hey Ross Tech
Got a new car for my self. It had a ABS light on, connected my VCDS, it couldnt communicate with the module, bought a new one. Now I need your help with the coding of this thing.
Thank You
Monday,18,December,2017,16:30:46:13779
VCDS Version: 17.8.1.0 (x64)
VIN: WVWEV71K99W133138 License Plate:
Mileage: 162260km-100823mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 0F 15 16 17 19 1C 25 42 44 46 52 55 56 65
VIN: WVWEV71K99W133138 Mileage: 162260km-100823miles
01-Engine -- Status: Sporadic communication error 1000
1C-Position Sensing -- Status: Malfunction 0010
Address 01: Engine (CCT) Labels:. 06J-906-026-CCT.clb
Part No SW: 1K0 907 115 AE HW: 1K0 907 115 AA
Component: 2.0l R4/4V TFSI 0030
Revision: AAH03--- Serial number: VWX7Z0H83NM8SZ
Coding: 0403010A18070160
Shop #: WSC 13363 153 460326
VCID: 69D839E9404C310E26-803C
Readiness: 0110 0101
Address 03: ABS Brakes (-----) Labels:. 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AD HW: 1K0 907 379 AD
Component: ESP MK60EC1 H35 0104
Revision: 00H35001
Shop #: WSC 00066 000 00000
VCID: 74E6589DD78EFCE685-8020
Fault Status: 01100101
Reset counter: 45
Mileage: 162267 km
Count: 3
Count: 2
Count: 12288
Count: 279
Count: 44800
Reset counter: 45
Mileage: 162267 km
Count: 3
Count: 2
Count: 12288
Count: 295
Count: 44800
Reset counter: 45
Mileage: 162267 km
Count: 3
Count: 2
Count: 12288
Count: 270
Count: 44800
Reset counter: 45
Mileage: 162267 km
Count: 7
Count: 2
Count: 12288
Count: 195
Count: 44800
Part No SW: 1K0 820 047 JM HW: 1K0 820 047 JM
Component: Climatic PQ35 142 1212
Revision: 00142032 Serial number: 00000000000000
VCID: 78FE6CAD0BE69886A9-802C
01316 - ABS Control Module
Revision: 00H54000 Serial number: 00000008690090
Coding: 178D8F214004150047140000001400000028770B5C000100000000000000
VCID: 33649B815200BBDE5C-8066
Component: Wischer 230908 021 0501
Coding: 00038805
Shop #: WSC 01357
00906 - Horn (H1)
Fault Status: 00101001
Reset counter: 82
Mileage: 162267 km
Voltage: 11.80 V
Reset counter: 82
Mileage: 162267 km
Voltage: 11.80 V
Revision: 00000000 Serial number: AUZ4Z7H0426248
Coding: 0000100
00532 - Supply Voltage B+
Reset counter: 83
Mileage: 162267 km
Time: 23:03:24
Voltage: 5.90 V
Reset counter: 83
Mileage: 162267 km
Time: 23:02:54
Voltage: 5.90 V
Reset counter: 42
Mileage: 162267 km
Time: 19:18:31
01304 - Radio
Reset counter: 45
Mileage: 162267 km
Time: 00:01:31
Component: 6K AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6D0BZZWH
Coding: 0013899
VCID: 6CD640FD4FBE24265D-8038
Subsystem 1 - Part No: 1K0 959 339 G
Component: BF-Gewichtsens. 007 0007
Subsystem 2 - Serial number: 6332MSME424236574
Subsystem 3 - Serial number: 6342MSME41331122W
Subsystem 4 - Serial number: 6352QSME3E0C411EQ
Subsystem 5 - Serial number: 6362QSME2F08252CO
Subsystem 6 - Serial number: 63727SME186B6D3FN
Subsystem 7 - Serial number: 63827SME19065F1B9
Part No SW: 1K0 953 549 BP HW: 1K0 953 549 BP
Component: J0527 051 0101
Coding: 0002022
VCID: 01080149583CD94E9E-8054
Component: E0221 002 0010
01426 - Controls in Steering Wheel (E221)
Part No SW: 1K6 920 974 H HW: 1K6 920 974 H
Component: KOMBIINSTRUMENT VDD 2416
Revision: V0003000 Serial number: VWX7Z0H83NM8SZ
Coding: 0007203
VCID: 3978A9A9706C418E96-806C
Fault Frequency: 39
Reset counter: 84
Mileage: 162267 km
Time: 19:18:20
Reset counter: 82
Mileage: 162267 km
Time: 19:24:06
Reset counter: 83
Mileage: 162267 km
Time: 22:52:25
Reset counter: 83
Mileage: 162267 km
Time: 22:52:25
Component: J533 Gateway H07 5063
Revision: H07 01 Serial number: 040908F2001904
Coding: E9811F070013020000
VCID: 3560A5995C74A5EE72-8060
Fault Status: 00110100
Reset counter: 82
Mileage: 162267 km
Time: 19:24:07
Reset counter: 84
Mileage: 162267 km
Time: 19:18:21
01304 - Radio
Reset counter: 42
Mileage: 162267 km
Time: 19:18:25
Part No SW: 1K6 919 879 HW: 1K6 919 879
Component: Kompass 001 0003
Revision: 00001000 Serial number: 1225223T477L03
VCID: 7DF07DB924C4BDAEFA-8028
Fault Frequency: 23
Reset counter: 84
Mileage: 162267 km
Time: 19:18:20
Component: IMMO VDD 2416
Shop #: WSC 09449 444 12570
01176 - Key
Mileage: 162267 km
Time: 15:01:45
Component: Tuer-SG 006 1207
Coding: 0001077
VCID: 387EACAD4B66588669-806C
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
01340 - Mirror Adjustment Switch
00109 - Left Mirror Turn Signal Lamp (L131)
Part No: 1K1 909 144 M
Component: EPS_ZFLS Kl.074 H08 1901
00625 - Vehicle Speed Signal
Temperature: -70.0°C
Voltage: 0.00 V
Voltage: 0.00 V
Voltage: 0.00 V
Voltage: 0.00 V
Coding: 139006885103403F2D04058FB0080A04889C00
VCID: 0406085D472ECC66B5-8050
Reset counter: 83
Mileage: 162267 km
Time: 23:03:23
Coding: 0001076
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
Address 55: Headlight Range Labels: 1T0-907-357.lbl
Part No: 1T0 907 357
Component: Dynamische LWR 0003
Coding: 0000003
VCID: 74E6589D178EFCE685-8020
Address 56: Radio
Component: RDK 0450
Coding: 0100101
Fault Status: 00111000
Reset counter: 84
Mileage: 162267 km
Time: 19:36:31
End-------------------------(Elapsed Time: 01:46)--------------------------
Thank You
