Service -interval- display: history 2-Block 10,FF FF FF FF,
IDE03912-MAS01400,Service -interval- display: history 2-Block 11,FF FF FF FF,
IDE03912-MAS01401,Service -interval- display: history 2-Block 12,FF FF FF FF,
IDE03912-MAS01402,Service -interval- display: history 2-Block 13,FF FF FF FF,
IDE03912-MAS01403,Service -interval- display: history 2-Block 14,FF FF FF FF,
IDE03912-MAS01404,Service -interval- display: history 2-Block 15,FF FF FF FF,
IDE03912-MAS01405,Service -interval- display: history 2-Block 16,FF FF FF FF,
IDE03913-MAS01390,Service -interval- display: history 3-Block 1,FF FF FF FF,
IDE03913-MAS01391,Service -interval- display: history 3-Block 2,FF FF FF FF,
IDE03913-MAS01392,Service -interval- display: history 3-Block 3,FF FF FF FF,
IDE03913-MAS01393,Service -interval- display: history 3-Block 4,FF FF FF FF,
IDE03913-MAS01394,Service -interval- display: history 3-Block 5,FF FF FF FF,
IDE03913-MAS01395,Service -interval- display: history 3-Block 6,FF FF FF FF,
IDE03913-MAS01396,Service -interval- display: history 3-Block 7,FF FF FF FF,
IDE03913-MAS01397,Service -interval- display: history 3-Block 8,FF FF FF FF,
IDE03913-MAS01398,Service -interval- display: history 3-Block 9,FF FF FF FF,
IDE03913-MAS01399,Service -interval- display: history 3-Block 10,FF FF FF FF,
IDE03913-MAS01400,Service -interval- display: history 3-Block 11,FF FF FF FF,
IDE03913-MAS01401,Service -interval- display: history 3-Block 12,FF FF FF FF,
IDE03913-MAS01402,Service -interval- display: history 3-Block 13,FF FF FF FF,
IDE03913-MAS01403,Service -interval- display: history 3-Block 14,FF FF FF FF,
IDE03913-MAS01404,Service -interval- display: history 3-Block 15,FF FF FF FF,
IDE03913-MAS01405,Service -interval- display: history 3-Block 16,FF FF FF FF,
IDE03914-MAS01390,Service -interval- display: history 4-Block 1,FF FF FF FF,
IDE03914-MAS01391,Service -interval- display: history 4-Block 2,FF FF FF FF,
IDE03914-MAS01392,Service -interval- display: history 4-Block 3,FF FF FF FF,
IDE03914-MAS01393,Service -interval- display: history 4-Block 4,FF FF FF FF,
IDE03914-MAS01394,Service -interval- display: history 4-Block 5,FF FF FF FF,
IDE03914-MAS01395,Service -interval- display: history 4-Block 6,FF FF FF FF,
IDE03914-MAS01396,Service -interval- display: history 4-Block 7,FF FF FF FF,
IDE03914-MAS01397,Service -interval- display: history 4-Block 8,FF FF FF FF,
IDE03914-MAS01398,Service -interval- display: history 4-Block 9,FF FF FF FF,
IDE03914-MAS01399,Service -interval- display: history 4-Block 10,FF FF FF FF,
IDE03914-MAS01400,Service -interval- display: history 4-Block 11,FF FF FF FF,
IDE03914-MAS01401,Service -interval- display: history 4-Block 12,FF FF FF FF,
IDE03914-MAS01402,Service -interval- display: history 4-Block 13,FF FF FF FF,
IDE03914-MAS01403,Service -interval- display: history 4-Block 14,FF FF FF FF,
IDE03914-MAS01404,Service -interval- display: history 4-Block 15,FF FF FF FF,
IDE03914-MAS01405,Service -interval- display: history 4-Block 16,FF FF FF FF,
IDE05931,FIX: Reset value for next mileage-dependent inspection,30000, km
IDE05932,FIX: Reset value for next time-dependent inspections,365, d
IDE09552-IDE07944,Vehicle configuration 2-electronic brake booster,Correct coding,
IDE09552-MAS06008,Vehicle configuration 2-Internal noise sound actuator,Correct coding,
IDE09552-MAS08940,Vehicle configuration 2-Collision warning,Correct coding,
MAS03121,Ring break diagnostic line status,Supply voltage,
ENG124477-MAS06854,Adapted_transponders_checksum-Version,01,
ENG124477-MAS06855,Adapted_transponders_checksum-Test sum,3F F6 8F DD,
ENG105830-ENG104002,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_bar_graph_and_ACC,0, %
ENG105830-ENG119807,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_clock_dial,0, %
ENG105830-ENG101889,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_gauge/finger/hand,0, %
ENG105830-ENG100477,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_indicator_lights,90, %
ENG105830-ENG103803,dmmng_chan_instr_clust/dmmng_char_curve_gauge/fnger-dimming_characteristic_curve_middle_display_main_field,96, %
ENG106303-ENG99140,ESI_active_warning-advance_warning_fixed_days,not active,
ENG106303-ENG100265,ESI_active_warning-advance_warning_fixed_km,not active,
ENG106303-ENG101600,ESI_active_warning-advance_warning_WIV_days,not active,
ENG106303-ENG102887,ESI_active_warning-advance_warning_WIV_km,not active,
ENG106303-ENG99971,ESI_active_warning-in_calculation,active,
ENG106303-ENG101015,ESI_active_warning-no_calculation_available,not active,
ENG106303-ENG101477,ESI_active_warning-service_warning_fixed_days,not active,
ENG106303-ENG101550,ESI_active_warning-service_warning_fixed_km,not active,
ENG106303-ENG101709,ESI_active_warning-service_warning_WIV_days,not active,
ENG106303-ENG102993,ESI_active_warning-service_warning_WIV_km,not active,
ENG119883,ESI_mileage_per_day,36, km
ENG106922,Immobilizer - Challenge,AC 5A BA A8,
ENG99439,Instrument_recorder,02 04 71 00 4D 51 42 56 57 31 34 53 31 46 41 43 00 00 00 00 03 00 5D 00 1D 00 00 02 01 00 00 00 00 80 00 00 0D 00 62 00 1D 00 00 02 57 00 00 00 02 00 00 00 00 00 9A 00 0F 00 00 01 9C 00 00 00 0A 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 AA 00 2D 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 0A FF FF FF FF FF FF FF FF FF 00 00 1D 00 5D 00 01 02 00 00 00 00 00 00 0F 00 9A 00 9C 01 00 00 0A 00 00 00 1D 00 5D 00 01 02 00 00 00 00 00 00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 FF FF 00 00 00 00 0E 44 B0 54 00 20 04 24 00 00 01 01,
ENG128745,Instrument_recorder_graphic,01 04 71 00 4D 51 42 56 57 31 34 53 31 46 47 43 00 00 00 00 01 00 00 C9 29 50 5C 01 2C 04 32 0F FB FF FF 00 00 00 00 00 04 00 00 00 C5 00 00 00 24 00 00 02 01 00 00 00 00 00 00 00 00 00 00 01 6B 00 00 00 3B 00 16 00 A2 00 00 00 00 00 00 00 08 00 00 00 F5 00 00 00 2D 00 00 00 00 00 00 C1 03 00 00 00 01 00 00 00 F5 00 00 00 2D 00 00 00 00 00 00 C2 03 80 00 00 01 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 00 00 00 4B 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 1D 0A FF FF FF FF FF FF FF FF FF,
ENG107920-ENG100914,onboard_computer-current_consumption,0.0,
ENG107920-ENG119788,onboard_computer-range_average_consumption,7.7, l/100km
ENG107920-ENG119789,onboard_computer-range_average_consumption_high,7.9, l/100km
ENG107920-ENG119790,onboard_computer-range_average_consumption_low,7.5, l/100km
ENG107920-ENG119791,onboard_computer-range_display_value,60, km
ENG107920-ENG119792,onboard_computer-range_R,64,
ENG107920-ENG112418,onboard_computer-total_range_gas,60, km
ENG124505-ENG100914,onboard_computer_cng-current_consumption,0.0,
ENG124505-ENG119788,onboard_computer_cng-range_average_consumption,6.0,
ENG124505-ENG119789,onboard_computer_cng-range_average_consumption_high,6.0,
ENG124505-ENG119790,onboard_computer_cng-range_average_consumption_low,6.0,
ENG124505-ENG119791,onboard_computer_cng-range_display_value,0, km
ENG124505-ENG119792,onboard_computer_cng-range_R,0,
ENG107953-ENG100938,outside_temp_algorithm_group-coolant_temperature_outdated_bit,not active,
ENG107953-ENG101136,outside_temp_algorithm_group-distance_threshold_not_yet_reached,active,
ENG107953-ENG99778,outside_temp_algorithm_group-downward_tendency,not active,
ENG107953-ENG99788,outside_temp_algorithm_group-engine_running_detection_MSG,not active,
ENG107953-ENG102352,outside_temp_algorithm_group-ice_warning_symbol,not active,
ENG107953-ENG99520,outside_temp_algorithm_group-no_blockage_active,not active,
ENG107953-ENG99784,outside_temp_algorithm_group-outside_temperature_filtered,131,
ENG107953-ENG99258,outside_temp_algorithm_group-outside_temperature_filtered_error_state_bit,not active,
ENG107953-ENG102589,outside_temp_algorithm_group-outside_temperature_old,not active,
ENG107953-ENG102387,outside_temp_algorithm_group-outside_temperature_raw_score_error_state_bit,not active,
ENG103405,read_out_measured_value_block,53,
ENG119885-ENG103300,Service_Key_current_data-Service_Data,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
ENG108927-ENG119819,Service_Key_Master_Counter-Counter_ID_Kessy,1,
ENG108927-ENG119811,Service_Key_Master_Counter-Counter_Key_ID_1,0,
ENG108927-ENG119812,Service_Key_Master_Counter-Counter_Key_ID_2,0,
ENG108927-ENG119813,Service_Key_Master_Counter-Counter_Key_ID_3,0,
ENG108927-ENG119814,Service_Key_Master_Counter-Counter_Key_ID_4,0,
ENG108927-ENG119815,Service_Key_Master_Counter-Counter_Key_ID_5,0,
ENG108927-ENG119816,Service_Key_Master_Counter-Counter_Key_ID_6,0,
ENG108927-ENG119817,Service_Key_Master_Counter-Counter_Key_ID_7,0,
ENG108927-ENG119818,Service_Key_Master_Counter-Counter_Key_ID_8,0,
ENG108927-ENG119821,Service_Key_Master_Counter-Counter_Trigger,0,
ENG108927-ENG119822,Service_Key_Master_Counter-Error_Counter,0,
ENG108927-ENG119823,Service_Key_Master_Counter-Immo_Key,0,
ENG108927-ENG119820,Service_Key_Master_Counter-Last_Key,ID_Kessy,
ENG108927-ENG99298,Service_Key_Master_Counter-State,Engine_off,
ENG108929-ENG99961,Service_Key_Pointer-Current_Bank,key_not_readable,
ENG108929-ENG119808,Service_Key_Pointer-Write_Pointer_Adr_159,0,
ENG108929-ENG119809,Service_Key_Pointer-Write_Pointer_Adr_191,0,
ENG108929-ENG119810,Service_Key_Pointer-Write_Pointer_Adr_223,0,
ENG100879-ENG118224,State Blocking Time-blocking_time,00 00 00 00 00 00,
ENG103899-ENG99298,State of Immobilizer-State,02 01 03 D6 02 00 00 00 01 00,
ENG103284-ENG118223,State of Immobilizer Slaves-ELV_State,C0,
ENG103284-ENG118222,State of Immobilizer Slaves-GSG_State,F8,
ENG103284-ENG118217,State of Immobilizer Slaves-Immobilizer_State,00,
ENG103284-ENG118216,State of Immobilizer Slaves-key_state,1C,
ENG103284-ENG118218,State of Immobilizer Slaves-MSG_1_State,F8,
ENG103284-ENG118219,State of Immobilizer Slaves-MSG_2_State,00,
ENG103284-ENG118220,State of Immobilizer Slaves-MSG_3_State,00,
ENG103284-ENG118221,State of Immobilizer Slaves-MSG_4_State,00,
ENG103284-ENG20775,State of Immobilizer Slaves-OCU_state,00,
ENG103284-ENG20776,State of Immobilizer Slaves-VTS_state,00,
ENG109576,Transponder ID Key 1,08 0B C6 27,
ENG109577,Transponder ID Key 2,08 0C 44 9B,
Elapsed Time: 00:12
;SW:8V0-919-191-E   HW:8V0-919-191 ---  TV Tuner
;Component:DVB-DTV       H08 0900, Coding:0204020000000100000000
;EV_TVMELC,001033,EV_TVMELC_VW37.rod
;Thursday,04,October,2018,11:37:51:02525
;VCID: 41DEB5DE710957DFD18-8014
IDE00019,Voltage terminal 30,11.6, V
IDE00030,Status of actuator test,not active,
IDE00767,No. of unscheduled ECU resets,0, counts
IDE01285-ENG101364,Counter of component protection malfunctions-Theft Protection Error Counter,00 00,
IDE03880-MAS03119,MOST address-Functional block: diagnostic instance,57,
IDE03880-MAS03425,MOST address-Physical address,04 01,
IDE04317-MAS00108,Total system run time-Day,38, d
IDE04317-MAS00109,Total system run time-Hours,3, H
IDE04317-MAS00110,Total system run time-Minutes,47, min
IDE05704-MAS02646,Digital Transmission Content Protection (DTCP) key-Key type,License key (DTLA),
IDE05705-MAS01159,Digital Transmission Content Protection (DTCP) device cert-Version number,0,
IDE05705-MAS01779,Digital Transmission Content Protection (DTCP) device cert-Length,0,
IDE05705-MAS06742,Digital Transmission Content Protection (DTCP) device cert-Certificate type,0,
IDE06055,Invalid authentication (DTCP),5F,
IDE07938,Cause of system start,Optical data bus,
IDE07939,Last cause of system start,Optical data bus,
IDE08128,Antenna inputs,3,
IDE08129-MAS05807,Country setting TV-Norm-Coding,Italy,
IDE08129-MAS06596,Country setting TV-Norm-chosen in MMI,Italy,
IDE08129-MAS06597,Country setting TV-Norm-previously chosen MMI,Italy,
IDE08145-MAS01808,Connection status antenna 1-Antenna current,51, mA
IDE08145-MAS06666,Connection status antenna 1-TV tuner to impedance converter,Electrical OK,
IDE08145-MAS06667,Connection status antenna 1-Impedance converter to antenna,Electrical OK,
IDE08145-MAS06668,Connection status antenna 1-Phantom voltage,8.6, V
IDE08145-MAS06669,Connection status antenna 1-level,52,
IDE08146-MAS01808,Connection status antenna 2-Antenna current,54, mA
IDE08146-MAS06666,Connection status antenna 2-TV tuner to impedance converter,Electrical OK,
IDE08146-MAS06667,Connection status antenna 2-Impedance converter to antenna,Electrical OK,
IDE08146-MAS06668,Connection status antenna 2-Phantom voltage,8.6, V
IDE08146-MAS06669,Connection status antenna 2-level,46,
IDE08147-MAS01808,Connection status antenna 3-Antenna current,54, mA
IDE08147-MAS06666,Connection status antenna 3-TV tuner to impedance converter,Electrical OK,
IDE08147-MAS06667,Connection status antenna 3-Impedance converter to antenna,Electrical OK,
IDE08147-MAS06668,Connection status antenna 3-Phantom voltage,8.7, V
IDE08147-MAS06669,Connection status antenna 3-level,47,
IDE08148-MAS01632,Tuner 1: Status-Status,On,
IDE08148-MAS06669,Tuner 1: Status-level,52,
IDE08148-MAS06670,Tuner 1: Status-Channel,056,
IDE08149-MAS01632,Tuner 2: Status-Status,On,
IDE08149-MAS06669,Tuner 2: Status-level,46,
IDE08149-MAS06670,Tuner 2: Status-Channel,056,
IDE08150-MAS01632,Tuner 3: Status-Status,On,
IDE08150-MAS06669,Tuner 3: Status-level,47,
IDE08150-MAS06670,Tuner 3: Status-Channel,056,
IDE08151-MAS01632,Video connection to end unit-Status,Not available,
IDE08151-MAS06669,Video connection to end unit-level,255,
IDE08152-MAS01632,Video connection to rear seat entertainment-Status,Not available,
IDE08152-MAS06669,Video connection to rear seat entertainment-level,255,
IDE08153-MAS06671,Audio connection to rear seat entertainment-Status RSE left,no measured value present,
IDE08153-MAS06672,Audio connection to rear seat entertainment-Status RSE right,no measured value present,
IDE08154,Video signal from external source,Not Present,
IDE08211-MAS00106,History data control module reset-Year,2000,
IDE08211-MAS00107,History data control module reset-Month,0,
IDE08211-MAS00108,History data control module reset-Day,0,
IDE08211-MAS00109,History data control module reset-Hours,31,
IDE08211-MAS00110,History data control module reset-Minutes,63,
IDE08211-MAS00111,History data control module reset-Seconds,63,
IDE08211-MAS06734,History data control module reset-last cause of reset,FF,
IDE08211-MAS06735,History data control module reset-second-to last cause of reset,FF,
IDE08211-MAS06736,History data control module reset-third-to-last cause of reset,FF,
IDE08510,Information data,01 D1 00 00 01 53 01 01 01 2D 24 16 22 15 00 78 00 00 00 00 00 00 01 00 00 00 4D 00 00 00 23 00 00 00 00 00 00 00 03 60 00 00 44 01 20 00 00 C0 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 4D 1E 6F B1 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 4D 1E 81 22 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 01 53 01 01 01 2D 26 16 22 15 00 78 00 00 00 00 00 00 01 00 00 00 4D 00 00 00 23 00 00 00 00 00 00 00 03 60 00 00 44 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 EA 64 00 01 53 01 01 01 2D 24 16 22 15 00 78 00 00 00 00 00 00 01 00 00 00 4D 00 00 00 23 00 00 00 00 00 00 00 03 60 00 00 44 01 20 00 00 C0 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 4D 1E 6F B1 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 4D 1E 81 22 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 01 53 01 01 01 2D 26 16 22 15 00 78 00 00 00 00 00 00 01 00 00 00 4D 00 00 00 00 00 00 00 D7 00 00 00 4F 04 00 00 62 24 D7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 EA 64 00 8C 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 4D 1E 6F B1 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 4D 1E 81 22 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 20 00 00 00 00 14 00 00 00 00 11 00 00 00 00 12 00 00 00 00 0A 00 00 00 00 00 53 01 01 01 31 08 1B 22 15 00 77 00 00 00 00 01 00 01 36 37 35 4D 00 00 00 23 00 0E 0D FF 00 00 00 03 60 00 00 44 01 00 00 00 80 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 05 00 19 00 00 0A 01 FF FF 00 00 FF FF 00 00 01 00 01 00 00 00 00 45 00 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 01 01 01 31 04 1B 22 15 00 77 00 00 00 00 01 00 01 36 37 35 4D 00 00 00 23 00 0E 0D FF 00 00 00 03 60 00 00 44 01 00 00 00 80 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 05 00 18 00 00 0A 01 FF FF FF FF FF FF FF FF 01 00 01 00 01 00 00 46 00 46 00 47 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 14 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 53 01 01 01 31 06 1B 22 15 00 77 00 00 00 00 01 00 01 36 37 35 4D 00 00 00 23 00 0E 0D FF 00 00 00 03 60 00 00 44 01 00 00 00 80 C0 00 00 00 00 00 00 00 00 00 00 00 00 13 00 00 42 00 05 00 18 00 00 0A 01 FF FF FF FF FF FF FF FF 01 00 01 00 01 00 00 46 00 46 00 48 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D7 00 00 00 4F 04 00 00 62 24 D7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 D7 00 00 00 1E 03 00 00 62 24 D7 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00,
IDE08784-MAS03991,Reception level antenna-Reception level antenna 1,255, dB
IDE08784-MAS04344,Reception level antenna-Reception level antenna 2,255, dB
IDE08784-MAS07641,Reception level antenna-Duration hours,0, H
IDE08784-MAS07642,Reception level antenna-Dur. minutes,0, min
IDE08784-MAS07643,Reception level antenna-Duration seconds,0, s
IDE08784-MAS07644,Reception level antenna-Reception level antenna 3,255, dB
IDE08784-MAS07645,Reception level antenna-Avge. value reception level antenna 1,255, dB
IDE08784-MAS07646,Reception level antenna-Avge. value reception level antenna 2,255, dB
IDE08784-MAS07647,Reception level antenna-Avge. value reception level antenna 3,255, dB
MAS00464-MAS00106,Standard - ambient data 1-Year,2018,
MAS00464-MAS00107,Standard - ambient data 1-Month,10,
MAS00464-MAS00108,Standard - ambient data 1-Day,4,
MAS00464-MAS00109,Standard - ambient data 1-Hours,11,
MAS00464-MAS00110,Standard - ambient data 1-Minutes,39,
MAS00464-MAS00111,Standard - ambient data 1-Seconds,42,
MAS00464-MAS00468,Standard - ambient data 1-Unlearning counter,175,
MAS00464-MAS00711,Standard - ambient data 1-Odometer reading,53242, km
MAS04266-MAS01424,Temperature sensor 1-max.value,59, °C
MAS04266-MAS01425,Temperature sensor 1-min.value,-3, °C
MAS04266-MAS02238,Temperature sensor 1-Current,37, °C
ENG117872-ENG117778,Byte_Coding_Condition-byte_0_condition,OK,
ENG117872-ENG117779,Byte_Coding_Condition-byte_1_condition,OK,
ENG117872-ENG117788,Byte_Coding_Condition-byte_10_condition,OK,
ENG117872-ENG117789,Byte_Coding_Condition-byte_11_condition,dont care,
ENG117872-ENG117790,Byte_Coding_Condition-byte_12_condition,dont care,
ENG117872-ENG117791,Byte_Coding_Condition-byte_13_condition,dont care,
ENG117872-ENG117792,Byte_Coding_Condition-byte_14_condition,dont care,
ENG117872-ENG117793,Byte_Coding_Condition-byte_15_condition,dont care,
ENG117872-ENG117794,Byte_Coding_Condition-byte_16_condition,dont care,
ENG117872-ENG117795,Byte_Coding_Condition-byte_17_condition,dont care,
ENG117872-ENG117796,Byte_Coding_Condition-byte_18_condition,dont care,
ENG117872-ENG117797,Byte_Coding_Condition-byte_19_condition,dont care,
ENG117872-ENG117780,Byte_Coding_Condition-byte_2_condition,OK,
ENG117872-ENG117798,Byte_Coding_Condition-byte_20_condition,dont care,
ENG117872-ENG117799,Byte_Coding_Condition-byte_21_condition,dont care,
ENG117872-ENG117800,Byte_Coding_Condition-byte_22_condition,dont care,
ENG117872-ENG117801,Byte_Coding_Condition-byte_23_condition,dont care,
ENG117872-ENG117802,Byte_Coding_Condition-byte_24_condition,dont care,
ENG117872-ENG117803,Byte_Coding_Condition-byte_25_condition,dont care,
ENG117872-ENG117804,Byte_Coding_Condition-byte_26_condition,dont care,
ENG117872-ENG117805,Byte_Coding_Condition-byte_27_condition,dont care,
ENG117872-ENG117781,Byte_Coding_Condition-byte_3_condition,OK,
ENG117872-ENG117782,Byte_Coding_Condition-byte_4_condition,OK,
ENG117872-ENG117783,Byte_Coding_Condition-byte_5_condition,OK,
ENG117872-ENG117784,Byte_Coding_Condition-byte_6_condition,OK,
ENG117872-ENG117785,Byte_Coding_Condition-byte_7_condition,OK,
ENG117872-ENG117786,Byte_Coding_Condition-byte_8_condition,OK,
ENG117872-ENG117787,Byte_Coding_Condition-byte_9_condition,OK,
Elapsed Time: 00:07
