06 Audi Allroad 4F 3.0 TDI Control Module for Elect. Park/Hand Brake
sheim
Oppdal, Norway
C?ID=326660
Hi, I have an Audi Allroad 3.0.TDI 4F 2006 mod, VIN: WAUZZZ4F87N044306 and I have problem with the Electronical Park Brake. I got a fault code on left park brake motor so I changed that. When changed I got a fault code for the ABS control module. ABS I working but the park brake is not working properly. When I test it with the test function in VCDS it working, but after short time it`s faulty again.
I probably need to change the control module, but where is the control module located? I will be happy for any advice in this issue. :)
Address 03: ABS Brakes Labels: 4F0-910-517.lbl
Part No SW: 4F0 910 517 AB HW: 4F0 614 517 R
Component: ESP 8.0 quattro H05 0040
Coding: 0000392
Shop #: WSC 02325 785 00200
VCID: 649151F062521417F60-8030
