Tiguan 2013 Bi-xenon retrofit (No AFS)
m87a
Bosnia and Herzegovina
C?ID=156900
your option 1 is while keeping those headlights, is to install AFS module with rear height sensor, buy used one especially from tiguan AFS module to avoid programming module, code it and code in bcm that high beams are triggered via can. you will have working AFS with high beams this way or
option 2 to sell these and buy regular bi xenon headlights and connect, high beams will work, AFS will not
   #22
Dana
Western PA, USA
I think m87a is correct and installing a fully functional AFS system (used Tiguan module module, level sensor, CAN wiring) is probably best but what happens when you tick the High Beam via Shutter active/installed bit in Byte 25?
m87a
C?ID=156900
i'm speaking from experience, been there done that, what is happening is that when you pull high beam stalk, bcm is sendind can signal to AFS and AFS is sending signal to headlights via sub can to operate stepper motor to high beam position, so ticking byte 25 won't change a thing, this is the only way to make these headlight operate
   #24
nickpi
Greece
C?ID=40501
High beams still not working!
Dear Dana and m87a,
Thank you again for your help!
When byte 25 is ticked and light switch is on for only DRL lights, when the momentary switch is hit, the xenons go on. When light switch is on the Low beams on position and the xenons are on, nothing happens.
The Xenons go on when hitting the momentary switch only when Byte 17 Bit 2 is ticked (Bi-xenon without additional high beam)
To install AFS as proposed, do I need any extra wiring modifications ?? - I've already ordered everything needed
Best regards,
Nicolas
   #25
nickpi
Greece
C?ID=40501
Merry Xmas to you all!!
After numerous mods done and hours after hours spent, an AFS system is installed, it perfectly works by the way, my high beams still won't work. I've tried everything.... My next guess is that I have to change some values in adaptations in 09 module. My auto scan follows. Is there anybody willing to help?
Saturday,09,December,2017,15:02:39:52699
VCDS Version: 17.8.1.0 (x64)
VIN: WVGZZZ5NZDW043218   License Plate: 8554
Mileage: 132320km-82219mi   Repair Order:
Chassis Type: 5N-VW36 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 4C 52 53 55 56 61 62 72
          77
VIN: WVGZZZ5NZDW043218   Mileage: 132320km-82219miles
   Part No SW: 03L 906 018 LE    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   H28 4571
   Revision: 41H28---    Serial number: 00000000000000
   Coding: 00190012040401080000
   ASAM Dataset: EV_ECM20TDI01103L906018LE 003009
   ROD: EV_ECM20TDI01103L906018LE.rod
   VCID: 78F43811C31E9086A9-802C
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 AR    HW: 5N0 614 109 AR
   Component: J104   C6 450M VDCE 0006
   Revision: --H07---    Serial number: 00000006258606
   Coding: 0037947
   VCID: 7BFE271D3A28BB9EC4-802E
   Part No SW: 5K0 907 044 GJ    HW: 5K0 907 044 GJ
   Component: Climatronic   H19 1313
   Revision: 00001004
   Coding: 0010004003
   VCID: 79F23D15F814898ED6-802C
   Part No SW: 5K0 937 087 AB    HW: 5K0 937 087 AB
   Component: BCM PQ35 H    122 0174
   Revision: BE122001
   Coding: 46180A38802500C0008800C0300089C84FFDAB88436D8160E480C7040041
   Shop #: WSC 00020 790 12345
   VCID: 75EA3125DC0CEDEEB2-8020
   Subsystem 1 - Part No SW: 5N1 955 119     HW:              Labels: 1KX-955-119.CLB
   Component: Wischer 08101  013 0204
   Serial number: N1955119   °204!
   Coding: 009795
   Component: RLS 051012 05  54  0403
   Coding: 02304D
   Part No SW: 5N0 959 655 AA    HW: 5N0 959 655 AA
   Component: J234__20J VW10 HI   2118
   Revision: 24017000    Serial number: 003L7PLTU4Q.
   Coding: 0012362
   VCID: 7CFC24013F26BCA6CD-8028
   Subsystem 1 - Serial number: 6332MTS661652712
   Subsystem 2 - Serial number: 6342MTS670032702
   Subsystem 3 - Serial number: 6351HTS6P6IVBBKR
   Subsystem 4 - Serial number: 6361HTS6CUTADBKR
Address 16: Steering wheel (J527)       Labels:| 8X0-953-569.clb
   Part No SW: 8X0 953 501 Q    HW: 5K0 953 569 AP
   Revision: FF010018    Serial number: 20140409200806
   Coding: 118A040000
   Shop #: WSC 00049 770 00118
   VCID: 489488D1F37E200619-801C
   Subsystem 1 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H31 0033
   Coding: 820000
   Part No SW: 5N0 920 883 A    HW: 5N0 920 883 A
   Component: KOMBI         H05 0505
   Coding: 111F00
   VCID: 3260CA3965E2BAD657-8066
   Part No SW: 7N0 907 530 AC    HW: 7N0 907 530 AC
   Component: J533  Gateway H48 1633
   Revision:   H48       Serial number: 270912F2000492
   Coding: 356002
   VCID: 71E20535A864C1CE6E-8024
   Component: IMMO          H05 0505
   VCID: 6AD012598DB232162F-803E
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0005716407
   Coding: 0200BC
   VCID: 3874F811839E508669-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 F    HW: 3C0 959 794 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1504
   Serial number: 00000007278896
   Coding: 000090
   Part No SW: 5N1 909 144 N    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.285 1101
   Revision: 1AH03837    Serial number: 00122690267701
   Coding: 0000258
   VCID: 3D7AE90564BC75AEBA-8068
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0005756361
   Coding: 0200BC
   VCID: 3972FD15B894498E96-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 F    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  008 1504
   Serial number: 00000007283631
   Coding: 000090
   Part No SW: 3AA 907 801 H    HW: 3AA 907 801 H
   Component: J540 EPB4  VW-86594 0010
   Revision:   H19       Serial number: 00000000511436
   Coding: 0026167
   VCID: 3668F629418AA6F67B-8062
   Coding: 041200000B000400
   VCID: 3776FB2D8E805FFE60-8062
   Subsystem 1 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H02 0010
   Coding: 140000
   Subsystem 2 - Part No SW: 4H0 941 329     HW: 4H0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H02 0008
   Coding: 140000
   Part No SW: 5ND 035 190 B    HW: 5ND 035 190 B
   Component: RCD510USBRVC  003 0003
   Revision: -----001    Serial number: VWZ4Z3R8092332
   Coding: 0100042504000C
   Shop #: WSC 79107 123 12345
   VCID: 3B7EE71DBAA87B9E84-806E
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AC
   Component: Batt.regelung H48 1633
   Coding: 030F1859
   Component: J367-BDM  H07 0180
   Serial number: 00000000008900271979
Address 77: Telephone (J738)       Labels:. 1K8-035-730.clb
   Part No SW: 1K8 035 730 D    HW: 1K8 035 730 D
   Component: Telefon       H08 6900
   Revision: 00008000    Serial number: 00000A10634076
   Coding: 412120
   Shop #: WSC 00078 790 00199
   VCID: 2A50D2594532F216EF-807E
End-------------------------(Elapsed Time: 02:38)--------------------------
I notice you have posted this in two places - not a good idea as it just splits replies you get, just post in one place it's a much better idea :thumbs:
BTW I seem to recall that you need to connect the Bi-Xenon shutters to different pins on the BCM, ones which are not used otherwise. Maybe worth doing some research (Google?) about that?
   #27
nickpi
Greece
C?ID=40501
Hello PetrolDave!
Thanks for your reply! I'm searching fro about six months now... I did connect the shutters to BCM gold connector.
   #29
nickpi
Greece
C?ID=40501
THANKS DO MUCH M87A ONCE AGAIN !!!!! NOW IT WORKS!!!! AFTER SIX MONTHS....... THANKS AND HAVE A HAPPY NEW YEAR !!!!!
