- Joined
- Jan 29, 2014
- Messages
- 21,923
- Reaction score
- 9,309
- Location
- Montgomery, NY, USA
- VCDS Serial number
- C?ID=57337
YUp......................
You have to save images onto an image hosting website and link to there, posting a link to your local hard drive won't work/Users/frankmiscione/Desktop/Image.jpg
Got the WD and Engine repair and 5 other manuals
ZNOSTREET, might try disconnect n205, then see if voltage out of j220 back probing pin t60/20' I.E. pin 20 of the 60 pin bundle. Is it the same as what is at n205, IF so this is what j220 is sending. Not being as savvy as many here this validates WIRING to n205 is not corrupted,
I noted voltage at n205 is not system voltage, again above my pay grade as if it is a square wave it might not be. IF it is a variable position adjuster then I might assume it is not system voltage. IF merely one way or the other then maybe.
If voltage is not same then can as JACK likes to say, bifuricate, meaning pull another wire there
To simpletons like I, best of luck.
LARIMORE
