Laser Headlamps Retrofit 2017 Audi R8, Need Coding!
phonerebel
C?ID=162146
Hi there guys, I am attempting to install laser headlamps on my 2017 Audi R8 v10 plus NA version and need help with coding as VCDS is missing descriptions in long coding helper. Is there anyone here with access to an Audi R8 Gen 2 with laser headlamps installed or any info I can use? I am willing to pay you for your time if need be.
More Info if needed here:
Driver Side Headlamp Part #: 4S0 941 085
Passenger Side Headlamp Part #: 4S0 941 086
Module on rear side of headlamps: 4G0 907 397 Q
Module on underside: 7PP 941 572 AB
My VCDS Auto Scan:
Monday,08,May,2017,08:52:15:00489
VCDS Version: 17.4.1.1 (x64)  HEX-V2 CB: 0.4336.4
Data version: 20170413 DS270.4
VIN: WUAKBAFX8H7904441   License Plate:
Chassis Type: FX (4S0)
Scan: 01 02 03 05 06 08 09 11 31 15 16 17 19 1B 20 22 36 3B 42 44
          46 52 53 55 5F 65 6C 81 A6 C2
A6-Microphone -- Status: OK 0000
C2-Auto Trans 2 -- Status: OK 0000
Address 01: Engine (------CSPA)       Labels: None
   Part No SW: 4S0 907 552 A    HW: 4T0 907 552 A
   Component: 5.2l V10HDZ / H56 0005
   Revision: NHH56---
   Coding: 1A2500320526000D3000
   ASAM Dataset: EV_ECM52FSI1114S0907552A 001006
   ROD: EV_ECM52FSI1114S0907552A.rod
   VCID: 343215369EBB7137978-8060
Address 02: Auto Trans (J217)       Labels: None
   Part No SW: 4S0 927 155 E    HW: 0BH 927 711 F
   Component: AU 7 SB   NAR H10 3913
   Revision: 00H10V01
   ASAM Dataset: EV_TCMDL800041 001013
   ROD: EV_TCMDL800041_AU35.rod
   VCID: 392C2402B9D98C5F44E-806C
   Part No SW: 4S0 907 379 D    HW: 4S0 907 379 D
   Component: ESP PREMIUM   H09 0300
   Coding: 21A88109841581904B00
   ASAM Dataset: EV_ESPPremiAU57X 004048
   ROD: EV_ESPPremiAU57X_AU72.rod
   VCID: 3E26371EA0F7AB6771C-806A
   Part No SW: 4H0 907 064 JD    HW: 4H0 907 064 JD
   Component: BCM2 2.0      H44 0582
   Coding: 0D806506000000000000
   VCID: 74B2D536DEBB3137578-8020
   Serial number: 3216000310133013
   Part No SW: 4S0 959 760     HW: 4S0 959 760
   Component: MEM-BFS       001 0020
   Revision: AA001003    Serial number: 00000183852606
   Coding: 00001000000420F1000001210101210000000000000000
   VCID: 7BA0FE0AF3E57E4F162-802E
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 4S0 820 043 K    HW: 4S0 820 043 K
   Component: AC Automat    H08 0040
   Revision: 20012000    Serial number: 96800000005905
   Coding: 4000A01000000410
   ASAM Dataset: EV_AirCondiVAPrehAU72x 003005
   ROD: EV_AirCondiVAPrehAU72x.rod
   VCID: 3330162A9BB5760F8E2-8066
   Operating and display unit 2 for air conditioning:
   Subsystem 1 - Part No SW: 8S0 820 359 A    HW: 8S0 820 359 A
   Component: E775 BuA_2  H07 0020
   Serial number: 00000000000000007484
   Operating and display unit 3 for air conditioning:
   Subsystem 2 - Part No SW: 8S0 820 359     HW: 8S0 820 359
   Component: E776 BuA_3  H07 0020
   Operating and display unit 4 for air conditioning:
   Subsystem 3 - Part No SW: 8S0 820 359 B    HW: 8S0 820 359 B
   Component: E777 BuA_4  H07 0020
   Part No SW: 4H0 907 063 HK    HW: 4H0 907 063 EK
   Component: BCM1 2.0      H21 0725
   Revision: 2502102S    Serial number: 00001583385302
   Coding: 010D0011143C9FF0750048C380003800C59CD2882A08322100040894F1001100006000340B0000
   VCID: 78AAE106C2D355577B0-802C
   Subsystem 1 - Part No SW: 4S1 955 119 B    HW: 8V2 955 119 A
   Component: WWS624 170122  043 0081
   Serial number: 90248162170206143459
   Coding: 3247FD
   Serial number: 62551567
   Coding: 02005D
   Subsystem 3 - Part No SW: 4S0 941 531     HW: 4S0 941 531
   Component: E1 - LDS  H01 0044
   Serial number: 08 02 2017  00001490
   Component: USHL4.2  H30 0030
   Serial number: 00000000095Z02AF2B36
   Subsystem 5 - Part No SW: 4H0 907 658 B    HW: 4H0 907 658 B
   Serial number: 37B80C8800PAG0MUFU03
Address 11: Engine II (-----)       Labels: None
   Revision: NHH56---
   ASAM Dataset: EV_ECM52FSI2114S0907552A 001006
   ROD: EV_ECM52FSI2114S0907552A.rod
Address 15: Airbags (J234)       Labels: None
   Part No SW: 4S0 959 655     HW: 4S0 959 655
   Component: Airbag10.43   H62 0204
   Revision: --------    Serial number: 003NJ0015ZPP
   Coding: 303338453036303038324A55304C34533053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001036
   VCID: 7EA6F71EE0776B6731C-802A
   Serial number: 6940000Y160001K3NW0A
   Serial number: 3575HRB406947OGUD89X
   Serial number: 3585HRB405F47OGU7G1X
   Serial number: 3515JRB4018599BEDP31
   Serial number: 3525JRB400E598PKPPJB
   Serial number: 3554VRB40165971E81JW
   Serial number: 3564VRB40165971EK9VM
   Part No SW: 4S0 907 129 K    HW: 4S0 907 129 K
   Component: Lenks.Modul   H06 0007
   Revision: C0071527    Serial number: 91335QA700096-
   Coding: 000034
   VCID: 3E26371EA077AB6771C-806A
Address 17: Instruments (J285)       Labels: None
   Part No SW: 4S0 920 890 A    HW: 4S0 920 890 A
   Component: FBenUSA       H14 0251
   Coding: 086F32C1AA81CF050230ECC41800001000000000
   ASAM Dataset: EV_DashBoardBOSCHAU724 001022
   ROD: EV_DashBoardBOSCHAU724.rod
   Part No SW: 4S0 907 468 B    HW: 4S0 907 468 A
   Component: J533--Gateway H15 0074
   Revision: --------    Serial number: 00000002528777
   Coding: 802103161C
   ROD: EV_GatewPkoUDS_VW51.rod
   VCID: 3B203E0AB3E5BE4F562-806E
   Subsystem 1 - Part No SW: 4S0 915 181     HW: 4S0 915 181
   Component: J367-BDM  H08 0270
   Serial number: 54033404062871167736
   Part No SW: 8K0 907 144 N    HW: 8K0 907 144 N
   Component: DYNAMIKLENK.  H06 0740
   Coding: 0D0000
   VCID: 3A2E3B0EBC5F87474D4-806E
   Part No SW: 81A 857 511 H    HW: 81A 857 511 H
   Component: FLA           H10 0003
   Revision: AB001001
   Coding: 0404001D00010001000001
   ASAM Dataset: EV_HighBeamAssisAU724 001007
   ROD: EV_HighBeamAssisAU724.rod
   VCID: 2D0400527D9120FFD86-8078
Address 22: AWD (J492)       Labels: None
   Part No SW: 4S0 907 160     HW: 4S0 907 160
   Component: 4 Wheel Drive H07 0207
   Revision: 00001002    Serial number: BBPX5FO
   ASAM Dataset: EV_AllWheelContrBORGLB724 006012
   ROD: EV_AllWheelContrBORGLB724.rod
   VCID: 6E86C75EB0171BE7A1C-803A
   Component: MEM-FS        001 0020
   Revision: AA001003    Serial number: 00000183852605
   Coding: 00181900000420F1C00001210101210000000000000000
   Component: SARA 6D red   H04 0056
   Revision: --------    Serial number: EJ1BPA7E02LSBY
   ASAM Dataset: EV_SARA2 005012
   ROD: EV_SARA2.rod
   VCID: 3728223A8FCD9A2FB2A-8062
   Coding: 011C53425000000300000402
   VCID: 47C852FAFFADEAAFC2A-8012
Address 44: Steering Assist (J500)       Labels: None
   Part No SW: 4S0 909 144 H    HW: 4S0 909 144 B
   Component: EPS           H13 0905
   Revision: 00000000    Serial number:      L00189141
   Coding: 0903
   ASAM Dataset: EV_EPSZFAU72X 003010
   ROD: EV_EPSZFAU72X_003.rod
   VCID: 3A2E3B0EBCDF87474D4-806E
Address 46: Central Conv. (J393)       Labels: 4H0-907-064-46.clb
   Revision: 00002001    Serial number: 0431821718
   Coding: 0106069A00F24081E0B0CC00008500000001000000000000000000000000
   Subsystem 1 - Part No SW: 4S0 959 719 A    HW: 4S0 959 719 A
   Component: GTO BF  H01 0010
   Serial number: 20170116080759 00110
   Coding: 011C53425E00000300000400
   VCID: 46D65FFEF8A7F3A739C-8012
   Part No SW: 4S0 907 801     HW: 8K0 907 801 J
   Component: EPB-4         H03 0001
   Revision: --------    Serial number: 30000000002951
   ROD: EV_ParkiBrake_AU72.rod
   VCID: 70BAD926AA230D17B30-8024
Address 55: Headlight Range (J745)       Labels: None
   Part No SW: 4H4 907 357 G    HW: 7P6 907 357 B
   Component: MxB-ECU       001 0115
   Coding: 077A081122600400
   ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005011
   VCID: 36362F3E88C76327A9C-8062
   Subsystem 1 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0008
   Coding: E02200
   Subsystem 2 - Part No SW: 7PP 941 572 AC    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0008
   Coding: E02200
   Part No SW: 4S0 035 025 B    HW: 4S0 035 025
   Component: MU-H-LNS-US   053 0907
   Serial number: A353B0H7515434
   Coding: 012704020000000013220002041A00102F0000E1007000047E
   ASAM Dataset: EV_MUHig6C8Gen2HBAS 001182
   ROD: EV_MUHig6C8Gen2HBAS.rod
   VCID: 280AF146527305D72B0-807C
   Subsystem 1 - Part No SW: V03 959 801 GG    HW: -----------
   Component: NAR 2017  --- 0057
   Multimedia Operating Unit:
   Subsystem 2 - Part No SW: 4S1 919 614 D    HW: 4S1 919 614 D
   Serial number: APVAK123121600010167
   Component: Gracenote2---  --- 3011
Address 65: Tire Pressure (-----)       Labels: 3Y0-907-273.clb
   Part No SW: 4H0 907 273 D    HW: 4H0 907 273 B
   Component: RDKBERU25     H10 0900
   Serial number: 10000000037136
   ROD: EV_RDKBERU25_AU57.rod
   VCID: 2C020D56468B29F7CF8-8078
Address 6C: Back-up Cam. (J772)       Labels: None
   Part No SW: 4S0 980 556 A    HW: 95B 980 551 L
   Component: RVC Compact   H12 0201
   Coding: 027504010A000001000040
   ASAM Dataset: EV_CamSysRVRVCPANAAU57X 002003
   ROD: EV_CamSysRVRVCPANAAU57X_AU72.rod
   Part No SW: 4S1 713 041 E    HW: 4M1 713 041 F
   Component: GSM-LL        H09 0073
   Revision: 0L0D5012    Serial number: 20161111001943
   ROD: EV_GSMWaehlZFAU736_AU49.rod
Address A6: Microphone (J886)       Labels: 420-907-394.clb
   Part No SW: 420 907 394 B    HW: 420 907 394
   Component: BELTMICBOX    H10 0820
   Coding: 0101030202
   ASAM Dataset: EV_BeltMicPARAGAU335 003011
   ROD: EV_BeltMicPARAGAU335_AU35.rod
   VCID: 186AC186E213B5579B0-804C
Address C2: Auto Trans 2 (J217)       Labels: None
   Part No SW: 4S0 927 109     HW: 4S0 927 109
   Component: DL800 ZSG     H12 0002
   Revision: --H12---    Serial number: 0000000059
   Coding: 000001
   ASAM Dataset: EV_TCMDL800421 001024
   ROD: EV_TCMDL800.rod
   VCID: 73B0D62ADB35360F4E2-8026
Andy
Sector 7G
HC424490
I found a scan from a car with "Headlight 8IZ LED headlamp with variable light distribution and additional laser high beam" and this is what the 09 and 55 modules look like:
     Part No SW: 4H0 907 063 GK    HW: 4H0 907 063 EK
     Component: BCM1 2.0      H20 0369
     Revision: 25020001    Serial number: 00001234335301
     Coding: 010D0052143C9FF0750048C300003800C59CD2882A08322140040894F1001100006000340B0000
     VCID: 77F7F3C2C6A8A1F9D8-8022
     Subsystem 1 - Part No SW: 4S1 955 119     HW: 8V2 955 119 A
     Component: WWS624 150808  042 0071
     Serial number: 90248139151123123400
     Coding: 3247FD
     Serial number: 61201206
     Coding: 02005D
     Serial number: 05 01 2016  00000133
     Serial number: 00000000095Z0220E002
     Subsystem 5 - Part No SW: 4H0 907 658     HW: 4H0 907 658
     Serial number: B128CAD7000000000001
     Subsystem 6 - Part No SW: 4S0 941 330     HW: 4S0 941 330
     Component: J1054 OsramL2  H06 S003
     Serial number: 152470935
     Subsystem 7 - Part No SW: 4S0 941 330     HW: 4S0 941 330
     Component: J1055 OsramL2  H06 S003
     Serial number: 151540473
     Coding: 077A083122600400
     VCID: 36693EC6892298F103-8062
     Coding: E02300
     Coding: E02300
These modules are the subsytems or slave modules to the master 09 module:
It doesn't look like they have Coding of their own.
phonerebel
C?ID=162146
Thank you so much! You're a lifesaver. I have installed the lights on the car and will attempt this coding now. My car seems to be missing 2 modules though is that correct?
phonerebel
C?ID=162146
Coding was accepted. The blue diode in the headlamps was activated and high beams now work. Laser light option is now showing up in the MMI settings. Unfortunately this error is staying on probably due to the missing modules.
03455 - Function Restriction due to Faults in Other Modules
Reset counter: 17
Mileage: 552 km
Date: 2017.05.12
Time: 13:11:23
phonerebel
C?ID=162146
Is there any way you can give me the coding for the high beam assistant as well?
Dana
Western PA, USA
Yeah we think so. We can't share the VIN or full scan from that example car but it was a Canadian (B0E Component parts set, complying with
vehicle type for Canada, various parts) market R8:
Model audi r8 qu. 5.2
R8
Date of production 12.02.2016
Year 2017
Sales type 4S35BE
Engine Code CSPA
Transmission Code RZZ
8K4 Separate daytime running lights -- NAR --
I'm not entirely sure what those Osram slaves are though based on the part number shown in the scan. It is possible they are part of the lamp itself and need to be coded. This was the parts screen from the example car:
Dana
Western PA, USA
Sure:
> Part No SW: 4S0 857 511 A HW: 8S0 857 511 D
> Component: FLA H09 0003
> Revision: AB001001
> Coding: 040C001D00010001000001
> VCID: 336F07D29A508DD924-8066
Please post another scan from your car after the coding tweak.
phonerebel
C?ID=162146
Thank you! The coding was different there as well. I have a feeling that there is more coding discrepancies elsewhere that could possibly be affecting this. Is a full auto scan too much to ask for? Of course omitting the vin number.
phonerebel
C?ID=162146
Just saw you said you couldn't share full scan. How about the 17 Instruments and Central Conv.?
Dana
Western PA, USA
I just sent the owner of that factory equipped Laser Headlamp R8 an e-mail linking him to this thread. He was looking for some tweak assistance so hopefully you guys can speak directly.
Does your car have the ability to turn on/off the auto-locks (i.e. doors lock at xx mph) feature in the MMI?
Dana
Western PA, USA
Thanks, I think I found the bit for him to turn OFF auto-locks completely in #46 (Byte 5, Bit 4) but I don't know if 17 (or even 5F) support Adp or Coding that may make the menu available. Please don't feel obligated but I wonder if Byte 05, Bit 5 in #17 would enable that menu.
>     Part No SW: 4S0 920 790     HW: 4S0 920 790
>     Component: FBenRDW       H14 0228
>     Coding: 082F32C1AA8100080230ECC41800001000000000
>     ASAM Dataset: EV_DashBoardBOSCHAU724 001020
>     VCID: 72E1C2D6A5CAC4D706-8026
>     Part No SW: 4H0 907 064 GD    HW: 4H0 907 064 GD
>     Component: BCM2 2.0      H37 0572
>     Revision: 00002001    Serial number: removed
>     Coding: 0106029A00F24081E0B0CC00008500000001000000000000000000000000
>     VCID: 71E3CDDAA8CCFFCFFF-8024
phonerebel
C?ID=162146
I'll definitely try that option for you, the least I can do for the help. Will report back in a few minutes.
roentgen68
Canada
C?ID=144775
Hello!
I'm the Canadian Guy...
Here is the complete Auto-Scan:
Monday,08,May,2017,13:33:57:26085
VIN: private   License Plate:
Scan: 01 02 03 05 08 09 11 31 15 16 17 19 1B 20 22 3B 42 44 46 52
VIN: private
   Revision: NHH56---
   VCID: 346D04CE9F5E8AE7D4-8060
Readiness: 1110 1101
   Part No SW: 4S0 927 155 A    HW: 0BH 927 711 F
   Component: AU 7G D   NAR H10 3709
   Revision: 00H10V01
   VCID: 356B39CA942493EFE3-8060
   Part No SW: 4S0 907 379 A    HW: 4S0 907 379 A
   Component: ESP PREMIUM   H09 0210
   VCID: 3B7F2FF2B200459F15-806E
   Coding: 0D806006000000000000
   Serial number: 3215000205618003
   Part No SW: 4S0 820 043 H    HW: 4S0 820 043 H
   Component: AC Automat    H08 0030
   Revision: 20011000    Serial number: 96800000001797
   VCID: 306508DE6B46B6C7B0-8064
   Serial number: 00000000000000002758
   VCID: 77F7F3C2C6A8A1FF31-8022
   Coding: 3247FD
   Coding: 02005D
   Revision: NHH56---
   Component: Airbag10.43   H62 0203
   Revision: --------    Serial number: 003NJ0011T3-
   Coding: 30333845303530303731554A304C34533053
   ASAM Dataset: EV_AirbaAU10BPAAU64X 001034
   VCID: 7EF9E6E6E19290B772-802A
   Serial number: 6940000Y140001A7UV08
   Serial number: 3575HRB40513M4706PUA
   Serial number: 3585HRB405V3M470A8VT
   Serial number: 3515JRB40573KTB4JHEW
   Serial number: 3525JRB405H3KTB428FI
   Serial number: 3554VRB404V3L82CHOC9
   Serial number: 3564VRB404V3L82CNOIM
   Component: Lenks.Modul   H06 0006
   Revision: C0071527    Serial number: 91335OLD01442-
   Coding: 000034
   VCID: 3E7926E6A91250B732-806A
   Component: J533--Gateway H14 0073
   Revision: --------    Serial number: 00000002106963
   Coding: 802103161C
   Subsystem 1 - Part No SW: 8K0 915 181 M    HW: 8K0 915 181 M
   Serial number: 62317318513371980485
   Coding: 0D0000
   VCID: 3A712AF6B53A7C970E-806E
   Revision: AB001001
   VCID: 336F07D29A508DDFCD-8066
   Revision: 00001002    Serial number: BBN15Q7
   VCID: 6ED9D6A6B1F2E037E2-803A
   Revision: --------    Serial number: EJ1BPA7E01YFH$
   ROD: EV_SARA2.rod
   VCID: 377733C28E2861FFF1-8062
   Coding: 011C53425000000100000402
   VCID: 47974302F6C8117F81-8012
   Part No SW: 4S0 909 144 G    HW: 4S0 909 144 B
   Component: EPS           H13 0904
   Revision: 00000000    Serial number:      L00117541
   Coding: 0903
   ASAM Dataset: EV_EPSZFAU72X 002010
   ROD: EV_EPSZFAU72X_002.rod
   VCID: 397335FAB83C778F07-806C
   Revision: 00002001    Serial number: 0384871164
   Serial number: 20160105072942 00006
   Coding: 011C53425E00000100000400
   VCID: 46894E06F1C208777A-8012
   Component: EPB-4         H02 0001
   Revision: --------    Serial number: 30000000001269
   VCID: 70E5C8DEABC6F6C7F0-8024
   VCID: 36693EC6892298F7EA-8062
   Coding: E02300
   Coding: E02300
   Part No SW: 4S0 035 025     HW: 4S0 035 025
   Component: MU-H-LNS-US   051 0383
   Serial number: A353A0GB000707
   Coding: 012704020000000013220002041A00002F0000E0007000047E
   VCID: 66C9AE86990228779A-8032
   Subsystem 2 - Part No SW: 4S1 919 614     HW: 4S1 919 614
   Component: ControlUnit_H  H23 0136
   Serial number: C1000017091500010165
   Component: Gracenote2  --- 3008
          B11CF 53 [009] - Deactivated
                    Reset counter: 249
                    Mileage: 13320 km
                    Date: 2017.05.07
                    Time: 07:59:42
                    Voltage terminal 30: 12.1 V
                    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
                    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
   Serial number: 10000000021113
   VCID: 2C5D1CAE476ED2278C-8078
Address 6C: Back-up Cam. (J772)       Labels: 5Q0-907-441.clb
   Part No SW: 4S0 907 441 B    HW: 5Q0 907 441 A
   Component: D4-PA RVC Mid H07 0050
   Coding: 022704010A01000100
   ASAM Dataset: EV_CamSysRearPANAAU914 002002
   ROD: EV_CamSysRearPANAAU914.rod
   VCID: 326102D6654A84D7C6-8066
   Part No SW: 4S1 713 041 B    HW: 4M1 713 041 D
   Component: GSM-LL        H07 0068
   Revision: 0L0D5012    Serial number: 20151116000818
   ASAM Dataset: EV_GSMWaehlZFAU736 001013
   VCID: 2A511AB64D9ACC177E-807E
   Part No SW: 420 907 394 A    HW: 420 907 394
   Component: BELTMICBOX    H10 0600
   Coding: 0101030202
   VCID: 1737D342EEE841FFD1-8042
   Component: DL800 ZSG     H11 0002
   Revision: --H11---    Serial number: 0000000061
   Coding: 000001
   VCID: 73EFC7D2DAD0CDDF0D-8026
End-------------------------(Elapsed Time: 05:04)--------------------------
phonerebel
C?ID=162146
Hey there, just want to thank you extensively for your code. It made all the difference and the headlamps are fully installed now without any errors :D
I have tried that coding for you and I wasn't able to get any additional options in my locking menu. I do see options which look like what you need in my VCDS menu which I'm not sure if you see on your end, they are here: http://imgur.com/a/KW3jY
phonerebel
C?ID=162146
Also does your Audi R8 come equipped with Apple CarPlay feature? I am trying to see if a retrofit of this is at all possible. It might be software or an additional module.
Dana
Western PA, USA
Filip,
I'm glad to hear the lights are functioning properly! Would you mind posting the final (fully functional) Auto-Scan?
phonerebel
C?ID=162146
Yes, I can't get to my car right now but this scan was right before getting the lasers to work. Currently there are no fault codes.
Monday,15,May,2017,18:07:42:00489
VCDS Version: 17.4.2.3 (x64)  HEX-V2 CB: 0.4336.4
Data version: 20170505 DS270.4
   Revision: NHH56---
   VCID: 343215369EBB7137974-8060
   Revision: 00H10V01
   VCID: 392C2402B9D98C5F442-806C
   VCID: 3E26371EA0F7AB67710-806A
   VCID: 74B2D536DEBB3137574-8020
   VCID: 7BA0FE0AF3E57E4F16E-802E
   VCID: 3330162A9BB5760F8EE-8066
   Shop #: WSC 12345 123 61029
   VCID: 78AAE106C2D355577BC-802C
   Coding: 3247FD
   Coding: 02005D
   Serial number: 151040743
   Serial number: 150830357
                    Reset counter: 19
                    Mileage: 596 km
                    Date: 2017.05.13
                    Time: 01:10:44
   Revision: NHH56---
   VCID: 7EA6F71EE0776B67310-802A
   Coding: 000034
   VCID: 3E26371EA077AB67710-806A
   Coding: 802103161C
   VCID: 3B203E0AB3E5BE4F56E-806E
   Coding: 0D0000
   VCID: 3A2E3B0EBC5F87474D8-806E
   Revision: AB001001
   VCID: 2D0400527D9120FFD8A-8078
   VCID: 6E86C75EB0171BE7A10-803A
   ROD: EV_SARA2.rod
   VCID: 3728223A8FCD9A2FB26-8062
   VCID: 47C852FAFFADEAAFC26-8012
   Coding: 0903
   VCID: 3A2E3B0EBCDF87474D8-806E
   VCID: 46D65FFEF8A7F3A7390-8012
   VCID: 70BAD926AA230D17B3C-8024
   VCID: 36362F3E88C76327A90-8062
   Subsystem 1 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo li.  H09 0003
   Coding: E02300
   Subsystem 2 - Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A  Labels: 3D0-941-329.CLB
   Component: LED LeiMo re.  H09 0003
   Coding: E02300
5275220 - Headlight
                    Reset counter: 19
                    Mileage: 596 km
                    Date: 2017.05.13
                    Time: 01:10:45
   VCID: 280AF146527305D72BC-807C
   VCID: 2C020D56468B29F7CF4-8078
   Coding: 0101030202
   VCID: 186AC186E213B5579BC-804C
   Coding: 000001
   VCID: 73B0D62ADB35360F4EE-8026
End----------(Elapsed Time: 01:56, VBatt start/end: 12.2V/12.3V)-----------
roentgen68
Canada
C?ID=144775
No Apple CarPlay.
What is Apple?? Just kidding!!
S.
roentgen68
Canada
C?ID=144775
Autolock DISABLED !!
Thanks to all.
Menu item not available with second coding, but I don't care as long as the Autolock is gone.
GR8 !!!
