- Joined
- Mar 30, 2014
- Messages
- 226
- Reaction score
- 11
- Location
- Brighton, MI
- VCDS Serial number
- C?ID=102239
Still fighting code
17748 - Camshaft Position Sensor (G40) / Engine Speed Sensor (G28) P1340 - 35-00 - Incor. Correlation
after engine build.
2001 Audi TT225
AMU block. New bearings, rods, rings, seals, oil pump.
Rebuild AEB head.
New VVT cam chain tensioner (not connected).
AMU valve cover (has vent, vs AEB no vent).
Existing Single Mass Flywheel (CM/Ringer Racing) and clutch.
New timing kit.
Existing Wideband O2 conversion to newer Golf ECU 8N0 906 018 K.
Replaced AEB cam timing plate (one window) to 4 window plate from AMU head.
Replaced AEB cam sprocket with AMU sprocket.
Done sofar:
- switched cam sensor 2 times
- test unplug cam sensor shows code
- test unplug crank sensor with engine running shut engine down (I am normally expect engine to run (off the cam sensor in limp mode) until shut off, but won't restart). Indicates to me that ECU cannot use or is not using cam sensor at all).
- verified timing. Cylinder (passenger side) physically at TDC, crank pulley TDC mark lines up. Cam sprocket mark lines up with valve cover mark. Camshaft 'squares' line up the cam holder bracket triangles.
- cam chain tensioner chain link count "15.5" see photo
- tried to find TDC mark on flywheel cut did NOT find (current waiting for Ringer Racing to inform if their Clutchmaster single mass flywheel have a TDC mark and how it looks like)
after engine build.
2001 Audi TT225
Rebuild AEB head.
New timing kit.
Done sofar:
