MQB (Mk7 Golf) Steering Angle Sensor (G85) Calibration in 44 - Steering Assist
Andy
Sector 7G
HC424490
We've had some customer inquiries about this so I was able to induce a fault in my 2015 GTI in 44-Steering Assist and was able to clear it using the following steps.
First, here is the fault in question:
So first with the engine running, I went into Adv Meas Values and made sure that the steering wheel was pointed straight and the front wheels were pointed straight, close enough:
Edit to show identifier for use use with recent versions of VCDS:
[IDE04448-IDE00924],Steering angle sensor: angle - Steering angle
Next, I went into Security Access -16 and entered the code that shows up in the little helper balloon and it was accepted.
Next, I went into Basic Settings - 04 and chose "Steering angle sensor" and clicked [Go!]
Edit to show identifier for recent versions of VCDS:
[MAS00815] Steering angle sensor
Here's the weird part, it showed "Running" but never changed from that. I left it in this mode for 60 seconds then clicked on [Stop] and [Done, Go Back] and [Close Controller, Go Back].
Next, I cycled the ignition off and back on again. At this point, the TPMS, steering wheel, and ESP lights were still lit up on the dash but a brief drive through a parking lot made them all go away.
Andy
Sector 7G
HC424490
Excellent, C?ID=211236 confirmed the procedure worked for his replaced steering rack. But I typed too soon, he has some end stop faults. I will update as he tests more.
Andy
Sector 7G
HC424490
Internal note: C?ID=142088 | E?ID=281238
ReflexSilverMkVII
C?ID=256588
Address 44: Steering Assist       Labels: 5Q0-909-144.clb
Control Module Part Number: 3Q0 909 144 J    HW: 3Q0 909 144 H
  Component and/or Version: EPS_MQB_ZFLS  505 5063
           Software Coding: 8102
            Work Shop Code: WSC 00066 790 00202
              ASAM Dataset: EV_SteerAssisMQB 012140 (VW37)
                       ROD: EV_SteerAssisMQB_VW31.rod
                      VCID: 393AFA0EB835028ACE-806C
16385 - Steering End Stops Not Learned
          C10AC F0 [009] - Unknown Error Elaboration
                    Reset counter: 157
                    Mileage: 21887 km
                    Date: 2016.11.29
                    Time: 16:04:39
                    Motor status: 01
                    System status: Driving mode
                    Supply voltage: 14.00 V
                    Temperature: 36.0 °C
                    KFC: 40
                    KFA: 00 01
                    Environmental conditions: 5F
                    Rotorlagesensorspannung AMR Sinus: 0.857 V
                    Rotorlagesensorspannung AMR Kosinus: 8.813 V
                    Rotorlagesensorspannung AMR Sinus 2: 0.837 V
                    Rotorlagesensorspannung AMR Cosinus 2: 3.916 V
                    Rotorlagesensorspannung Hall 1: 0.0 V
                    Rotorlagesensorspannung Hall 2: 0.0 V
                    Aktueller Sinus-Offset für ASIC: -0.0 mV
                    Aktueller Cosinus-Offset für ASIC: -0.1 mV
                    aktuelle Sinusverstärkung für ASIC: 0.169
I have the end stop faults and was wondering if you ever figured out what the solution is on the MkVII Golf.
automech
Poland
C?ID=14925
Start the car up, make sure that wheels and steering wheel is perfectly straight, go to 44, login, select basic setting of steering angle, then when it's saying "running" slowly turn the steering wheel all way to left, then slowly to the right, turn it back to straight. It should now show "Basic setting OK". Your G85 is now calibrated properly and end-stops faults should go away, if not do the same procedure but choose "learning end stops" in basic setting.
ReflexSilverMkVII
C?ID=256588
Thank you, I tried the first step under "steering angle", but then it made me have 4 new faults and my dash lit up with TPMS, ESC, Steering warning lamps that did not clear driving around the parking lot. I lost the active return function, steering felt really weird. I pulled back into parking lot, did the steering angle sensor reset again (no turning of the wheel) and that cleared the dash warning lights that were on and put my steering back to feeling normal, but it didn't clear the end stop fault... it came back. Just to confirm, when you say "learning end stops", you mean "software end stops"? Also, the status never changed from "running" to "Basic Setting Ok". I SINCERELY APPRECIATE YOUR HELP!
automech
Poland
C?ID=14925
Yes I meaned the "software end stops". Also when you will be turning the wheel, hold the wheel until dash beeps or for about 2 sec. in both left and right end positions.
Andy
Sector 7G
HC424490
We did some more testing on this in October and I don't think we've had a chance to detail a procedure yet but I will see what I can find.
ReflexSilverMkVII
C?ID=256588
Thank you so much. I really do appreciate it!
Dana
Western PA, USA
I believe automech has more experience than we do on the subject (we failed to truly break Andy's 2015 GTI) but these are notes from my most recent phone ticket on a crashed 2015 A3:
037224 - Steering angle sensor mechanical failure in 03 - ABS.
SA code 19249 = Adaptation/Basic Setting Enabling was needed for each basic setting attempt but you can only login once per diagnostic session (or it will error).
The somewhat successful run involved #44 > Adv MVB
[*IDE04448-IDE00924*],067,Steering angle sensor; angle - Steering angle,LINEAR,¡ã
to get it centered but he also checked some with descriptions like
[*IDE02216-IDE05795*],019,Steering angle sensor; basic setting - End basic setting,TT,
Which reported Not permitted. We selected SA > BS
[*IDE06133-*],4,Software end-stop reset,HEXBYTES,
which finished correctly and had to exit entirely because the next SA is refused. After another reconnect to 44 we got BS
[*MAS00815-*],5,Steering angle sensor,HEXBYTES,
to say Running and used [Stop] but he still had the ABS fault after a engine restart and lock-to-lock.
He will test drive it at this point and call back if needed. 5Q0-909-144.lbl and something like EV_SteerAssisMQB_AU37.TOD per our last internal DS
ST?ID=71374
That may or may not help here but he didn't call or e-mail back so I believe the test drive sorted it. It was unknown if the rack was original or replaced in this case.
ReflexSilverMkVII
C?ID=256588
ST?ID=71374
I'm not quite sure if any Ross tech employees found a solution. I took it to a shop and they didn't even know how to do it with VCDS.
ReflexSilverMkVII
C?ID=256588
So I've been waiting for several months to see if anything was ever posted about the correct steps to take. I've taken my car to two VW specialist centers with VCDS and neither of them knew what to do to clear steering end stops fault. I still have it. Any updates Andy?
Andy
Sector 7G
HC424490
We haven't verified this on a car yet but this should be what ODIS is doing when it runs the G85 calibration, but in VCDS terms:
1) Test step: Edge detection
Start the engine
Point the front wheels straight ahead
[44-Steering Assist]
[Security Access - 16]
Enter 19249
[Do It!]
Select these in [Adv Meas Values]:
[IDE04510-MAS03732] Steering angle sensor: slope detection index - Steering angle speed negative dropping slope on curve
[IDE04510-MAS03733] Steering angle sensor: slope detection index - Steering angle speed negative rising slope on curve
[IDE04510-MAS03734] Steering angle sensor: slope detection index - Steering angle speed positive dropping slope on curve
[IDE04510-MAS03735] Steering angle sensor: slope detection index - Steering angle speed positive rising slope on curve
[IDE04510-MAS03736]Steering angle sensor: slope detection index - Index mark
Slowly turn the steering wheel to the right and left, passing the index mark (approx. 45°) until all 4 slope detection indexes have been recognised (detected) and the index mark is set to (1).
[Done, Go Back]
2) Test step: Steer. angle sens. calibration
[Basic Settings - 04]
[Show Measuring Data]
Select the following items:
[IDE02216-IDE05795] Steering angle sensor: basic setting - End basic setting
[IDE02216-MAS03161] Steering angle sensor: basic setting - Start
In Basic Settings, pick [MAS00815] Steering angle sensor
[Go!]
It should show Running
- Turn the steering wheel slowly to the right and then to the left mechanical stop.
- Turn the steering wheel back to the mid position, the status should be indicated as Permitted. (IDE02216-MAS03161 or IDE02216-IDE05795 ?)
Note: in a test on the car it never showed permitted in either of those?
(after one or both show permitted, stop moving wheel and point straight)
Wait for it to show Finished correctly?
[Stop]
Note: in a test on the car there were no faults and no warning lamps.
3) Test step: Evaluation of basic setting (no VCDS needed)
Turn the steering wheel to the right end stop.
Turn the steering wheel to the left end stop.
Turn the steering back to its center position.
Check the yellow fault lamp on the dash.
The fault lamp on the dash must go out.
Stop the engine.
Check and clear DTCs
vw754
C?ID=52227
this baloon does not show up when i hover over it in vcds,so i dont know what the security access code is???????????
NEtech
C?ID=56995
You click the button [Security Access -16] in which Control Module ?
vw754
C?ID=52227
NEtech
C?ID=56995
Try again in Steering Assist-44, it should pop-up.
vw754
C?ID=52227
ok...will update,thanks
kamold
Australia
C?ID=241363
Start the engine
Enter 19249
[Do It!]
[Done, Go Back]
[Go!]
[Stop]
Stop the engine.
Tried this tonight remotely with someone and it worked.
Mk 7.5 Golf
Jef
HQ
When doing the Basic Settings [MAS00815] Steering angle sensor, did it ever go to "Finished Correctly"?
We have been testing this test plan last night and this morning on different vehicles within the Ross-Tech fleet, but these have all been vehicles in proper working order.
The Cliff Notes version of what we are doing:
Engine at idle.
Rotate steering wheel 90deg left then center, 90deg right then center so steering wheel is level, front wheels pointed straight ahead.
Enter 19249
[Go!]
Rotate steering wheel all the way to the left, hold firmly against end stop for 5 seconds.
Rotate steering wheel all the way to the right, hold firmly against end stop for 5 seconds.
Center steering wheel, front wheel straight ahead.
Note: our testing of this would still be "Running", never got a message of "Finished Correctly"
[Stop]
Now a bunch of error messages and warnings will appear on the cluster, what messages you get can vary based on how the vehicles is equipped.
[Done, Go Back]
Now most warning messaged in instrument cluster should be removed.
[Close Controller, Go Back - 06]
Cycle the ignition off for 10 seconds.
Several other control modules will flag DTCs, "Databus" type codes that can now be cleared out.
Again, we are doing this on vehicles that had no fault codes to begin with.
--------------------EDIT--------------------
We have a Finished Correctly!
Atlas that actually had hard codes for the G85.
--------------------EDIT 2.0--------------------
