first time user and clueless hopefully someone can help thanks
hardly runs keeps blowing #13 fuse under hood when engine is running unless i unplug either high pressure fuel pump i did an auto scan and i have posted the results below also epc light is on and cel is on and esp1 fault
Saturday,27,October,2018,22:53:59:37688
VCDS Version: 18.9.0.2 (x64) HEX-V2 CB: 0.4436.4
VIN: WA1BV74L37D065509 License Plate: BRAGG
Mileage: 249400km-154969mi Repair Order:
Chassis Type: 4L (4L0)
Scan: 01 02 03 05 07 08 09 0E 0F 13 15 16 17 19 28 34 36 37 3C 42
46 47 4F 52 55 56 61 62 65 67 69 6C 6D 6F 72 76 77
VIN: WA1BV74L37D065509 Mileage: 249400km-154969miles
Address 01: Engine Labels:. 079-907-560-BAR.clb
Part No SW: 4L0 910 560 C HW: 4L0 907 560 A
Component: 4.2l V8/4V 0060
Revision: 71H16--- Serial number:
Coding: 01210009190F0E60
Shop #: WSC 01117 444 54512
VCID: 2809FB750EFA28C7F65-807C
10 Faults Found:
000258 - Mass Air Flow Sensor (G70)
P0102 - 002 - Signal too Low - Intermittent
Mileage: 249405 km
RPM: 134 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 9.0°C
Absolute Pres.: 980.0 mbar
Voltage: 9.144 V
000268 - Mass Air Flow Sensor (G246)
P010C - 002 - Signal too Low - Intermittent
Mileage: 249405 km
RPM: 134 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 9.0°C
Voltage: 9.144 V
008852 - Fuel Pressure Regulator Valve (N276)
P2294 - 004 - Open Circuit - Intermittent - MIL ON
Fault Status: 10100100
Fault Frequency: 9
Mileage: 249405 km
Date: 2018.10.21
Time: 14:46:13
RPM: 134 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 9.0°C
Voltage: 9.398 V
004763 - Fuel Pressure Regulator Valve; Bank 2 (N276)
P129B - 004 - Open Circuit - Intermittent - MIL ON
Fault Frequency: 9
Mileage: 249405 km
Date: 2018.10.21
Time: 14:46:13
RPM: 134 /min
Load: 100.0 %
Temperature: 21.0°C
Temperature: 9.0°C
Voltage: 9.398 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground - Intermittent - MIL ON
Fault Status: 10100010
Mileage: 249405 km
Date: 2018.10.21
Time: 14:46:14
RPM: 1093 /min
Load: 31.8 %
Temperature: 21.0°C
Temperature: 9.0°C
Voltage: 12.573 V
005173 - Secondary Air Pump Relay (J299)
P1435 - 002 - Short to Ground - Intermittent - MIL ON
Mileage: 249405 km
Date: 2018.10.21
Time: 14:46:14
RPM: 1093 /min
Load: 31.8 %
Temperature: 21.0°C
Temperature: 9.0°C
Voltage: 11.684 V
009217 - EVAP Leak Detection Pump Control Circuit
P2401 - 002 - Short to GND - Intermittent - MIL ON
Mileage: 249405 km
Date: 2018.10.21
Time: 14:46:39
RPM: 771 /min
Load: 25.1 %
Temperature: 19.0°C
Temperature: 9.0°C
Voltage: 13.716 V
P0300 - 001 - - Intermittent - MIL ON
Fault Status: 10100001
Mileage: 249405 km
Date: 2018.10.21
Time: 14:47:55
RPM: 772 /min
Load: 31.4 %
Temperature: 28.0°C
Temperature: 9.0°C
Voltage: 13.843 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - Intermittent - MIL ON
Mileage: 249405 km
Date: 2018.10.21
Time: 14:47:55
RPM: 772 /min
Load: 31.4 %
Temperature: 28.0°C
Temperature: 9.0°C
Voltage: 13.843 V
000770 - Cylinder 2
P0302 - 001 - Misfire Detected - Intermittent - MIL ON
Mileage: 249405 km
Date: 2018.10.21
Time: 14:47:55
RPM: 772 /min
Load: 31.4 %
Temperature: 28.0°C
Temperature: 9.0°C
Voltage: 13.843 V
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09D-927-750.clb
Part No SW: 09D 927 750 FQ HW: 09D 927 750 FQ
Component: AL 750 6A 0999
Revision: 00H64000 Serial number:
Coding: 0000504
Shop #: WSC 31414 790 00001
VCID: 025D89DDC8062297881-8056
Fault Frequency: 7
Reset counter: 0
Date: 2006.05.10
Time: 12:00:02
Address 03: ABS Brakes Labels:. 4L0-910-517-V1.clb
Part No SW: 4L0 910 517 A HW: 4L0 614 517 A
Component: ESP ALLRAD MK25E1 0130
Revision: 00H22001
Coding: 0545841
Fault Status: 00101101
Reset counter: 102
Mileage: 249405 km
Date: 2018.10.18
Time: 15:09:37
Count: 64
Count: 12289
Count: 8193
Count: 41984
Reset counter: 102
Mileage: 249324 km
Date: 2018.10.15
Time: 12:14:52
Count: 64
Count: 12545
Count: 128
Count: 39936
Part No SW: 4F0 910 852 B HW: 4F0 905 852 H
Component: FBSAUDIC6 ELV H08 0210
Revision: 00H08000 Serial number: 10603902235463
Coding: 0000143
Shop #: WSC 02440 002 1048576
VCID: 2517F24179E835AFCD3-8070
Subsystem 1 - Part No: 4F0 910 131 L
Component: FBSAUDIC6 EZS H45 0080
Component: FBSAUDIC6 KSG H27 0080
007 - Short to Ground
Fault Status: 01110111
Reset counter: 0
00955 - Key 1
Fault Frequency: 20
Reset counter: 40
Mileage: 245642 km
Date: 2018.06.07
Time: 22:14:17
Address 07: Control Head Labels: 4L0-910-7xx-07-H.clb
Part No SW: 4L0 910 731 P HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 354KQ067514062
Coding: 0002003
VCID: 35372201C948452F7D3-8060
Component: E0380 BedienteilH01 0060
Subsystem 2 - Serial number: 00000000581043
Subsystem 3 - Serial number: 0113.11.060000000100010809ÿ
Subsystem 4 - Serial number: 010809ÿ
02849 - Control Module for Lane Change Assistance (J769)
Reset counter: 142
Mileage: 249405 km
Date: 2018.10.22
Time: 16:58:08
Part No SW: 4L0 910 043 HW: 4L0 820 043 F
Revision: 00---012 Serial number: 00000030014807
Coding: 0786472
VCID: 619FA6512D40998FF1B-8034
Part No SW: 4F0 910 279 J HW: 4F0 907 279 A
Component: ILM Fahrer H17 0240
Coding: 0113123
VCID: 30391315362A60072E5-8064
Subsystem 1 - Part No: 4L1 910 113 Labels: 1KX-955-119.CLB
Component: Wischer AU716 H12 0080
Coding: 00064792
Shop #: WSC 31414
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Coding: 00150059
Shop #: WSC 31414
Part No SW: 4L0 910 110 A HW: 4L0 035 110
Component: MP3-Changer H43 0350
Revision: 00043000 Serial number: AUZ5ZBF1017220
VCID: 1D67DAA151B8FD6F953-8048
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7F0015244
VCID: 2C0107651A0204E712D-8078
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4L0 910 561 HW: 4L0 907 561
Component: ABSTANDSREGELUNGH05 0120
Revision: -------- Serial number: 00000000000000
Coding: 0011111
VCID: 6695B54DC46EFEB7049-8032
Fault Frequency: 15
Reset counter: 142
Mileage: 249324 km
Date: 2018.10.15
Time: 12:14:52
Temperature: 8.0°C
Voltage: 11.39 V
Bin. Bits: 00000
Hex Value: 0x0442
Hex Value: 0x0002
Speed: -3.6 km/h
Lateral Accel.: 0.00 m/s^2
Reset counter: 142
Mileage: 249405 km
Date: 2018.10.25
Time: 14:43:10
Temperature: 10.0°C
Voltage: 8.83 V
Bin. Bits: 01000
Hex Value: 0x0346
Hex Value: 0x0003
Speed: -3.6 km/h
Address 15: Airbags Labels: 4L0-910-655.lbl
Part No SW: 4L0 910 655 A HW: 4L0 959 655 B
Component: 73 AIRBAG AUDI8RH39 0210
Revision: 03H39000 Serial number: 0038QD043AE
Coding: 0014131
VCID: 2B0304791F0C03DF1B7-807E
Subsystem 1 - Part No: 4L0 910 339
Component: BF-Gewichtsens. H02 0020
Subsystem 2 - Serial number: 6332QSME1A032C7DN
Subsystem 3 - Serial number: 6342QSME1A043647B
Subsystem 4 - Serial number: 6352QSME1A044D59N
Subsystem 5 - Serial number: 6362QSME1A03560BE
Subsystem 6 - Serial number: 63734SME187C121F5
Subsystem 7 - Serial number: 63834SME18783021W
Part No SW: 4F0 910 549 A HW: 4F0 953 549 C
Component: J0527 0410
Revision: 00H03000 Serial number: 90054062960075
Coding: 0012252
VCID: 270BF84903E427BFFFF-8072
Component: E0221 H07 0090
Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
Part No SW: 4F0 910 930 C HW: 4L0 920 980 B
Component: KOMBIINSTR. M73 H17 0170
Revision: 00700000 Serial number: 5HB36JFC6
Coding: 2801268
Shop #: WSC 63493 000 1048576
VCID: 2313EC5977DCCB9FA37-8076
Address 19: CAN Gateway Labels:. 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468 A
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0800D06B088096
Coding: F7F7FE7F357A02
VCID: 6C81C765DA82C4E752D-8038
Address 28: HVAC, Rear Labels: None
Part No SW: 4L0 910 158 HW: 4L0 919 158 D
Revision: 00---009 Serial number: 00000000084311
Coding: 0000006
VCID: 6889BB75CE7AE8C7365-803C
02599 - Rear Left Temperature Flap Motor (V313)
Fault Status: 00100011
Reset counter: 104
Mileage: 248640 km
Date: 2018.09.24
Time: 14:31:31
Voltage: 14.10 V
Temperature: -100.0°C
(no units): 173.0
(no units): 181.0
Reset counter: 122
Mileage: 247653 km
Date: 2018.08.27
Time: 17:03:36
Address 34: Level Control Labels: 4L0-910-553.lbl
Part No SW: 4L0 910 553 B HW: 4L0 907 553
Component: LUFTFDR.-CDC H03 7550
Revision: --H03001 Serial number: 15.1528-0095.2
Coding: 0015520
VCID: 290FFE7115F011CFE9B-807C
00140 - Front Right Body Acceleration Sensor (G342)
009 - Open or Short to Ground
Fault Status: 11101001
Fault Frequency: 80
Reset counter: 102
Mileage: 248973 km
Date: 2018.10.01
Time: 13:08:23
Error Code: 197
Fault Status: 11100010
Reset counter: 102
Mileage: 249405 km
Date: 2018.10.22
Time: 16:58:18
Error Code: 13
Fault Frequency: 80
Reset counter: 102
Mileage: 248973 km
Date: 2018.10.01
Time: 13:08:23
Error Code: 197
Part No SW: 4F0 910 760 HW: 4L0 959 760
Component: Sitzmemory FS H01 0100
Revision: 00000000 Serial number: 00000000896401
Coding: 0082954
Part No SW: 4E0 910 888 D HW: 4E0 919 887 L
Component: MNS US H48 0970
Revision: 00000000 Serial number: 313KO067511527
Shop #: WSC 01117 444 84384
VCID: 2F3B10692B147FFF37F-807A
Part No SW: 4L0 910 566 A HW: 4L0 907 566 A
Component: J0769_SWA_MasterH06 0060
Revision: 00H06000 Serial number: 6PZ 009 014-00
Coding: 0010001
Subsystem 1 - Part No: 4L0 910 568 A
Component: J0770_SWA_Slave_H05 0060
Subsystem 2 - Serial number: 6PZ 009 014-20
Subsystem 3 - Serial number: 3F04.11.0600H0500000010056ÿ
Subsystem 4 - Serial number: 010056ÿ
Address 42: Door Elect, Driver Labels: 4L0-910-793-42.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 793 B
Component: TSG FA H12 0130
Revision: 00-00000
Coding: 0051915
Address 46: Central Conv. Labels:. 4L0-910-289.lbl
Part No SW: 4L0 910 289 D HW: 4L0 907 289 A
Component: Komfortgeraet H05 0020
Revision: 0020 --- Serial number: 01024529760000
Coding: 7632925
VCID: 313F16113D20690F21B-8064
02956 - Lamp in Trunk/Hatch Lid; Left
Fault Status: 01101001
Reset counter: 102
Mileage: 205504 km
Date: 2015.09.22
Time: 18:45:34
Bin. Bits: 000 001
Address 47: Sound System Labels: 4L0-910-223-BO.lbl
Part No SW: 4L0 910 223 G HW: 4L0 035 223 D
Component: DSP-High AU716 H03 0150
Revision: PROD_01 Serial number: 00000000003739
Coding: 0000026
Part No SW: 4F0 910 280 HW: 4F0 907 280 B
Component: ILM Beifahrer H10 0080
Revision: Serial number: 00000000057237
Coding: 0012001
VCID: 5EE59DAD1C3EA677CC9-800A
Address 52: Door Elect, Pass. Labels: 4L0-910-793-52.lbl
Part No SW: 4L0 910 793 B HW: 4L0 959 792 B
Component: TSG BF H12 0130
Revision: 00-00000
Coding: 0051915
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Coding: 0000022
Part No SW: 4E0 910 541 Q HW: 4E0 035 541 P
Revision: 00000000 Serial number: 388K.067570154
VCID: 2E050D6D2C1E76F73C9-807A
Part No SW: 4L0 910 181 HW: 4L0 915 181
Component: J0644 BEM H12 0530
Revision: -------- Serial number: 00000000060961
VCID: 6491AF4532528CA71AD-8030
Component: von VA0 1234567890
Coding: 344630393135313035442056413031323334353637383930
Shop #: WSC 49791 000 1048576
Fault Frequency: 35
Mileage: 249405 km
Date: 2018.10.18
Time: 15:08:51
Address 62: Door, Rear Left Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 795 B
Component: TSG HL H21 0050
Coding: 0051722
Address 65: Tire Pressure Labels: 4F0-910-273-BA.lbl
Part No SW: 4F0 910 273 B HW: 4F0 907 273 A
Component: Reifendruck 3 H05 0100
Revision: 00050100 Serial number: 00000700034964
Coding: 0062424
VCID: 221DE95D68C6C297A81-8076
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000611130147
Shop #: WSC 12336 024 394758
VCID: 34311F05C2325C274AD-8060
Address 69: Trailer Labels: 4E0-910-383.lbl
Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
Component: ANHAENGERELEKTR 004 0060
VCID: 2411EF4572D2CCA7DAD-8070
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4L0 910 441 A HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6X43ET
Coding: 1001001
Part No SW: 4L0 910 945 HW: 4L0 827 851 B
Component: ValeoHeckdeckel H21 0280
Revision: --H21001 Serial number: E5030000B
Shop #: WSC 98765 666 38354
Subsystem 3 - Serial number: RD14.11.06--H21001001B0071ÿ
Subsystem 4 - Serial number: 1B0071ÿ
Address 6F: Centr. Conv. II Labels:. 4L0-910-290.lbl
Part No SW: 4L0 910 290 A HW: 4L0 907 290 A
Component: ILM HINTEN 2 H05 0060
Revision: AAH05061 Serial number: 002185533-----
Coding: 0003595
VCID: 2615F54D04EE3EB7C49-8072
Component: J_245_EE15_SKB09H10 0180
Component: J_394_EE15_SKB09H10 0180
Component: J_392_EE15_SKB09H10 0180
02960 - Lamp in Bumper; Rear Left
Reset counter: 102
Mileage: 245441 km
Date: 2018.06.06
Time: 12:10:56
Bin. Bits: 000 100
01514 - Regulator for Roof
Fault Status: 00101100
Fault Frequency: 210
Reset counter: 129
Mileage: 245605 km
Date: 2018.06.07
Time: 16:42:08
Address 72: Door, Rear Right Labels: 4L0-910-795.lbl
Part No SW: 4L0 910 795 B HW: 4L0 959 794 B
Component: TSG HR H21 0050
Coding: 0051722
Fault Frequency: 15
Reset counter: 102
Mileage: 248247 km
Date: 2018.09.15
Time: 12:29:38
Part No SW: 4F0 910 283 F HW: 4F0 919 283 F
Revision: 00H09000 Serial number: 06230631003790
Coding: 0031246
Part No SW: 4F0 910 336 D HW: 4E0 862 335
Component: Handyvorb2 H18 0700
Revision: 00000000 Serial number: 00000005073131
Coding: 0010900
End----(Elapsed Time: 02:36, VBatt start/end: 10.7V/10.7V. VIgn 10.7V)-----
