- Joined
- Aug 22, 2014
- Messages
- 500
- Reaction score
- 231
- Location
- Maryland, USA
- VCDS Serial number
- C?ID=66650
Hi Folks,
I happened to check this car for no start issues.Found key stuck in ignition switch, car does nothing when I tried to start with key or start button. Car has strong battery. The message "move gear level to park position otherwise car may roll'' sometimes appear on dash insert, though gear is already in park. I diagnosed the car but found floor carpet wet.
I found the access and start auth. module under driver seat wet, opened module to find moisture and rusts/shorts on the printed circuits. i checked for power and ground inputs to module all ok. As access and start module has no commuication, I am thinking of replacing it but not sure what other tasks may be required in addition to enable start permission. Would I need to replace the steering colum lock and reprogram keys?
Anybody done this before and willing to share will be great.
Saturday,15,April,2017,15:42:42:46890
VCDS Version: 17.1.3.0 (x64)
VIN: WAUMV44E87N015128 License Plate:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 34 36 37 38 42 46 47
4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUMV44E87N015128 Mileage: 207860km-129158miles
00-Steering Angle Sensor -- Status: Cannot be reached 1100
02-Auto Trans -- Status: Cannot be reached 1100
03-ABS Brakes -- Status: Cannot be reached 1100
05-Acc/Start Auth. -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
0E-Media Player 1 -- Status: Malfunction 0010
15-Airbags -- Status: Cannot be reached 1100
34-Level Control -- Status: Cannot be reached 1100
36-Seat Mem. Drvr -- Status: Malfunction 1010
42-Door Elect, Driver -- Status: Malfunction 1010
46-Central Conv. -- Status: Malfunction 1010
4F-Centr. Electr. II -- Status: Malfunction 1010
53-Parking Brake -- Status: Cannot be reached 1100
55-Headlight Range -- Status: Cannot be reached 1100
61-Battery Regul. -- Status: Malfunction 1010
62-Door, Rear Left -- Status: Sporadic communication error 1000
65-Tire Pressure -- Status: Malfunction 1010
67-Voice Control -- Status: Malfunction 0010
6C-Back-up Cam. -- Status: Malfunction 1010
76-Park Assist -- Status: Malfunction 1010
Address 01: Engine
Address 02: Auto Trans
Address 03: ABS Brakes
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0FD713911
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58B44179EBA44181F1-800C
Component: ELV XXXX
15 Faults Found:
00956 - Key 2
002 - Lower Limit Exceeded
Fault Status: 01100010
Fault Frequency: 11
Reset counter: 214
Mileage: 205792 km
Date: 2016.08.27
Time: 18:14:30
00191 - Passenger's Door Handle Touch Sensor (G416)
007 - Short to Ground
Fault Frequency: 11
Reset counter: 214
Mileage: 205792 km
Date: 2016.08.27
Time: 18:14:30
00179 - Access/Start Authorization Antenna; Drivers Side (R134)
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 00:00:10
00180 - Access/Start Authorization Antenna; Passenger Side (R135)
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 00:00:10
00181 - Access/Start Authorization Antenna (in Rear bumper) (R136)
Fault Frequency: 14
Reset counter: 17
Mileage: 207856 km
Date: 2016.10.30
Time: 00:04:14
00182 - Luggage Compartment Access/Start Authorization Antenna (R137)
Fault Frequency: 14
Reset counter: 17
Mileage: 207856 km
Date: 2016.10.30
Time: 00:04:14
00183 - Interior Access/Start Authorization Antenna 1 (R138)
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 02:12:00
00288 - Steering Column Lock Actuator (N360)
010 - Open or Short to Plus
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 02:12:00
00192 - Rear Left Door Handle Touch Sensor (G417)
Fault Status: 01100111
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 00:26:38
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 00:26:38
00955 - Key 1
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 00:28:34
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.30
Time: 00:28:34
00187 - Control Circuit; Relay for Supply Voltage Terminal 75X
009 - Open or Short to Ground
Fault Status: 01101001
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.31
Time: 01:10:52
00166 - Access/Start Authorization Switch (E415)
014 - Defective
Fault Frequency: 0
Reset counter: 232
Mileage: 207856 km
Date: 2016.10.31
Time: 01:10:52
Temperature: 66.2°C
Raw, Form. N/A: 000 000 000
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Shop #: WSC 02313 785 00200
VCID: 244C2589E76CD561AD-8070
Reset counter: 17
Mileage: 207864 km
Date: 2016.10.31
Time: 00:41:34
00456 - Control Module for Access and Start Control (J518)
Reset counter: 17
Mileage: 207864 km
Date: 2016.10.31
Time: 00:41:34
Reset counter: 17
Mileage: 207864 km
Date: 2016.10.31
Time: 00:37:20
01875 - Backrest/Head Adjustment Button (E332); Down
Reset counter: 17
Mileage: 207864 km
Date: 2016.10.31
Time: 00:37:20
01874 - Backrest/Head Adjustment Button (E332); Up
Fault Status: 00100011
Reset counter: 17
Mileage: 207864 km
Date: 2016.10.31
Time: 00:08:44
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 C HW: 4E0 035 729 A
Component: Interfacebox H43 4140
Revision: 00000000 Serial number: 348AJ077509210
Coding: 0000000
VCID: 22402391FD78DB51DF-8076
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0040
Subsystem 2 - Serial number: 00000000029809
Subsystem 3 - Serial number: 0129.01.070000000100010034ÿ
Subsystem 4 - Serial number: 010034ÿ
00003 - Control Module
Fault Status: 01100101
Reset counter: 232
Mileage: 207866 km
Date: 2016.10.31
Time: 00:00:19
Reset counter: 232
Mileage: 207866 km
Date: 2016.10.31
Time: 00:00:19
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.31
Time: 00:06:29
02103 - Control Module 2 for Vehicle Electrical System (J520)
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.31
Time: 00:06:29
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.31
Time: 00:06:29
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000112731
Coding: 0037185
VCID: 1C3C1D69DF1CEDA115-8048
7 Faults Found:
Fault Frequency: 24
Reset counter: 232
Mileage: 207866 km
Date: 2016.10.30
Time: 06:07:26
Bin. Bits: 00011111
00532 - Supply Voltage B+
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.30
Time: 08:28:37
Voltage: 8.60 V
00455 - Control Module for Access and Start Control; Comfort CAN (J518)
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.30
Time: 08:28:37
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.30
Time: 00:00:19
Bin. Bits: 00011000
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.30
Time: 00:00:19
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.30
Time: 00:59:17
Voltage: 11.70 V
014 - Defective
Reset counter: 17
Mileage: 207866 km
Date: 2016.10.30
Time: 00:59:17
Address 09: Cent. Elect.
Address 0E: Media Player 1
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0530
Revision: D04 Serial number: AUDID3G0002793
Coding: 0048263
Shop #: WSC 56311 001 1048576
VCID: 254A388DEC562C69BA-8070
01704 - Terminal 58 (Dimming)
Fault Status: 00000011
Reset counter: 168
Mileage: 189826 km
Date: 2015.08.22
Time: 14:43:14
Reset counter: 168
Mileage: 189826 km
Date: 2015.08.22
Time: 14:43:14
Address 19: CAN Gateway
Address 34: Level Control
Address 36: Seat Mem. Drvr
Address 37: Navigation
Address 38: Roof Electronics
Address 46: Central Conv.
Address 47: Sound System
Address 4F: Centr. Electr. II
Address 52: Door Elect, Pass.
Address 53: Parking Brake
Address 55: Headlight Range
Address 56: Radio
Address 61: Battery Regul.
Address 62: Door, Rear Left
Address 65: Tire Pressure
Address 67: Voice Control
Address 6C: Back-up Cam.
Address 72: Door, Rear Right
Address 76: Park Assist
Address 77: Telephone
End-------------------------(Elapsed Time: 03:10)--------------------------
