VW Polo 6C 1.2 TSI CJZD Cruise Control and Park Assist retrofit
undertaker
Croatia
C?ID=267794
I'm the owner of 2016 VW Polo 6C 1.2 TSI Lounge. Additional equipment are LED lights and board computer.
Couple weeks ago I installed PDC and Cruise Control switch.
Here is auto scan before installation:
Saturday,10,December,2016,11:03:58:11885
VCDS Version: 16.8.3.1
VIN: WVWZZZ6RZGY030654   License Plate: OS985AK
Mileage: 29160km-18119mi   Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 15 17 19 44 55 5F
VIN: WVWZZZ6RZGY030654   Mileage: 29160km-18119miles
Address 01: Engine (J623-CJZD)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 027 BC    HW: 04E 907 309 AF
   Component: R4 1.2l TFS   H22 9023
   Revision: R4H22---
   Coding: 01190012230411080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TFS01104E906027BC 001008
   ROD: EV_ECM12TFS01104E906027BC.rod
   VCID: 66ECEFA99949A07226-8032
   CAN Converter 01:
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08501143150603
   Coding: 21DD4885492633C0091A106E0055841292CC90080005CB098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   VCID: 375272ED8E63E9FA4D-8062
Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
   Part No SW: 6C0 820 045 A    HW: 6C0 820 045 A
   Component: AC Manuell    H03 0108
   Serial number:  1506081B-0542
   Coding: 200000001000100000
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 1D1E80450C9FA3AAB7-8048
Address 09: Cent. Elect. (J519)       Labels: 6C0-937-089-V1.clb
   Part No SW: 6C0 937 089 C    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0084
   Serial number: 001378011606
   Coding: 00000A404253005B4F844000400F07080000580251010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_VW26.rod
   VCID: 304049F16B0D3EC20C-8064
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 AT    HW: 6R0 959 801 AT  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8612
   Serial number: KU0KU009061551602369
   Coding: 0400A0
   Subsystem 2 - Part No SW: 6R0 959 802 BE    HW: 6R0 959 802 BE  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8612
   Serial number: KU0KU008061551591678
   Coding: 1400A0
   Subsystem 3 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8611
   Serial number: KU0KU003061551540716
   Coding: 0400A0
   Subsystem 4 - Part No SW: 6R0 959 812 N    HW: 6R0 959 812 N
   Component: J389__TSG_HR  003 8611
   Serial number: KU0KU002061551531949
   Coding: 1400A0
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 E    HW: 6C0 959 655 E
   Component: VW20Airbag00B 001 0360
   Revision: --------    Serial number: 003RH0023A3M
   Coding: 88C0C000000000005C000000000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 354E78E5946F1BEA5F-8060
   Subsystem 1 - Part No SW: -----------    HW: 410 821 006 15
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00A91ACFD2331B+
   Subsystem 2 - Part No SW: -----------    HW: 410 821 006 15
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00AB1ACFD21E0CA
   Subsystem 3 - Part No SW: -----------    HW: 442 151 406 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00A11A72810327Z
   Subsystem 4 - Part No SW: -----------    HW: 442 151 506 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00A11A7281640D4
   Part No SW: 6C0 920 730 E    HW: 6C0 920 730 E
   Component: KOMBI         101 1420
   Coding: 0724090029000008000808000000000000000000
   VCID: 236AB6BD2AFB955A81-8076
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 089
   Component: GW MQB A0     H08 0084
   Revision: --------    Serial number: 001378011606
   Coding: 030000046F0A560071000000000000010001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 65EEE8A5644FAB6A2F-8030
   Subsystem 1 - Part No SW: 6C0 915 181 A    HW: 6C0 915 181 A
   Component: J367-BDM  H08 0223
   Serial number: 22160B37292821214393
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: PF6I1094
   Coding: 000700
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 6DFE9085BCBF932A67-8038
Address 55: Headlight Range (J431)       Labels: 5Q0-907-357.clb
   Coding: 0D88000001000000
   ROD: EV_HeadlRegulVWLWRMQB_VW26.rod
   VCID: 75CEB8E5D4EF5BEA9F-8020
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-ENT2.clb
   Part No SW: 6C0 035 869 D    HW: 6C0 035 869 D
   Component: MU-E--ER      851 6490
   Serial number: 29051500012458
   Coding: 02620000BE00000041110001000000001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2C785D8147255A2230-8078
End-------------------------(Elapsed Time: 02:13)--------------------------
After installation PDC worked fine except no OPS on the radio. After adjustment of adaptations finally i get this.
But I also get error:
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391502017830
   Coding: 0011051041
   ROD: EV_EPHVA18AU3700000_VW26.rod
   VCID: 3D5E60C5AC5FC3A9C2-8068
12658704 - Databus
                    Reset counter: 27
                    Mileage: 39509 km
                    Date: 2017.05.28
                    Time: 19:03:26
I checked adaptation channels and didn't found something what could cause this error.
Second problem shows after cruise control installation.
It's controled via steering column lever. Car don't have multi functional steering wheel.
Due to missing descriptions of bytes in control modules I compared auto-scans from similar Polos and Škodas posted on this forum.
I figured out that Byte 18 in BCM (09) has something with this. So I thicked bit 0.
In Engine (01) controller it's easy.
Just thick byte 5 bit 5 to Cruise control System (CCS) installed.
After that I get CCS light on instrument panel, but also error message. EPC light also lit on.
Here is auto scan after CCS coding:
Sunday,28,May,2017,19:12:14:11885
VCDS Version: 17.1.3.0
Mileage: 39509km-24549mi   Repair Order:
Scan: 01 03 08 09 10 15 17 19 44 55 5F
VIN: WVWZZZ6RZGY030654   Mileage: 39509km-24549miles
   Revision: R4H22---
   Coding: 01190032232411080000
   VCID: 66ECEFA99949A07173-8032
   CAN Converter 01:
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 39509 km
                    Date: 2017.05.28
                    Time: 19:08:01
                    Coolant temperature: 27 �C
                    Intake air temperature: 28 �C
                    Voltage terminal 30: 12.298 V
                    Mass flow through throttle valve: 0.0 kg/h
Readiness: 0110 0001
   VCID: 375272ED8E63E9F918-8062
   VCID: 1D1E80450C9FA3A9E2-8048
   Part No SW: 6C0 937 089 D    HW: 6C0 937 089
   Component: BCM PQ26 Hi4R H08 0094
   Coding: 00000A404253005B4F844000400F07080000590251010000000000000000
   Shop #: WSC 131071 102 209715
   ASAM Dataset: EV_BCMA0 006002
   ROD: EV_BCMA0_006.rod
   VCID: 31464CF5600737C956-8064
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0011051041
12658704 - Databus
                    Reset counter: 27
                    Mileage: 39509 km
                    Date: 2017.05.28
                    Time: 19:03:26
   VCID: 354E78E5946F1BE90A-8060
   Coding: 0324090029000008000808000000000000000000
   VCID: 236AB6BD2AFB9559D4-8076
   Part No SW: 6C0 909 901 A    HW: 6C0 937 089
   Component: GW MQB A0     H08 0094
   VCID: 266CAFA959C96071B3-8072
   Coding: 000700
   VCID: 6DFE9085BCBF932932-8038
   VCID: 75CEB8E5D4EF5BE9CA-8020
   VCID: 2C785D8147255A2165-8078
End-------------------------(Elapsed Time: 02:19)--------------------------
I have checked measuring values and lever is wired correctly. It gets voltage and all commands are functional. During driving CCS is not working.
I believe that I have problem with some addaptation.
Any suggestions?
m87a
Bosnia and Herzegovina
C?ID=156900
you also need to code ABS for CCS, still will it work I don't know, on MQB it needs SWAP activation
undertaker
Croatia
C?ID=267794
I checked coding of ABS today. There are no descriptions of bits, except for Hill holder.
I tried to change some bytes from my comparation chart from another car with CCS.
I only gets error 31. Code out of request.
So, I will go to dealer for an activation. I have activation document anyway.
After that I will post new auto-scan.
undertaker
Croatia
C?ID=267794
So, I visit VW shop last Friday. CCS is enabled finally. Running perfectly.
Here is Autoscan after coding:
Monday,07,August,2017,18:04:43:11885
VIN: WVWZZZ6RZGY030654   Mileage: 42333km-26304miles
   Revision: R4H22---
   Coding: 01190012232411080000
   Shop #: WSC 40361 001 1048576
   CAN Converter 01:
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0400A0
   Coding: 1400A0
   Coding: 0030051041
12658704 - Databus
                    Reset counter: 147
                    Mileage: 42224 km
                    Date: 2017.08.04
                    Time: 09:34:14
   Coding: 0724090029000008010808000000000000000000
   Coding: 000700
End-------------------------(Elapsed Time: 02:23)--------------------------
So, I go quickly through autoscan and I notice next coding changes
Adress 01
old
new
Adress 09
old
new
Adress 17
old
new
So, I'm aware now that I never change coding of instrument cluster. There is answer why CCS didn't work with my coding, maybe?
I have noticed that they did some changes in Adress 19 (WSC number is different), but guy from the shop asked me how did I connect wirings after job was done. They were trying to code through Gateway and on second attempt they code it right. So, maybe this is the reason for new WSC.
DV52
C?ID=194404
Adress 17
old
new
Undertaker: Very interesting - thanks for the detail. Two questions-please:
First: regarding address hex17: what does the descriptor in "yellow" long coding helper screen say about Byte 8, Bit 0?
Second: did you manage to take an admap of the BCM before and after the trip to the dealer? If so, I'd love to get hold of both and compare the settings in the adaptation channels
undertaker
Croatia
C?ID=267794
Here is admap with settings before coding, with my coding attempt and after dealer coding.
;SW:6C0-937-089-D   HW:6C0-937-089 ---  Cent. Elect.
;Component:BCM PQ26 Hi4R H08 0094	Coding:00000A404253005B4F844000400F07480000580251010000000000000000
;EV_BCMA0	6002	EV_BCMA0_006.rod
;Sunday	21	May	2017	16:11:51:11885
;VCDS Version: Release 17.1.3  Data version: 20170320 DS267.7
;VCID: 31464CF5600737C956-8064
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG130235-Production mode-Entry_control	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1	not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition	keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	not activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	800 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	800 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart	kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	active
IDE02152-Characteristics in production mode	2000 ms
IDE02200-Component protection showroom mode	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl	not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl	not active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on	not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80,00%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80,00%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80,00%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.50 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	180 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	120 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken	active
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger	separate
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken	not active
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen	5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker	SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2	not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung	not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung	Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor	0.100 %
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert	3.0 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht	active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren	not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	255 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	Not Present
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	ignition
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	0.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	not enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert	not active
IDE04926-ENG126570-Comfort illumination-lho_zeit	0 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	0 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	not active
IDE04927-IDE01446-Window heater-Running time of heated front window	6 s (second)
IDE04927-ENG11110-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung	170 °C
IDE04927-ENG11109-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung	170 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung	0 s (second)
IDE04927-ENG11108-Window heater-Heckscheibenheizung_Zeitwert	15 s (second)
IDE04927-ENG11107-Window heater-Temperaturabhaengige_Einschaltzeit_FSH	active
IDE04927-ENG11106-Window heater-Temperaturabhaengige_Einschaltzeit_HSH	active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	immidiat_driver_door_contact_thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	not active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0	34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1	3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10	0
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11	0
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12	38
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13	42
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14	0
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15	0
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16	0
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17	0
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18	8
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19	18
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2	0
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20	9
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21	19
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22	29
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23	0A
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24	1A
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25	28
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26	2A
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27	0
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28	2B
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29	0
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3	0
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30	0
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31	0
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32	0
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33	0
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34	0
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4	48
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5	4C
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6	36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7	40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8	37
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9	41
IDE05145-ENG115018-Light configuration-Dimming_AB_0	100
IDE05145-ENG115037-Light configuration-Dimming_AB_1	100
IDE05145-ENG114999-Light configuration-Dimming_AB_10	0
IDE05145-ENG115193-Light configuration-Dimming_AB_11	100
IDE05145-ENG115212-Light configuration-Dimming_AB_12	100
IDE05145-ENG114958-Light configuration-Dimming_AB_13	100
IDE05145-ENG115233-Light configuration-Dimming_AB_14	100
IDE05145-ENG115252-Light configuration-Dimming_AB_15	100
IDE05145-ENG115271-Light configuration-Dimming_AB_16	100
IDE05145-ENG115290-Light configuration-Dimming_AB_17	100
IDE05145-ENG115309-Light configuration-Dimming_AB_18	100
IDE05145-ENG115328-Light configuration-Dimming_AB_19	100
IDE05145-ENG115056-Light configuration-Dimming_AB_2	70
IDE05145-ENG115347-Light configuration-Dimming_AB_20	100
IDE05145-ENG115366-Light configuration-Dimming_AB_21	100
IDE05145-ENG115385-Light configuration-Dimming_AB_22	100
IDE05145-ENG115404-Light configuration-Dimming_AB_23	60
IDE05145-ENG115423-Light configuration-Dimming_AB_24	60
IDE05145-ENG115442-Light configuration-Dimming_AB_25	100
IDE05145-ENG115461-Light configuration-Dimming_AB_26	100
IDE05145-ENG115480-Light configuration-Dimming_AB_27	100
IDE05145-ENG115499-Light configuration-Dimming_AB_28	100
IDE05145-ENG115518-Light configuration-Dimming_AB_29	100
IDE05145-ENG115075-Light configuration-Dimming_AB_3	70
IDE05145-ENG115537-Light configuration-Dimming_AB_30	126
IDE05145-ENG115556-Light configuration-Dimming_AB_31	0
IDE05145-ENG115575-Light configuration-Dimming_AB_32	0
IDE05145-ENG115594-Light configuration-Dimming_AB_33	0
IDE05145-ENG115613-Light configuration-Dimming_AB_34	0
IDE05145-ENG115094-Light configuration-Dimming_AB_4	127
IDE05145-ENG114977-Light configuration-Dimming_AB_5	127
IDE05145-ENG115115-Light configuration-Dimming_AB_6	127
IDE05145-ENG115134-Light configuration-Dimming_AB_7	127
IDE05145-ENG115153-Light configuration-Dimming_AB_8	127
IDE05145-ENG115172-Light configuration-Dimming_AB_9	127
IDE05145-ENG115022-Light configuration-Dimming_CD_0	0
IDE05145-ENG115041-Light configuration-Dimming_CD_1	0
IDE05145-ENG115003-Light configuration-Dimming_CD_10	0
IDE05145-ENG115197-Light configuration-Dimming_CD_11	0
IDE05145-ENG115216-Light configuration-Dimming_CD_12	0
IDE05145-ENG114962-Light configuration-Dimming_CD_13	0
IDE05145-ENG115237-Light configuration-Dimming_CD_14	0
IDE05145-ENG115256-Light configuration-Dimming_CD_15	0
IDE05145-ENG115275-Light configuration-Dimming_CD_16	0
IDE05145-ENG115294-Light configuration-Dimming_CD_17	0
IDE05145-ENG115313-Light configuration-Dimming_CD_18	0
IDE05145-ENG115332-Light configuration-Dimming_CD_19	0
IDE05145-ENG115060-Light configuration-Dimming_CD_2	30
IDE05145-ENG115351-Light configuration-Dimming_CD_20	0
IDE05145-ENG115370-Light configuration-Dimming_CD_21	0
IDE05145-ENG115389-Light configuration-Dimming_CD_22	0
IDE05145-ENG115408-Light configuration-Dimming_CD_23	0
IDE05145-ENG115427-Light configuration-Dimming_CD_24	0
IDE05145-ENG115446-Light configuration-Dimming_CD_25	0
IDE05145-ENG115465-Light configuration-Dimming_CD_26	0
IDE05145-ENG115484-Light configuration-Dimming_CD_27	0
IDE05145-ENG115503-Light configuration-Dimming_CD_28	0
IDE05145-ENG115522-Light configuration-Dimming_CD_29	0
IDE05145-ENG115079-Light configuration-Dimming_CD_3	30
IDE05145-ENG115541-Light configuration-Dimming_CD_30	0
IDE05145-ENG115560-Light configuration-Dimming_CD_31	0
IDE05145-ENG115579-Light configuration-Dimming_CD_32	0
IDE05145-ENG115598-Light configuration-Dimming_CD_33	0
IDE05145-ENG115617-Light configuration-Dimming_CD_34	0
IDE05145-ENG115098-Light configuration-Dimming_CD_4	127
IDE05145-ENG114981-Light configuration-Dimming_CD_5	127
IDE05145-ENG115119-Light configuration-Dimming_CD_6	0
IDE05145-ENG115138-Light configuration-Dimming_CD_7	0
IDE05145-ENG115157-Light configuration-Dimming_CD_8	0
IDE05145-ENG115176-Light configuration-Dimming_CD_9	0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0	maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1	maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10	maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11	maximize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12	maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13	maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14	maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15	maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16	maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17	maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18	maximize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19	maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2	maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20	maximize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21	maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22	maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23	maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24	maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25	maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26	maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27	maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28	maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29	maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3	maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30	maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31	maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32	maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33	maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34	maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4	maximize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5	maximize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6	maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7	maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8	maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9	maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0	maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1	maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10	maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11	maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12	maximize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13	maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14	maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15	maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16	maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17	maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18	maximize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19	maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2	minimize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20	maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21	maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22	maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23	maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24	maximize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25	maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26	maximize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27	maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28	maximize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29	maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3	minimize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30	maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31	maximize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32	maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33	maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34	maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4	maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5	maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6	maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7	maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8	maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9	maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0	maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1	maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10	maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11	maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12	maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13	maximize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14	maximize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15	maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16	maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17	maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18	maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19	maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2	maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20	maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21	maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22	maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23	maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24	maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25	maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26	maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27	maximize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28	maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29	maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3	maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30	maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31	maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32	maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33	maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34	maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4	maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5	maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6	maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7	maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8	maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9	maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0	0
IDE05145-ENG115045-Light configuration-Dimming_EF_1	0
IDE05145-ENG115007-Light configuration-Dimming_EF_10	0
IDE05145-ENG115201-Light configuration-Dimming_EF_11	0
IDE05145-ENG115220-Light configuration-Dimming_EF_12	0
IDE05145-ENG114966-Light configuration-Dimming_EF_13	0
IDE05145-ENG115241-Light configuration-Dimming_EF_14	0
IDE05145-ENG115260-Light configuration-Dimming_EF_15	0
IDE05145-ENG115279-Light configuration-Dimming_EF_16	0
IDE05145-ENG115298-Light configuration-Dimming_EF_17	0
IDE05145-ENG115317-Light configuration-Dimming_EF_18	0
IDE05145-ENG115336-Light configuration-Dimming_EF_19	0
IDE05145-ENG115064-Light configuration-Dimming_EF_2	30
IDE05145-ENG115355-Light configuration-Dimming_EF_20	0
IDE05145-ENG115374-Light configuration-Dimming_EF_21	0
IDE05145-ENG115393-Light configuration-Dimming_EF_22	0
IDE05145-ENG115412-Light configuration-Dimming_EF_23	0
IDE05145-ENG115431-Light configuration-Dimming_EF_24	0
IDE05145-ENG115450-Light configuration-Dimming_EF_25	0
IDE05145-ENG115469-Light configuration-Dimming_EF_26	0
IDE05145-ENG115488-Light configuration-Dimming_EF_27	0
IDE05145-ENG115507-Light configuration-Dimming_EF_28	0
IDE05145-ENG115526-Light configuration-Dimming_EF_29	0
IDE05145-ENG115083-Light configuration-Dimming_EF_3	30
IDE05145-ENG115545-Light configuration-Dimming_EF_30	0
IDE05145-ENG115564-Light configuration-Dimming_EF_31	0
IDE05145-ENG115583-Light configuration-Dimming_EF_32	0
IDE05145-ENG115602-Light configuration-Dimming_EF_33	0
IDE05145-ENG115621-Light configuration-Dimming_EF_34	0
IDE05145-ENG115102-Light configuration-Dimming_EF_4	0
IDE05145-ENG114985-Light configuration-Dimming_EF_5	0
IDE05145-ENG115123-Light configuration-Dimming_EF_6	0
IDE05145-ENG115142-Light configuration-Dimming_EF_7	0
IDE05145-ENG115161-Light configuration-Dimming_EF_8	0
IDE05145-ENG115180-Light configuration-Dimming_EF_9	0
IDE05145-ENG115030-Light configuration-Dimming_GH_0	0
IDE05145-ENG115049-Light configuration-Dimming_GH_1	0
IDE05145-ENG115011-Light configuration-Dimming_GH_10	0
IDE05145-ENG115205-Light configuration-Dimming_GH_11	0
IDE05145-ENG115224-Light configuration-Dimming_GH_12	0
IDE05145-ENG114970-Light configuration-Dimming_GH_13	0
IDE05145-ENG115245-Light configuration-Dimming_GH_14	0
IDE05145-ENG115264-Light configuration-Dimming_GH_15	0
IDE05145-ENG115283-Light configuration-Dimming_GH_16	0
IDE05145-ENG115302-Light configuration-Dimming_GH_17	0
IDE05145-ENG115321-Light configuration-Dimming_GH_18	0
IDE05145-ENG115340-Light configuration-Dimming_GH_19	0
IDE05145-ENG115068-Light configuration-Dimming_GH_2	0
IDE05145-ENG115359-Light configuration-Dimming_GH_20	0
IDE05145-ENG115378-Light configuration-Dimming_GH_21	0
IDE05145-ENG115397-Light configuration-Dimming_GH_22	0
IDE05145-ENG115416-Light configuration-Dimming_GH_23	0
IDE05145-ENG115435-Light configuration-Dimming_GH_24	0
IDE05145-ENG115454-Light configuration-Dimming_GH_25	0
IDE05145-ENG115473-Light configuration-Dimming_GH_26	0
IDE05145-ENG115492-Light configuration-Dimming_GH_27	0
IDE05145-ENG115511-Light configuration-Dimming_GH_28	0
IDE05145-ENG115530-Light configuration-Dimming_GH_29	0
IDE05145-ENG115087-Light configuration-Dimming_GH_3	0
IDE05145-ENG115549-Light configuration-Dimming_GH_30	0
IDE05145-ENG115568-Light configuration-Dimming_GH_31	0
IDE05145-ENG115587-Light configuration-Dimming_GH_32	0
IDE05145-ENG115606-Light configuration-Dimming_GH_33	0
IDE05145-ENG115625-Light configuration-Dimming_GH_34	0
IDE05145-ENG115106-Light configuration-Dimming_GH_4	0
IDE05145-ENG114989-Light configuration-Dimming_GH_5	0
IDE05145-ENG115127-Light configuration-Dimming_GH_6	0
IDE05145-ENG115146-Light configuration-Dimming_GH_7	0
IDE05145-ENG115165-Light configuration-Dimming_GH_8	0
IDE05145-ENG115184-Light configuration-Dimming_GH_9	0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0	14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1	15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10	0
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11	0
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12	22
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13	23
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14	0
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15	0
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16	0
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17	0
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18	16
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19	18
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2	0
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20	2B
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21	2D
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22	2C
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23	29
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24	2A
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25	30
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26	33
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27	8
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28	34
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29	1
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3	0
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30	7
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31	0
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32	0
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33	0
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34	0
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4	49
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5	4B
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6	1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7	1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8	1C
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9	1D
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0	Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1	Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10	Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11	Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12	Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13	Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14	Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15	Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16	Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17	Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18	Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19	Always
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2	Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20	Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21	Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22	Always
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23	Always
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24	Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25	Always
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26	Always
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27	Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28	Always
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29	Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3	Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30	Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31	Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32	Always
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33	Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34	Always
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4	Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5	Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6	Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7	Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8	Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9	Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0	2
IDE05145-ENG115035-Light configuration-Light_Function_A_1	4
IDE05145-ENG114997-Light configuration-Light_Function_A_10	0
IDE05145-ENG115191-Light configuration-Light_Function_A_11	62
IDE05145-ENG115210-Light configuration-Light_Function_A_12	18
IDE05145-ENG114956-Light configuration-Light_Function_A_13	19
IDE05145-ENG115231-Light configuration-Light_Function_A_14	63
IDE05145-ENG115250-Light configuration-Light_Function_A_15	64
IDE05145-ENG115269-Light configuration-Light_Function_A_16	2
IDE05145-ENG115288-Light configuration-Light_Function_A_17	4
IDE05145-ENG115307-Light configuration-Light_Function_A_18	2
IDE05145-ENG115326-Light configuration-Light_Function_A_19	4
IDE05145-ENG115054-Light configuration-Light_Function_A_2	20
IDE05145-ENG115345-Light configuration-Light_Function_A_20	24
IDE05145-ENG115364-Light configuration-Light_Function_A_21	24
IDE05145-ENG115383-Light configuration-Light_Function_A_22	24
IDE05145-ENG115402-Light configuration-Light_Function_A_23	8
IDE05145-ENG115421-Light configuration-Light_Function_A_24	8
IDE05145-ENG115440-Light configuration-Light_Function_A_25	8
IDE05145-ENG115459-Light configuration-Light_Function_A_26	27
IDE05145-ENG115478-Light configuration-Light_Function_A_27	38
IDE05145-ENG115497-Light configuration-Light_Function_A_28	25
IDE05145-ENG115516-Light configuration-Light_Function_A_29	37
IDE05145-ENG115073-Light configuration-Light_Function_A_3	20
IDE05145-ENG115535-Light configuration-Light_Function_A_30	41
IDE05145-ENG115554-Light configuration-Light_Function_A_31	0
IDE05145-ENG115573-Light configuration-Light_Function_A_32	0
IDE05145-ENG115592-Light configuration-Light_Function_A_33	0
IDE05145-ENG115611-Light configuration-Light_Function_A_34	0
IDE05145-ENG115092-Light configuration-Light_Function_A_4	20
IDE05145-ENG114975-Light configuration-Light_Function_A_5	20
IDE05145-ENG115113-Light configuration-Light_Function_A_6	11
IDE05145-ENG115132-Light configuration-Light_Function_A_7	12
IDE05145-ENG115151-Light configuration-Light_Function_A_8	13
IDE05145-ENG115170-Light configuration-Light_Function_A_9	14
IDE05145-ENG115017-Light configuration-Light_Function_B_0	0
IDE05145-ENG115036-Light configuration-Light_Function_B_1	0
IDE05145-ENG114998-Light configuration-Light_Function_B_10	0
IDE05145-ENG115192-Light configuration-Light_Function_B_11	0
IDE05145-ENG115211-Light configuration-Light_Function_B_12	22
IDE05145-ENG114957-Light configuration-Light_Function_B_13	23
IDE05145-ENG115232-Light configuration-Light_Function_B_14	0
IDE05145-ENG115251-Light configuration-Light_Function_B_15	0
IDE05145-ENG115270-Light configuration-Light_Function_B_16	0
IDE05145-ENG115289-Light configuration-Light_Function_B_17	0
IDE05145-ENG115308-Light configuration-Light_Function_B_18	0
IDE05145-ENG115327-Light configuration-Light_Function_B_19	0
IDE05145-ENG115055-Light configuration-Light_Function_B_2	0
IDE05145-ENG115346-Light configuration-Light_Function_B_20	0
IDE05145-ENG115365-Light configuration-Light_Function_B_21	0
IDE05145-ENG115384-Light configuration-Light_Function_B_22	0
IDE05145-ENG115403-Light configuration-Light_Function_B_23	9
IDE05145-ENG115422-Light configuration-Light_Function_B_24	10
IDE05145-ENG115441-Light configuration-Light_Function_B_25	0
IDE05145-ENG115460-Light configuration-Light_Function_B_26	0
IDE05145-ENG115479-Light configuration-Light_Function_B_27	0
IDE05145-ENG115498-Light configuration-Light_Function_B_28	0
IDE05145-ENG115517-Light configuration-Light_Function_B_29	0
IDE05145-ENG115074-Light configuration-Light_Function_B_3	0
IDE05145-ENG115536-Light configuration-Light_Function_B_30	0
IDE05145-ENG115555-Light configuration-Light_Function_B_31	0
IDE05145-ENG115574-Light configuration-Light_Function_B_32	0
IDE05145-ENG115593-Light configuration-Light_Function_B_33	0
IDE05145-ENG115612-Light configuration-Light_Function_B_34	0
IDE05145-ENG115093-Light configuration-Light_Function_B_4	8
IDE05145-ENG114976-Light configuration-Light_Function_B_5	8
IDE05145-ENG115114-Light configuration-Light_Function_B_6	30
IDE05145-ENG115133-Light configuration-Light_Function_B_7	30
IDE05145-ENG115152-Light configuration-Light_Function_B_8	15
IDE05145-ENG115171-Light configuration-Light_Function_B_9	15
IDE05145-ENG115020-Light configuration-Light_Function_C_0	0
IDE05145-ENG115039-Light configuration-Light_Function_C_1	0
IDE05145-ENG115001-Light configuration-Light_Function_C_10	0
IDE05145-ENG115195-Light configuration-Light_Function_C_11	0
IDE05145-ENG115214-Light configuration-Light_Function_C_12	0
IDE05145-ENG114960-Light configuration-Light_Function_C_13	0
IDE05145-ENG115235-Light configuration-Light_Function_C_14	0
IDE05145-ENG115254-Light configuration-Light_Function_C_15	0
IDE05145-ENG115273-Light configuration-Light_Function_C_16	0
IDE05145-ENG115292-Light configuration-Light_Function_C_17	0
IDE05145-ENG115311-Light configuration-Light_Function_C_18	0
IDE05145-ENG115330-Light configuration-Light_Function_C_19	0
IDE05145-ENG115058-Light configuration-Light_Function_C_2	8
IDE05145-ENG115349-Light configuration-Light_Function_C_20	0
IDE05145-ENG115368-Light configuration-Light_Function_C_21	0
IDE05145-ENG115387-Light configuration-Light_Function_C_22	0
IDE05145-ENG115406-Light configuration-Light_Function_C_23	0
IDE05145-ENG115425-Light configuration-Light_Function_C_24	0
IDE05145-ENG115444-Light configuration-Light_Function_C_25	0
IDE05145-ENG115463-Light configuration-Light_Function_C_26	0
IDE05145-ENG115482-Light configuration-Light_Function_C_27	0
IDE05145-ENG115501-Light configuration-Light_Function_C_28	0
IDE05145-ENG115519-Light configuration-Light_Function_C_29	0
IDE05145-ENG115077-Light configuration-Light_Function_C_3	8
IDE05145-ENG115539-Light configuration-Light_Function_C_30	0
IDE05145-ENG115558-Light configuration-Light_Function_C_31	0
IDE05145-ENG115577-Light configuration-Light_Function_C_32	0
IDE05145-ENG115596-Light configuration-Light_Function_C_33	0
IDE05145-ENG115615-Light configuration-Light_Function_C_34	0
IDE05145-ENG115096-Light configuration-Light_Function_C_4	9
IDE05145-ENG114979-Light configuration-Light_Function_C_5	10
IDE05145-ENG115117-Light configuration-Light_Function_C_6	0
IDE05145-ENG115136-Light configuration-Light_Function_C_7	0
IDE05145-ENG115155-Light configuration-Light_Function_C_8	0
IDE05145-ENG115174-Light configuration-Light_Function_C_9	0
IDE05145-ENG115021-Light configuration-Light_Function_D_0	0
IDE05145-ENG115040-Light configuration-Light_Function_D_1	0
IDE05145-ENG115002-Light configuration-Light_Function_D_10	0
IDE05145-ENG115196-Light configuration-Light_Function_D_11	0
IDE05145-ENG115215-Light configuration-Light_Function_D_12	0
IDE05145-ENG114961-Light configuration-Light_Function_D_13	0
IDE05145-ENG115236-Light configuration-Light_Function_D_14	0
IDE05145-ENG115255-Light configuration-Light_Function_D_15	0
IDE05145-ENG115274-Light configuration-Light_Function_D_16	0
IDE05145-ENG115293-Light configuration-Light_Function_D_17	0
IDE05145-ENG115312-Light configuration-Light_Function_D_18	0
IDE05145-ENG115331-Light configuration-Light_Function_D_19	0
IDE05145-ENG115059-Light configuration-Light_Function_D_2	9
IDE05145-ENG115350-Light configuration-Light_Function_D_20	0
IDE05145-ENG115369-Light configuration-Light_Function_D_21	0
IDE05145-ENG115388-Light configuration-Light_Function_D_22	0
IDE05145-ENG115407-Light configuration-Light_Function_D_23	0
IDE05145-ENG115426-Light configuration-Light_Function_D_24	0
IDE05145-ENG115445-Light configuration-Light_Function_D_25	0
IDE05145-ENG115464-Light configuration-Light_Function_D_26	0
IDE05145-ENG115483-Light configuration-Light_Function_D_27	0
IDE05145-ENG115502-Light configuration-Light_Function_D_28	0
IDE05145-ENG115521-Light configuration-Light_Function_D_29	0
IDE05145-ENG115078-Light configuration-Light_Function_D_3	10
IDE05145-ENG115540-Light configuration-Light_Function_D_30	0
IDE05145-ENG115559-Light configuration-Light_Function_D_31	0
IDE05145-ENG115578-Light configuration-Light_Function_D_32	0
IDE05145-ENG115597-Light configuration-Light_Function_D_33	0
IDE05145-ENG115616-Light configuration-Light_Function_D_34	0
IDE05145-ENG115097-Light configuration-Light_Function_D_4	0
IDE05145-ENG114980-Light configuration-Light_Function_D_5	0
IDE05145-ENG115118-Light configuration-Light_Function_D_6	0
IDE05145-ENG115137-Light configuration-Light_Function_D_7	0
IDE05145-ENG115156-Light configuration-Light_Function_D_8	0
IDE05145-ENG115175-Light configuration-Light_Function_D_9	0
IDE05145-ENG115024-Light configuration-Light_Function_E_0	0
IDE05145-ENG115043-Light configuration-Light_Function_E_1	0
IDE05145-ENG115005-Light configuration-Light_Function_E_10	0
IDE05145-ENG115199-Light configuration-Light_Function_E_11	0
IDE05145-ENG115218-Light configuration-Light_Function_E_12	0
IDE05145-ENG114964-Light configuration-Light_Function_E_13	0
IDE05145-ENG115239-Light configuration-Light_Function_E_14	0
IDE05145-ENG115258-Light configuration-Light_Function_E_15	0
IDE05145-ENG115277-Light configuration-Light_Function_E_16	0
IDE05145-ENG115296-Light configuration-Light_Function_E_17	0
IDE05145-ENG115315-Light configuration-Light_Function_E_18	0
IDE05145-ENG115334-Light configuration-Light_Function_E_19	0
IDE05145-ENG115062-Light configuration-Light_Function_E_2	18
IDE05145-ENG115353-Light configuration-Light_Function_E_20	0
IDE05145-ENG115372-Light configuration-Light_Function_E_21	0
IDE05145-ENG115391-Light configuration-Light_Function_E_22	0
IDE05145-ENG115410-Light configuration-Light_Function_E_23	0
IDE05145-ENG115429-Light configuration-Light_Function_E_24	0
IDE05145-ENG115448-Light configuration-Light_Function_E_25	0
IDE05145-ENG115467-Light configuration-Light_Function_E_26	0
IDE05145-ENG115486-Light configuration-Light_Function_E_27	0
IDE05145-ENG115505-Light configuration-Light_Function_E_28	0
IDE05145-ENG115524-Light configuration-Light_Function_E_29	0
IDE05145-ENG115081-Light configuration-Light_Function_E_3	19
IDE05145-ENG115543-Light configuration-Light_Function_E_30	0
IDE05145-ENG115562-Light configuration-Light_Function_E_31	0
IDE05145-ENG115581-Light configuration-Light_Function_E_32	0
IDE05145-ENG115600-Light configuration-Light_Function_E_33	0
IDE05145-ENG115619-Light configuration-Light_Function_E_34	0
IDE05145-ENG115100-Light configuration-Light_Function_E_4	0
IDE05145-ENG114983-Light configuration-Light_Function_E_5	0
IDE05145-ENG115121-Light configuration-Light_Function_E_6	0
IDE05145-ENG115140-Light configuration-Light_Function_E_7	0
IDE05145-ENG115159-Light configuration-Light_Function_E_8	0
IDE05145-ENG115178-Light configuration-Light_Function_E_9	0
IDE05145-ENG115025-Light configuration-Light_Function_F_0	0
IDE05145-ENG115044-Light configuration-Light_Function_F_1	0
IDE05145-ENG115006-Light configuration-Light_Function_F_10	0
IDE05145-ENG115200-Light configuration-Light_Function_F_11	0
IDE05145-ENG115219-Light configuration-Light_Function_F_12	0
IDE05145-ENG114965-Light configuration-Light_Function_F_13	0
IDE05145-ENG115240-Light configuration-Light_Function_F_14	0
IDE05145-ENG115259-Light configuration-Light_Function_F_15	0
IDE05145-ENG115278-Light configuration-Light_Function_F_16	0
IDE05145-ENG115297-Light configuration-Light_Function_F_17	0
IDE05145-ENG115316-Light configuration-Light_Function_F_18	0
IDE05145-ENG115335-Light configuration-Light_Function_F_19	0
IDE05145-ENG115063-Light configuration-Light_Function_F_2	0
IDE05145-ENG115354-Light configuration-Light_Function_F_20	0
IDE05145-ENG115373-Light configuration-Light_Function_F_21	0
IDE05145-ENG115392-Light configuration-Light_Function_F_22	0
IDE05145-ENG115411-Light configuration-Light_Function_F_23	0
IDE05145-ENG115430-Light configuration-Light_Function_F_24	0
IDE05145-ENG115449-Light configuration-Light_Function_F_25	0
IDE05145-ENG115468-Light configuration-Light_Function_F_26	0
IDE05145-ENG115487-Light configuration-Light_Function_F_27	0
IDE05145-ENG115506-Light configuration-Light_Function_F_28	0
IDE05145-ENG115525-Light configuration-Light_Function_F_29	0
IDE05145-ENG115082-Light configuration-Light_Function_F_3	0
IDE05145-ENG115544-Light configuration-Light_Function_F_30	0
IDE05145-ENG115563-Light configuration-Light_Function_F_31	0
IDE05145-ENG115582-Light configuration-Light_Function_F_32	0
IDE05145-ENG115601-Light configuration-Light_Function_F_33	0
IDE05145-ENG115620-Light configuration-Light_Function_F_34	0
IDE05145-ENG115101-Light configuration-Light_Function_F_4	0
IDE05145-ENG114984-Light configuration-Light_Function_F_5	0
IDE05145-ENG115122-Light configuration-Light_Function_F_6	0
IDE05145-ENG115141-Light configuration-Light_Function_F_7	0
IDE05145-ENG115160-Light configuration-Light_Function_F_8	0
IDE05145-ENG115179-Light configuration-Light_Function_F_9	0
IDE05145-ENG115028-Light configuration-Light_Function_G_0	0
IDE05145-ENG115047-Light configuration-Light_Function_G_1	0
IDE05145-ENG115009-Light configuration-Light_Function_G_10	0
IDE05145-ENG115203-Light configuration-Light_Function_G_11	0
IDE05145-ENG115222-Light configuration-Light_Function_G_12	0
IDE05145-ENG114968-Light configuration-Light_Function_G_13	0
IDE05145-ENG115243-Light configuration-Light_Function_G_14	0
IDE05145-ENG115262-Light configuration-Light_Function_G_15	0
IDE05145-ENG115281-Light configuration-Light_Function_G_16	0
IDE05145-ENG115300-Light configuration-Light_Function_G_17	0
IDE05145-ENG115319-Light configuration-Light_Function_G_18	0
IDE05145-ENG115338-Light configuration-Light_Function_G_19	0
IDE05145-ENG115066-Light configuration-Light_Function_G_2	0
IDE05145-ENG115357-Light configuration-Light_Function_G_20	0
IDE05145-ENG115376-Light configuration-Light_Function_G_21	0
IDE05145-ENG115395-Light configuration-Light_Function_G_22	0
IDE05145-ENG115414-Light configuration-Light_Function_G_23	0
IDE05145-ENG115433-Light configuration-Light_Function_G_24	0
IDE05145-ENG115452-Light configuration-Light_Function_G_25	0
IDE05145-ENG115471-Light configuration-Light_Function_G_26	0
IDE05145-ENG115490-Light configuration-Light_Function_G_27	0
IDE05145-ENG115509-Light configuration-Light_Function_G_28	0
IDE05145-ENG115528-Light configuration-Light_Function_G_29	0
IDE05145-ENG115085-Light configuration-Light_Function_G_3	0
IDE05145-ENG115547-Light configuration-Light_Function_G_30	0
IDE05145-ENG115566-Light configuration-Light_Function_G_31	0
IDE05145-ENG115585-Light configuration-Light_Function_G_32	0
IDE05145-ENG115604-Light configuration-Light_Function_G_33	0
IDE05145-ENG115623-Light configuration-Light_Function_G_34	0
IDE05145-ENG115104-Light configuration-Light_Function_G_4	0
IDE05145-ENG114987-Light configuration-Light_Function_G_5	0
IDE05145-ENG115125-Light configuration-Light_Function_G_6	0
IDE05145-ENG115144-Light configuration-Light_Function_G_7	0
IDE05145-ENG115163-Light configuration-Light_Function_G_8	0
IDE05145-ENG115182-Light configuration-Light_Function_G_9	0
IDE05145-ENG115029-Light configuration-Light_Function_H_0	0
IDE05145-ENG115048-Light configuration-Light_Function_H_1	0
IDE05145-ENG115010-Light configuration-Light_Function_H_10	0
IDE05145-ENG115204-Light configuration-Light_Function_H_11	0
IDE05145-ENG115223-Light configuration-Light_Function_H_12	0
IDE05145-ENG114969-Light configuration-Light_Function_H_13	0
IDE05145-ENG115244-Light configuration-Light_Function_H_14	0
IDE05145-ENG115263-Light configuration-Light_Function_H_15	0
IDE05145-ENG115282-Light configuration-Light_Function_H_16	0
IDE05145-ENG115301-Light configuration-Light_Function_H_17	0
IDE05145-ENG115320-Light configuration-Light_Function_H_18	0
IDE05145-ENG115339-Light configuration-Light_Function_H_19	0
IDE05145-ENG115067-Light configuration-Light_Function_H_2	0
IDE05145-ENG115358-Light configuration-Light_Function_H_20	0
IDE05145-ENG115377-Light configuration-Light_Function_H_21	0
IDE05145-ENG115396-Light configuration-Light_Function_H_22	0
IDE05145-ENG115415-Light configuration-Light_Function_H_23	0
IDE05145-ENG115434-Light configuration-Light_Function_H_24	0
IDE05145-ENG115453-Light configuration-Light_Function_H_25	0
IDE05145-ENG115472-Light configuration-Light_Function_H_26	0
IDE05145-ENG115491-Light configuration-Light_Function_H_27	0
IDE05145-ENG115510-Light configuration-Light_Function_H_28	0
IDE05145-ENG115529-Light configuration-Light_Function_H_29	0
IDE05145-ENG115086-Light configuration-Light_Function_H_3	0
IDE05145-ENG115548-Light configuration-Light_Function_H_30	0
IDE05145-ENG115567-Light configuration-Light_Function_H_31	0
IDE05145-ENG115586-Light configuration-Light_Function_H_32	0
IDE05145-ENG115605-Light configuration-Light_Function_H_33	0
IDE05145-ENG115624-Light configuration-Light_Function_H_34	0
IDE05145-ENG115105-Light configuration-Light_Function_H_4	0
IDE05145-ENG114988-Light configuration-Light_Function_H_5	0
IDE05145-ENG115126-Light configuration-Light_Function_H_6	0
IDE05145-ENG115145-Light configuration-Light_Function_H_7	0
IDE05145-ENG115164-Light configuration-Light_Function_H_8	0
IDE05145-ENG115183-Light configuration-Light_Function_H_9	0
IDE05145-ENG115013-Light configuration-Type_Of_Load_0	Blinkleuchten
IDE05145-ENG115032-Light configuration-Type_Of_Load_1	Blinkleuchten
IDE05145-ENG114995-Light configuration-Type_Of_Load_10	not active
IDE05145-ENG115188-Light configuration-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115207-Light configuration-Type_Of_Load_12	allgemeine Scheinwerfer
IDE05145-ENG114954-Light configuration-Type_Of_Load_13	allgemeine Scheinwerfer
IDE05145-ENG115228-Light configuration-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115247-Light configuration-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115266-Light configuration-Type_Of_Load_16	LED Blinkleuchten
IDE05145-ENG115285-Light configuration-Type_Of_Load_17	LED Blinkleuchten
IDE05145-ENG115304-Light configuration-Type_Of_Load_18	Blinkleuchten
IDE05145-ENG115323-Light configuration-Type_Of_Load_19	Blinkleuchten
IDE05145-ENG115051-Light configuration-Type_Of_Load_2	LED Tagfahrlichtmodul Signal
IDE05145-ENG115342-Light configuration-Type_Of_Load_20	Bremsleuchten
IDE05145-ENG115361-Light configuration-Type_Of_Load_21	Bremsleuchten
IDE05145-ENG115380-Light configuration-Type_Of_Load_22	LEDdritteBremsleuchte
IDE05145-ENG115399-Light configuration-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115418-Light configuration-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115437-Light configuration-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115456-Light configuration-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115475-Light configuration-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115494-Light configuration-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115513-Light configuration-Type_Of_Load_29	allgemeineGluehlampe12W
IDE05145-ENG115070-Light configuration-Type_Of_Load_3	LED Tagfahrlichtmodul Signal
IDE05145-ENG115532-Light configuration-Type_Of_Load_30	allgemeineGluehlampe12W
IDE05145-ENG115551-Light configuration-Type_Of_Load_31	not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32	not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33	not active
IDE05145-ENG115608-Light configuration-Type_Of_Load_34	not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG114973-Light configuration-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100,00%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration	0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts	0
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	No
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel	active
IDE08542-ENG115671-Access control 2-Regenschließen	not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	0 ms
IDE08786-ENG11105-Assistance light functions-Assistance_lighting_sensitivity_adjustable	Not Present
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC	55
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0	not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1	not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10	not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11	not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12	not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13	not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14	not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15	not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16	not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17	not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18	not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19	not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2	not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20	not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21	not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22	not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23	not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24	not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25	not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26	not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27	not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28	not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29	not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3	not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30	not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31	not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32	not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33	not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34	not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4	not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5	not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6	active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7	not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8	active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9	not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand	150_Ohm
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC	56
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0	not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1	not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10	not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11	not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12	not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13	not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14	not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15	not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16	not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17	not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18	not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19	not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2	not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20	not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21	not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22	not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23	not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24	not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25	not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26	not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27	not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28	not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29	not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3	not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30	not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31	not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32	not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33	not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34	not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4	not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5	not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6	not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7	active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8	not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9	active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand	150_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs	not active
IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung	Energy management
IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung	Energy management
IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit	0 min
IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit	24 s
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein	not active
MAS01490-IDE07474-Energy management-Adapting for energy management	Energy management active
MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement	not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter	closed
MAS08233-ENG126575-other-mute_mode_aktiv	not active
MAS08233-ENG125011-other-pa_Funktion_2aus3	not installed
ENG05956-Adaptation_theft_protection_2	not active
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.0 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.0 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.0 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.0 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.0 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.0 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.0 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.0 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.0 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.0 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.0 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.0 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.0 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.0 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.0 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.0 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.0 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.0 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.0 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.0 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.0 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.0 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.0 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.0 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.0 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.0 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.0 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.0 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16.0
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16.0
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100.0
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100.0
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100.0
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6.0
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6.0
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100.0
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100.0
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100.0
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	100.0 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	100.0 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	100.0 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	100.0 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	100.0 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.0 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100.0
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100.0
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100.0
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100.0
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6.0
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6.0
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100.0
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100.0
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.0 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.0 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.0 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.0 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.0 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.0 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100.0
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100.0
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100.0
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100.0
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6.0
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6.0
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100.0
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100.0
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.0 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.0 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.0 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.0 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.0 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.0 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.0 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5.0
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15.0
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40.0
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100.0
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0	100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0	0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0	maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0	maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0	maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0	0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0	0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0	14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0	34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0	Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0	Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0	not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0	not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0	not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0	not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0	not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0	not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0	not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0	Blinkleuchten
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10	0
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10	0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10	maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10	maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10	maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10	0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10	0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10	0
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10	0
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10	Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10	not active
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10	not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10	not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10	not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10	not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10	not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10	not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10	not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10	not active
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11	100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11	0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11	maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11	maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11	maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11	0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11	0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11	0
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11	0
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11	Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11	Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11	not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11	not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11	not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11	not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11	not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11	not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11	not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12	100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12	0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12	maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12	maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12	maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12	0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12	0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12	22
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12	38
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12	Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12	Nebellicht links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12	Abbiegelicht links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12	not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12	not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12	not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12	not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12	not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12	not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12	allgemeine Scheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13	100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13	0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13	maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13	maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13	maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13	0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13	0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13	23
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13	42
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13	Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13	Nebellicht rechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13	Abbiegelicht rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13	not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13	not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13	not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13	not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13	not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13	not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13	allgemeine Scheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15	100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15	0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15	maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15	maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15	maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15	0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15	0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15	0
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15	0
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15	Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15	SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15	not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15	not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15	not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15	not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15	not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15	not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15	not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16	100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16	0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16	maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16	maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16	maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16	0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16	0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16	0
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16	0
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16	Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16	Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16	not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16	not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16	not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16	not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16	not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16	not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16	not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16	LED Blinkleuchten
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17	100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17	0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17	maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17	maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17	maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17	0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17	0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17	0
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17	0
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17	Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17	Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17	not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17	not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17	not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17	not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17	not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17	not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17	not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17	LED Blinkleuchten
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18	100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18	0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18	maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18	maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18	maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18	0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18	0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18	16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18	8
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18	Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18	Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18	not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18	not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18	not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18	not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18	not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18	not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18	not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18	Blinkleuchten
ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19	100
ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19	0
ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19	maximize
ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19	maximize
ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19	maximize
ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19	0
ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19	0
ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19	18
ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19	18
ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19	Always
ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19	Blinken rechts Hellphase
ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19	not active
ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19	not active
ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19	not active
ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19	not active
ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19	not active
ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19	not active
ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19	not active
ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19	Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1	100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1	0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1	maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1	maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1	maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1	0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1	0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1	15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1	3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1	Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1	Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1	not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1	not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1	not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1	not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1	not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1	not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1	not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1	Blinkleuchten
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20	100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20	0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20	maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20	maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20	maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20	0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20	0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20	2B
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20	9
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20	Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20	Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20	not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20	not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20	not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20	not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20	not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20	not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20	not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20	Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21	100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21	0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21	maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21	maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21	maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21	0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21	0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21	2D
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21	19
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21	Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21	Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21	not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21	not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21	not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21	not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21	not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21	not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21	not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21	Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22	100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22	0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22	maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22	maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22	maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22	0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22	0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22	2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22	29
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22	Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22	Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22	not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22	not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22	not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22	not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22	not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22	not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22	not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22	LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23	60
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23	0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23	maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23	maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23	maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23	0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23	0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23	29
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23	0A
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23	Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23	Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23	Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23	not active
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23	not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23	not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23	not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23	not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23	not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24	60
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24	0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24	maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24	maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24	maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24	0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24	0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24	2A
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24	1A
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24	Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24	Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24	Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24	not active
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24	not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24	not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24	not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24	not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24	not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25	100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25	0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25	maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25	maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25	maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25	0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25	0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25	30
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25	28
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25	Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25	Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25	not active
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25	not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25	not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25	not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25	not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25	not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25	not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26	100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26	0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26	maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26	maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26	maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26	0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26	0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26	33
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26	2A
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26	Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26	NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26	not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26	not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26	not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26	not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26	not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26	not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26	not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27	100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27	0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27	maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27	maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27	maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27	0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27	0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27	8
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27	0
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27	Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27	Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27	not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27	not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27	not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27	not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27	not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27	not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27	not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28	100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28	0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28	maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28	maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28	maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28	0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28	0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28	34
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28	2B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28	Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28	Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28	not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28	not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28	not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28	not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28	not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28	not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28	not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29	100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29	0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29	maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29	maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29	maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29	0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29	0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29	1
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29	0
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29	Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29	Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29	not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29	not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29	not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29	not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29	not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29	not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29	not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29	allgemeineGluehlampe12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2	70
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2	30
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2	maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2	minimize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2	maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2	30
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2	0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2	0
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2	0
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2	Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2	Daytime running lights
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2	not active
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2	Parking light
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2	Parking light left
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2	Nebellicht links
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2	not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2	not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2	not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2	LED Tagfahrlichtmodul Signal
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30	126
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30	0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30	maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30	maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30	maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30	0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30	0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30	7
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30	0
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30	Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30	Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30	not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30	not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30	not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30	not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30	not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30	not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30	not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30	allgemeineGluehlampe12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31	0
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31	0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31	maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31	maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31	maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31	0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31	0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31	0
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31	0
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31	Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31	not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31	not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31	not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31	not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31	not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31	not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31	not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31	not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31	not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32	0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32	0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32	maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32	maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32	maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32	0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32	0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32	0
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32	0
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32	Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32	not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32	not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32	not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32	not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32	not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32	not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32	not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32	not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32	not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33	0
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33	0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33	maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33	maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33	maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33	0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33	0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33	0
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33	0
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33	Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33	not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33	not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33	not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33	not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33	not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33	not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33	not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33	not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33	not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34	0
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34	0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34	maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34	maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34	maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34	0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34	0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34	0
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34	0
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34	Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34	not active
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34	not active
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34	not active
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34	not active
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34	not active
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34	not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34	not active
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34	not active
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34	not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3	70
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3	30
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3	maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3	minimize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3	maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3	30
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3	0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3	0
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3	0
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3	Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3	Daytime running lights
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3	not active
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3	Parking light
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3	Parking light right
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3	Nebellicht rechts
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3	not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3	not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3	not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3	LED Tagfahrlichtmodul Signal
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4	127
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4	127
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4	maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4	maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4	maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4	0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4	0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4	49
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4	48
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4	Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4	Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4	Parking light
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4	Parking light left
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4	not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4	not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4	not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4	not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4	not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5	127
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5	127
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5	maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5	maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5	maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5	0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5	0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5	4B
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5	4C
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5	Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5	Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5	Parking light
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5	Parking light right
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5	not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5	not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5	not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5	not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5	not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6	127
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6	0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6	maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6	maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6	maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6	0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6	0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6	1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6	36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6	Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6	Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6	ComingHome LeavingHome
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6	not active
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6	not active
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6	not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6	not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6	not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6	not active
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7	127
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7	0
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7	maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7	maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7	maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7	0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7	0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7	1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7	40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7	Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7	Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7	ComingHome LeavingHome
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7	not active
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7	not active
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7	not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7	not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7	not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7	not active
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8	127
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8	0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8	maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8	maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7	maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8	0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8	0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8	1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8	37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8	Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8	Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8	Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8	not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8	not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8	not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8	not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8	not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8	not active
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9	127
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9	0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9	maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9	maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9	maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9	0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9	0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9	1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9	41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9	Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9	Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9	Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9	not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9	not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9	not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9	not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9	not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9	not active
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14	100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14	0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14	maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14	maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14	maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14	0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14	0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14	0
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14	0
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14	Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14	LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14	not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14	not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14	not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14	not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14	not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14	not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14	not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
ENG126648-MAS02526-LIN-Mirrormode-Activation	not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.0 %
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Elapsed Time: 02:21
;SW:6C0-937-089-D   HW:6C0-937-089 ---  Cent. Elect.
;Component:BCM PQ26 Hi4R H08 0094	Coding:00000A404253005B4F844000400F07080000590251010000000000000000
;EV_BCMA0	6002	EV_BCMA0_006.rod
;Sunday	28	May	2017	19:14:39:11885
;VCDS Version: Release 17.1.3  Data version: 20170320 DS267.7
;VCID: 31464CF5600737C956-8064
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG130235-Production mode-Entry_control	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1	not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition	keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	not activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	800 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	800 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart	kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	active
IDE02152-Characteristics in production mode	2000 ms
IDE02200-Component protection showroom mode	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl	not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl	not active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on	not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80,00%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80,00%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80,00%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.50 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	180 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	120 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken	active
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger	separate
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken	not active
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen	5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker	SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2	not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung	not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung	Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor	0.100 %
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert	3.0 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht	active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren	not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	255 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	Not Present
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	ignition
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	0.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	not enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert	not active
IDE04926-ENG126570-Comfort illumination-lho_zeit	0 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	0 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	not active
IDE04927-IDE01446-Window heater-Running time of heated front window	6 s (second)
IDE04927-ENG11110-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung	170 °C
IDE04927-ENG11109-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung	170 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung	0 s (second)
IDE04927-ENG11108-Window heater-Heckscheibenheizung_Zeitwert	15 s (second)
IDE04927-ENG11107-Window heater-Temperaturabhaengige_Einschaltzeit_FSH	active
IDE04927-ENG11106-Window heater-Temperaturabhaengige_Einschaltzeit_HSH	active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	immidiat_driver_door_contact_thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	not active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0	34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1	3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10	0
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11	0
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12	38
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13	42
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14	0
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15	0
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16	0
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17	0
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18	8
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19	18
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2	0
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20	9
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21	19
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22	29
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23	0A
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24	1A
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25	28
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26	2A
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27	0
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28	2B
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29	0
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3	0
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30	0
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31	0
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32	0
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33	0
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34	0
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4	48
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5	4C
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6	36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7	40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8	37
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9	41
IDE05145-ENG115018-Light configuration-Dimming_AB_0	100
IDE05145-ENG115037-Light configuration-Dimming_AB_1	100
IDE05145-ENG114999-Light configuration-Dimming_AB_10	0
IDE05145-ENG115193-Light configuration-Dimming_AB_11	100
IDE05145-ENG115212-Light configuration-Dimming_AB_12	100
IDE05145-ENG114958-Light configuration-Dimming_AB_13	100
IDE05145-ENG115233-Light configuration-Dimming_AB_14	100
IDE05145-ENG115252-Light configuration-Dimming_AB_15	100
IDE05145-ENG115271-Light configuration-Dimming_AB_16	100
IDE05145-ENG115290-Light configuration-Dimming_AB_17	100
IDE05145-ENG115309-Light configuration-Dimming_AB_18	100
IDE05145-ENG115328-Light configuration-Dimming_AB_19	100
IDE05145-ENG115056-Light configuration-Dimming_AB_2	70
IDE05145-ENG115347-Light configuration-Dimming_AB_20	100
IDE05145-ENG115366-Light configuration-Dimming_AB_21	100
IDE05145-ENG115385-Light configuration-Dimming_AB_22	100
IDE05145-ENG115404-Light configuration-Dimming_AB_23	60
IDE05145-ENG115423-Light configuration-Dimming_AB_24	60
IDE05145-ENG115442-Light configuration-Dimming_AB_25	100
IDE05145-ENG115461-Light configuration-Dimming_AB_26	100
IDE05145-ENG115480-Light configuration-Dimming_AB_27	100
IDE05145-ENG115499-Light configuration-Dimming_AB_28	100
IDE05145-ENG115518-Light configuration-Dimming_AB_29	100
IDE05145-ENG115075-Light configuration-Dimming_AB_3	70
IDE05145-ENG115537-Light configuration-Dimming_AB_30	126
IDE05145-ENG115556-Light configuration-Dimming_AB_31	0
IDE05145-ENG115575-Light configuration-Dimming_AB_32	0
IDE05145-ENG115594-Light configuration-Dimming_AB_33	0
IDE05145-ENG115613-Light configuration-Dimming_AB_34	0
IDE05145-ENG115094-Light configuration-Dimming_AB_4	127
IDE05145-ENG114977-Light configuration-Dimming_AB_5	127
IDE05145-ENG115115-Light configuration-Dimming_AB_6	127
IDE05145-ENG115134-Light configuration-Dimming_AB_7	127
IDE05145-ENG115153-Light configuration-Dimming_AB_8	127
IDE05145-ENG115172-Light configuration-Dimming_AB_9	127
IDE05145-ENG115022-Light configuration-Dimming_CD_0	0
IDE05145-ENG115041-Light configuration-Dimming_CD_1	0
IDE05145-ENG115003-Light configuration-Dimming_CD_10	0
IDE05145-ENG115197-Light configuration-Dimming_CD_11	0
IDE05145-ENG115216-Light configuration-Dimming_CD_12	0
IDE05145-ENG114962-Light configuration-Dimming_CD_13	0
IDE05145-ENG115237-Light configuration-Dimming_CD_14	0
IDE05145-ENG115256-Light configuration-Dimming_CD_15	0
IDE05145-ENG115275-Light configuration-Dimming_CD_16	0
IDE05145-ENG115294-Light configuration-Dimming_CD_17	0
IDE05145-ENG115313-Light configuration-Dimming_CD_18	0
IDE05145-ENG115332-Light configuration-Dimming_CD_19	0
IDE05145-ENG115060-Light configuration-Dimming_CD_2	30
IDE05145-ENG115351-Light configuration-Dimming_CD_20	0
IDE05145-ENG115370-Light configuration-Dimming_CD_21	0
IDE05145-ENG115389-Light configuration-Dimming_CD_22	0
IDE05145-ENG115408-Light configuration-Dimming_CD_23	0
IDE05145-ENG115427-Light configuration-Dimming_CD_24	0
IDE05145-ENG115446-Light configuration-Dimming_CD_25	0
IDE05145-ENG115465-Light configuration-Dimming_CD_26	0
IDE05145-ENG115484-Light configuration-Dimming_CD_27	0
IDE05145-ENG115503-Light configuration-Dimming_CD_28	0
IDE05145-ENG115522-Light configuration-Dimming_CD_29	0
IDE05145-ENG115079-Light configuration-Dimming_CD_3	30
IDE05145-ENG115541-Light configuration-Dimming_CD_30	0
IDE05145-ENG115560-Light configuration-Dimming_CD_31	0
IDE05145-ENG115579-Light configuration-Dimming_CD_32	0
IDE05145-ENG115598-Light configuration-Dimming_CD_33	0
IDE05145-ENG115617-Light configuration-Dimming_CD_34	0
IDE05145-ENG115098-Light configuration-Dimming_CD_4	127
IDE05145-ENG114981-Light configuration-Dimming_CD_5	127
IDE05145-ENG115119-Light configuration-Dimming_CD_6	0
IDE05145-ENG115138-Light configuration-Dimming_CD_7	0
IDE05145-ENG115157-Light configuration-Dimming_CD_8	0
IDE05145-ENG115176-Light configuration-Dimming_CD_9	0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0	maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1	maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10	maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11	maximize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12	maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13	maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14	maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15	maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16	maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17	maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18	maximize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19	maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2	maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20	maximize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21	maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22	maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23	maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24	maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25	maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26	maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27	maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28	maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29	maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3	maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30	maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31	maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32	maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33	maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34	maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4	maximize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5	maximize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6	maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7	maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8	maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9	maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0	maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1	maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10	maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11	maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12	maximize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13	maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14	maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15	maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16	maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17	maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18	maximize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19	maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2	minimize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20	maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21	maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22	maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23	maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24	maximize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25	maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26	maximize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27	maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28	maximize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29	maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3	minimize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30	maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31	maximize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32	maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33	maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34	maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4	maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5	maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6	maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7	maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8	maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9	maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0	maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1	maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10	maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11	maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12	maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13	maximize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14	maximize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15	maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16	maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17	maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18	maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19	maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2	maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20	maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21	maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22	maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23	maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24	maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25	maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26	maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27	maximize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28	maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29	maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3	maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30	maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31	maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32	maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33	maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34	maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4	maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5	maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6	maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7	maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8	maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9	maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0	0
IDE05145-ENG115045-Light configuration-Dimming_EF_1	0
IDE05145-ENG115007-Light configuration-Dimming_EF_10	0
IDE05145-ENG115201-Light configuration-Dimming_EF_11	0
IDE05145-ENG115220-Light configuration-Dimming_EF_12	0
IDE05145-ENG114966-Light configuration-Dimming_EF_13	0
IDE05145-ENG115241-Light configuration-Dimming_EF_14	0
IDE05145-ENG115260-Light configuration-Dimming_EF_15	0
IDE05145-ENG115279-Light configuration-Dimming_EF_16	0
IDE05145-ENG115298-Light configuration-Dimming_EF_17	0
IDE05145-ENG115317-Light configuration-Dimming_EF_18	0
IDE05145-ENG115336-Light configuration-Dimming_EF_19	0
IDE05145-ENG115064-Light configuration-Dimming_EF_2	30
IDE05145-ENG115355-Light configuration-Dimming_EF_20	0
IDE05145-ENG115374-Light configuration-Dimming_EF_21	0
IDE05145-ENG115393-Light configuration-Dimming_EF_22	0
IDE05145-ENG115412-Light configuration-Dimming_EF_23	0
IDE05145-ENG115431-Light configuration-Dimming_EF_24	0
IDE05145-ENG115450-Light configuration-Dimming_EF_25	0
IDE05145-ENG115469-Light configuration-Dimming_EF_26	0
IDE05145-ENG115488-Light configuration-Dimming_EF_27	0
IDE05145-ENG115507-Light configuration-Dimming_EF_28	0
IDE05145-ENG115526-Light configuration-Dimming_EF_29	0
IDE05145-ENG115083-Light configuration-Dimming_EF_3	30
IDE05145-ENG115545-Light configuration-Dimming_EF_30	0
IDE05145-ENG115564-Light configuration-Dimming_EF_31	0
IDE05145-ENG115583-Light configuration-Dimming_EF_32	0
IDE05145-ENG115602-Light configuration-Dimming_EF_33	0
IDE05145-ENG115621-Light configuration-Dimming_EF_34	0
IDE05145-ENG115102-Light configuration-Dimming_EF_4	0
IDE05145-ENG114985-Light configuration-Dimming_EF_5	0
IDE05145-ENG115123-Light configuration-Dimming_EF_6	0
IDE05145-ENG115142-Light configuration-Dimming_EF_7	0
IDE05145-ENG115161-Light configuration-Dimming_EF_8	0
IDE05145-ENG115180-Light configuration-Dimming_EF_9	0
IDE05145-ENG115030-Light configuration-Dimming_GH_0	0
IDE05145-ENG115049-Light configuration-Dimming_GH_1	0
IDE05145-ENG115011-Light configuration-Dimming_GH_10	0
IDE05145-ENG115205-Light configuration-Dimming_GH_11	0
IDE05145-ENG115224-Light configuration-Dimming_GH_12	0
IDE05145-ENG114970-Light configuration-Dimming_GH_13	0
IDE05145-ENG115245-Light configuration-Dimming_GH_14	0
IDE05145-ENG115264-Light configuration-Dimming_GH_15	0
IDE05145-ENG115283-Light configuration-Dimming_GH_16	0
IDE05145-ENG115302-Light configuration-Dimming_GH_17	0
IDE05145-ENG115321-Light configuration-Dimming_GH_18	0
IDE05145-ENG115340-Light configuration-Dimming_GH_19	0
IDE05145-ENG115068-Light configuration-Dimming_GH_2	0
IDE05145-ENG115359-Light configuration-Dimming_GH_20	0
IDE05145-ENG115378-Light configuration-Dimming_GH_21	0
IDE05145-ENG115397-Light configuration-Dimming_GH_22	0
IDE05145-ENG115416-Light configuration-Dimming_GH_23	0
IDE05145-ENG115435-Light configuration-Dimming_GH_24	0
IDE05145-ENG115454-Light configuration-Dimming_GH_25	0
IDE05145-ENG115473-Light configuration-Dimming_GH_26	0
IDE05145-ENG115492-Light configuration-Dimming_GH_27	0
IDE05145-ENG115511-Light configuration-Dimming_GH_28	0
IDE05145-ENG115530-Light configuration-Dimming_GH_29	0
IDE05145-ENG115087-Light configuration-Dimming_GH_3	0
IDE05145-ENG115549-Light configuration-Dimming_GH_30	0
IDE05145-ENG115568-Light configuration-Dimming_GH_31	0
IDE05145-ENG115587-Light configuration-Dimming_GH_32	0
IDE05145-ENG115606-Light configuration-Dimming_GH_33	0
IDE05145-ENG115625-Light configuration-Dimming_GH_34	0
IDE05145-ENG115106-Light configuration-Dimming_GH_4	0
IDE05145-ENG114989-Light configuration-Dimming_GH_5	0
IDE05145-ENG115127-Light configuration-Dimming_GH_6	0
IDE05145-ENG115146-Light configuration-Dimming_GH_7	0
IDE05145-ENG115165-Light configuration-Dimming_GH_8	0
IDE05145-ENG115184-Light configuration-Dimming_GH_9	0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0	14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1	15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10	0
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11	0
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12	22
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13	23
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14	0
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15	0
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16	0
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17	0
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18	16
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19	18
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2	0
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20	2B
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21	2D
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22	2C
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23	29
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24	2A
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25	30
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26	33
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27	8
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28	34
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29	1
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3	0
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30	7
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31	0
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32	0
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33	0
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34	0
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4	49
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5	4B
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6	1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7	1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8	1C
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9	1D
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0	Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1	Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10	Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11	Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12	Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13	Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14	Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15	Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16	Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17	Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18	Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19	Always
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2	Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20	Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21	Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22	Always
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23	Always
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24	Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25	Always
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26	Always
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27	Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28	Always
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29	Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3	Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30	Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31	Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32	Always
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33	Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34	Always
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4	Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5	Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6	Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7	Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8	Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9	Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0	2
IDE05145-ENG115035-Light configuration-Light_Function_A_1	4
IDE05145-ENG114997-Light configuration-Light_Function_A_10	0
IDE05145-ENG115191-Light configuration-Light_Function_A_11	62
IDE05145-ENG115210-Light configuration-Light_Function_A_12	18
IDE05145-ENG114956-Light configuration-Light_Function_A_13	19
IDE05145-ENG115231-Light configuration-Light_Function_A_14	63
IDE05145-ENG115250-Light configuration-Light_Function_A_15	64
IDE05145-ENG115269-Light configuration-Light_Function_A_16	2
IDE05145-ENG115288-Light configuration-Light_Function_A_17	4
IDE05145-ENG115307-Light configuration-Light_Function_A_18	2
IDE05145-ENG115326-Light configuration-Light_Function_A_19	4
IDE05145-ENG115054-Light configuration-Light_Function_A_2	20
IDE05145-ENG115345-Light configuration-Light_Function_A_20	24
IDE05145-ENG115364-Light configuration-Light_Function_A_21	24
IDE05145-ENG115383-Light configuration-Light_Function_A_22	24
IDE05145-ENG115402-Light configuration-Light_Function_A_23	8
IDE05145-ENG115421-Light configuration-Light_Function_A_24	8
IDE05145-ENG115440-Light configuration-Light_Function_A_25	8
IDE05145-ENG115459-Light configuration-Light_Function_A_26	27
IDE05145-ENG115478-Light configuration-Light_Function_A_27	38
IDE05145-ENG115497-Light configuration-Light_Function_A_28	25
IDE05145-ENG115516-Light configuration-Light_Function_A_29	37
IDE05145-ENG115073-Light configuration-Light_Function_A_3	20
IDE05145-ENG115535-Light configuration-Light_Function_A_30	41
IDE05145-ENG115554-Light configuration-Light_Function_A_31	0
IDE05145-ENG115573-Light configuration-Light_Function_A_32	0
IDE05145-ENG115592-Light configuration-Light_Function_A_33	0
IDE05145-ENG115611-Light configuration-Light_Function_A_34	0
IDE05145-ENG115092-Light configuration-Light_Function_A_4	20
IDE05145-ENG114975-Light configuration-Light_Function_A_5	20
IDE05145-ENG115113-Light configuration-Light_Function_A_6	11
IDE05145-ENG115132-Light configuration-Light_Function_A_7	12
IDE05145-ENG115151-Light configuration-Light_Function_A_8	13
IDE05145-ENG115170-Light configuration-Light_Function_A_9	14
IDE05145-ENG115017-Light configuration-Light_Function_B_0	0
IDE05145-ENG115036-Light configuration-Light_Function_B_1	0
IDE05145-ENG114998-Light configuration-Light_Function_B_10	0
IDE05145-ENG115192-Light configuration-Light_Function_B_11	0
IDE05145-ENG115211-Light configuration-Light_Function_B_12	22
IDE05145-ENG114957-Light configuration-Light_Function_B_13	23
IDE05145-ENG115232-Light configuration-Light_Function_B_14	0
IDE05145-ENG115251-Light configuration-Light_Function_B_15	0
IDE05145-ENG115270-Light configuration-Light_Function_B_16	0
IDE05145-ENG115289-Light configuration-Light_Function_B_17	0
IDE05145-ENG115308-Light configuration-Light_Function_B_18	0
IDE05145-ENG115327-Light configuration-Light_Function_B_19	0
IDE05145-ENG115055-Light configuration-Light_Function_B_2	0
IDE05145-ENG115346-Light configuration-Light_Function_B_20	0
IDE05145-ENG115365-Light configuration-Light_Function_B_21	0
IDE05145-ENG115384-Light configuration-Light_Function_B_22	0
IDE05145-ENG115403-Light configuration-Light_Function_B_23	9
IDE05145-ENG115422-Light configuration-Light_Function_B_24	10
IDE05145-ENG115441-Light configuration-Light_Function_B_25	0
IDE05145-ENG115460-Light configuration-Light_Function_B_26	0
IDE05145-ENG115479-Light configuration-Light_Function_B_27	0
IDE05145-ENG115498-Light configuration-Light_Function_B_28	0
IDE05145-ENG115517-Light configuration-Light_Function_B_29	0
IDE05145-ENG115074-Light configuration-Light_Function_B_3	0
IDE05145-ENG115536-Light configuration-Light_Function_B_30	0
IDE05145-ENG115555-Light configuration-Light_Function_B_31	0
IDE05145-ENG115574-Light configuration-Light_Function_B_32	0
IDE05145-ENG115593-Light configuration-Light_Function_B_33	0
IDE05145-ENG115612-Light configuration-Light_Function_B_34	0
IDE05145-ENG115093-Light configuration-Light_Function_B_4	8
IDE05145-ENG114976-Light configuration-Light_Function_B_5	8
IDE05145-ENG115114-Light configuration-Light_Function_B_6	30
IDE05145-ENG115133-Light configuration-Light_Function_B_7	30
IDE05145-ENG115152-Light configuration-Light_Function_B_8	15
IDE05145-ENG115171-Light configuration-Light_Function_B_9	15
IDE05145-ENG115020-Light configuration-Light_Function_C_0	0
IDE05145-ENG115039-Light configuration-Light_Function_C_1	0
IDE05145-ENG115001-Light configuration-Light_Function_C_10	0
IDE05145-ENG115195-Light configuration-Light_Function_C_11	0
IDE05145-ENG115214-Light configuration-Light_Function_C_12	0
IDE05145-ENG114960-Light configuration-Light_Function_C_13	0
IDE05145-ENG115235-Light configuration-Light_Function_C_14	0
IDE05145-ENG115254-Light configuration-Light_Function_C_15	0
IDE05145-ENG115273-Light configuration-Light_Function_C_16	0
IDE05145-ENG115292-Light configuration-Light_Function_C_17	0
IDE05145-ENG115311-Light configuration-Light_Function_C_18	0
IDE05145-ENG115330-Light configuration-Light_Function_C_19	0
IDE05145-ENG115058-Light configuration-Light_Function_C_2	8
IDE05145-ENG115349-Light configuration-Light_Function_C_20	0
IDE05145-ENG115368-Light configuration-Light_Function_C_21	0
IDE05145-ENG115387-Light configuration-Light_Function_C_22	0
IDE05145-ENG115406-Light configuration-Light_Function_C_23	0
IDE05145-ENG115425-Light configuration-Light_Function_C_24	0
IDE05145-ENG115444-Light configuration-Light_Function_C_25	0
IDE05145-ENG115463-Light configuration-Light_Function_C_26	0
IDE05145-ENG115482-Light configuration-Light_Function_C_27	0
IDE05145-ENG115501-Light configuration-Light_Function_C_28	0
IDE05145-ENG115519-Light configuration-Light_Function_C_29	0
IDE05145-ENG115077-Light configuration-Light_Function_C_3	8
IDE05145-ENG115539-Light configuration-Light_Function_C_30	0
IDE05145-ENG115558-Light configuration-Light_Function_C_31	0
IDE05145-ENG115577-Light configuration-Light_Function_C_32	0
IDE05145-ENG115596-Light configuration-Light_Function_C_33	0
IDE05145-ENG115615-Light configuration-Light_Function_C_34	0
IDE05145-ENG115096-Light configuration-Light_Function_C_4	9
IDE05145-ENG114979-Light configuration-Light_Function_C_5	10
IDE05145-ENG115117-Light configuration-Light_Function_C_6	0
IDE05145-ENG115136-Light configuration-Light_Function_C_7	0
IDE05145-ENG115155-Light configuration-Light_Function_C_8	0
IDE05145-ENG115174-Light configuration-Light_Function_C_9	0
IDE05145-ENG115021-Light configuration-Light_Function_D_0	0
IDE05145-ENG115040-Light configuration-Light_Function_D_1	0
IDE05145-ENG115002-Light configuration-Light_Function_D_10	0
IDE05145-ENG115196-Light configuration-Light_Function_D_11	0
IDE05145-ENG115215-Light configuration-Light_Function_D_12	0
IDE05145-ENG114961-Light configuration-Light_Function_D_13	0
IDE05145-ENG115236-Light configuration-Light_Function_D_14	0
IDE05145-ENG115255-Light configuration-Light_Function_D_15	0
IDE05145-ENG115274-Light configuration-Light_Function_D_16	0
IDE05145-ENG115293-Light configuration-Light_Function_D_17	0
IDE05145-ENG115312-Light configuration-Light_Function_D_18	0
IDE05145-ENG115331-Light configuration-Light_Function_D_19	0
IDE05145-ENG115059-Light configuration-Light_Function_D_2	9
IDE05145-ENG115350-Light configuration-Light_Function_D_20	0
IDE05145-ENG115369-Light configuration-Light_Function_D_21	0
IDE05145-ENG115388-Light configuration-Light_Function_D_22	0
IDE05145-ENG115407-Light configuration-Light_Function_D_23	0
IDE05145-ENG115426-Light configuration-Light_Function_D_24	0
IDE05145-ENG115445-Light configuration-Light_Function_D_25	0
IDE05145-ENG115464-Light configuration-Light_Function_D_26	0
IDE05145-ENG115483-Light configuration-Light_Function_D_27	0
IDE05145-ENG115502-Light configuration-Light_Function_D_28	0
IDE05145-ENG115521-Light configuration-Light_Function_D_29	0
IDE05145-ENG115078-Light configuration-Light_Function_D_3	10
IDE05145-ENG115540-Light configuration-Light_Function_D_30	0
IDE05145-ENG115559-Light configuration-Light_Function_D_31	0
IDE05145-ENG115578-Light configuration-Light_Function_D_32	0
IDE05145-ENG115597-Light configuration-Light_Function_D_33	0
IDE05145-ENG115616-Light configuration-Light_Function_D_34	0
IDE05145-ENG115097-Light configuration-Light_Function_D_4	0
IDE05145-ENG114980-Light configuration-Light_Function_D_5	0
IDE05145-ENG115118-Light configuration-Light_Function_D_6	0
IDE05145-ENG115137-Light configuration-Light_Function_D_7	0
IDE05145-ENG115156-Light configuration-Light_Function_D_8	0
IDE05145-ENG115175-Light configuration-Light_Function_D_9	0
IDE05145-ENG115024-Light configuration-Light_Function_E_0	0
IDE05145-ENG115043-Light configuration-Light_Function_E_1	0
IDE05145-ENG115005-Light configuration-Light_Function_E_10	0
IDE05145-ENG115199-Light configuration-Light_Function_E_11	0
IDE05145-ENG115218-Light configuration-Light_Function_E_12	0
IDE05145-ENG114964-Light configuration-Light_Function_E_13	0
IDE05145-ENG115239-Light configuration-Light_Function_E_14	0
IDE05145-ENG115258-Light configuration-Light_Function_E_15	0
IDE05145-ENG115277-Light configuration-Light_Function_E_16	0
IDE05145-ENG115296-Light configuration-Light_Function_E_17	0
IDE05145-ENG115315-Light configuration-Light_Function_E_18	0
IDE05145-ENG115334-Light configuration-Light_Function_E_19	0
IDE05145-ENG115062-Light configuration-Light_Function_E_2	18
IDE05145-ENG115353-Light configuration-Light_Function_E_20	0
IDE05145-ENG115372-Light configuration-Light_Function_E_21	0
IDE05145-ENG115391-Light configuration-Light_Function_E_22	0
IDE05145-ENG115410-Light configuration-Light_Function_E_23	0
IDE05145-ENG115429-Light configuration-Light_Function_E_24	0
IDE05145-ENG115448-Light configuration-Light_Function_E_25	0
IDE05145-ENG115467-Light configuration-Light_Function_E_26	0
IDE05145-ENG115486-Light configuration-Light_Function_E_27	0
IDE05145-ENG115505-Light configuration-Light_Function_E_28	0
IDE05145-ENG115524-Light configuration-Light_Function_E_29	0
IDE05145-ENG115081-Light configuration-Light_Function_E_3	19
IDE05145-ENG115543-Light configuration-Light_Function_E_30	0
IDE05145-ENG115562-Light configuration-Light_Function_E_31	0
IDE05145-ENG115581-Light configuration-Light_Function_E_32	0
IDE05145-ENG115600-Light configuration-Light_Function_E_33	0
IDE05145-ENG115619-Light configuration-Light_Function_E_34	0
IDE05145-ENG115100-Light configuration-Light_Function_E_4	0
IDE05145-ENG114983-Light configuration-Light_Function_E_5	0
IDE05145-ENG115121-Light configuration-Light_Function_E_6	0
IDE05145-ENG115140-Light configuration-Light_Function_E_7	0
IDE05145-ENG115159-Light configuration-Light_Function_E_8	0
IDE05145-ENG115178-Light configuration-Light_Function_E_9	0
IDE05145-ENG115025-Light configuration-Light_Function_F_0	0
IDE05145-ENG115044-Light configuration-Light_Function_F_1	0
IDE05145-ENG115006-Light configuration-Light_Function_F_10	0
IDE05145-ENG115200-Light configuration-Light_Function_F_11	0
IDE05145-ENG115219-Light configuration-Light_Function_F_12	0
IDE05145-ENG114965-Light configuration-Light_Function_F_13	0
IDE05145-ENG115240-Light configuration-Light_Function_F_14	0
IDE05145-ENG115259-Light configuration-Light_Function_F_15	0
IDE05145-ENG115278-Light configuration-Light_Function_F_16	0
IDE05145-ENG115297-Light configuration-Light_Function_F_17	0
IDE05145-ENG115316-Light configuration-Light_Function_F_18	0
IDE05145-ENG115335-Light configuration-Light_Function_F_19	0
IDE05145-ENG115063-Light configuration-Light_Function_F_2	0
IDE05145-ENG115354-Light configuration-Light_Function_F_20	0
IDE05145-ENG115373-Light configuration-Light_Function_F_21	0
IDE05145-ENG115392-Light configuration-Light_Function_F_22	0
IDE05145-ENG115411-Light configuration-Light_Function_F_23	0
IDE05145-ENG115430-Light configuration-Light_Function_F_24	0
IDE05145-ENG115449-Light configuration-Light_Function_F_25	0
IDE05145-ENG115468-Light configuration-Light_Function_F_26	0
IDE05145-ENG115487-Light configuration-Light_Function_F_27	0
IDE05145-ENG115506-Light configuration-Light_Function_F_28	0
IDE05145-ENG115525-Light configuration-Light_Function_F_29	0
IDE05145-ENG115082-Light configuration-Light_Function_F_3	0
IDE05145-ENG115544-Light configuration-Light_Function_F_30	0
IDE05145-ENG115563-Light configuration-Light_Function_F_31	0
IDE05145-ENG115582-Light configuration-Light_Function_F_32	0
IDE05145-ENG115601-Light configuration-Light_Function_F_33	0
IDE05145-ENG115620-Light configuration-Light_Function_F_34	0
IDE05145-ENG115101-Light configuration-Light_Function_F_4	0
IDE05145-ENG114984-Light configuration-Light_Function_F_5	0
IDE05145-ENG115122-Light configuration-Light_Function_F_6	0
IDE05145-ENG115141-Light configuration-Light_Function_F_7	0
IDE05145-ENG115160-Light configuration-Light_Function_F_8	0
IDE05145-ENG115179-Light configuration-Light_Function_F_9	0
IDE05145-ENG115028-Light configuration-Light_Function_G_0	0
IDE05145-ENG115047-Light configuration-Light_Function_G_1	0
IDE05145-ENG115009-Light configuration-Light_Function_G_10	0
IDE05145-ENG115203-Light configuration-Light_Function_G_11	0
IDE05145-ENG115222-Light configuration-Light_Function_G_12	0
IDE05145-ENG114968-Light configuration-Light_Function_G_13	0
IDE05145-ENG115243-Light configuration-Light_Function_G_14	0
IDE05145-ENG115262-Light configuration-Light_Function_G_15	0
IDE05145-ENG115281-Light configuration-Light_Function_G_16	0
IDE05145-ENG115300-Light configuration-Light_Function_G_17	0
IDE05145-ENG115319-Light configuration-Light_Function_G_18	0
IDE05145-ENG115338-Light configuration-Light_Function_G_19	0
IDE05145-ENG115066-Light configuration-Light_Function_G_2	0
IDE05145-ENG115357-Light configuration-Light_Function_G_20	0
IDE05145-ENG115376-Light configuration-Light_Function_G_21	0
IDE05145-ENG115395-Light configuration-Light_Function_G_22	0
IDE05145-ENG115414-Light configuration-Light_Function_G_23	0
IDE05145-ENG115433-Light configuration-Light_Function_G_24	0
IDE05145-ENG115452-Light configuration-Light_Function_G_25	0
IDE05145-ENG115471-Light configuration-Light_Function_G_26	0
IDE05145-ENG115490-Light configuration-Light_Function_G_27	0
IDE05145-ENG115509-Light configuration-Light_Function_G_28	0
IDE05145-ENG115528-Light configuration-Light_Function_G_29	0
IDE05145-ENG115085-Light configuration-Light_Function_G_3	0
IDE05145-ENG115547-Light configuration-Light_Function_G_30	0
IDE05145-ENG115566-Light configuration-Light_Function_G_31	0
IDE05145-ENG115585-Light configuration-Light_Function_G_32	0
IDE05145-ENG115604-Light configuration-Light_Function_G_33	0
IDE05145-ENG115623-Light configuration-Light_Function_G_34	0
IDE05145-ENG115104-Light configuration-Light_Function_G_4	0
IDE05145-ENG114987-Light configuration-Light_Function_G_5	0
IDE05145-ENG115125-Light configuration-Light_Function_G_6	0
IDE05145-ENG115144-Light configuration-Light_Function_G_7	0
IDE05145-ENG115163-Light configuration-Light_Function_G_8	0
IDE05145-ENG115182-Light configuration-Light_Function_G_9	0
IDE05145-ENG115029-Light configuration-Light_Function_H_0	0
IDE05145-ENG115048-Light configuration-Light_Function_H_1	0
IDE05145-ENG115010-Light configuration-Light_Function_H_10	0
IDE05145-ENG115204-Light configuration-Light_Function_H_11	0
IDE05145-ENG115223-Light configuration-Light_Function_H_12	0
IDE05145-ENG114969-Light configuration-Light_Function_H_13	0
IDE05145-ENG115244-Light configuration-Light_Function_H_14	0
IDE05145-ENG115263-Light configuration-Light_Function_H_15	0
IDE05145-ENG115282-Light configuration-Light_Function_H_16	0
IDE05145-ENG115301-Light configuration-Light_Function_H_17	0
IDE05145-ENG115320-Light configuration-Light_Function_H_18	0
IDE05145-ENG115339-Light configuration-Light_Function_H_19	0
IDE05145-ENG115067-Light configuration-Light_Function_H_2	0
IDE05145-ENG115358-Light configuration-Light_Function_H_20	0
IDE05145-ENG115377-Light configuration-Light_Function_H_21	0
IDE05145-ENG115396-Light configuration-Light_Function_H_22	0
IDE05145-ENG115415-Light configuration-Light_Function_H_23	0
IDE05145-ENG115434-Light configuration-Light_Function_H_24	0
IDE05145-ENG115453-Light configuration-Light_Function_H_25	0
IDE05145-ENG115472-Light configuration-Light_Function_H_26	0
IDE05145-ENG115491-Light configuration-Light_Function_H_27	0
IDE05145-ENG115510-Light configuration-Light_Function_H_28	0
IDE05145-ENG115529-Light configuration-Light_Function_H_29	0
IDE05145-ENG115086-Light configuration-Light_Function_H_3	0
IDE05145-ENG115548-Light configuration-Light_Function_H_30	0
IDE05145-ENG115567-Light configuration-Light_Function_H_31	0
IDE05145-ENG115586-Light configuration-Light_Function_H_32	0
IDE05145-ENG115605-Light configuration-Light_Function_H_33	0
IDE05145-ENG115624-Light configuration-Light_Function_H_34	0
IDE05145-ENG115105-Light configuration-Light_Function_H_4	0
IDE05145-ENG114988-Light configuration-Light_Function_H_5	0
IDE05145-ENG115126-Light configuration-Light_Function_H_6	0
IDE05145-ENG115145-Light configuration-Light_Function_H_7	0
IDE05145-ENG115164-Light configuration-Light_Function_H_8	0
IDE05145-ENG115183-Light configuration-Light_Function_H_9	0
IDE05145-ENG115013-Light configuration-Type_Of_Load_0	Blinkleuchten
IDE05145-ENG115032-Light configuration-Type_Of_Load_1	Blinkleuchten
IDE05145-ENG114995-Light configuration-Type_Of_Load_10	not active
IDE05145-ENG115188-Light configuration-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115207-Light configuration-Type_Of_Load_12	allgemeine Scheinwerfer
IDE05145-ENG114954-Light configuration-Type_Of_Load_13	allgemeine Scheinwerfer
IDE05145-ENG115228-Light configuration-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115247-Light configuration-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115266-Light configuration-Type_Of_Load_16	LED Blinkleuchten
IDE05145-ENG115285-Light configuration-Type_Of_Load_17	LED Blinkleuchten
IDE05145-ENG115304-Light configuration-Type_Of_Load_18	Blinkleuchten
IDE05145-ENG115323-Light configuration-Type_Of_Load_19	Blinkleuchten
IDE05145-ENG115051-Light configuration-Type_Of_Load_2	LED Tagfahrlichtmodul Signal
IDE05145-ENG115342-Light configuration-Type_Of_Load_20	Bremsleuchten
IDE05145-ENG115361-Light configuration-Type_Of_Load_21	Bremsleuchten
IDE05145-ENG115380-Light configuration-Type_Of_Load_22	LEDdritteBremsleuchte
IDE05145-ENG115399-Light configuration-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115418-Light configuration-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115437-Light configuration-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115456-Light configuration-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115475-Light configuration-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115494-Light configuration-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115513-Light configuration-Type_Of_Load_29	allgemeineGluehlampe12W
IDE05145-ENG115070-Light configuration-Type_Of_Load_3	LED Tagfahrlichtmodul Signal
IDE05145-ENG115532-Light configuration-Type_Of_Load_30	allgemeineGluehlampe12W
IDE05145-ENG115551-Light configuration-Type_Of_Load_31	not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32	not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33	not active
IDE05145-ENG115608-Light configuration-Type_Of_Load_34	not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG114973-Light configuration-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100,00%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration	0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts	0
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	No
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel	active
IDE08542-ENG115671-Access control 2-Regenschließen	not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	0 ms
IDE08786-ENG11105-Assistance light functions-Assistance_lighting_sensitivity_adjustable	Not Present
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC	55
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0	not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1	not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10	not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11	not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12	not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13	not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14	not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15	not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16	not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17	not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18	not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19	not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2	not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20	not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21	not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22	not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23	not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24	not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25	not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26	not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27	not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28	not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29	not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3	not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30	not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31	not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32	not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33	not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34	not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4	not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5	not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6	active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7	not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8	active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9	not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand	150_Ohm
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC	56
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0	not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1	not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10	not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11	not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12	not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13	not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14	not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15	not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16	not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17	not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18	not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19	not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2	not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20	not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21	not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22	not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23	not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24	not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25	not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26	not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27	not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28	not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29	not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3	not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30	not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31	not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32	not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33	not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34	not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4	not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5	not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6	not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7	active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8	not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9	active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand	150_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs	not active
IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung	Energy management
IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung	Energy management
IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit	0 min
IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit	24 s
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein	not active
MAS01490-IDE07474-Energy management-Adapting for energy management	Energy management active
MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement	not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter	closed
MAS08233-ENG126575-other-mute_mode_aktiv	not active
MAS08233-ENG125011-other-pa_Funktion_2aus3	not installed
ENG05956-Adaptation_theft_protection_2	not active
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.0 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.0 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.0 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.0 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.0 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.0 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.0 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.0 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.0 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.0 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.0 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.0 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.0 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.0 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.0 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.0 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.0 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.0 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.0 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.0 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.0 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.0 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.0 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.0 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.0 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.0 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.0 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.0 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16.0
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16.0
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100.0
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100.0
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100.0
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6.0
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6.0
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100.0
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100.0
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100.0
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	100.0 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	100.0 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	100.0 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	100.0 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	100.0 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.0 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100.0
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100.0
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100.0
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100.0
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6.0
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6.0
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100.0
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100.0
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.0 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.0 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.0 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.0 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.0 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.0 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100.0
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100.0
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100.0
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100.0
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6.0
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6.0
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100.0
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100.0
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.0 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.0 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.0 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.0 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.0 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.0 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.0 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5.0
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15.0
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40.0
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100.0
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0	100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0	0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0	maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0	maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0	maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0	0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0	0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0	14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0	34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0	Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0	Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0	not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0	not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0	not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0	not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0	not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0	not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0	not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0	Blinkleuchten
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10	0
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10	0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10	maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10	maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10	maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10	0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10	0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10	0
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10	0
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10	Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10	not active
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10	not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10	not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10	not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10	not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10	not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10	not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10	not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10	not active
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11	100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11	0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11	maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11	maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11	maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11	0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11	0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11	0
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11	0
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11	Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11	Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11	not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11	not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11	not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11	not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11	not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11	not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11	not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12	100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12	0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12	maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12	maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12	maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12	0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12	0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12	22
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12	38
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12	Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12	Nebellicht links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12	Abbiegelicht links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12	not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12	not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12	not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12	not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12	not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12	not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12	allgemeine Scheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13	100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13	0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13	maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13	maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13	maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13	0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13	0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13	23
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13	42
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13	Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13	Nebellicht rechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13	Abbiegelicht rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13	not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13	not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13	not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13	not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13	not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13	not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13	allgemeine Scheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15	100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15	0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15	maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15	maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15	maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15	0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15	0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15	0
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15	0
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15	Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15	SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15	not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15	not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15	not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15	not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15	not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15	not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15	not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16	100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16	0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16	maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16	maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16	maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16	0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16	0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16	0
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16	0
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16	Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16	Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16	not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16	not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16	not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16	not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16	not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16	not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16	not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16	LED Blinkleuchten
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17	100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17	0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17	maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17	maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17	maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17	0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17	0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17	0
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17	0
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17	Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17	Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17	not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17	not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17	not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17	not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17	not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17	not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17	not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17	LED Blinkleuchten
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18	100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18	0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18	maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18	maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18	maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18	0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18	0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18	16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18	8
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18	Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18	Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18	not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18	not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18	not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18	not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18	not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18	not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18	not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18	Blinkleuchten
ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19	100
ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19	0
ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19	maximize
ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19	maximize
ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19	maximize
ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19	0
ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19	0
ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19	18
ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19	18
ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19	Always
ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19	Blinken rechts Hellphase
ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19	not active
ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19	not active
ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19	not active
ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19	not active
ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19	not active
ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19	not active
ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19	not active
ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19	Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1	100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1	0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1	maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1	maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1	maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1	0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1	0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1	15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1	3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1	Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1	Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1	not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1	not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1	not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1	not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1	not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1	not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1	not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1	Blinkleuchten
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20	100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20	0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20	maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20	maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20	maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20	0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20	0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20	2B
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20	9
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20	Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20	Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20	not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20	not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20	not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20	not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20	not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20	not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20	not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20	Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21	100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21	0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21	maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21	maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21	maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21	0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21	0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21	2D
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21	19
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21	Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21	Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21	not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21	not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21	not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21	not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21	not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21	not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21	not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21	Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22	100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22	0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22	maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22	maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22	maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22	0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22	0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22	2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22	29
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22	Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22	Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22	not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22	not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22	not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22	not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22	not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22	not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22	not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22	LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23	60
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23	0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23	maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23	maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23	maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23	0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23	0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23	29
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23	0A
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23	Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23	Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23	Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23	not active
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23	not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23	not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23	not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23	not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23	not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24	60
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24	0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24	maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24	maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24	maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24	0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24	0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24	2A
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24	1A
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24	Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24	Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24	Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24	not active
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24	not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24	not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24	not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24	not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24	not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25	100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25	0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25	maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25	maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25	maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25	0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25	0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25	30
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25	28
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25	Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25	Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25	not active
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25	not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25	not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25	not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25	not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25	not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25	not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26	100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26	0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26	maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26	maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26	maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26	0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26	0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26	33
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26	2A
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26	Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26	NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26	not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26	not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26	not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26	not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26	not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26	not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26	not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27	100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27	0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27	maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27	maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27	maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27	0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27	0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27	8
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27	0
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27	Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27	Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27	not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27	not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27	not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27	not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27	not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27	not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27	not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28	100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28	0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28	maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28	maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28	maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28	0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28	0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28	34
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28	2B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28	Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28	Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28	not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28	not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28	not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28	not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28	not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28	not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28	not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29	100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29	0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29	maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29	maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29	maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29	0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29	0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29	1
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29	0
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29	Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29	Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29	not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29	not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29	not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29	not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29	not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29	not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29	not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29	allgemeineGluehlampe12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2	70
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2	30
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2	maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2	minimize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2	maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2	30
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2	0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2	0
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2	0
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2	Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2	Daytime running lights
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2	not active
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2	Parking light
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2	Parking light left
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2	Nebellicht links
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2	not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2	not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2	not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2	LED Tagfahrlichtmodul Signal
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30	126
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30	0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30	maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30	maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30	maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30	0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30	0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30	7
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30	0
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30	Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30	Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30	not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30	not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30	not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30	not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30	not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30	not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30	not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30	allgemeineGluehlampe12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31	0
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31	0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31	maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31	maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31	maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31	0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31	0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31	0
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31	0
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31	Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31	not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31	not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31	not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31	not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31	not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31	not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31	not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31	not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31	not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32	0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32	0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32	maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32	maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32	maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32	0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32	0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32	0
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32	0
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32	Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32	not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32	not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32	not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32	not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32	not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32	not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32	not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32	not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32	not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33	0
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33	0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33	maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33	maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33	maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33	0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33	0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33	0
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33	0
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33	Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33	not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33	not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33	not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33	not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33	not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33	not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33	not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33	not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33	not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34	0
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34	0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34	maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34	maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34	maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34	0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34	0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34	0
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34	0
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34	Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34	not active
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34	not active
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34	not active
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34	not active
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34	not active
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34	not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34	not active
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34	not active
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34	not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3	70
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3	30
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3	maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3	minimize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3	maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3	30
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3	0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3	0
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3	0
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3	Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3	Daytime running lights
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3	not active
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3	Parking light
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3	Parking light right
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3	Nebellicht rechts
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3	not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3	not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3	not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3	LED Tagfahrlichtmodul Signal
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4	127
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4	127
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4	maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4	maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4	maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4	0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4	0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4	49
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4	48
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4	Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4	Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4	Parking light
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4	Parking light left
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4	not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4	not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4	not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4	not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4	not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5	127
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5	127
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5	maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5	maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5	maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5	0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5	0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5	4B
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5	4C
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5	Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5	Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5	Parking light
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5	Parking light right
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5	not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5	not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5	not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5	not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5	not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6	127
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6	0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6	maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6	maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6	maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6	0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6	0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6	1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6	36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6	Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6	Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6	ComingHome LeavingHome
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6	not active
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6	not active
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6	not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6	not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6	not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6	not active
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7	127
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7	0
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7	maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7	maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7	maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7	0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7	0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7	1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7	40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7	Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7	Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7	ComingHome LeavingHome
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7	not active
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7	not active
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7	not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7	not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7	not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7	not active
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8	127
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8	0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8	maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8	maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7	maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8	0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8	0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8	1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8	37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8	Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8	Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8	Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8	not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8	not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8	not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8	not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8	not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8	not active
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9	127
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9	0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9	maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9	maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9	maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9	0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9	0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9	1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9	41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9	Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9	Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9	Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9	not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9	not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9	not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9	not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9	not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9	not active
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14	100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14	0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14	maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14	maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14	maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14	0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14	0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14	0
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14	0
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14	Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14	LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14	not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14	not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14	not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14	not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14	not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14	not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14	not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
ENG126648-MAS02526-LIN-Mirrormode-Activation	not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.0 %
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Elapsed Time: 02:23
;SW:6C0-937-089-D   HW:6C0-937-089 ---  Cent. Elect.
;Component:BCM PQ26 Hi4R H08 0094	Coding:00000A404253005B4F844000400F07080000590251010000000000000000
;EV_BCMA0	6002	EV_BCMA0_006.rod
;Monday	7	August	2017	18:14:49:11885
;VCDS Version: Release 17.1.3  Data version: 20170320 DS267.7
;VCID: 31464CF5600737C956-8064
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG130235-Production mode-Entry_control	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG130231-Production mode-Window_regulator_nr_1	not active
IDE00001-ENG130232-Production mode-Window_reversing_threshold	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10
IDE01268-ENG122992-Windshield wiper-Frontwischer Abtauposition	keine Abtaupostition
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG126573-Windshield wiper-Frontwischer_Serviceposition	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	not activated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	800 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	800 ms
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122991-Windshield wiper-Wischer stop bei Motorstart	kein Wischerstopp
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	active
IDE02152-Characteristics in production mode	2000 ms
IDE02200-Component protection showroom mode	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02269-ENG130230-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Auf_Befehl	not active
IDE02269-ENG130229-Acknowledgement signals-pa_quittungston_beim_zweiten_ZV_Zu_Befehl	not active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG126572-Rear Window Wiper-no_automativ_parking_after_kl15_on	not active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	not active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80,00%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80,00%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80,00%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.50 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	180 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	120 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken	active
IDE04923-ENG130187-Turn signal control-Blinkkontrolleuchte_fuer_Anhaenger	separate
IDE04923-ENG130192-Turn signal control-Freilaufendes_Warnblinken	not active
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG115854-Turn signal control-Komfortblinken_Blinkzyklen	5
IDE04923-ENG130186-Turn signal control-Signalprioritaet_fuer_Blinker	SMLS
IDE04923-ENG126568-Turn signal control-Sonderfunktionen_2	not enabled
IDE04923-ENG130191-Turn signal control-Warnblinken_bei_Verdeckentriegelung	not active
IDE04923-ENG130188-Turn signal control-Warnblinktastersuchbeleuchtung_Aktivierung	Always active
IDE04923-ENG130190-Turn signal control-Warnblinktastersuchbeleuchtung_Faktor	0.100 %
IDE04923-ENG130189-Turn signal control-Warnblinktastersuchbeleuchtung_Grundwert	3.0 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350.0 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350.0 km/h
IDE04924-ENG126566-Driving light and parking light-beidseitiges_dauerparklicht	active
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integrated
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG126567-Driving light and parking light-max_scheinwerfer_2limitieren	not active
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	255 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126565-Driving light and parking light-standlicht_aus_bei_kl_s_aus_s_kontakt	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	Not Present
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	ignition
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	0
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	0.0
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	not enabled
IDE04926-ENG126569-Comfort illumination-lho_aktiviert	not active
IDE04926-ENG126570-Comfort illumination-lho_zeit	0 s
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	0 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	not active
IDE04927-IDE01446-Window heater-Running time of heated front window	6 s (second)
IDE04927-ENG11110-Window heater-Abschalttemperatur_fuer_Frontscheibenheizung	170 °C
IDE04927-ENG11109-Window heater-Abschalttemperatur_fuer_Heckscheibenheizung	170 °C
IDE04927-ENG126613-Window heater-Aussenspiegelheizung	0 s (second)
IDE04927-ENG11108-Window heater-Heckscheibenheizung_Zeitwert	15 s (second)
IDE04927-ENG11107-Window heater-Temperaturabhaengige_Einschaltzeit_FSH	active
IDE04927-ENG11106-Window heater-Temperaturabhaengige_Einschaltzeit_HSH	active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	immidiat_driver_door_contact_thatcham
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	not active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115014-Light configuration-BAP_Bitposition_0	34
IDE05145-ENG115033-Light configuration-BAP_Bitposition_1	3E
IDE05145-ENG115186-Light configuration-BAP_Bitposition_10	0
IDE05145-ENG115189-Light configuration-BAP_Bitposition_11	0
IDE05145-ENG115208-Light configuration-BAP_Bitposition_12	38
IDE05145-ENG115226-Light configuration-BAP_Bitposition_13	42
IDE05145-ENG115229-Light configuration-BAP_Bitposition_14	0
IDE05145-ENG115248-Light configuration-BAP_Bitposition_15	0
IDE05145-ENG115267-Light configuration-BAP_Bitposition_16	0
IDE05145-ENG115286-Light configuration-BAP_Bitposition_17	0
IDE05145-ENG115305-Light configuration-BAP_Bitposition_18	8
IDE05145-ENG115324-Light configuration-BAP_Bitposition_19	18
IDE05145-ENG115052-Light configuration-BAP_Bitposition_2	0
IDE05145-ENG115343-Light configuration-BAP_Bitposition_20	9
IDE05145-ENG115362-Light configuration-BAP_Bitposition_21	19
IDE05145-ENG115381-Light configuration-BAP_Bitposition_22	29
IDE05145-ENG115400-Light configuration-BAP_Bitposition_23	0A
IDE05145-ENG115419-Light configuration-BAP_Bitposition_24	1A
IDE05145-ENG115438-Light configuration-BAP_Bitposition_25	28
IDE05145-ENG115457-Light configuration-BAP_Bitposition_26	2A
IDE05145-ENG115476-Light configuration-BAP_Bitposition_27	0
IDE05145-ENG115495-Light configuration-BAP_Bitposition_28	2B
IDE05145-ENG115514-Light configuration-BAP_Bitposition_29	0
IDE05145-ENG115071-Light configuration-BAP_Bitposition_3	0
IDE05145-ENG115533-Light configuration-BAP_Bitposition_30	0
IDE05145-ENG115552-Light configuration-BAP_Bitposition_31	0
IDE05145-ENG115571-Light configuration-BAP_Bitposition_32	0
IDE05145-ENG115590-Light configuration-BAP_Bitposition_33	0
IDE05145-ENG115609-Light configuration-BAP_Bitposition_34	0
IDE05145-ENG115090-Light configuration-BAP_Bitposition_4	48
IDE05145-ENG115108-Light configuration-BAP_Bitposition_5	4C
IDE05145-ENG115111-Light configuration-BAP_Bitposition_6	36
IDE05145-ENG115130-Light configuration-BAP_Bitposition_7	40
IDE05145-ENG115149-Light configuration-BAP_Bitposition_8	37
IDE05145-ENG115168-Light configuration-BAP_Bitposition_9	41
IDE05145-ENG115018-Light configuration-Dimming_AB_0	100
IDE05145-ENG115037-Light configuration-Dimming_AB_1	100
IDE05145-ENG114999-Light configuration-Dimming_AB_10	0
IDE05145-ENG115193-Light configuration-Dimming_AB_11	100
IDE05145-ENG115212-Light configuration-Dimming_AB_12	100
IDE05145-ENG114958-Light configuration-Dimming_AB_13	100
IDE05145-ENG115233-Light configuration-Dimming_AB_14	100
IDE05145-ENG115252-Light configuration-Dimming_AB_15	100
IDE05145-ENG115271-Light configuration-Dimming_AB_16	100
IDE05145-ENG115290-Light configuration-Dimming_AB_17	100
IDE05145-ENG115309-Light configuration-Dimming_AB_18	100
IDE05145-ENG115328-Light configuration-Dimming_AB_19	100
IDE05145-ENG115056-Light configuration-Dimming_AB_2	70
IDE05145-ENG115347-Light configuration-Dimming_AB_20	100
IDE05145-ENG115366-Light configuration-Dimming_AB_21	100
IDE05145-ENG115385-Light configuration-Dimming_AB_22	100
IDE05145-ENG115404-Light configuration-Dimming_AB_23	60
IDE05145-ENG115423-Light configuration-Dimming_AB_24	60
IDE05145-ENG115442-Light configuration-Dimming_AB_25	100
IDE05145-ENG115461-Light configuration-Dimming_AB_26	100
IDE05145-ENG115480-Light configuration-Dimming_AB_27	100
IDE05145-ENG115499-Light configuration-Dimming_AB_28	100
IDE05145-ENG115518-Light configuration-Dimming_AB_29	100
IDE05145-ENG115075-Light configuration-Dimming_AB_3	70
IDE05145-ENG115537-Light configuration-Dimming_AB_30	126
IDE05145-ENG115556-Light configuration-Dimming_AB_31	0
IDE05145-ENG115575-Light configuration-Dimming_AB_32	0
IDE05145-ENG115594-Light configuration-Dimming_AB_33	0
IDE05145-ENG115613-Light configuration-Dimming_AB_34	0
IDE05145-ENG115094-Light configuration-Dimming_AB_4	127
IDE05145-ENG114977-Light configuration-Dimming_AB_5	127
IDE05145-ENG115115-Light configuration-Dimming_AB_6	127
IDE05145-ENG115134-Light configuration-Dimming_AB_7	127
IDE05145-ENG115153-Light configuration-Dimming_AB_8	127
IDE05145-ENG115172-Light configuration-Dimming_AB_9	127
IDE05145-ENG115022-Light configuration-Dimming_CD_0	0
IDE05145-ENG115041-Light configuration-Dimming_CD_1	0
IDE05145-ENG115003-Light configuration-Dimming_CD_10	0
IDE05145-ENG115197-Light configuration-Dimming_CD_11	0
IDE05145-ENG115216-Light configuration-Dimming_CD_12	0
IDE05145-ENG114962-Light configuration-Dimming_CD_13	0
IDE05145-ENG115237-Light configuration-Dimming_CD_14	0
IDE05145-ENG115256-Light configuration-Dimming_CD_15	0
IDE05145-ENG115275-Light configuration-Dimming_CD_16	0
IDE05145-ENG115294-Light configuration-Dimming_CD_17	0
IDE05145-ENG115313-Light configuration-Dimming_CD_18	0
IDE05145-ENG115332-Light configuration-Dimming_CD_19	0
IDE05145-ENG115060-Light configuration-Dimming_CD_2	30
IDE05145-ENG115351-Light configuration-Dimming_CD_20	0
IDE05145-ENG115370-Light configuration-Dimming_CD_21	0
IDE05145-ENG115389-Light configuration-Dimming_CD_22	0
IDE05145-ENG115408-Light configuration-Dimming_CD_23	0
IDE05145-ENG115427-Light configuration-Dimming_CD_24	0
IDE05145-ENG115446-Light configuration-Dimming_CD_25	0
IDE05145-ENG115465-Light configuration-Dimming_CD_26	0
IDE05145-ENG115484-Light configuration-Dimming_CD_27	0
IDE05145-ENG115503-Light configuration-Dimming_CD_28	0
IDE05145-ENG115522-Light configuration-Dimming_CD_29	0
IDE05145-ENG115079-Light configuration-Dimming_CD_3	30
IDE05145-ENG115541-Light configuration-Dimming_CD_30	0
IDE05145-ENG115560-Light configuration-Dimming_CD_31	0
IDE05145-ENG115579-Light configuration-Dimming_CD_32	0
IDE05145-ENG115598-Light configuration-Dimming_CD_33	0
IDE05145-ENG115617-Light configuration-Dimming_CD_34	0
IDE05145-ENG115098-Light configuration-Dimming_CD_4	127
IDE05145-ENG114981-Light configuration-Dimming_CD_5	127
IDE05145-ENG115119-Light configuration-Dimming_CD_6	0
IDE05145-ENG115138-Light configuration-Dimming_CD_7	0
IDE05145-ENG115157-Light configuration-Dimming_CD_8	0
IDE05145-ENG115176-Light configuration-Dimming_CD_9	0
IDE05145-ENG115023-Light configuration-Dimming_Direction_CD_0	maximize
IDE05145-ENG115042-Light configuration-Dimming_Direction_CD_1	maximize
IDE05145-ENG115004-Light configuration-Dimming_Direction_CD_10	maximize
IDE05145-ENG115198-Light configuration-Dimming_Direction_CD_11	maximize
IDE05145-ENG115217-Light configuration-Dimming_Direction_CD_12	maximize
IDE05145-ENG114963-Light configuration-Dimming_Direction_CD_13	maximize
IDE05145-ENG115238-Light configuration-Dimming_Direction_CD_14	maximize
IDE05145-ENG115257-Light configuration-Dimming_Direction_CD_15	maximize
IDE05145-ENG115276-Light configuration-Dimming_Direction_CD_16	maximize
IDE05145-ENG115295-Light configuration-Dimming_Direction_CD_17	maximize
IDE05145-ENG115314-Light configuration-Dimming_Direction_CD_18	maximize
IDE05145-ENG115333-Light configuration-Dimming_Direction_CD_19	maximize
IDE05145-ENG115061-Light configuration-Dimming_Direction_CD_2	maximize
IDE05145-ENG115352-Light configuration-Dimming_Direction_CD_20	maximize
IDE05145-ENG115371-Light configuration-Dimming_Direction_CD_21	maximize
IDE05145-ENG115390-Light configuration-Dimming_Direction_CD_22	maximize
IDE05145-ENG115409-Light configuration-Dimming_Direction_CD_23	maximize
IDE05145-ENG115428-Light configuration-Dimming_Direction_CD_24	maximize
IDE05145-ENG115447-Light configuration-Dimming_Direction_CD_25	maximize
IDE05145-ENG115466-Light configuration-Dimming_Direction_CD_26	maximize
IDE05145-ENG115485-Light configuration-Dimming_Direction_CD_27	maximize
IDE05145-ENG115504-Light configuration-Dimming_Direction_CD_28	maximize
IDE05145-ENG115523-Light configuration-Dimming_Direction_CD_29	maximize
IDE05145-ENG115080-Light configuration-Dimming_Direction_CD_3	maximize
IDE05145-ENG115542-Light configuration-Dimming_Direction_CD_30	maximize
IDE05145-ENG115561-Light configuration-Dimming_Direction_CD_31	maximize
IDE05145-ENG115580-Light configuration-Dimming_Direction_CD_32	maximize
IDE05145-ENG115599-Light configuration-Dimming_Direction_CD_33	maximize
IDE05145-ENG115618-Light configuration-Dimming_Direction_CD_34	maximize
IDE05145-ENG115099-Light configuration-Dimming_Direction_CD_4	maximize
IDE05145-ENG114982-Light configuration-Dimming_Direction_CD_5	maximize
IDE05145-ENG115120-Light configuration-Dimming_Direction_CD_6	maximize
IDE05145-ENG115139-Light configuration-Dimming_Direction_CD_7	maximize
IDE05145-ENG115158-Light configuration-Dimming_Direction_CD_8	maximize
IDE05145-ENG115177-Light configuration-Dimming_Direction_CD_9	maximize
IDE05145-ENG115027-Light configuration-Dimming_Direction_EF_0	maximize
IDE05145-ENG115046-Light configuration-Dimming_Direction_EF_1	maximize
IDE05145-ENG115008-Light configuration-Dimming_Direction_EF_10	maximize
IDE05145-ENG115202-Light configuration-Dimming_Direction_EF_11	maximize
IDE05145-ENG115221-Light configuration-Dimming_Direction_EF_12	maximize
IDE05145-ENG114967-Light configuration-Dimming_Direction_EF_13	maximize
IDE05145-ENG115242-Light configuration-Dimming_Direction_EF_14	maximize
IDE05145-ENG115261-Light configuration-Dimming_Direction_EF_15	maximize
IDE05145-ENG115280-Light configuration-Dimming_Direction_EF_16	maximize
IDE05145-ENG115299-Light configuration-Dimming_Direction_EF_17	maximize
IDE05145-ENG115318-Light configuration-Dimming_Direction_EF_18	maximize
IDE05145-ENG115337-Light configuration-Dimming_Direction_EF_19	maximize
IDE05145-ENG115065-Light configuration-Dimming_Direction_EF_2	minimize
IDE05145-ENG115356-Light configuration-Dimming_Direction_EF_20	maximize
IDE05145-ENG115375-Light configuration-Dimming_Direction_EF_21	maximize
IDE05145-ENG115394-Light configuration-Dimming_Direction_EF_22	maximize
IDE05145-ENG115413-Light configuration-Dimming_Direction_EF_23	maximize
IDE05145-ENG115432-Light configuration-Dimming_Direction_EF_24	maximize
IDE05145-ENG115451-Light configuration-Dimming_Direction_EF_25	maximize
IDE05145-ENG115470-Light configuration-Dimming_Direction_EF_26	maximize
IDE05145-ENG115489-Light configuration-Dimming_Direction_EF_27	maximize
IDE05145-ENG115508-Light configuration-Dimming_Direction_EF_28	maximize
IDE05145-ENG115527-Light configuration-Dimming_Direction_EF_29	maximize
IDE05145-ENG115084-Light configuration-Dimming_Direction_EF_3	minimize
IDE05145-ENG115546-Light configuration-Dimming_Direction_EF_30	maximize
IDE05145-ENG115565-Light configuration-Dimming_Direction_EF_31	maximize
IDE05145-ENG115584-Light configuration-Dimming_Direction_EF_32	maximize
IDE05145-ENG115603-Light configuration-Dimming_Direction_EF_33	maximize
IDE05145-ENG115622-Light configuration-Dimming_Direction_EF_34	maximize
IDE05145-ENG115103-Light configuration-Dimming_Direction_EF_4	maximize
IDE05145-ENG114986-Light configuration-Dimming_Direction_EF_5	maximize
IDE05145-ENG115124-Light configuration-Dimming_Direction_EF_6	maximize
IDE05145-ENG115143-Light configuration-Dimming_Direction_EF_7	maximize
IDE05145-ENG115162-Light configuration-Dimming_Direction_EF_8	maximize
IDE05145-ENG115181-Light configuration-Dimming_Direction_EF_9	maximize
IDE05145-ENG115031-Light configuration-Dimming_Direction_GH_0	maximize
IDE05145-ENG115050-Light configuration-Dimming_Direction_GH_1	maximize
IDE05145-ENG115012-Light configuration-Dimming_Direction_GH_10	maximize
IDE05145-ENG115206-Light configuration-Dimming_Direction_GH_11	maximize
IDE05145-ENG115225-Light configuration-Dimming_Direction_GH_12	maximize
IDE05145-ENG114971-Light configuration-Dimming_Direction_GH_13	maximize
IDE05145-ENG115246-Light configuration-Dimming_Direction_GH_14	maximize
IDE05145-ENG115265-Light configuration-Dimming_Direction_GH_15	maximize
IDE05145-ENG115284-Light configuration-Dimming_Direction_GH_16	maximize
IDE05145-ENG115303-Light configuration-Dimming_Direction_GH_17	maximize
IDE05145-ENG115322-Light configuration-Dimming_Direction_GH_18	maximize
IDE05145-ENG115341-Light configuration-Dimming_Direction_GH_19	maximize
IDE05145-ENG115069-Light configuration-Dimming_Direction_GH_2	maximize
IDE05145-ENG115360-Light configuration-Dimming_Direction_GH_20	maximize
IDE05145-ENG115379-Light configuration-Dimming_Direction_GH_21	maximize
IDE05145-ENG115398-Light configuration-Dimming_Direction_GH_22	maximize
IDE05145-ENG115417-Light configuration-Dimming_Direction_GH_23	maximize
IDE05145-ENG115436-Light configuration-Dimming_Direction_GH_24	maximize
IDE05145-ENG115455-Light configuration-Dimming_Direction_GH_25	maximize
IDE05145-ENG115474-Light configuration-Dimming_Direction_GH_26	maximize
IDE05145-ENG115493-Light configuration-Dimming_Direction_GH_27	maximize
IDE05145-ENG115512-Light configuration-Dimming_Direction_GH_28	maximize
IDE05145-ENG115531-Light configuration-Dimming_Direction_GH_29	maximize
IDE05145-ENG115088-Light configuration-Dimming_Direction_GH_3	maximize
IDE05145-ENG115550-Light configuration-Dimming_Direction_GH_30	maximize
IDE05145-ENG115569-Light configuration-Dimming_Direction_GH_31	maximize
IDE05145-ENG115588-Light configuration-Dimming_Direction_GH_32	maximize
IDE05145-ENG115607-Light configuration-Dimming_Direction_GH_33	maximize
IDE05145-ENG115626-Light configuration-Dimming_Direction_GH_34	maximize
IDE05145-ENG115107-Light configuration-Dimming_Direction_GH_4	maximize
IDE05145-ENG114990-Light configuration-Dimming_Direction_GH_5	maximize
IDE05145-ENG115128-Light configuration-Dimming_Direction_GH_6	maximize
IDE05145-ENG115147-Light configuration-Dimming_Direction_GH_7	maximize
IDE05145-ENG115166-Light configuration-Dimming_Direction_GH_8	maximize
IDE05145-ENG115185-Light configuration-Dimming_Direction_GH_9	maximize
IDE05145-ENG115026-Light configuration-Dimming_EF_0	0
IDE05145-ENG115045-Light configuration-Dimming_EF_1	0
IDE05145-ENG115007-Light configuration-Dimming_EF_10	0
IDE05145-ENG115201-Light configuration-Dimming_EF_11	0
IDE05145-ENG115220-Light configuration-Dimming_EF_12	0
IDE05145-ENG114966-Light configuration-Dimming_EF_13	0
IDE05145-ENG115241-Light configuration-Dimming_EF_14	0
IDE05145-ENG115260-Light configuration-Dimming_EF_15	0
IDE05145-ENG115279-Light configuration-Dimming_EF_16	0
IDE05145-ENG115298-Light configuration-Dimming_EF_17	0
IDE05145-ENG115317-Light configuration-Dimming_EF_18	0
IDE05145-ENG115336-Light configuration-Dimming_EF_19	0
IDE05145-ENG115064-Light configuration-Dimming_EF_2	30
IDE05145-ENG115355-Light configuration-Dimming_EF_20	0
IDE05145-ENG115374-Light configuration-Dimming_EF_21	0
IDE05145-ENG115393-Light configuration-Dimming_EF_22	0
IDE05145-ENG115412-Light configuration-Dimming_EF_23	0
IDE05145-ENG115431-Light configuration-Dimming_EF_24	0
IDE05145-ENG115450-Light configuration-Dimming_EF_25	0
IDE05145-ENG115469-Light configuration-Dimming_EF_26	0
IDE05145-ENG115488-Light configuration-Dimming_EF_27	0
IDE05145-ENG115507-Light configuration-Dimming_EF_28	0
IDE05145-ENG115526-Light configuration-Dimming_EF_29	0
IDE05145-ENG115083-Light configuration-Dimming_EF_3	30
IDE05145-ENG115545-Light configuration-Dimming_EF_30	0
IDE05145-ENG115564-Light configuration-Dimming_EF_31	0
IDE05145-ENG115583-Light configuration-Dimming_EF_32	0
IDE05145-ENG115602-Light configuration-Dimming_EF_33	0
IDE05145-ENG115621-Light configuration-Dimming_EF_34	0
IDE05145-ENG115102-Light configuration-Dimming_EF_4	0
IDE05145-ENG114985-Light configuration-Dimming_EF_5	0
IDE05145-ENG115123-Light configuration-Dimming_EF_6	0
IDE05145-ENG115142-Light configuration-Dimming_EF_7	0
IDE05145-ENG115161-Light configuration-Dimming_EF_8	0
IDE05145-ENG115180-Light configuration-Dimming_EF_9	0
IDE05145-ENG115030-Light configuration-Dimming_GH_0	0
IDE05145-ENG115049-Light configuration-Dimming_GH_1	0
IDE05145-ENG115011-Light configuration-Dimming_GH_10	0
IDE05145-ENG115205-Light configuration-Dimming_GH_11	0
IDE05145-ENG115224-Light configuration-Dimming_GH_12	0
IDE05145-ENG114970-Light configuration-Dimming_GH_13	0
IDE05145-ENG115245-Light configuration-Dimming_GH_14	0
IDE05145-ENG115264-Light configuration-Dimming_GH_15	0
IDE05145-ENG115283-Light configuration-Dimming_GH_16	0
IDE05145-ENG115302-Light configuration-Dimming_GH_17	0
IDE05145-ENG115321-Light configuration-Dimming_GH_18	0
IDE05145-ENG115340-Light configuration-Dimming_GH_19	0
IDE05145-ENG115068-Light configuration-Dimming_GH_2	0
IDE05145-ENG115359-Light configuration-Dimming_GH_20	0
IDE05145-ENG115378-Light configuration-Dimming_GH_21	0
IDE05145-ENG115397-Light configuration-Dimming_GH_22	0
IDE05145-ENG115416-Light configuration-Dimming_GH_23	0
IDE05145-ENG115435-Light configuration-Dimming_GH_24	0
IDE05145-ENG115454-Light configuration-Dimming_GH_25	0
IDE05145-ENG115473-Light configuration-Dimming_GH_26	0
IDE05145-ENG115492-Light configuration-Dimming_GH_27	0
IDE05145-ENG115511-Light configuration-Dimming_GH_28	0
IDE05145-ENG115530-Light configuration-Dimming_GH_29	0
IDE05145-ENG115087-Light configuration-Dimming_GH_3	0
IDE05145-ENG115549-Light configuration-Dimming_GH_30	0
IDE05145-ENG115568-Light configuration-Dimming_GH_31	0
IDE05145-ENG115587-Light configuration-Dimming_GH_32	0
IDE05145-ENG115606-Light configuration-Dimming_GH_33	0
IDE05145-ENG115625-Light configuration-Dimming_GH_34	0
IDE05145-ENG115106-Light configuration-Dimming_GH_4	0
IDE05145-ENG114989-Light configuration-Dimming_GH_5	0
IDE05145-ENG115127-Light configuration-Dimming_GH_6	0
IDE05145-ENG115146-Light configuration-Dimming_GH_7	0
IDE05145-ENG115165-Light configuration-Dimming_GH_8	0
IDE05145-ENG115184-Light configuration-Dimming_GH_9	0
IDE05145-ENG115015-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_0	14
IDE05145-ENG115034-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_1	15
IDE05145-ENG115187-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_10	0
IDE05145-ENG115190-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_11	0
IDE05145-ENG115209-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_12	22
IDE05145-ENG115227-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_13	23
IDE05145-ENG115230-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_14	0
IDE05145-ENG115249-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_15	0
IDE05145-ENG115268-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_16	0
IDE05145-ENG115287-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_17	0
IDE05145-ENG115306-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_18	16
IDE05145-ENG115325-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_19	18
IDE05145-ENG115053-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_2	0
IDE05145-ENG115344-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_20	2B
IDE05145-ENG115363-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_21	2D
IDE05145-ENG115382-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_22	2C
IDE05145-ENG115401-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_23	29
IDE05145-ENG115420-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_24	2A
IDE05145-ENG115439-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_25	30
IDE05145-ENG115458-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_26	33
IDE05145-ENG115477-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_27	8
IDE05145-ENG115496-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_28	34
IDE05145-ENG115515-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_29	1
IDE05145-ENG115072-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_3	0
IDE05145-ENG115534-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_30	7
IDE05145-ENG115553-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_31	0
IDE05145-ENG115572-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_32	0
IDE05145-ENG115591-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_33	0
IDE05145-ENG115610-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_34	0
IDE05145-ENG115091-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_4	49
IDE05145-ENG115109-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_5	4B
IDE05145-ENG115112-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_6	1A
IDE05145-ENG115131-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_7	1B
IDE05145-ENG115150-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_8	1C
IDE05145-ENG115169-Light configuration-Fehlerort (mittleres Byte DTC-DFCC)_9	1D
IDE05145-ENG115019-Light configuration-Light_Control_HD_AB_0	Always
IDE05145-ENG115038-Light configuration-Light_Control_HD_AB_1	Always
IDE05145-ENG115000-Light configuration-Light_Control_HD_AB_10	Always
IDE05145-ENG115194-Light configuration-Light_Control_HD_AB_11	Always
IDE05145-ENG115213-Light configuration-Light_Control_HD_AB_12	Always
IDE05145-ENG114959-Light configuration-Light_Control_HD_AB_13	Always
IDE05145-ENG115234-Light configuration-Light_Control_HD_AB_14	Always
IDE05145-ENG115253-Light configuration-Light_Control_HD_AB_15	Always
IDE05145-ENG115272-Light configuration-Light_Control_HD_AB_16	Always
IDE05145-ENG115291-Light configuration-Light_Control_HD_AB_17	Always
IDE05145-ENG115310-Light configuration-Light_Control_HD_AB_18	Always
IDE05145-ENG115329-Light configuration-Light_Control_HD_AB_19	Always
IDE05145-ENG115057-Light configuration-Light_Control_HD_AB_2	Always
IDE05145-ENG115348-Light configuration-Light_Control_HD_AB_20	Always
IDE05145-ENG115367-Light configuration-Light_Control_HD_AB_21	Always
IDE05145-ENG115386-Light configuration-Light_Control_HD_AB_22	Always
IDE05145-ENG115405-Light configuration-Light_Control_HD_AB_23	Always
IDE05145-ENG115424-Light configuration-Light_Control_HD_AB_24	Always
IDE05145-ENG115443-Light configuration-Light_Control_HD_AB_25	Always
IDE05145-ENG115462-Light configuration-Light_Control_HD_AB_26	Always
IDE05145-ENG115481-Light configuration-Light_Control_HD_AB_27	Always
IDE05145-ENG115500-Light configuration-Light_Control_HD_AB_28	Always
IDE05145-ENG115520-Light configuration-Light_Control_HD_AB_29	Always
IDE05145-ENG115076-Light configuration-Light_Control_HD_AB_3	Always
IDE05145-ENG115538-Light configuration-Light_Control_HD_AB_30	Always
IDE05145-ENG115557-Light configuration-Light_Control_HD_AB_31	Always
IDE05145-ENG115576-Light configuration-Light_Control_HD_AB_32	Always
IDE05145-ENG115595-Light configuration-Light_Control_HD_AB_33	Always
IDE05145-ENG115614-Light configuration-Light_Control_HD_AB_34	Always
IDE05145-ENG115095-Light configuration-Light_Control_HD_AB_4	Always
IDE05145-ENG114978-Light configuration-Light_Control_HD_AB_5	Always
IDE05145-ENG115116-Light configuration-Light_Control_HD_AB_6	Always
IDE05145-ENG115135-Light configuration-Light_Control_HD_AB_7	Always
IDE05145-ENG115154-Light configuration-Light_Control_HD_AB_8	Always
IDE05145-ENG115173-Light configuration-Light_Control_HD_AB_9	Always
IDE05145-ENG115016-Light configuration-Light_Function_A_0	2
IDE05145-ENG115035-Light configuration-Light_Function_A_1	4
IDE05145-ENG114997-Light configuration-Light_Function_A_10	0
IDE05145-ENG115191-Light configuration-Light_Function_A_11	62
IDE05145-ENG115210-Light configuration-Light_Function_A_12	18
IDE05145-ENG114956-Light configuration-Light_Function_A_13	19
IDE05145-ENG115231-Light configuration-Light_Function_A_14	63
IDE05145-ENG115250-Light configuration-Light_Function_A_15	64
IDE05145-ENG115269-Light configuration-Light_Function_A_16	2
IDE05145-ENG115288-Light configuration-Light_Function_A_17	4
IDE05145-ENG115307-Light configuration-Light_Function_A_18	2
IDE05145-ENG115326-Light configuration-Light_Function_A_19	4
IDE05145-ENG115054-Light configuration-Light_Function_A_2	20
IDE05145-ENG115345-Light configuration-Light_Function_A_20	24
IDE05145-ENG115364-Light configuration-Light_Function_A_21	24
IDE05145-ENG115383-Light configuration-Light_Function_A_22	24
IDE05145-ENG115402-Light configuration-Light_Function_A_23	8
IDE05145-ENG115421-Light configuration-Light_Function_A_24	8
IDE05145-ENG115440-Light configuration-Light_Function_A_25	8
IDE05145-ENG115459-Light configuration-Light_Function_A_26	27
IDE05145-ENG115478-Light configuration-Light_Function_A_27	38
IDE05145-ENG115497-Light configuration-Light_Function_A_28	25
IDE05145-ENG115516-Light configuration-Light_Function_A_29	37
IDE05145-ENG115073-Light configuration-Light_Function_A_3	20
IDE05145-ENG115535-Light configuration-Light_Function_A_30	41
IDE05145-ENG115554-Light configuration-Light_Function_A_31	0
IDE05145-ENG115573-Light configuration-Light_Function_A_32	0
IDE05145-ENG115592-Light configuration-Light_Function_A_33	0
IDE05145-ENG115611-Light configuration-Light_Function_A_34	0
IDE05145-ENG115092-Light configuration-Light_Function_A_4	20
IDE05145-ENG114975-Light configuration-Light_Function_A_5	20
IDE05145-ENG115113-Light configuration-Light_Function_A_6	11
IDE05145-ENG115132-Light configuration-Light_Function_A_7	12
IDE05145-ENG115151-Light configuration-Light_Function_A_8	13
IDE05145-ENG115170-Light configuration-Light_Function_A_9	14
IDE05145-ENG115017-Light configuration-Light_Function_B_0	0
IDE05145-ENG115036-Light configuration-Light_Function_B_1	0
IDE05145-ENG114998-Light configuration-Light_Function_B_10	0
IDE05145-ENG115192-Light configuration-Light_Function_B_11	0
IDE05145-ENG115211-Light configuration-Light_Function_B_12	22
IDE05145-ENG114957-Light configuration-Light_Function_B_13	23
IDE05145-ENG115232-Light configuration-Light_Function_B_14	0
IDE05145-ENG115251-Light configuration-Light_Function_B_15	0
IDE05145-ENG115270-Light configuration-Light_Function_B_16	0
IDE05145-ENG115289-Light configuration-Light_Function_B_17	0
IDE05145-ENG115308-Light configuration-Light_Function_B_18	0
IDE05145-ENG115327-Light configuration-Light_Function_B_19	0
IDE05145-ENG115055-Light configuration-Light_Function_B_2	0
IDE05145-ENG115346-Light configuration-Light_Function_B_20	0
IDE05145-ENG115365-Light configuration-Light_Function_B_21	0
IDE05145-ENG115384-Light configuration-Light_Function_B_22	0
IDE05145-ENG115403-Light configuration-Light_Function_B_23	9
IDE05145-ENG115422-Light configuration-Light_Function_B_24	10
IDE05145-ENG115441-Light configuration-Light_Function_B_25	0
IDE05145-ENG115460-Light configuration-Light_Function_B_26	0
IDE05145-ENG115479-Light configuration-Light_Function_B_27	0
IDE05145-ENG115498-Light configuration-Light_Function_B_28	0
IDE05145-ENG115517-Light configuration-Light_Function_B_29	0
IDE05145-ENG115074-Light configuration-Light_Function_B_3	0
IDE05145-ENG115536-Light configuration-Light_Function_B_30	0
IDE05145-ENG115555-Light configuration-Light_Function_B_31	0
IDE05145-ENG115574-Light configuration-Light_Function_B_32	0
IDE05145-ENG115593-Light configuration-Light_Function_B_33	0
IDE05145-ENG115612-Light configuration-Light_Function_B_34	0
IDE05145-ENG115093-Light configuration-Light_Function_B_4	8
IDE05145-ENG114976-Light configuration-Light_Function_B_5	8
IDE05145-ENG115114-Light configuration-Light_Function_B_6	30
IDE05145-ENG115133-Light configuration-Light_Function_B_7	30
IDE05145-ENG115152-Light configuration-Light_Function_B_8	15
IDE05145-ENG115171-Light configuration-Light_Function_B_9	15
IDE05145-ENG115020-Light configuration-Light_Function_C_0	0
IDE05145-ENG115039-Light configuration-Light_Function_C_1	0
IDE05145-ENG115001-Light configuration-Light_Function_C_10	0
IDE05145-ENG115195-Light configuration-Light_Function_C_11	0
IDE05145-ENG115214-Light configuration-Light_Function_C_12	0
IDE05145-ENG114960-Light configuration-Light_Function_C_13	0
IDE05145-ENG115235-Light configuration-Light_Function_C_14	0
IDE05145-ENG115254-Light configuration-Light_Function_C_15	0
IDE05145-ENG115273-Light configuration-Light_Function_C_16	0
IDE05145-ENG115292-Light configuration-Light_Function_C_17	0
IDE05145-ENG115311-Light configuration-Light_Function_C_18	0
IDE05145-ENG115330-Light configuration-Light_Function_C_19	0
IDE05145-ENG115058-Light configuration-Light_Function_C_2	8
IDE05145-ENG115349-Light configuration-Light_Function_C_20	0
IDE05145-ENG115368-Light configuration-Light_Function_C_21	0
IDE05145-ENG115387-Light configuration-Light_Function_C_22	0
IDE05145-ENG115406-Light configuration-Light_Function_C_23	0
IDE05145-ENG115425-Light configuration-Light_Function_C_24	0
IDE05145-ENG115444-Light configuration-Light_Function_C_25	0
IDE05145-ENG115463-Light configuration-Light_Function_C_26	0
IDE05145-ENG115482-Light configuration-Light_Function_C_27	0
IDE05145-ENG115501-Light configuration-Light_Function_C_28	0
IDE05145-ENG115519-Light configuration-Light_Function_C_29	0
IDE05145-ENG115077-Light configuration-Light_Function_C_3	8
IDE05145-ENG115539-Light configuration-Light_Function_C_30	0
IDE05145-ENG115558-Light configuration-Light_Function_C_31	0
IDE05145-ENG115577-Light configuration-Light_Function_C_32	0
IDE05145-ENG115596-Light configuration-Light_Function_C_33	0
IDE05145-ENG115615-Light configuration-Light_Function_C_34	0
IDE05145-ENG115096-Light configuration-Light_Function_C_4	9
IDE05145-ENG114979-Light configuration-Light_Function_C_5	10
IDE05145-ENG115117-Light configuration-Light_Function_C_6	0
IDE05145-ENG115136-Light configuration-Light_Function_C_7	0
IDE05145-ENG115155-Light configuration-Light_Function_C_8	0
IDE05145-ENG115174-Light configuration-Light_Function_C_9	0
IDE05145-ENG115021-Light configuration-Light_Function_D_0	0
IDE05145-ENG115040-Light configuration-Light_Function_D_1	0
IDE05145-ENG115002-Light configuration-Light_Function_D_10	0
IDE05145-ENG115196-Light configuration-Light_Function_D_11	0
IDE05145-ENG115215-Light configuration-Light_Function_D_12	0
IDE05145-ENG114961-Light configuration-Light_Function_D_13	0
IDE05145-ENG115236-Light configuration-Light_Function_D_14	0
IDE05145-ENG115255-Light configuration-Light_Function_D_15	0
IDE05145-ENG115274-Light configuration-Light_Function_D_16	0
IDE05145-ENG115293-Light configuration-Light_Function_D_17	0
IDE05145-ENG115312-Light configuration-Light_Function_D_18	0
IDE05145-ENG115331-Light configuration-Light_Function_D_19	0
IDE05145-ENG115059-Light configuration-Light_Function_D_2	9
IDE05145-ENG115350-Light configuration-Light_Function_D_20	0
IDE05145-ENG115369-Light configuration-Light_Function_D_21	0
IDE05145-ENG115388-Light configuration-Light_Function_D_22	0
IDE05145-ENG115407-Light configuration-Light_Function_D_23	0
IDE05145-ENG115426-Light configuration-Light_Function_D_24	0
IDE05145-ENG115445-Light configuration-Light_Function_D_25	0
IDE05145-ENG115464-Light configuration-Light_Function_D_26	0
IDE05145-ENG115483-Light configuration-Light_Function_D_27	0
IDE05145-ENG115502-Light configuration-Light_Function_D_28	0
IDE05145-ENG115521-Light configuration-Light_Function_D_29	0
IDE05145-ENG115078-Light configuration-Light_Function_D_3	10
IDE05145-ENG115540-Light configuration-Light_Function_D_30	0
IDE05145-ENG115559-Light configuration-Light_Function_D_31	0
IDE05145-ENG115578-Light configuration-Light_Function_D_32	0
IDE05145-ENG115597-Light configuration-Light_Function_D_33	0
IDE05145-ENG115616-Light configuration-Light_Function_D_34	0
IDE05145-ENG115097-Light configuration-Light_Function_D_4	0
IDE05145-ENG114980-Light configuration-Light_Function_D_5	0
IDE05145-ENG115118-Light configuration-Light_Function_D_6	0
IDE05145-ENG115137-Light configuration-Light_Function_D_7	0
IDE05145-ENG115156-Light configuration-Light_Function_D_8	0
IDE05145-ENG115175-Light configuration-Light_Function_D_9	0
IDE05145-ENG115024-Light configuration-Light_Function_E_0	0
IDE05145-ENG115043-Light configuration-Light_Function_E_1	0
IDE05145-ENG115005-Light configuration-Light_Function_E_10	0
IDE05145-ENG115199-Light configuration-Light_Function_E_11	0
IDE05145-ENG115218-Light configuration-Light_Function_E_12	0
IDE05145-ENG114964-Light configuration-Light_Function_E_13	0
IDE05145-ENG115239-Light configuration-Light_Function_E_14	0
IDE05145-ENG115258-Light configuration-Light_Function_E_15	0
IDE05145-ENG115277-Light configuration-Light_Function_E_16	0
IDE05145-ENG115296-Light configuration-Light_Function_E_17	0
IDE05145-ENG115315-Light configuration-Light_Function_E_18	0
IDE05145-ENG115334-Light configuration-Light_Function_E_19	0
IDE05145-ENG115062-Light configuration-Light_Function_E_2	18
IDE05145-ENG115353-Light configuration-Light_Function_E_20	0
IDE05145-ENG115372-Light configuration-Light_Function_E_21	0
IDE05145-ENG115391-Light configuration-Light_Function_E_22	0
IDE05145-ENG115410-Light configuration-Light_Function_E_23	0
IDE05145-ENG115429-Light configuration-Light_Function_E_24	0
IDE05145-ENG115448-Light configuration-Light_Function_E_25	0
IDE05145-ENG115467-Light configuration-Light_Function_E_26	0
IDE05145-ENG115486-Light configuration-Light_Function_E_27	0
IDE05145-ENG115505-Light configuration-Light_Function_E_28	0
IDE05145-ENG115524-Light configuration-Light_Function_E_29	0
IDE05145-ENG115081-Light configuration-Light_Function_E_3	19
IDE05145-ENG115543-Light configuration-Light_Function_E_30	0
IDE05145-ENG115562-Light configuration-Light_Function_E_31	0
IDE05145-ENG115581-Light configuration-Light_Function_E_32	0
IDE05145-ENG115600-Light configuration-Light_Function_E_33	0
IDE05145-ENG115619-Light configuration-Light_Function_E_34	0
IDE05145-ENG115100-Light configuration-Light_Function_E_4	0
IDE05145-ENG114983-Light configuration-Light_Function_E_5	0
IDE05145-ENG115121-Light configuration-Light_Function_E_6	0
IDE05145-ENG115140-Light configuration-Light_Function_E_7	0
IDE05145-ENG115159-Light configuration-Light_Function_E_8	0
IDE05145-ENG115178-Light configuration-Light_Function_E_9	0
IDE05145-ENG115025-Light configuration-Light_Function_F_0	0
IDE05145-ENG115044-Light configuration-Light_Function_F_1	0
IDE05145-ENG115006-Light configuration-Light_Function_F_10	0
IDE05145-ENG115200-Light configuration-Light_Function_F_11	0
IDE05145-ENG115219-Light configuration-Light_Function_F_12	0
IDE05145-ENG114965-Light configuration-Light_Function_F_13	0
IDE05145-ENG115240-Light configuration-Light_Function_F_14	0
IDE05145-ENG115259-Light configuration-Light_Function_F_15	0
IDE05145-ENG115278-Light configuration-Light_Function_F_16	0
IDE05145-ENG115297-Light configuration-Light_Function_F_17	0
IDE05145-ENG115316-Light configuration-Light_Function_F_18	0
IDE05145-ENG115335-Light configuration-Light_Function_F_19	0
IDE05145-ENG115063-Light configuration-Light_Function_F_2	0
IDE05145-ENG115354-Light configuration-Light_Function_F_20	0
IDE05145-ENG115373-Light configuration-Light_Function_F_21	0
IDE05145-ENG115392-Light configuration-Light_Function_F_22	0
IDE05145-ENG115411-Light configuration-Light_Function_F_23	0
IDE05145-ENG115430-Light configuration-Light_Function_F_24	0
IDE05145-ENG115449-Light configuration-Light_Function_F_25	0
IDE05145-ENG115468-Light configuration-Light_Function_F_26	0
IDE05145-ENG115487-Light configuration-Light_Function_F_27	0
IDE05145-ENG115506-Light configuration-Light_Function_F_28	0
IDE05145-ENG115525-Light configuration-Light_Function_F_29	0
IDE05145-ENG115082-Light configuration-Light_Function_F_3	0
IDE05145-ENG115544-Light configuration-Light_Function_F_30	0
IDE05145-ENG115563-Light configuration-Light_Function_F_31	0
IDE05145-ENG115582-Light configuration-Light_Function_F_32	0
IDE05145-ENG115601-Light configuration-Light_Function_F_33	0
IDE05145-ENG115620-Light configuration-Light_Function_F_34	0
IDE05145-ENG115101-Light configuration-Light_Function_F_4	0
IDE05145-ENG114984-Light configuration-Light_Function_F_5	0
IDE05145-ENG115122-Light configuration-Light_Function_F_6	0
IDE05145-ENG115141-Light configuration-Light_Function_F_7	0
IDE05145-ENG115160-Light configuration-Light_Function_F_8	0
IDE05145-ENG115179-Light configuration-Light_Function_F_9	0
IDE05145-ENG115028-Light configuration-Light_Function_G_0	0
IDE05145-ENG115047-Light configuration-Light_Function_G_1	0
IDE05145-ENG115009-Light configuration-Light_Function_G_10	0
IDE05145-ENG115203-Light configuration-Light_Function_G_11	0
IDE05145-ENG115222-Light configuration-Light_Function_G_12	0
IDE05145-ENG114968-Light configuration-Light_Function_G_13	0
IDE05145-ENG115243-Light configuration-Light_Function_G_14	0
IDE05145-ENG115262-Light configuration-Light_Function_G_15	0
IDE05145-ENG115281-Light configuration-Light_Function_G_16	0
IDE05145-ENG115300-Light configuration-Light_Function_G_17	0
IDE05145-ENG115319-Light configuration-Light_Function_G_18	0
IDE05145-ENG115338-Light configuration-Light_Function_G_19	0
IDE05145-ENG115066-Light configuration-Light_Function_G_2	0
IDE05145-ENG115357-Light configuration-Light_Function_G_20	0
IDE05145-ENG115376-Light configuration-Light_Function_G_21	0
IDE05145-ENG115395-Light configuration-Light_Function_G_22	0
IDE05145-ENG115414-Light configuration-Light_Function_G_23	0
IDE05145-ENG115433-Light configuration-Light_Function_G_24	0
IDE05145-ENG115452-Light configuration-Light_Function_G_25	0
IDE05145-ENG115471-Light configuration-Light_Function_G_26	0
IDE05145-ENG115490-Light configuration-Light_Function_G_27	0
IDE05145-ENG115509-Light configuration-Light_Function_G_28	0
IDE05145-ENG115528-Light configuration-Light_Function_G_29	0
IDE05145-ENG115085-Light configuration-Light_Function_G_3	0
IDE05145-ENG115547-Light configuration-Light_Function_G_30	0
IDE05145-ENG115566-Light configuration-Light_Function_G_31	0
IDE05145-ENG115585-Light configuration-Light_Function_G_32	0
IDE05145-ENG115604-Light configuration-Light_Function_G_33	0
IDE05145-ENG115623-Light configuration-Light_Function_G_34	0
IDE05145-ENG115104-Light configuration-Light_Function_G_4	0
IDE05145-ENG114987-Light configuration-Light_Function_G_5	0
IDE05145-ENG115125-Light configuration-Light_Function_G_6	0
IDE05145-ENG115144-Light configuration-Light_Function_G_7	0
IDE05145-ENG115163-Light configuration-Light_Function_G_8	0
IDE05145-ENG115182-Light configuration-Light_Function_G_9	0
IDE05145-ENG115029-Light configuration-Light_Function_H_0	0
IDE05145-ENG115048-Light configuration-Light_Function_H_1	0
IDE05145-ENG115010-Light configuration-Light_Function_H_10	0
IDE05145-ENG115204-Light configuration-Light_Function_H_11	0
IDE05145-ENG115223-Light configuration-Light_Function_H_12	0
IDE05145-ENG114969-Light configuration-Light_Function_H_13	0
IDE05145-ENG115244-Light configuration-Light_Function_H_14	0
IDE05145-ENG115263-Light configuration-Light_Function_H_15	0
IDE05145-ENG115282-Light configuration-Light_Function_H_16	0
IDE05145-ENG115301-Light configuration-Light_Function_H_17	0
IDE05145-ENG115320-Light configuration-Light_Function_H_18	0
IDE05145-ENG115339-Light configuration-Light_Function_H_19	0
IDE05145-ENG115067-Light configuration-Light_Function_H_2	0
IDE05145-ENG115358-Light configuration-Light_Function_H_20	0
IDE05145-ENG115377-Light configuration-Light_Function_H_21	0
IDE05145-ENG115396-Light configuration-Light_Function_H_22	0
IDE05145-ENG115415-Light configuration-Light_Function_H_23	0
IDE05145-ENG115434-Light configuration-Light_Function_H_24	0
IDE05145-ENG115453-Light configuration-Light_Function_H_25	0
IDE05145-ENG115472-Light configuration-Light_Function_H_26	0
IDE05145-ENG115491-Light configuration-Light_Function_H_27	0
IDE05145-ENG115510-Light configuration-Light_Function_H_28	0
IDE05145-ENG115529-Light configuration-Light_Function_H_29	0
IDE05145-ENG115086-Light configuration-Light_Function_H_3	0
IDE05145-ENG115548-Light configuration-Light_Function_H_30	0
IDE05145-ENG115567-Light configuration-Light_Function_H_31	0
IDE05145-ENG115586-Light configuration-Light_Function_H_32	0
IDE05145-ENG115605-Light configuration-Light_Function_H_33	0
IDE05145-ENG115624-Light configuration-Light_Function_H_34	0
IDE05145-ENG115105-Light configuration-Light_Function_H_4	0
IDE05145-ENG114988-Light configuration-Light_Function_H_5	0
IDE05145-ENG115126-Light configuration-Light_Function_H_6	0
IDE05145-ENG115145-Light configuration-Light_Function_H_7	0
IDE05145-ENG115164-Light configuration-Light_Function_H_8	0
IDE05145-ENG115183-Light configuration-Light_Function_H_9	0
IDE05145-ENG115013-Light configuration-Type_Of_Load_0	Blinkleuchten
IDE05145-ENG115032-Light configuration-Type_Of_Load_1	Blinkleuchten
IDE05145-ENG114995-Light configuration-Type_Of_Load_10	not active
IDE05145-ENG115188-Light configuration-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115207-Light configuration-Type_Of_Load_12	allgemeine Scheinwerfer
IDE05145-ENG114954-Light configuration-Type_Of_Load_13	allgemeine Scheinwerfer
IDE05145-ENG115228-Light configuration-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115247-Light configuration-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115266-Light configuration-Type_Of_Load_16	LED Blinkleuchten
IDE05145-ENG115285-Light configuration-Type_Of_Load_17	LED Blinkleuchten
IDE05145-ENG115304-Light configuration-Type_Of_Load_18	Blinkleuchten
IDE05145-ENG115323-Light configuration-Type_Of_Load_19	Blinkleuchten
IDE05145-ENG115051-Light configuration-Type_Of_Load_2	LED Tagfahrlichtmodul Signal
IDE05145-ENG115342-Light configuration-Type_Of_Load_20	Bremsleuchten
IDE05145-ENG115361-Light configuration-Type_Of_Load_21	Bremsleuchten
IDE05145-ENG115380-Light configuration-Type_Of_Load_22	LEDdritteBremsleuchte
IDE05145-ENG115399-Light configuration-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115418-Light configuration-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
IDE05145-ENG115437-Light configuration-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG115456-Light configuration-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115475-Light configuration-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
IDE05145-ENG115494-Light configuration-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
IDE05145-ENG115513-Light configuration-Type_Of_Load_29	allgemeineGluehlampe12W
IDE05145-ENG115070-Light configuration-Type_Of_Load_3	LED Tagfahrlichtmodul Signal
IDE05145-ENG115532-Light configuration-Type_Of_Load_30	allgemeineGluehlampe12W
IDE05145-ENG115551-Light configuration-Type_Of_Load_31	not active
IDE05145-ENG115570-Light configuration-Type_Of_Load_32	not active
IDE05145-ENG115589-Light configuration-Type_Of_Load_33	not active
IDE05145-ENG115608-Light configuration-Type_Of_Load_34	not active
IDE05145-ENG115089-Light configuration-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose
IDE05145-ENG114973-Light configuration-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	not active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100,00%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	active
IDE07007-ENG115783-A/C heater function via remote control-Remote_Start_Duration	0 min
IDE07007-ENG126614-A/C heater function via remote control-valid_remote_starts	0
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG116649-Access control 2-Freigabenachlauf FH bei Tueroeffnen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	not active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	No
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	not active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	not active
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG125658-Access control 2-Profilfunktion für Anklappung der Außenspiegel	active
IDE08542-ENG115671-Access control 2-Regenschließen	not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	Open
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	active
IDE08542-ENG126612-Access control 2-Spiegelanklappung geschwindigkeitsabhängig	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	0 ms
IDE08786-ENG11105-Assistance light functions-Assistance_lighting_sensitivity_adjustable	Not Present
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE10286-ENG127071-Configuration of light collective diagnostic line 1: instance 1-DTCDFCC	55
IDE10286-ENG130193-Configuration of light collective diagnostic line 1: instance 1-Leuchte_0	not active
IDE10286-ENG130194-Configuration of light collective diagnostic line 1: instance 1-Leuchte_1	not active
IDE10286-ENG130203-Configuration of light collective diagnostic line 1: instance 1-Leuchte_10	not active
IDE10286-ENG130204-Configuration of light collective diagnostic line 1: instance 1-Leuchte_11	not active
IDE10286-ENG130205-Configuration of light collective diagnostic line 1: instance 1-Leuchte_12	not active
IDE10286-ENG130206-Configuration of light collective diagnostic line 1: instance 1-Leuchte_13	not active
IDE10286-ENG130207-Configuration of light collective diagnostic line 1: instance 1-Leuchte_14	not active
IDE10286-ENG130208-Configuration of light collective diagnostic line 1: instance 1-Leuchte_15	not active
IDE10286-ENG130209-Configuration of light collective diagnostic line 1: instance 1-Leuchte_16	not active
IDE10286-ENG130210-Configuration of light collective diagnostic line 1: instance 1-Leuchte_17	not active
IDE10286-ENG130211-Configuration of light collective diagnostic line 1: instance 1-Leuchte_18	not active
IDE10286-ENG130212-Configuration of light collective diagnostic line 1: instance 1-Leuchte_19	not active
IDE10286-ENG130195-Configuration of light collective diagnostic line 1: instance 1-Leuchte_2	not active
IDE10286-ENG130213-Configuration of light collective diagnostic line 1: instance 1-Leuchte_20	not active
IDE10286-ENG130214-Configuration of light collective diagnostic line 1: instance 1-Leuchte_21	not active
IDE10286-ENG130215-Configuration of light collective diagnostic line 1: instance 1-Leuchte_22	not active
IDE10286-ENG130216-Configuration of light collective diagnostic line 1: instance 1-Leuchte_23	not active
IDE10286-ENG130217-Configuration of light collective diagnostic line 1: instance 1-Leuchte_24	not active
IDE10286-ENG130218-Configuration of light collective diagnostic line 1: instance 1-Leuchte_25	not active
IDE10286-ENG130219-Configuration of light collective diagnostic line 1: instance 1-Leuchte_26	not active
IDE10286-ENG130220-Configuration of light collective diagnostic line 1: instance 1-Leuchte_27	not active
IDE10286-ENG130221-Configuration of light collective diagnostic line 1: instance 1-Leuchte_28	not active
IDE10286-ENG130222-Configuration of light collective diagnostic line 1: instance 1-Leuchte_29	not active
IDE10286-ENG130196-Configuration of light collective diagnostic line 1: instance 1-Leuchte_3	not active
IDE10286-ENG130223-Configuration of light collective diagnostic line 1: instance 1-Leuchte_30	not active
IDE10286-ENG130224-Configuration of light collective diagnostic line 1: instance 1-Leuchte_31	not active
IDE10286-ENG130225-Configuration of light collective diagnostic line 1: instance 1-Leuchte_32	not active
IDE10286-ENG130226-Configuration of light collective diagnostic line 1: instance 1-Leuchte_33	not active
IDE10286-ENG130227-Configuration of light collective diagnostic line 1: instance 1-Leuchte_34	not active
IDE10286-ENG130197-Configuration of light collective diagnostic line 1: instance 1-Leuchte_4	not active
IDE10286-ENG130198-Configuration of light collective diagnostic line 1: instance 1-Leuchte_5	not active
IDE10286-ENG130199-Configuration of light collective diagnostic line 1: instance 1-Leuchte_6	active
IDE10286-ENG130200-Configuration of light collective diagnostic line 1: instance 1-Leuchte_7	not active
IDE10286-ENG130201-Configuration of light collective diagnostic line 1: instance 1-Leuchte_8	active
IDE10286-ENG130202-Configuration of light collective diagnostic line 1: instance 1-Leuchte_9	not active
IDE10286-ENG127072-Configuration of light collective diagnostic line 1: instance 1-Wiederstand	150_Ohm
IDE10288-ENG127071-Configuration of light collective diagnostic line 2: instance 1-DTCDFCC	56
IDE10288-ENG130193-Configuration of light collective diagnostic line 2: instance 1-Leuchte_0	not active
IDE10288-ENG130194-Configuration of light collective diagnostic line 2: instance 1-Leuchte_1	not active
IDE10288-ENG130203-Configuration of light collective diagnostic line 2: instance 1-Leuchte_10	not active
IDE10288-ENG130204-Configuration of light collective diagnostic line 2: instance 1-Leuchte_11	not active
IDE10288-ENG130205-Configuration of light collective diagnostic line 2: instance 1-Leuchte_12	not active
IDE10288-ENG130206-Configuration of light collective diagnostic line 2: instance 1-Leuchte_13	not active
IDE10288-ENG130207-Configuration of light collective diagnostic line 2: instance 1-Leuchte_14	not active
IDE10288-ENG130208-Configuration of light collective diagnostic line 2: instance 1-Leuchte_15	not active
IDE10288-ENG130209-Configuration of light collective diagnostic line 2: instance 1-Leuchte_16	not active
IDE10288-ENG130210-Configuration of light collective diagnostic line 2: instance 1-Leuchte_17	not active
IDE10288-ENG130211-Configuration of light collective diagnostic line 2: instance 1-Leuchte_18	not active
IDE10288-ENG130212-Configuration of light collective diagnostic line 2: instance 1-Leuchte_19	not active
IDE10288-ENG130195-Configuration of light collective diagnostic line 2: instance 1-Leuchte_2	not active
IDE10288-ENG130213-Configuration of light collective diagnostic line 2: instance 1-Leuchte_20	not active
IDE10288-ENG130214-Configuration of light collective diagnostic line 2: instance 1-Leuchte_21	not active
IDE10288-ENG130215-Configuration of light collective diagnostic line 2: instance 1-Leuchte_22	not active
IDE10288-ENG130216-Configuration of light collective diagnostic line 2: instance 1-Leuchte_23	not active
IDE10288-ENG130217-Configuration of light collective diagnostic line 2: instance 1-Leuchte_24	not active
IDE10288-ENG130218-Configuration of light collective diagnostic line 2: instance 1-Leuchte_25	not active
IDE10288-ENG130219-Configuration of light collective diagnostic line 2: instance 1-Leuchte_26	not active
IDE10288-ENG130220-Configuration of light collective diagnostic line 2: instance 1-Leuchte_27	not active
IDE10288-ENG130221-Configuration of light collective diagnostic line 2: instance 1-Leuchte_28	not active
IDE10288-ENG130222-Configuration of light collective diagnostic line 2: instance 1-Leuchte_29	not active
IDE10288-ENG130196-Configuration of light collective diagnostic line 2: instance 1-Leuchte_3	not active
IDE10288-ENG130223-Configuration of light collective diagnostic line 2: instance 1-Leuchte_30	not active
IDE10288-ENG130224-Configuration of light collective diagnostic line 2: instance 1-Leuchte_31	not active
IDE10288-ENG130225-Configuration of light collective diagnostic line 2: instance 1-Leuchte_32	not active
IDE10288-ENG130226-Configuration of light collective diagnostic line 2: instance 1-Leuchte_33	not active
IDE10288-ENG130227-Configuration of light collective diagnostic line 2: instance 1-Leuchte_34	not active
IDE10288-ENG130197-Configuration of light collective diagnostic line 2: instance 1-Leuchte_4	not active
IDE10288-ENG130198-Configuration of light collective diagnostic line 2: instance 1-Leuchte_5	not active
IDE10288-ENG130199-Configuration of light collective diagnostic line 2: instance 1-Leuchte_6	not active
IDE10288-ENG130200-Configuration of light collective diagnostic line 2: instance 1-Leuchte_7	active
IDE10288-ENG130201-Configuration of light collective diagnostic line 2: instance 1-Leuchte_8	not active
IDE10288-ENG130202-Configuration of light collective diagnostic line 2: instance 1-Leuchte_9	active
IDE10288-ENG127072-Configuration of light collective diagnostic line 2: instance 1-Wiederstand	150_Ohm
IDE11421-ENG116719-Leaving concept-Bedingungen zur Beendigung des Standlichtnachlaufs	not active
IDE11421-ENG02309-Leaving concept-Bedingungen zur Parklichtbegrenzung	Energy management
IDE11421-ENG02308-Leaving concept-Bedingungen zur Standlichtbegrenzung	Energy management
IDE11421-ENG05962-Leaving concept-Faktor fuer Verfuegbarkeitstimer	Faktor fuer x5 Minuten
IDE11421-ENG116720-Leaving concept-Standlicht-Nachlaufzeit	0 min
IDE11421-ENG05963-Leaving concept-Standlicht-Verfuegbarkeit	24 s
IDE11421-ENG126843-Leaving concept-ZV verriegeln bei Klemme 15 Ein	not active
MAS01490-IDE07474-Energy management-Adapting for energy management	Energy management active
MAS01490-MAS12921-Energy management-Prädiktives Energiemanagement	not active
MAS08233-ENG126574-other-auspraegung_Bremsfluessigkeitsschalter	closed
MAS08233-ENG126575-other-mute_mode_aktiv	not active
MAS08233-ENG125011-other-pa_Funktion_2aus3	not installed
ENG05956-Adaptation_theft_protection_2	not active
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.0 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.0 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.0 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.0 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.0 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.0 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.0 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.0 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.0 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.0 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.0 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.0 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.0 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.0 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.0 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.0 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.0 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.0 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.0 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.0 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.0 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.0 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.0 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.0 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.0 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.0 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.0 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.0 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16.0
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16.0
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100.0
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100.0
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100.0
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6.0
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6.0
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100.0
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100.0
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100.0
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	100.0 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	100.0 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	100.0 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	100.0 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	100.0 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.0 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100.0
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100.0
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100.0
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100.0
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6.0
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6.0
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100.0
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100.0
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.0 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.0 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.0 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.0 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.0 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.0 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100.0
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100.0
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100.0
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100.0
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6.0
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6.0
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100.0
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100.0
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.0 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.0 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.0 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.0 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.0 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.0 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.0 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5.0
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15.0
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	40.0
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100.0
ENG124861-ENG115018-Leuchte 0 BLK VL B35-Dimming_AB_0	100
ENG124861-ENG115022-Leuchte 0 BLK VL B35-Dimming_CD_0	0
ENG124861-ENG115023-Leuchte 0 BLK VL B35-Dimming_Direction_CD_0	maximize
ENG124861-ENG115027-Leuchte 0 BLK VL B35-Dimming_Direction_EF_0	maximize
ENG124861-ENG115031-Leuchte 0 BLK VL B35-Dimming_Direction_GH_0	maximize
ENG124861-ENG115026-Leuchte 0 BLK VL B35-Dimming_EF_0	0
ENG124861-ENG115030-Leuchte 0 BLK VL B35-Dimming_GH_0	0
ENG124861-ENG126576-Leuchte 0 BLK VL B35-Fehlerort_mittleres_Byte_DTC-DFCC_0	14
ENG124861-ENG115751-Leuchte 0 BLK VL B35-Lampendefektbit_Position_0	34
ENG124861-ENG115019-Leuchte 0 BLK VL B35-Light_Control_HD_AB_0	Always
ENG124861-ENG115016-Leuchte 0 BLK VL B35-Light_Function_A_0	Blinken links Hellphase
ENG124861-ENG115017-Leuchte 0 BLK VL B35-Light_Function_B_0	not active
ENG124861-ENG115020-Leuchte 0 BLK VL B35-Light_Function_C_0	not active
ENG124861-ENG115021-Leuchte 0 BLK VL B35-Light_Function_D_0	not active
ENG124861-ENG115024-Leuchte 0 BLK VL B35-Light_Function_E_0	not active
ENG124861-ENG115025-Leuchte 0 BLK VL B35-Light_Function_F_0	not active
ENG124861-ENG115028-Leuchte 0 BLK VL B35-Light_Function_G_0	not active
ENG124861-ENG115029-Leuchte 0 BLK VL B35-Light_Function_H_0	not active
ENG124861-ENG115013-Leuchte 0 BLK VL B35-Type_Of_Load_0	Blinkleuchten
ENG124871-ENG114999-Leuchte10SHUTTER LRB45-Dimming_AB_10	0
ENG124871-ENG115003-Leuchte10SHUTTER LRB45-Dimming_CD_10	0
ENG124871-ENG115004-Leuchte10SHUTTER LRB45-Dimming_Direction_CD_10	maximize
ENG124871-ENG115008-Leuchte10SHUTTER LRB45-Dimming_Direction_EF_10	maximize
ENG124871-ENG115012-Leuchte10SHUTTER LRB45-Dimming_Direction_GH_10	maximize
ENG124871-ENG115007-Leuchte10SHUTTER LRB45-Dimming_EF_10	0
ENG124871-ENG115011-Leuchte10SHUTTER LRB45-Dimming_GH_10	0
ENG124871-ENG126585-Leuchte10SHUTTER LRB45-Fehlerort_mittleres_Byte_DTC-DFCC_10	0
ENG124871-ENG114996-Leuchte10SHUTTER LRB45-Lampendefektbit_Position_10	0
ENG124871-ENG115000-Leuchte10SHUTTER LRB45-Light_Control_HD_AB_10	Always
ENG124871-ENG114997-Leuchte10SHUTTER LRB45-Light_Function_A_10	not active
ENG124871-ENG114998-Leuchte10SHUTTER LRB45-Light_Function_B_10	not active
ENG124871-ENG115001-Leuchte10SHUTTER LRB45-Light_Function_C_10	not active
ENG124871-ENG115002-Leuchte10SHUTTER LRB45-Light_Function_D_10	not active
ENG124871-ENG115005-Leuchte10SHUTTER LRB45-Light_Function_E_10	not active
ENG124871-ENG115006-Leuchte10SHUTTER LRB45-Light_Function_F_10	not active
ENG124871-ENG115009-Leuchte10SHUTTER LRB45-Light_Function_G_10	not active
ENG124871-ENG115010-Leuchte10SHUTTER LRB45-Light_Function_H_10	not active
ENG124871-ENG114995-Leuchte10SHUTTER LRB45-Type_Of_Load_10	not active
ENG124872-ENG115193-Leuchte11WARNBLK TASTERC54-Dimming_AB_11	100
ENG124872-ENG115197-Leuchte11WARNBLK TASTERC54-Dimming_CD_11	0
ENG124872-ENG115198-Leuchte11WARNBLK TASTERC54-Dimming_Direction_CD_11	maximize
ENG124872-ENG115202-Leuchte11WARNBLK TASTERC54-Dimming_Direction_EF_11	maximize
ENG124872-ENG115206-Leuchte11WARNBLK TASTERC54-Dimming_Direction_GH_11	maximize
ENG124872-ENG115201-Leuchte11WARNBLK TASTERC54-Dimming_EF_11	0
ENG124872-ENG115205-Leuchte11WARNBLK TASTERC54-Dimming_GH_11	0
ENG124872-ENG126586-Leuchte11WARNBLK TASTERC54-Fehlerort_mittleres_Byte_DTC-DFCC_11	0
ENG124872-ENG115735-Leuchte11WARNBLK TASTERC54-Lampendefektbit_Position_11	0
ENG124872-ENG115194-Leuchte11WARNBLK TASTERC54-Light_Control_HD_AB_11	Always
ENG124872-ENG115191-Leuchte11WARNBLK TASTERC54-Light_Function_A_11	Warnblinktaster
ENG124872-ENG115192-Leuchte11WARNBLK TASTERC54-Light_Function_B_11	not active
ENG124872-ENG115195-Leuchte11WARNBLK TASTERC54-Light_Function_C_11	not active
ENG124872-ENG115196-Leuchte11WARNBLK TASTERC54-Light_Function_D_11	not active
ENG124872-ENG115199-Leuchte11WARNBLK TASTERC54-Light_Function_E_11	not active
ENG124872-ENG115200-Leuchte11WARNBLK TASTERC54-Light_Function_F_11	not active
ENG124872-ENG115203-Leuchte11WARNBLK TASTERC54-Light_Function_G_11	not active
ENG124872-ENG115204-Leuchte11WARNBLK TASTERC54-Light_Function_H_11	not active
ENG124872-ENG115188-Leuchte11WARNBLK TASTERC54-Type_Of_Load_11	LED Kleinleistung ohne Open Load Diagnose
ENG124873-ENG115212-Leuchte12NL LB40-Dimming_AB_12	100
ENG124873-ENG115216-Leuchte12NL LB40-Dimming_CD_12	0
ENG124873-ENG115217-Leuchte12NL LB40-Dimming_Direction_CD_12	maximize
ENG124873-ENG115221-Leuchte12NL LB40-Dimming_Direction_EF_12	maximize
ENG124873-ENG115225-Leuchte12NL LB40-Dimming_Direction_GH_12	maximize
ENG124873-ENG115220-Leuchte12NL LB40-Dimming_EF_12	0
ENG124873-ENG115224-Leuchte12NL LB40-Dimming_GH_12	0
ENG124873-ENG126587-Leuchte12NL LB40-Fehlerort_mittleres_Byte_DTC-DFCC_12	22
ENG124873-ENG115750-Leuchte12NL LB40-Lampendefektbit_Position_12	38
ENG124873-ENG115213-Leuchte12NL LB40-Light_Control_HD_AB_12	Always
ENG124873-ENG115210-Leuchte12NL LB40-Light_Function_A_12	Nebellicht links
ENG124873-ENG115211-Leuchte12NL LB40-Light_Function_B_12	Abbiegelicht links
ENG124873-ENG115214-Leuchte12NL LB40-Light_Function_C_12	not active
ENG124873-ENG115215-Leuchte12NL LB40-Light_Function_D_12	not active
ENG124873-ENG115218-Leuchte12NL LB40-Light_Function_E_12	not active
ENG124873-ENG115219-Leuchte12NL LB40-Light_Function_F_12	not active
ENG124873-ENG115222-Leuchte12NL LB40-Light_Function_G_12	not active
ENG124873-ENG115223-Leuchte12NL LB40-Light_Function_H_12	not active
ENG124873-ENG115207-Leuchte12NL LB40-Type_Of_Load_12	allgemeine Scheinwerfer
ENG124874-ENG114958-Leuchte13NL RB3-Dimming_AB_13	100
ENG124874-ENG114962-Leuchte13NL RB3-Dimming_CD_13	0
ENG124874-ENG114963-Leuchte13NL RB3-Dimming_Direction_CD_13	maximize
ENG124874-ENG114967-Leuchte13NL RB3-Dimming_Direction_EF_13	maximize
ENG124874-ENG114971-Leuchte13NL RB3-Dimming_Direction_GH_13	maximize
ENG124874-ENG114966-Leuchte13NL RB3-Dimming_EF_13	0
ENG124874-ENG114970-Leuchte13NL RB3-Dimming_GH_13	0
ENG124874-ENG126588-Leuchte13NL RB3-Fehlerort_mittleres_Byte_DTC-DFCC_13	23
ENG124874-ENG114955-Leuchte13NL RB3-Lampendefektbit_Position_13	42
ENG124874-ENG114959-Leuchte13NL RB3-Light_Control_HD_AB_13	Always
ENG124874-ENG114956-Leuchte13NL RB3-Light_Function_A_13	Nebellicht rechts
ENG124874-ENG114957-Leuchte13NL RB3-Light_Function_B_13	Abbiegelicht rechts
ENG124874-ENG114960-Leuchte13NL RB3-Light_Function_C_13	not active
ENG124874-ENG114961-Leuchte13NL RB3-Light_Function_D_13	not active
ENG124874-ENG114964-Leuchte13NL RB3-Light_Function_E_13	not active
ENG124874-ENG114965-Leuchte13NL RB3-Light_Function_F_13	not active
ENG124874-ENG114968-Leuchte13NL RB3-Light_Function_G_13	not active
ENG124874-ENG114969-Leuchte13NL RB3-Light_Function_H_13	not active
ENG124874-ENG114954-Leuchte13NL RB3-Type_Of_Load_13	allgemeine Scheinwerfer
ENG124876-ENG115252-Leuchte15 SAFE LED C55-Dimming_AB_15	100
ENG124876-ENG115256-Leuchte15 SAFE LED C55-Dimming_CD_15	0
ENG124876-ENG115257-Leuchte15 SAFE LED C55-Dimming_Direction_CD_15	maximize
ENG124876-ENG115261-Leuchte15 SAFE LED C55-Dimming_Direction_EF_15	maximize
ENG124876-ENG115265-Leuchte15 SAFE LED C55-Dimming_Direction_GH_15	maximize
ENG124876-ENG115260-Leuchte15 SAFE LED C55-Dimming_EF_15	0
ENG124876-ENG115264-Leuchte15 SAFE LED C55-Dimming_GH_15	0
ENG124876-ENG126590-Leuchte15 SAFE LED C55-Fehlerort_mittleres_Byte_DTC-DFCC_15	0
ENG124876-ENG115800-Leuchte15 SAFE LED C55-Lampendefektbit_Position_15	0
ENG124876-ENG115253-Leuchte15 SAFE LED C55-Light_Control_HD_AB_15	Always
ENG124876-ENG115250-Leuchte15 SAFE LED C55-Light_Function_A_15	SafeLED
ENG124876-ENG115251-Leuchte15 SAFE LED C55-Light_Function_B_15	not active
ENG124876-ENG115254-Leuchte15 SAFE LED C55-Light_Function_C_15	not active
ENG124876-ENG115255-Leuchte15 SAFE LED C55-Light_Function_D_15	not active
ENG124876-ENG115258-Leuchte15 SAFE LED C55-Light_Function_E_15	not active
ENG124876-ENG115259-Leuchte15 SAFE LED C55-Light_Function_F_15	not active
ENG124876-ENG115262-Leuchte15 SAFE LED C55-Light_Function_G_15	not active
ENG124876-ENG115263-Leuchte15 SAFE LED C55-Light_Function_H_15	not active
ENG124876-ENG115247-Leuchte15 SAFE LED C55-Type_Of_Load_15	allgemeineLEDmitOpenLoadDiagnose
ENG124877-ENG115271-Leuchte16BLK SLC11-Dimming_AB_16	100
ENG124877-ENG115275-Leuchte16BLK SLC11-Dimming_CD_16	0
ENG124877-ENG115276-Leuchte16BLK SLC11-Dimming_Direction_CD_16	maximize
ENG124877-ENG115280-Leuchte16BLK SLC11-Dimming_Direction_EF_16	maximize
ENG124877-ENG115284-Leuchte16BLK SLC11-Dimming_Direction_GH_16	maximize
ENG124877-ENG115279-Leuchte16BLK SLC11-Dimming_EF_16	0
ENG124877-ENG115283-Leuchte16BLK SLC11-Dimming_GH_16	0
ENG124877-ENG126591-Leuchte16BLK SLC11-Fehlerort_mittleres_Byte_DTC-DFCC_16	0
ENG124877-ENG115649-Leuchte16BLK SLC11-Lampendefektbit_Position_16	0
ENG124877-ENG115272-Leuchte16BLK SLC11-Light_Control_HD_AB_16	Always
ENG124877-ENG115269-Leuchte16BLK SLC11-Light_Function_A_16	Blinken links Hellphase
ENG124877-ENG115270-Leuchte16BLK SLC11-Light_Function_B_16	not active
ENG124877-ENG115273-Leuchte16BLK SLC11-Light_Function_C_16	not active
ENG124877-ENG115274-Leuchte16BLK SLC11-Light_Function_D_16	not active
ENG124877-ENG115277-Leuchte16BLK SLC11-Light_Function_E_16	not active
ENG124877-ENG115278-Leuchte16BLK SLC11-Light_Function_F_16	not active
ENG124877-ENG115281-Leuchte16BLK SLC11-Light_Function_G_16	not active
ENG124877-ENG115282-Leuchte16BLK SLC11-Light_Function_H_16	not active
ENG124877-ENG115266-Leuchte16BLK SLC11-Type_Of_Load_16	LED Blinkleuchten
ENG124878-ENG115290-Leuchte17 BLK SR A72-Dimming_AB_17	100
ENG124878-ENG115294-Leuchte17 BLK SR A72-Dimming_CD_17	0
ENG124878-ENG115295-Leuchte17 BLK SR A72-Dimming_Direction_CD_17	maximize
ENG124878-ENG115299-Leuchte17 BLK SR A72-Dimming_Direction_EF_17	maximize
ENG124878-ENG115303-Leuchte17 BLK SR A72-Dimming_Direction_GH_17	maximize
ENG124878-ENG115298-Leuchte17 BLK SR A72-Dimming_EF_17	0
ENG124878-ENG115302-Leuchte17 BLK SR A72-Dimming_GH_17	0
ENG124878-ENG126592-Leuchte17 BLK SR A72-Fehlerort_mittleres_Byte_DTC-DFCC_17	0
ENG124878-ENG115799-Leuchte17 BLK SR A72-Lampendefektbit_Position_17	0
ENG124878-ENG115291-Leuchte17 BLK SR A72-Light_Control_HD_AB_17	Always
ENG124878-ENG115288-Leuchte17 BLK SR A72-Light_Function_A_17	Blinken rechts Hellphase
ENG124878-ENG115289-Leuchte17 BLK SR A72-Light_Function_B_17	not active
ENG124878-ENG115292-Leuchte17 BLK SR A72-Light_Function_C_17	not active
ENG124878-ENG115293-Leuchte17 BLK SR A72-Light_Function_D_17	not active
ENG124878-ENG115296-Leuchte17 BLK SR A72-Light_Function_E_17	not active
ENG124878-ENG115297-Leuchte17 BLK SR A72-Light_Function_F_17	not active
ENG124878-ENG115300-Leuchte17 BLK SR A72-Light_Function_G_17	not active
ENG124878-ENG115301-Leuchte17 BLK SR A72-Light_Function_H_17	not active
ENG124878-ENG115285-Leuchte17 BLK SR A72-Type_Of_Load_17	LED Blinkleuchten
ENG124879-ENG115309-Leuchte18BLK HLA71-Dimming_AB_18	100
ENG124879-ENG115313-Leuchte18BLK HLA71-Dimming_CD_18	0
ENG124879-ENG115314-Leuchte18BLK HLA71-Dimming_Direction_CD_18	maximize
ENG124879-ENG115318-Leuchte18BLK HLA71-Dimming_Direction_EF_18	maximize
ENG124879-ENG115322-Leuchte18BLK HLA71-Dimming_Direction_GH_18	maximize
ENG124879-ENG115317-Leuchte18BLK HLA71-Dimming_EF_18	0
ENG124879-ENG115321-Leuchte18BLK HLA71-Dimming_GH_18	0
ENG124879-ENG126593-Leuchte18BLK HLA71-Fehlerort_mittleres_Byte_DTC-DFCC_18	16
ENG124879-ENG115651-Leuchte18BLK HLA71-Lampendefektbit_Position_18	8
ENG124879-ENG115310-Leuchte18BLK HLA71-Light_Control_HD_AB_18	Always
ENG124879-ENG115307-Leuchte18BLK HLA71-Light_Function_A_18	Blinken links Hellphase
ENG124879-ENG115308-Leuchte18BLK HLA71-Light_Function_B_18	not active
ENG124879-ENG115311-Leuchte18BLK HLA71-Light_Function_C_18	not active
ENG124879-ENG115312-Leuchte18BLK HLA71-Light_Function_D_18	not active
ENG124879-ENG115315-Leuchte18BLK HLA71-Light_Function_E_18	not active
ENG124879-ENG115316-Leuchte18BLK HLA71-Light_Function_F_18	not active
ENG124879-ENG115319-Leuchte18BLK HLA71-Light_Function_G_18	not active
ENG124879-ENG115320-Leuchte18BLK HLA71-Light_Function_H_18	not active
ENG124879-ENG115304-Leuchte18BLK HLA71-Type_Of_Load_18	Blinkleuchten
ENG05979-ENG115328-Leuchte19BLK HRC10-Dimming_AB_19	100
ENG05979-ENG115332-Leuchte19BLK HRC10-Dimming_CD_19	0
ENG05979-ENG115333-Leuchte19BLK HRC10-Dimming_Direction_CD_19	maximize
ENG05979-ENG115337-Leuchte19BLK HRC10-Dimming_Direction_EF_19	maximize
ENG05979-ENG115341-Leuchte19BLK HRC10-Dimming_Direction_GH_19	maximize
ENG05979-ENG115336-Leuchte19BLK HRC10-Dimming_EF_19	0
ENG05979-ENG115340-Leuchte19BLK HRC10-Dimming_GH_19	0
ENG05979-ENG126594-Leuchte19BLK HRC10-Fehlerort_mittleres_Byte_DTC-DFCC_19	18
ENG05979-ENG115785-Leuchte19BLK HRC10-Lampendefektbit_Position_19	18
ENG05979-ENG115329-Leuchte19BLK HRC10-Light_Control_HD_AB_19	Always
ENG05979-ENG115326-Leuchte19BLK HRC10-Light_Function_A_19	Blinken rechts Hellphase
ENG05979-ENG115327-Leuchte19BLK HRC10-Light_Function_B_19	not active
ENG05979-ENG115330-Leuchte19BLK HRC10-Light_Function_C_19	not active
ENG05979-ENG115331-Leuchte19BLK HRC10-Light_Function_D_19	not active
ENG05979-ENG115334-Leuchte19BLK HRC10-Light_Function_E_19	not active
ENG05979-ENG115335-Leuchte19BLK HRC10-Light_Function_F_19	not active
ENG05979-ENG115338-Leuchte19BLK HRC10-Light_Function_G_19	not active
ENG05979-ENG115339-Leuchte19BLK HRC10-Light_Function_H_19	not active
ENG05979-ENG115323-Leuchte19BLK HRC10-Type_Of_Load_19	Blinkleuchten
ENG124862-ENG115037-Leuchte1BLK VRB23-Dimming_AB_1	100
ENG124862-ENG115041-Leuchte1BLK VRB23-Dimming_CD_1	0
ENG124862-ENG115042-Leuchte1BLK VRB23-Dimming_Direction_CD_1	maximize
ENG124862-ENG115046-Leuchte1BLK VRB23-Dimming_Direction_EF_1	maximize
ENG124862-ENG115050-Leuchte1BLK VRB23-Dimming_Direction_GH_1	maximize
ENG124862-ENG115045-Leuchte1BLK VRB23-Dimming_EF_1	0
ENG124862-ENG115049-Leuchte1BLK VRB23-Dimming_GH_1	0
ENG124862-ENG126571-Leuchte1BLK VRB23-Fehlerort_mittleres_Byte_DTC-DFCC_1	15
ENG124862-ENG115732-Leuchte1BLK VRB23-Lampendefektbit_Position_1	3E
ENG124862-ENG115038-Leuchte1BLK VRB23-Light_Control_HD_AB_1	Always
ENG124862-ENG115035-Leuchte1BLK VRB23-Light_Function_A_1	Blinken rechts Hellphase
ENG124862-ENG115036-Leuchte1BLK VRB23-Light_Function_B_1	not active
ENG124862-ENG115039-Leuchte1BLK VRB23-Light_Function_C_1	not active
ENG124862-ENG115040-Leuchte1BLK VRB23-Light_Function_D_1	not active
ENG124862-ENG115043-Leuchte1BLK VRB23-Light_Function_E_1	not active
ENG124862-ENG115044-Leuchte1BLK VRB23-Light_Function_F_1	not active
ENG124862-ENG115047-Leuchte1BLK VRB23-Light_Function_G_1	not active
ENG124862-ENG115048-Leuchte1BLK VRB23-Light_Function_H_1	not active
ENG124862-ENG115032-Leuchte1BLK VRB23-Type_Of_Load_1	Blinkleuchten
ENG124881-ENG115347-Leuchte20BR LA70-Dimming_AB_20	100
ENG124881-ENG115351-Leuchte20BR LA70-Dimming_CD_20	0
ENG124881-ENG115352-Leuchte20BR LA70-Dimming_Direction_CD_20	maximize
ENG124881-ENG115356-Leuchte20BR LA70-Dimming_Direction_EF_20	maximize
ENG124881-ENG115360-Leuchte20BR LA70-Dimming_Direction_GH_20	maximize
ENG124881-ENG115355-Leuchte20BR LA70-Dimming_EF_20	0
ENG124881-ENG115359-Leuchte20BR LA70-Dimming_GH_20	0
ENG124881-ENG126595-Leuchte20BR LA70-Fehlerort_mittleres_Byte_DTC-DFCC_20	2B
ENG124881-ENG115629-Leuchte20BR LA70-Lampendefektbit_Position_20	9
ENG124881-ENG115348-Leuchte20BR LA70-Light_Control_HD_AB_20	Always
ENG124881-ENG115345-Leuchte20BR LA70-Light_Function_A_20	Brake light
ENG124881-ENG115346-Leuchte20BR LA70-Light_Function_B_20	not active
ENG124881-ENG115349-Leuchte20BR LA70-Light_Function_C_20	not active
ENG124881-ENG115350-Leuchte20BR LA70-Light_Function_D_20	not active
ENG124881-ENG115353-Leuchte20BR LA70-Light_Function_E_20	not active
ENG124881-ENG115354-Leuchte20BR LA70-Light_Function_F_20	not active
ENG124881-ENG115357-Leuchte20BR LA70-Light_Function_G_20	not active
ENG124881-ENG115358-Leuchte20BR LA70-Light_Function_H_20	not active
ENG124881-ENG115342-Leuchte20BR LA70-Type_Of_Load_20	Bremsleuchten
ENG116957-ENG115366-Leuchte21BR RC8-Dimming_AB_21	100
ENG116957-ENG115370-Leuchte21BR RC8-Dimming_CD_21	0
ENG116957-ENG115371-Leuchte21BR RC8-Dimming_Direction_CD_21	maximize
ENG116957-ENG115375-Leuchte21BR RC8-Dimming_Direction_EF_21	maximize
ENG116957-ENG115379-Leuchte21BR RC8-Dimming_Direction_GH_21	maximize
ENG116957-ENG115374-Leuchte21BR RC8-Dimming_EF_21	0
ENG116957-ENG115378-Leuchte21BR RC8-Dimming_GH_21	0
ENG116957-ENG126596-Leuchte21BR RC8-Fehlerort_mittleres_Byte_DTC-DFCC_21	2D
ENG116957-ENG115811-Leuchte21BR RC8-Lampendefektbit_Position_21	19
ENG116957-ENG115367-Leuchte21BR RC8-Light_Control_HD_AB_21	Always
ENG116957-ENG115364-Leuchte21BR RC8-Light_Function_A_21	Brake light
ENG116957-ENG115365-Leuchte21BR RC8-Light_Function_B_21	not active
ENG116957-ENG115368-Leuchte21BR RC8-Light_Function_C_21	not active
ENG116957-ENG115369-Leuchte21BR RC8-Light_Function_D_21	not active
ENG116957-ENG115372-Leuchte21BR RC8-Light_Function_E_21	not active
ENG116957-ENG115373-Leuchte21BR RC8-Light_Function_F_21	not active
ENG116957-ENG115376-Leuchte21BR RC8-Light_Function_G_21	not active
ENG116957-ENG115377-Leuchte21BR RC8-Light_Function_H_21	not active
ENG116957-ENG115361-Leuchte21BR RC8-Type_Of_Load_21	Bremsleuchten
ENG124882-ENG115385-Leuchte22BR MC9-Dimming_AB_22	100
ENG124882-ENG115389-Leuchte22BR MC9-Dimming_CD_22	0
ENG124882-ENG115390-Leuchte22BR MC9-Dimming_Direction_CD_22	maximize
ENG124882-ENG115394-Leuchte22BR MC9-Dimming_Direction_EF_22	maximize
ENG124882-ENG115398-Leuchte22BR MC9-Dimming_Direction_GH_22	maximize
ENG124882-ENG115393-Leuchte22BR MC9-Dimming_EF_22	0
ENG124882-ENG115397-Leuchte22BR MC9-Dimming_GH_22	0
ENG124882-ENG126597-Leuchte22BR MC9-Fehlerort_mittleres_Byte_DTC-DFCC_22	2C
ENG124882-ENG115780-Leuchte22BR MC9-Lampendefektbit_Position_22	29
ENG124882-ENG115386-Leuchte22BR MC9-Light_Control_HD_AB_22	Always
ENG124882-ENG115383-Leuchte22BR MC9-Light_Function_A_22	Brake light
ENG124882-ENG115384-Leuchte22BR MC9-Light_Function_B_22	not active
ENG124882-ENG115387-Leuchte22BR MC9-Light_Function_C_22	not active
ENG124882-ENG115388-Leuchte22BR MC9-Light_Function_D_22	not active
ENG124882-ENG115391-Leuchte22BR MC9-Light_Function_E_22	not active
ENG124882-ENG115392-Leuchte22BR MC9-Light_Function_F_22	not active
ENG124882-ENG115395-Leuchte22BR MC9-Light_Function_G_22	not active
ENG124882-ENG115396-Leuchte22BR MC9-Light_Function_H_22	not active
ENG124882-ENG115380-Leuchte22BR MC9-Type_Of_Load_22	LEDdritteBremsleuchte
ENG124883-ENG115404-Leuchte23SL HLC7-Dimming_AB_23	60
ENG124883-ENG115408-Leuchte23SL HLC7-Dimming_CD_23	0
ENG124883-ENG115409-Leuchte23SL HLC7-Dimming_Direction_CD_23	maximize
ENG124883-ENG115413-Leuchte23SL HLC7-Dimming_Direction_EF_23	maximize
ENG124883-ENG115417-Leuchte23SL HLC7-Dimming_Direction_GH_23	maximize
ENG124883-ENG115412-Leuchte23SL HLC7-Dimming_EF_23	0
ENG124883-ENG115416-Leuchte23SL HLC7-Dimming_GH_23	0
ENG124883-ENG126598-Leuchte23SL HLC7-Fehlerort_mittleres_Byte_DTC-DFCC_23	29
ENG124883-ENG115781-Leuchte23SL HLC7-Lampendefektbit_Position_23	0A
ENG124883-ENG115405-Leuchte23SL HLC7-Light_Control_HD_AB_23	Always
ENG124883-ENG115402-Leuchte23SL HLC7-Light_Function_A_23	Parking light
ENG124883-ENG115403-Leuchte23SL HLC7-Light_Function_B_23	Parking light left
ENG124883-ENG115406-Leuchte23SL HLC7-Light_Function_C_23	not active
ENG124883-ENG115407-Leuchte23SL HLC7-Light_Function_D_23	not active
ENG124883-ENG115410-Leuchte23SL HLC7-Light_Function_E_23	not active
ENG124883-ENG115411-Leuchte23SL HLC7-Light_Function_F_23	not active
ENG124883-ENG115414-Leuchte23SL HLC7-Light_Function_G_23	not active
ENG124883-ENG115415-Leuchte23SL HLC7-Light_Function_H_23	not active
ENG124883-ENG115399-Leuchte23SL HLC7-Type_Of_Load_23	allgemeineGluehlampe6W:auchH6W
ENG124884-ENG115423-Leuchte24SL HRA69-Dimming_AB_24	60
ENG124884-ENG115427-Leuchte24SL HRA69-Dimming_CD_24	0
ENG124884-ENG115428-Leuchte24SL HRA69-Dimming_Direction_CD_24	maximize
ENG124884-ENG115432-Leuchte24SL HRA69-Dimming_Direction_EF_24	maximize
ENG124884-ENG115436-Leuchte24SL HRA69-Dimming_Direction_GH_24	maximize
ENG124884-ENG115431-Leuchte24SL HRA69-Dimming_EF_24	0
ENG124884-ENG115435-Leuchte24SL HRA69-Dimming_GH_24	0
ENG124884-ENG126599-Leuchte24SL HRA69-Fehlerort_mittleres_Byte_DTC-DFCC_24	2A
ENG124884-ENG115669-Leuchte24SL HRA69-Lampendefektbit_Position_24	1A
ENG124884-ENG115424-Leuchte24SL HRA69-Light_Control_HD_AB_24	Always
ENG124884-ENG115421-Leuchte24SL HRA69-Light_Function_A_24	Parking light
ENG124884-ENG115422-Leuchte24SL HRA69-Light_Function_B_24	Parking light right
ENG124884-ENG115425-Leuchte24SL HRA69-Light_Function_C_24	not active
ENG124884-ENG115426-Leuchte24SL HRA69-Light_Function_D_24	not active
ENG124884-ENG115429-Leuchte24SL HRA69-Light_Function_E_24	not active
ENG124884-ENG115430-Leuchte24SL HRA69-Light_Function_F_24	not active
ENG124884-ENG115433-Leuchte24SL HRA69-Light_Function_G_24	not active
ENG124884-ENG115434-Leuchte24SL HRA69-Light_Function_H_24	not active
ENG124884-ENG115418-Leuchte24SL HRA69-Type_Of_Load_24	allgemeineGluehlampe6W:auchH6W
ENG124885-ENG115442-Leuchte25KZL HA60-Dimming_AB_25	100
ENG124885-ENG115446-Leuchte25KZL HA60-Dimming_CD_25	0
ENG124885-ENG115447-Leuchte25KZL HA60-Dimming_Direction_CD_25	maximize
ENG124885-ENG115451-Leuchte25KZL HA60-Dimming_Direction_EF_25	maximize
ENG124885-ENG115455-Leuchte25KZL HA60-Dimming_Direction_GH_25	maximize
ENG124885-ENG115450-Leuchte25KZL HA60-Dimming_EF_25	0
ENG124885-ENG115454-Leuchte25KZL HA60-Dimming_GH_25	0
ENG124885-ENG126600-Leuchte25KZL HA60-Fehlerort_mittleres_Byte_DTC-DFCC_25	30
ENG124885-ENG115725-Leuchte25KZL HA60-Lampendefektbit_Position_25	28
ENG124885-ENG115443-Leuchte25KZL HA60-Light_Control_HD_AB_25	Always
ENG124885-ENG115440-Leuchte25KZL HA60-Light_Function_A_25	Parking light
ENG124885-ENG115441-Leuchte25KZL HA60-Light_Function_B_25	not active
ENG124885-ENG115444-Leuchte25KZL HA60-Light_Function_C_25	not active
ENG124885-ENG115445-Leuchte25KZL HA60-Light_Function_D_25	not active
ENG124885-ENG115448-Leuchte25KZL HA60-Light_Function_E_25	not active
ENG124885-ENG115449-Leuchte25KZL HA60-Light_Function_F_25	not active
ENG124885-ENG115452-Leuchte25KZL HA60-Light_Function_G_25	not active
ENG124885-ENG115453-Leuchte25KZL HA60-Light_Function_H_25	not active
ENG124885-ENG115437-Leuchte25KZL HA60-Type_Of_Load_25	allgemeineLEDmitOpenLoadDiagnose
ENG124886-ENG115461-Leuchte26NSL A65-Dimming_AB_26	100
ENG124886-ENG115465-Leuchte26NSL A65-Dimming_CD_26	0
ENG124886-ENG115466-Leuchte26NSL A65-Dimming_Direction_CD_26	maximize
ENG124886-ENG115470-Leuchte26NSL A65-Dimming_Direction_EF_26	maximize
ENG124886-ENG115474-Leuchte26NSL A65-Dimming_Direction_GH_26	maximize
ENG124886-ENG115469-Leuchte26NSL A65-Dimming_EF_26	0
ENG124886-ENG115473-Leuchte26NSL A65-Dimming_GH_26	0
ENG124886-ENG126601-Leuchte26NSL A65-Fehlerort_mittleres_Byte_DTC-DFCC_26	33
ENG124886-ENG115627-Leuchte26NSL A65-Lampendefektbit_Position_26	2A
ENG124886-ENG115462-Leuchte26NSL A65-Light_Control_HD_AB_26	Always
ENG124886-ENG115459-Leuchte26NSL A65-Light_Function_A_26	NebelschlusslichtwennkeinAnhaengergestecktundRechtsverkehr
ENG124886-ENG115460-Leuchte26NSL A65-Light_Function_B_26	not active
ENG124886-ENG115463-Leuchte26NSL A65-Light_Function_C_26	not active
ENG124886-ENG115464-Leuchte26NSL A65-Light_Function_D_26	not active
ENG124886-ENG115467-Leuchte26NSL A65-Light_Function_E_26	not active
ENG124886-ENG115468-Leuchte26NSL A65-Light_Function_F_26	not active
ENG124886-ENG115471-Leuchte26NSL A65-Light_Function_G_26	not active
ENG124886-ENG115472-Leuchte26NSL A65-Light_Function_H_26	not active
ENG124886-ENG115456-Leuchte26NSL A65-Type_Of_Load_26	allgemeineGluehlampe27W:auchH15-TFL
ENG124887-ENG115480-Leuchte27 KL58XS C67-Dimming_AB_27	100
ENG124887-ENG115484-Leuchte27 KL58XS C67-Dimming_CD_27	0
ENG124887-ENG115485-Leuchte27 KL58XS C67-Dimming_Direction_CD_27	maximize
ENG124887-ENG115489-Leuchte27 KL58XS C67-Dimming_Direction_EF_27	maximize
ENG124887-ENG115493-Leuchte27 KL58XS C67-Dimming_Direction_GH_27	maximize
ENG124887-ENG115488-Leuchte27 KL58XS C67-Dimming_EF_27	0
ENG124887-ENG115492-Leuchte27 KL58XS C67-Dimming_GH_27	0
ENG124887-ENG126602-Leuchte27 KL58XS C67-Fehlerort_mittleres_Byte_DTC-DFCC_27	8
ENG124887-ENG115648-Leuchte27 KL58XS C67-Lampendefektbit_Position_27	0
ENG124887-ENG115481-Leuchte27 KL58XS C67-Light_Control_HD_AB_27	Always
ENG124887-ENG115478-Leuchte27 KL58XS C67-Light_Function_A_27	Terminal 58xs dimmer
ENG124887-ENG115479-Leuchte27 KL58XS C67-Light_Function_B_27	not active
ENG124887-ENG115482-Leuchte27 KL58XS C67-Light_Function_C_27	not active
ENG124887-ENG115483-Leuchte27 KL58XS C67-Light_Function_D_27	not active
ENG124887-ENG115486-Leuchte27 KL58XS C67-Light_Function_E_27	not active
ENG124887-ENG115487-Leuchte27 KL58XS C67-Light_Function_F_27	not active
ENG124887-ENG115490-Leuchte27 KL58XS C67-Light_Function_G_27	not active
ENG124887-ENG115491-Leuchte27 KL58XS C67-Light_Function_H_27	not active
ENG124887-ENG115475-Leuchte27 KL58XS C67-Type_Of_Load_27	LED Kleinleistung ohne Open Load Diagnose
ENG124888-ENG115499-Leuchte28RFL C3-Dimming_AB_28	100
ENG124888-ENG115503-Leuchte28RFL C3-Dimming_CD_28	0
ENG124888-ENG115504-Leuchte28RFL C3-Dimming_Direction_CD_28	maximize
ENG124888-ENG115508-Leuchte28RFL C3-Dimming_Direction_EF_28	maximize
ENG124888-ENG115512-Leuchte28RFL C3-Dimming_Direction_GH_28	maximize
ENG124888-ENG115507-Leuchte28RFL C3-Dimming_EF_28	0
ENG124888-ENG115511-Leuchte28RFL C3-Dimming_GH_28	0
ENG124888-ENG126603-Leuchte28RFL C3-Fehlerort_mittleres_Byte_DTC-DFCC_28	34
ENG124888-ENG115647-Leuchte28RFL C3-Lampendefektbit_Position_28	2B
ENG124888-ENG115500-Leuchte28RFL C3-Light_Control_HD_AB_28	Always
ENG124888-ENG115497-Leuchte28RFL C3-Light_Function_A_28	Rueckfahrlicht
ENG124888-ENG115498-Leuchte28RFL C3-Light_Function_B_28	not active
ENG124888-ENG115501-Leuchte28RFL C3-Light_Function_C_28	not active
ENG124888-ENG115502-Leuchte28RFL C3-Light_Function_D_28	not active
ENG124888-ENG115505-Leuchte28RFL C3-Light_Function_E_28	not active
ENG124888-ENG115506-Leuchte28RFL C3-Light_Function_F_28	not active
ENG124888-ENG115509-Leuchte28RFL C3-Light_Function_G_28	not active
ENG124888-ENG115510-Leuchte28RFL C3-Light_Function_H_28	not active
ENG124888-ENG115494-Leuchte28RFL C3-Type_Of_Load_28	allgemeineGluehlampe27W:auchH15-TFL
ENG124889-ENG115518-Leuchte29 KL30G A69-Dimming_AB_29	100
ENG124889-ENG115522-Leuchte29 KL30G A69-Dimming_CD_29	0
ENG124889-ENG115523-Leuchte29 KL30G A69-Dimming_Direction_CD_29	maximize
ENG124889-ENG115527-Leuchte29 KL30G A69-Dimming_Direction_EF_29	maximize
ENG124889-ENG115531-Leuchte29 KL30G A69-Dimming_Direction_GH_29	maximize
ENG124889-ENG115526-Leuchte29 KL30G A69-Dimming_EF_29	0
ENG124889-ENG115530-Leuchte29 KL30G A69-Dimming_GH_29	0
ENG124889-ENG126604-Leuchte29 KL30G A69-Fehlerort_mittleres_Byte_DTC-DFCC_29	1
ENG124889-ENG115764-Leuchte29 KL30G A69-Lampendefektbit_Position_29	0
ENG124889-ENG115520-Leuchte29 KL30G A69-Light_Control_HD_AB_29	Always
ENG124889-ENG115516-Leuchte29 KL30G A69-Light_Function_A_29	Klemme 30G
ENG124889-ENG115517-Leuchte29 KL30G A69-Light_Function_B_29	not active
ENG124889-ENG115519-Leuchte29 KL30G A69-Light_Function_C_29	not active
ENG124889-ENG115521-Leuchte29 KL30G A69-Light_Function_D_29	not active
ENG124889-ENG115524-Leuchte29 KL30G A69-Light_Function_E_29	not active
ENG124889-ENG115525-Leuchte29 KL30G A69-Light_Function_F_29	not active
ENG124889-ENG115528-Leuchte29 KL30G A69-Light_Function_G_29	not active
ENG124889-ENG115529-Leuchte29 KL30G A69-Light_Function_H_29	not active
ENG124889-ENG115513-Leuchte29 KL30G A69-Type_Of_Load_29	allgemeineGluehlampe12W
ENG124863-ENG115056-Leuchte2SL VLB22-Dimming_AB_2	70
ENG124863-ENG115060-Leuchte2SL VLB22-Dimming_CD_2	30
ENG124863-ENG115061-Leuchte2SL VLB22-Dimming_Direction_CD_2	maximize
ENG124863-ENG115065-Leuchte2SL VLB22-Dimming_Direction_EF_2	minimize
ENG124863-ENG115069-Leuchte2SL VLB22-Dimming_Direction_GH_2	maximize
ENG124863-ENG115064-Leuchte2SL VLB22-Dimming_EF_2	30
ENG124863-ENG115068-Leuchte2SL VLB22-Dimming_GH_2	0
ENG124863-ENG126577-Leuchte2SL VLB22-Fehlerort_mittleres_Byte_DTC-DFCC_2	0
ENG124863-ENG115726-Leuchte2SL VLB22-Lampendefektbit_Position_2	0
ENG124863-ENG115057-Leuchte2SL VLB22-Light_Control_HD_AB_2	Always
ENG124863-ENG115054-Leuchte2SL VLB22-Light_Function_A_2	Daytime running lights
ENG124863-ENG115055-Leuchte2SL VLB22-Light_Function_B_2	not active
ENG124863-ENG115058-Leuchte2SL VLB22-Light_Function_C_2	Parking light
ENG124863-ENG115059-Leuchte2SL VLB22-Light_Function_D_2	Parking light left
ENG124863-ENG115062-Leuchte2SL VLB22-Light_Function_E_2	Nebellicht links
ENG124863-ENG115063-Leuchte2SL VLB22-Light_Function_F_2	not active
ENG124863-ENG115066-Leuchte2SL VLB22-Light_Function_G_2	not active
ENG124863-ENG115067-Leuchte2SL VLB22-Light_Function_H_2	not active
ENG124863-ENG115051-Leuchte2SL VLB22-Type_Of_Load_2	LED Tagfahrlichtmodul Signal
ENG124890-ENG115537-Leuchte30 INNENLICHT A68-Dimming_AB_30	126
ENG124890-ENG115541-Leuchte30 INNENLICHT A68-Dimming_CD_30	0
ENG124890-ENG115542-Leuchte30 INNENLICHT A68-Dimming_Direction_CD_30	maximize
ENG124890-ENG115546-Leuchte30 INNENLICHT A68-Dimming_Direction_EF_30	maximize
ENG124890-ENG115550-Leuchte30 INNENLICHT A68-Dimming_Direction_GH_30	maximize
ENG124890-ENG115545-Leuchte30 INNENLICHT A68-Dimming_EF_30	0
ENG124890-ENG115549-Leuchte30 INNENLICHT A68-Dimming_GH_30	0
ENG124890-ENG126605-Leuchte30 INNENLICHT A68-Fehlerort_mittleres_Byte_DTC-DFCC_30	7
ENG124890-ENG115797-Leuchte30 INNENLICHT A68-Lampendefektbit_Position_30	0
ENG124890-ENG115538-Leuchte30 INNENLICHT A68-Light_Control_HD_AB_30	Always
ENG124890-ENG115535-Leuchte30 INNENLICHT A68-Light_Function_A_30	Interior light
ENG124890-ENG115536-Leuchte30 INNENLICHT A68-Light_Function_B_30	not active
ENG124890-ENG115539-Leuchte30 INNENLICHT A68-Light_Function_C_30	not active
ENG124890-ENG115540-Leuchte30 INNENLICHT A68-Light_Function_D_30	not active
ENG124890-ENG115543-Leuchte30 INNENLICHT A68-Light_Function_E_30	not active
ENG124890-ENG115544-Leuchte30 INNENLICHT A68-Light_Function_F_30	not active
ENG124890-ENG115547-Leuchte30 INNENLICHT A68-Light_Function_G_30	not active
ENG124890-ENG115548-Leuchte30 INNENLICHT A68-Light_Function_H_30	not active
ENG124890-ENG115532-Leuchte30 INNENLICHT A68-Type_Of_Load_30	allgemeineGluehlampe12W
ENG124891-ENG115556-Leuchte31AMBL 1C65-Dimming_AB_31	0
ENG124891-ENG115560-Leuchte31AMBL 1C65-Dimming_CD_31	0
ENG124891-ENG115561-Leuchte31AMBL 1C65-Dimming_Direction_CD_31	maximize
ENG124891-ENG115565-Leuchte31AMBL 1C65-Dimming_Direction_EF_31	maximize
ENG124891-ENG115569-Leuchte31AMBL 1C65-Dimming_Direction_GH_31	maximize
ENG124891-ENG115564-Leuchte31AMBL 1C65-Dimming_EF_31	0
ENG124891-ENG115568-Leuchte31AMBL 1C65-Dimming_GH_31	0
ENG124891-ENG126606-Leuchte31AMBL 1C65-Fehlerort_mittleres_Byte_DTC-DFCC_31	0
ENG124891-ENG115707-Leuchte31AMBL 1C65-Lampendefektbit_Position_31	0
ENG124891-ENG115557-Leuchte31AMBL 1C65-Light_Control_HD_AB_31	Always
ENG124891-ENG115554-Leuchte31AMBL 1C65-Light_Function_A_31	not active
ENG124891-ENG115555-Leuchte31AMBL 1C65-Light_Function_B_31	not active
ENG124891-ENG115558-Leuchte31AMBL 1C65-Light_Function_C_31	not active
ENG124891-ENG115559-Leuchte31AMBL 1C65-Light_Function_D_31	not active
ENG124891-ENG115562-Leuchte31AMBL 1C65-Light_Function_E_31	not active
ENG124891-ENG115563-Leuchte31AMBL 1C65-Light_Function_F_31	not active
ENG124891-ENG115566-Leuchte31AMBL 1C65-Light_Function_G_31	not active
ENG124891-ENG115567-Leuchte31AMBL 1C65-Light_Function_H_31	not active
ENG124891-ENG115551-Leuchte31AMBL 1C65-Type_Of_Load_31	not active
ENG124892-ENG115575-Leuchte32AMBL 2C64-Dimming_AB_32	0
ENG124892-ENG115579-Leuchte32AMBL 2C64-Dimming_CD_32	0
ENG124892-ENG115580-Leuchte32AMBL 2C64-Dimming_Direction_CD_32	maximize
ENG124892-ENG115584-Leuchte32AMBL 2C64-Dimming_Direction_EF_32	maximize
ENG124892-ENG115588-Leuchte32AMBL 2C64-Dimming_Direction_GH_32	maximize
ENG124892-ENG115583-Leuchte32AMBL 2C64-Dimming_EF_32	0
ENG124892-ENG115587-Leuchte32AMBL 2C64-Dimming_GH_32	0
ENG124892-ENG126607-Leuchte32AMBL 2C64-Fehlerort_mittleres_Byte_DTC-DFCC_32	0
ENG124892-ENG115654-Leuchte32AMBL 2C64-Lampendefektbit_Position_32	0
ENG124892-ENG115576-Leuchte32AMBL 2C64-Light_Control_HD_AB_32	Always
ENG124892-ENG115573-Leuchte32AMBL 2C64-Light_Function_A_32	not active
ENG124892-ENG115574-Leuchte32AMBL 2C64-Light_Function_B_32	not active
ENG124892-ENG115577-Leuchte32AMBL 2C64-Light_Function_C_32	not active
ENG124892-ENG115578-Leuchte32AMBL 2C64-Light_Function_D_32	not active
ENG124892-ENG115581-Leuchte32AMBL 2C64-Light_Function_E_32	not active
ENG124892-ENG115582-Leuchte32AMBL 2C64-Light_Function_F_32	not active
ENG124892-ENG115585-Leuchte32AMBL 2C64-Light_Function_G_32	not active
ENG124892-ENG115586-Leuchte32AMBL 2C64-Light_Function_H_32	not active
ENG124892-ENG115570-Leuchte32AMBL 2C64-Type_Of_Load_32	not active
ENG124893-ENG115594-Leuchte33AMBL 3C72-Dimming_AB_33	0
ENG124893-ENG115598-Leuchte33AMBL 3C72-Dimming_CD_33	0
ENG124893-ENG115599-Leuchte33AMBL 3C72-Dimming_Direction_CD_33	maximize
ENG124893-ENG115603-Leuchte33AMBL 3C72-Dimming_Direction_EF_33	maximize
ENG124893-ENG115607-Leuchte33AMBL 3C72-Dimming_Direction_GH_33	maximize
ENG124893-ENG115602-Leuchte33AMBL 3C72-Dimming_EF_33	0
ENG124893-ENG115606-Leuchte33AMBL 3C72-Dimming_GH_33	0
ENG124893-ENG126608-Leuchte33AMBL 3C72-Fehlerort_mittleres_Byte_DTC-DFCC_33	0
ENG124893-ENG115655-Leuchte33AMBL 3C72-Lampendefektbit_Position_33	0
ENG124893-ENG115595-Leuchte33AMBL 3C72-Light_Control_HD_AB_33	Always
ENG124893-ENG115592-Leuchte33AMBL 3C72-Light_Function_A_33	not active
ENG124893-ENG115593-Leuchte33AMBL 3C72-Light_Function_B_33	not active
ENG124893-ENG115596-Leuchte33AMBL 3C72-Light_Function_C_33	not active
ENG124893-ENG115597-Leuchte33AMBL 3C72-Light_Function_D_33	not active
ENG124893-ENG115600-Leuchte33AMBL 3C72-Light_Function_E_33	not active
ENG124893-ENG115601-Leuchte33AMBL 3C72-Light_Function_F_33	not active
ENG124893-ENG115604-Leuchte33AMBL 3C72-Light_Function_G_33	not active
ENG124893-ENG115605-Leuchte33AMBL 3C72-Light_Function_H_33	not active
ENG124893-ENG115589-Leuchte33AMBL 3C72-Type_Of_Load_33	not active
ENG124894-ENG115613-Leuchte34AMBL 4C71-Dimming_AB_34	0
ENG124894-ENG115617-Leuchte34AMBL 4C71-Dimming_CD_34	0
ENG124894-ENG115618-Leuchte34AMBL 4C71-Dimming_Direction_CD_34	maximize
ENG124894-ENG115622-Leuchte34AMBL 4C71-Dimming_Direction_EF_34	maximize
ENG124894-ENG115626-Leuchte34AMBL 4C71-Dimming_Direction_GH_34	maximize
ENG124894-ENG115621-Leuchte34AMBL 4C71-Dimming_EF_34	0
ENG124894-ENG115625-Leuchte34AMBL 4C71-Dimming_GH_34	0
ENG124894-ENG126609-Leuchte34AMBL 4C71-Fehlerort_mittleres_Byte_DTC-DFCC_34	0
ENG124894-ENG115796-Leuchte34AMBL 4C71-Lampendefektbit_Position_34	0
ENG124894-ENG115614-Leuchte34AMBL 4C71-Light_Control_HD_AB_34	Always
ENG124894-ENG115611-Leuchte34AMBL 4C71-Light_Function_A_34	not active
ENG124894-ENG115612-Leuchte34AMBL 4C71-Light_Function_B_34	not active
ENG124894-ENG115615-Leuchte34AMBL 4C71-Light_Function_C_34	not active
ENG124894-ENG115616-Leuchte34AMBL 4C71-Light_Function_D_34	not active
ENG124894-ENG115619-Leuchte34AMBL 4C71-Light_Function_E_34	not active
ENG124894-ENG115620-Leuchte34AMBL 4C71-Light_Function_F_34	not active
ENG124894-ENG115623-Leuchte34AMBL 4C71-Light_Function_G_34	not active
ENG124894-ENG115624-Leuchte34AMBL 4C71-Light_Function_H_34	not active
ENG124894-ENG115608-Leuchte34AMBL 4C71-Type_Of_Load_34	not active
ENG124864-ENG115075-Leuchte3SL VRB36-Dimming_AB_3	70
ENG124864-ENG115079-Leuchte3SL VRB36-Dimming_CD_3	30
ENG124864-ENG115080-Leuchte3SL VRB36-Dimming_Direction_CD_3	maximize
ENG124864-ENG115084-Leuchte3SL VRB36-Dimming_Direction_EF_3	minimize
ENG124864-ENG115088-Leuchte3SL VRB36-Dimming_Direction_GH_3	maximize
ENG124864-ENG115083-Leuchte3SL VRB36-Dimming_EF_3	30
ENG124864-ENG115087-Leuchte3SL VRB36-Dimming_GH_3	0
ENG124864-ENG126578-Leuchte3SL VRB36-Fehlerort_mittleres_Byte_DTC-DFCC_3	0
ENG124864-ENG115645-Leuchte3SL VRB36-Lampendefektbit_Position_3	0
ENG124864-ENG115076-Leuchte3SL VRB36-Light_Control_HD_AB_3	Always
ENG124864-ENG115073-Leuchte3SL VRB36-Light_Function_A_3	Daytime running lights
ENG124864-ENG115074-Leuchte3SL VRB36-Light_Function_B_3	not active
ENG124864-ENG115077-Leuchte3SL VRB36-Light_Function_C_3	Parking light
ENG124864-ENG115078-Leuchte3SL VRB36-Light_Function_D_3	Parking light right
ENG124864-ENG115081-Leuchte3SL VRB36-Light_Function_E_3	Nebellicht rechts
ENG124864-ENG115082-Leuchte3SL VRB36-Light_Function_F_3	not active
ENG124864-ENG115085-Leuchte3SL VRB36-Light_Function_G_3	not active
ENG124864-ENG115086-Leuchte3SL VRB36-Light_Function_H_3	not active
ENG124864-ENG115070-Leuchte3SL VRB36-Type_Of_Load_3	LED Tagfahrlichtmodul Signal
ENG124865-ENG115094-Leuchte4TFL LB43-Dimming_AB_4	127
ENG124865-ENG115098-Leuchte4TFL LB43-Dimming_CD_4	127
ENG124865-ENG115099-Leuchte4TFL LB43-Dimming_Direction_CD_4	maximize
ENG124865-ENG115103-Leuchte4TFL LB43-Dimming_Direction_EF_4	maximize
ENG124865-ENG115107-Leuchte4TFL LB43-Dimming_Direction_GH_4	maximize
ENG124865-ENG115102-Leuchte4TFL LB43-Dimming_EF_4	0
ENG124865-ENG115106-Leuchte4TFL LB43-Dimming_GH_4	0
ENG124865-ENG126579-Leuchte4TFL LB43-Fehlerort_mittleres_Byte_DTC-DFCC_4	49
ENG124865-ENG115808-Leuchte4TFL LB43-Lampendefektbit_Position_4	48
ENG124865-ENG115095-Leuchte4TFL LB43-Light_Control_HD_AB_4	Always
ENG124865-ENG115092-Leuchte4TFL LB43-Light_Function_A_4	Daytime running lights
ENG124865-ENG115093-Leuchte4TFL LB43-Light_Function_B_4	Parking light
ENG124865-ENG115096-Leuchte4TFL LB43-Light_Function_C_4	Parking light left
ENG124865-ENG115097-Leuchte4TFL LB43-Light_Function_D_4	not active
ENG124865-ENG115100-Leuchte4TFL LB43-Light_Function_E_4	not active
ENG124865-ENG115101-Leuchte4TFL LB43-Light_Function_F_4	not active
ENG124865-ENG115104-Leuchte4TFL LB43-Light_Function_G_4	not active
ENG124865-ENG115105-Leuchte4TFL LB43-Light_Function_H_4	not active
ENG124865-ENG115089-Leuchte4TFL LB43-Type_Of_Load_4	allgemeineLEDmitOpenLoadDiagnose
ENG124866-ENG114977-Leuchte5 TFL RB6-Dimming_AB_5	127
ENG124866-ENG114981-Leuchte5 TFL RB6-Dimming_CD_5	127
ENG124866-ENG114982-Leuchte5 TFL RB6-Dimming_Direction_CD_5	maximize
ENG124866-ENG114986-Leuchte5 TFL RB6-Dimming_Direction_EF_5	maximize
ENG124866-ENG114990-Leuchte5 TFL RB6-Dimming_Direction_GH_5	maximize
ENG124866-ENG114985-Leuchte5 TFL RB6-Dimming_EF_5	0
ENG124866-ENG114989-Leuchte5 TFL RB6-Dimming_GH_5	0
ENG124866-ENG126580-Leuchte5 TFL RB6-Fehlerort_mittleres_Byte_DTC-DFCC_5	4B
ENG124866-ENG114974-Leuchte5 TFL RB6-Lampendefektbit_Position_5	4C
ENG124866-ENG114978-Leuchte5 TFL RB6-Light_Control_HD_AB_5	Always
ENG124866-ENG114975-Leuchte5 TFL RB6-Light_Function_A_5	Daytime running lights
ENG124866-ENG114976-Leuchte5 TFL RB6-Light_Function_B_5	Parking light
ENG124866-ENG114979-Leuchte5 TFL RB6-Light_Function_C_5	Parking light right
ENG124866-ENG114980-Leuchte5 TFL RB6-Light_Function_D_5	not active
ENG124866-ENG114983-Leuchte5 TFL RB6-Light_Function_E_5	not active
ENG124866-ENG114984-Leuchte5 TFL RB6-Light_Function_F_5	not active
ENG124866-ENG114987-Leuchte5 TFL RB6-Light_Function_G_5	not active
ENG124866-ENG114988-Leuchte5 TFL RB6-Light_Function_H_5	not active
ENG124866-ENG114973-Leuchte5 TFL RB6-Type_Of_Load_5	allgemeineLEDmitOpenLoadDiagnose
ENG124867-ENG115115-Leuchte6ABL LB44-Dimming_AB_6	127
ENG124867-ENG115119-Leuchte6ABL LB44-Dimming_CD_6	0
ENG124867-ENG115120-Leuchte6ABL LB44-Dimming_Direction_CD_6	maximize
ENG124867-ENG115124-Leuchte6ABL LB44-Dimming_Direction_EF_6	maximize
ENG124867-ENG115128-Leuchte6ABL LB44-Dimming_Direction_GH_6	maximize
ENG124867-ENG115123-Leuchte6ABL LB44-Dimming_EF_6	0
ENG124867-ENG115127-Leuchte6ABL LB44-Dimming_GH_6	0
ENG124867-ENG126581-Leuchte6ABL LB44-Fehlerort_mittleres_Byte_DTC-DFCC_6	1A
ENG124867-ENG115765-Leuchte6ABL LB44-Lampendefektbit_Position_6	36
ENG124867-ENG115116-Leuchte6ABL LB44-Light_Control_HD_AB_6	Always
ENG124867-ENG115113-Leuchte6ABL LB44-Light_Function_A_6	Abblendlicht links
ENG124867-ENG115114-Leuchte6ABL LB44-Light_Function_B_6	ComingHome LeavingHome
ENG124867-ENG115117-Leuchte6ABL LB44-Light_Function_C_6	not active
ENG124867-ENG115118-Leuchte6ABL LB44-Light_Function_D_6	not active
ENG124867-ENG115121-Leuchte6ABL LB44-Light_Function_E_6	not active
ENG124867-ENG115122-Leuchte6ABL LB44-Light_Function_F_6	not active
ENG124867-ENG115125-Leuchte6ABL LB44-Light_Function_G_6	not active
ENG124867-ENG115126-Leuchte6ABL LB44-Light_Function_H_6	not active
ENG124868-ENG115134-Leuchte7ABL RB5-Dimming_AB_7	127
ENG124868-ENG115138-Leuchte7ABL RB5-Dimming_CD_7	0
ENG124868-ENG115139-Leuchte7ABL RB5-Dimming_Direction_CD_7	maximize
ENG124868-ENG115143-Leuchte7ABL RB5-Dimming_Direction_EF_7	maximize
ENG124868-ENG115147-Leuchte7ABL RB5-Dimming_Direction_GH_7	maximize
ENG124868-ENG115142-Leuchte7ABL RB5-Dimming_EF_7	0
ENG124868-ENG115146-Leuchte7ABL RB5-Dimming_GH_7	0
ENG124868-ENG126582-Leuchte7ABL RB5-Fehlerort_mittleres_Byte_DTC-DFCC_7	1B
ENG124868-ENG115807-Leuchte7ABL RB5-Lampendefektbit_Position_7	40
ENG124868-ENG115135-Leuchte7ABL RB5-Light_Control_HD_AB_7	Always
ENG124868-ENG115132-Leuchte7ABL RB5-Light_Function_A_7	Abblendlicht rechts
ENG124868-ENG115133-Leuchte7ABL RB5-Light_Function_B_7	ComingHome LeavingHome
ENG124868-ENG115136-Leuchte7ABL RB5-Light_Function_C_7	not active
ENG124868-ENG115137-Leuchte7ABL RB5-Light_Function_D_7	not active
ENG124868-ENG115140-Leuchte7ABL RB5-Light_Function_E_7	not active
ENG124868-ENG115141-Leuchte7ABL RB5-Light_Function_F_7	not active
ENG124868-ENG115144-Leuchte7ABL RB5-Light_Function_G_7	not active
ENG124868-ENG115145-Leuchte7ABL RB5-Light_Function_H_7	not active
ENG124869-ENG115153-Leuchte8FL LB42-Dimming_AB_8	127
ENG124869-ENG115157-Leuchte8FL LB42-Dimming_CD_8	0
ENG124869-ENG115158-Leuchte8FL LB42-Dimming_Direction_CD_8	maximize
ENG124869-ENG115162-Leuchte8FL LB42-Dimming_Direction_EF_8	maximize
ENG124869-ENG115147-Leuchte8FL LB42-Dimming_Direction_GH_7	maximize
ENG124869-ENG115161-Leuchte8FL LB42-Dimming_EF_8	0
ENG124869-ENG115165-Leuchte8FL LB42-Dimming_GH_8	0
ENG124869-ENG126583-Leuchte8FL LB42-Fehlerort_mittleres_Byte_DTC-DFCC_8	1C
ENG124869-ENG115798-Leuchte8FL LB42-Lampendefektbit_Position_8	37
ENG124869-ENG115154-Leuchte8FL LB42-Light_Control_HD_AB_8	Always
ENG124869-ENG115151-Leuchte8FL LB42-Light_Function_A_8	Left high beam
ENG124869-ENG115152-Leuchte8FL LB42-Light_Function_B_8	Headlamp flasher
ENG124869-ENG115155-Leuchte8FL LB42-Light_Function_C_8	not active
ENG124869-ENG115156-Leuchte8FL LB42-Light_Function_D_8	not active
ENG124869-ENG115159-Leuchte8FL LB42-Light_Function_E_8	not active
ENG124869-ENG115160-Leuchte8FL LB42-Light_Function_F_8	not active
ENG124869-ENG115163-Leuchte8FL LB42-Light_Function_G_8	not active
ENG124869-ENG115164-Leuchte8FL LB42-Light_Function_H_8	not active
ENG124870-ENG115172-Leuchte9FL RB7-Dimming_AB_9	127
ENG124870-ENG115176-Leuchte9FL RB7-Dimming_CD_9	0
ENG124870-ENG115177-Leuchte9FL RB7-Dimming_Direction_CD_9	maximize
ENG124870-ENG115181-Leuchte9FL RB7-Dimming_Direction_EF_9	maximize
ENG124870-ENG115185-Leuchte9FL RB7-Dimming_Direction_GH_9	maximize
ENG124870-ENG115180-Leuchte9FL RB7-Dimming_EF_9	0
ENG124870-ENG115184-Leuchte9FL RB7-Dimming_GH_9	0
ENG124870-ENG126584-Leuchte9FL RB7-Fehlerort_mittleres_Byte_DTC-DFCC_9	1D
ENG124870-ENG115804-Leuchte9FL RB7-Lampendefektbit_Position_9	41
ENG124870-ENG115173-Leuchte9FL RB7-Light_Control_HD_AB_9	Always
ENG124870-ENG115170-Leuchte9FL RB7-Light_Function_A_9	Right high beam
ENG124870-ENG115171-Leuchte9FL RB7-Light_Function_B_9	Headlamp flasher
ENG124870-ENG115174-Leuchte9FL RB7-Light_Function_C_9	not active
ENG124870-ENG115175-Leuchte9FL RB7-Light_Function_D_9	not active
ENG124870-ENG115178-Leuchte9FL RB7-Light_Function_E_9	not active
ENG124870-ENG115179-Leuchte9FL RB7-Light_Function_F_9	not active
ENG124870-ENG115182-Leuchte9FL RB7-Light_Function_G_9	not active
ENG124870-ENG115183-Leuchte9FL RB7-Light_Function_H_9	not active
ENG124875-ENG115233-Leuchten14LOCKUNLOCKC61-Dimming_AB_14	100
ENG124875-ENG115237-Leuchten14LOCKUNLOCKC61-Dimming_CD_14	0
ENG124875-ENG115238-Leuchten14LOCKUNLOCKC61-Dimming_Direction_CD_14	maximize
ENG124875-ENG115242-Leuchten14LOCKUNLOCKC61-Dimming_Direction_EF_14	maximize
ENG124875-ENG115246-Leuchten14LOCKUNLOCKC61-Dimming_Direction_GH_14	maximize
ENG124875-ENG115241-Leuchten14LOCKUNLOCKC61-Dimming_EF_14	0
ENG124875-ENG115245-Leuchten14LOCKUNLOCKC61-Dimming_GH_14	0
ENG124875-ENG126589-Leuchten14LOCKUNLOCKC61-Fehlerort_mittleres_Byte_DTC-DFCC_14	0
ENG124875-ENG115786-Leuchten14LOCKUNLOCKC61-Lampendefektbit_Position_14	0
ENG124875-ENG115234-Leuchten14LOCKUNLOCKC61-Light_Control_HD_AB_14	Always
ENG124875-ENG115231-Leuchten14LOCKUNLOCKC61-Light_Function_A_14	LockUnlockLED
ENG124875-ENG115232-Leuchten14LOCKUNLOCKC61-Light_Function_B_14	not active
ENG124875-ENG115235-Leuchten14LOCKUNLOCKC61-Light_Function_C_14	not active
ENG124875-ENG115236-Leuchten14LOCKUNLOCKC61-Light_Function_D_14	not active
ENG124875-ENG115239-Leuchten14LOCKUNLOCKC61-Light_Function_E_14	not active
ENG124875-ENG115240-Leuchten14LOCKUNLOCKC61-Light_Function_F_14	not active
ENG124875-ENG115243-Leuchten14LOCKUNLOCKC61-Light_Function_G_14	not active
ENG124875-ENG115244-Leuchten14LOCKUNLOCKC61-Light_Function_H_14	not active
ENG124875-ENG115228-Leuchten14LOCKUNLOCKC61-Type_Of_Load_14	allgemeineLEDmitOpenLoadDiagnose
ENG126648-MAS02526-LIN-Mirrormode-Activation	not active
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3	not active
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4	not active
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5	not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.0 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.0 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.0 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.0 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.0 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.0 %
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG127068-Window_Regulator_VW_Settings_Driver_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127067-Window_Regulator_VW_Settings_Passenger_Side_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
ENG127069-Window_Regulator_VW_Settings_Passenger_Side_Rear_PQ25	00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Elapsed Time: 02:20
Photo of Byte 8, Bit 0 in hex17.
It's language selection only.
m87a
Bosnia and Herzegovina
C?ID=156900
did you try to check if there is difference in admap? thank you
DV52
C?ID=194404
m87a: Yes I did - the before and after settings in the BCM are identical for the entire channel count of 1809 items in undertaker's admap.
I have no experience with how to modify control module firmware, but is the "tell" for this a changed WSC?
Undertaker: So- is it normal for workshops in Croatia to use English language ? And does something like SWAP need this?
undertaker
Croatia
C?ID=267794
Workshops are using Croatian language version of Odis. Also instrument cluster in my car gives me warnings in Croatian.
EduardJS
Romania
C?ID=307521
@undertaker , I know this is a bit old, but, by any chance, do you have LED ( example ) or Xenon ( example ) headlights ?
Thank you very much !
undertaker
Croatia
C?ID=267794
My car was equipped with LED lights.
MasterTommy
Amsterdam
C?ID=295586
My brother has a 1.0TSI with LED lights and full options except direct TPMS. If you need anything....
EduardJS
Romania
C?ID=307521
Hey!
Thank you both! MasterTommy an autoscan and an 09 ad-map would be amazong if posdible :)
Send them via PM.
