MK5 Jetta LED tail lights
C?ID=313143
I've read a LOT of conflicting info regarding the correct coding for OEM functionality of the factory LED tails. I don't know when the Amber is supposed to come on or not. Does someone have the proper coding for FACTORY functionality?
I have a 07 Wolfsburg Jetta with a Highline 30 bit CECM, CH steering module, and a MK6 Steering wheel.
C?ID=313143
No one knows? Maybe can someone in Europe with a mkv Jetta post an auto scan?
Mika_M
C?ID=183725
Found a scan from my old car, don't know if this is any help? European MY07 Jetta.
Friday,07,March,2014,10:13:56:18691
VCDS Version: 12.12.0.0
Data version: 20130910
VIN: WVWZZZ1KZ7M118426   License Plate:
Mileage: 98520km-61217mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ7M118426   Mileage: 98520km/61217miles
Address 01: Engine        Labels: 03C-906-032-BLG.lbl
   Part No SW: 03C 906 032 D    HW: 03C 906 032
   Component: MED17.5.1       G   6454
   Revision: 69H07---    Serial number: VWZ7Z0G9010181
   Coding: 0000075
   Shop #: WSC 00230 205 80175
   VCID: 1E3301BAC9FED6EE86F-804B
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 044 A    HW: 02E 927 770 AE
   Component: GSG DSG         070 1302
   Revision: 00007000    Serial number: 00000611291291
   VCID: 1325608E323C8B86391-8046
Address 03: ABS Brakes        Labels: 1K0-614-517-MK60-F.lbl
   Part No SW: 1K0 614 517 AC    HW: 1K0 614 517 AC
   Component: ESP FRONT MK60-AT   0102
   Revision: 00H14001
   Coding: 0021122
   VCID: 68DF67625B3AD85E3C3-803D
   Part No SW: 1K0 907 044 BJ    HW: 1K0 907 044 BJ
   Component: ClimatronicPQ35 090 0909
   Revision: 00090016    Serial number: 00000000000000
   VCID: 70EF0F0263EA109E643-8025
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 AE    HW: 3C0 937 049 AE
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000000518344
   Coding: 09078E2700141E00430A00000F00000000085D035C4000
   VCID: 6CD71B724FC2F47E58B-8039
   Component: Wischer 180107 020  0501
   Coding: 00040853
                    Fault Status: 00101100
                    Reset counter: 11
                    Mileage: 98452 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.40 V
   Component: 2J AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD0X5AHS
   Coding: 0012874
   VCID: 3D71E6366438ADF6BF5-8068
   Subsystem 1 - Serial number: 6332MSME156C6036A
   Subsystem 2 - Serial number: 6342MSME1511662C6
   Subsystem 3 - Serial number: 6351HSME0C1F705FM
   Subsystem 4 - Serial number: 6361HSME0C201604-
   Part No SW: 1K0 953 549 AP    HW: 1K0 953 549 AP
   Component: Lenksäulenmodul 636 0070
   Coding: 0010041
   Shop #: WSC 26500 205 69651
   VCID: 800FDFC2D34A801E143-80D5
   Part No SW: 1K0 920 863 A    HW: 1K0 920 863 A
   Component: KOMBIINSTRUMENT 3HL 1610
   Revision: V0003000    Serial number: VWZ7Z0G9010181
   Coding: 0023103
   Shop #: WSC 26506 205 18334
   VCID: 2959226680B02156E3D-807C
Address 19: CAN Gateway        Labels: 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0020
   Revision:   H04 02    Serial number: 131206F1001451
   Coding: 3F3F034007001002
   VCID: 2F6DCC7EBE544F663D9-807A
                    Reset counter: 14
                    Mileage: 97482 km
                    Time: 18:26:55
   Component: IMMO            3HL 1610
   Component: J386  TUER-SG FT    1133
   Revision: 32008001    Serial number: 00000543478108
   Coding: 0000180
   VCID: 3B75E82E7A2CA3C6811-806E
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   VCID: 3467C31257726CBE40B-8061
   Component:    KSG PQ35 G2  020 0203
   Coding: 88900A000106087F2D04040FE0084F03E0F8A0
   Shop #: WSC 00066 123 12345
   VCID: 8305D0CEC25C9B06091-80D6
   Part No SW: 1K0 959 702 P    HW: 1K0 959 792 L
   Component: J387  TUER-SG BT    1133
   Revision: 32008001    Serial number: 00000018169222
   Coding: 0000180
   VCID: 3C77EB327F22A4FE88B-8069
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0045
   Revision: 00034000    Serial number: VWZ1Z2F1706255
   Coding: 0040400
   VCID: 377DF41E460487A6659-8062
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000001056961
   Coding: 0000144
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000001042115
   Coding: 0000144
   VCID: 3E73E13A693EB6EEA6F-806B
C?ID=313143
Did you have Factory LED tail lights?
Mika_M
C?ID=183725
Yes I think so. I believe it was standard in here, all had them.
