VW Passat 2009 CR DPF issues - Please help
cygnus216
New Member
Hi all,
This is my first post so apologies in advance for any faux pas.
I have a an issue with my DPF I am hoping to get some more info on with the help of your knowledge
The Car:
VW Passat B6 2.0 Diesel Common Rail 82KW/110HP Engine code CBD with 160k mile on the clock
Symptomns:
It was idling roughly and then it started smoking heavily when driving around town - immediate fear was head gasket but took to a mechanic and said it was the DPF and needed a good rag on the motorway, on the way to the motorway the EML light came on NOT DPF light, Ive since realised it put itself in regen mode and after a run cleared out and started idling smoothly and the start stop was back to working. the mechanic cleared the code (P2002 I will attach the VCDS below) and i thought all was ok.
on 2 more occasions the EML has come back on and i have had to run a regen using a ross tech VCDS
My first question is, is this normal for the DPF to block up within 2 weeks of a regen if only used for occasional town runs?
The second questions is when using the meas blocks 108 the "Particle Filter Carbon Mass (act.)" shows 0.0 at all times. Why could this be? and is this measurement taken from the LAMBDA sensor in the DPF?
Any help is much appreciated
Many Thanks
Jack
VCDS fault code
008194 - Particulate Trap Bank 1
P2002 - 000 - Efficiency Below Threshold
Fault Frequency: 7
Mileage: 256979 km
Date: 2039.14.26
Time: 12:59:22
RPM: 2139 /min
Speed: 34.0 km/h
Pressure: 8 mbar
Hex Value: 0xFF04
Temperature: 468.0°C
(no units): 260.1
Mileage: 280 km
billywhizz
C?ID=278038
Jack , im sorry too hear of your problems. the best way forewards now is too do and publish an auto scan so we have all the information.
cygnus216
New Member
Thanks billywhizz
Here's the full scan
The EML is now on and it is shaking violently on idle, any advice would be much appreciated
Monday,08,October,2018,20:12:06:11853
VCDS Version: 18.2.1.5 (x64)
VIN: WVWZZZ3CZ9E140368   License Plate:
Chassis Type: 3C-VW46 (3C0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4F 52 53 56 61
VIN: WVWZZZ3CZ9E140368   Mileage: 258160km-160413miles
Address 01: Engine (CBD)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 SC    HW: 03L 907 309 B
   Component: R4 2.0l TDI G000SG  9977
   Revision: 22H21---    Serial number: VWZCZ000000000
   Coding: 0000071
   Shop #: WSC 30140 002 1048576
   VCID: 78F49F8F0BFD06841C-802C
               P2002 - 000 - Efficiency Below Threshold - MIL ON
                    Fault Status: 11100000
                    Mileage: 258142 km
                    Date: 2013.02.28
                    Time: 11:40:51
                    RPM: 2277 /min
                    Speed: 60.0 km/h
                    Pressure: 13 mbar
                    Hex Value: 0xFF04
                    Temperature: 378.0°C
                    (no units): 249.9
                    Mileage: 380 km
Readiness: 1 1 0 0 0
   Part No SW: 3C0 614 109 M    HW: 3C0 614 109 M
   Component: J104    C4 440 V2   0021
   Revision: --025---    Serial number: 00000795155600
   Coding: 0034296
   Shop #: WSC 05311 000 00000
   VCID: 28548FCF9BDD56044C-807C
   Part No SW: 1K0 820 047 JD    HW: 1K0 820 047 JD
   Component: Climatic PQ35   143 1313
   Revision: 00143033    Serial number: 00000000000000
   VCID: 6FE6A4D37EB3413CCD-803A
Address 09: Cent. Elect.        Labels:. 3C0-937-049-30-M.lbl
   Part No SW: 3C8 937 049 N    HW: 3C8 937 049 N
   Component: Bordnetz-SG     H53 3101
   Revision: 00H53000    Serial number: 00000009448063
   Coding: 00880F0700041A00470A00000F000000000059435C000100000100000000
   Shop #: WSC 05124 000 00000
   VCID: 3C7C439F7F45EAA438-8068
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 260309 022  0601
   Coding: 00046997
   Shop #: WSC 05124
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__004 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P7B59LB
   Coding: 0012340
   VCID: 448C3B7F07B5926440-8010
   Subsystem 1 - Serial number: 6332MTS654140799
   Subsystem 2 - Serial number: 6342MTS629770809
   Subsystem 3 - Serial number: 6351HTS6VE2216KJ
   Subsystem 4 - Serial number: 6361HTS6JKD8U8KR
Address 16: Steering wheel        Labels: 3C0-953-549-SW25.lbl
   Part No SW: 3C0 953 549 BA    HW: 3C0 953 549 BA
   Component: J0527               0030
   Revision: 00034000    Serial number: 3C9953507CL
   Coding: 0000014
   Shop #: WSC 05314 000 00000
   VCID: 6CDCB3DF4FA5BA24E8-8038
   Part No SW: 3C0 920 971 R    HW: 3C0 920 971 R
   Component: KOMBI         H05 0110
   Coding: 460F00
   Shop #: WSC 05314 115 00000
   VCID: 346C6BBF9F1522E4F0-8060
Address 19: CAN Gateway        Labels:. 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 M    HW: 3C0 907 951
   Component: J533__Gateway   H14 0158
   Revision:   H14       Serial number: 0721G094170068
   Coding: F9801F06000203042003
   VCID: 2B5E70C38A2B7D1CA1-807E
   Part No SW: 3C0 959 433 AQ    HW: 3C0 959 433 AQ
   Component:    IMMO         044 0383
   Revision: 00044000    Serial number: VWZCZ000000000
   VCID: 79F29A8B30F71F8C63-802C
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
   Part No SW: 1K0 959 701 AC    HW: 1K0 959 793 N
   Component: J386  TUER-SG FT    1518
   Revision: 72009005    Serial number: 00000763398325
   Coding: 0000565
   Part No: 1K0 909 144 F
   Component: EPS_ZFLS Kl. 195    2701
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2D5A7EDBB43F732CBF-8078
   Component:    KSG PQ46 ELV 044 0612
   Coding: 0091020851030E763004941570085BCE103C01
   Subsystem 1 - Part No: 1K8 951 605
   Component: LIN BACKUP HORN H09 9002
01134 - Alarm Horn (H12)
            000 -  -
                    Reset counter: 131
                    Mileage: 257700 km
                    Date: 2013.02.24
                    Time: 14:33:19
Address 4F: Centr. Electr. II (J533_)       Labels:. 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Revision: --------    Serial number: 0721G006809417
   Coding: 00000000
   VCID: 66C8C1F791498074BE-8032
   Part No SW: 1K0 959 702 AC    HW: 1K0 959 792 N
   Component: J387  TUER-SG BT    1518
   Revision: 72009005    Serial number: 00000767498226
   Coding: 0000564
   VCID: 70E4A7AF638D5EC4D4-8024
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 B
   Component: J540 EPB3  VW-10498 0003
   Revision:   010       Serial number: 00000000059832
   Coding: 0000056
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3I4241903
   Coding: 0500040004
   VCID: 65CAC6FB6C4F8B6CB7-8030
   Part No SW: 1K0 907 534     HW: 3C0 907 951
   Component: Batt.regelung H14 0158
   Coding: 0301085A
   VCID: 68D4CFCF9B5D96048C-803C
   Subsystem 1 - Part No SW: 1K0 915 181 B    HW: 1K0 915 181 A
   Component: J367-BDM  H07 0121
   Serial number: 00000000002786405833
End-------------------------(Elapsed Time: 01:56)--------------------------
