VCDS Version: Release 14.10.2 (x64)
Data version: 20150311
Sunday,23,August,2015,20:26:49:10123
Chassis Type: BP (7P6)
Scan: 01 02 03 05 08 09 10 15 16 17 19 42 46 52 53 55 56 5F 62 65
69 6D 72
VIN: WVGFK9BP8CD003059 Mileage: 50506km-31382miles
Address 01: Engine (J623-CATA) Labels: Redir Fail!
Part No SW: 7P0 907 401 J HW: 7P0 907 401 E
Component: 3.0TDI EDC17 H17 0005
Revision: 56H17---
Coding: 292A4012233600050000
Shop #: WSC 50640 000 1048576
ASAM Dataset: EV_ECM30TDI0117P0907401J 001005
ROD: EV_ECM30TDI0117P0907401J.rod
VCID: 3620EF5F8960F691843-8063
Address 02: Auto Trans (J217) Labels: 0C8-927-750.clb
Part No SW: 0C8 927 750 G HW: 0C8 927 750 G
Component: AL1000 AISIN 001 1857
Coding: 001368
ASAM Dataset: EV_TCMAL991031 001001
ROD: EV_TCMAL991031_VW52.rod
VCID: 302CD9476B04D8A1DEF-8065
Address 03: ABS Brakes (J104) Labels: 7P0-907-379.clb
Part No SW: 7P0 907 379 K HW: 7P0 907 379 A
Component: MK25A H36 0418
Revision: -------- Serial number: 421710010EC815
Coding: 5B7613C349242556DAF4C89892DBA4407700
Shop #: WSC 31414 790 00001
ASAM Dataset: EV_MK25AXT 007001
ROD: EV_ESPMK25A00800.rod
VCID: 45C29893C4866D091D9-8010
Slave 1:
Part No SW: 4H0 907 064 BK HW: 4H0 907 064 BK
Component: BCM2 2.0 H31 0330
Coding: 09860000000000000000
VCID: 73A6164BD292A3B963D-8026
Subsystem 1 - Part No SW: 7P6 959 754 M HW: 7P6 959 754 M
Component: FBSTOUAREGIDG H04 0051
Subsystem 2 - Part No SW: 4H0 905 852 B HW: 4H0 905 852 B
Component: J764 ELV MLB H38 0044
Address 08: Auto HVAC (J255) Labels: 7P6-907-040.clb
Part No SW: 7P6 907 040 BA HW: 7P6 907 040 BA
Component: Klima 2 Zonen H20 1203
Coding: B606200880
VCID: 74A41557DF9CA4817A7-8021
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063.clb
Part No SW: 4H0 907 063 BD HW: 4H0 907 063 D
Component: BCM1 2.0 H12 0100
Revision: 15012002 Serial number: 00000001187118
Coding: 26001012973C5D010020180300005D0C431C660882010261000000020000
VCID: 6B960E2B8AA27B79ABD-803E
Subsystem 1 - Part No SW: 7P0 955 119 HW: 7P0 955 119 Labels: 1KX-955-119.CLB
Component: WWS 110725 31 0020
Coding: 004DBD
Subsystem 2 - Part No SW: 7P0 955 559 D HW: 7P0 955 559 D Labels: 8K0-955-559.CLB
Component: RLFS H09 0011
Coding: 025223
Subsystem 3 - Part No SW: 7P6 941 431 E HW: 7P6 941 431 E
Component: E1 - LDS H04 0031
Subsystem 4 - Part No SW: 4H0 907 410 A HW: 4H0 907 410 A
Component: USHL4.2 H30 0020
Address 10: Park/Steer Assist (J446) Labels: 7P6-919-475.clb
Part No SW: 7P6 919 475 B HW: 7N0 919 475
Component: PARKHILFE 8K H05 0021
Revision: -------- Serial number: 28261122301009
Coding: 110501
ASAM Dataset: EV_VW526ParkiAssis2 001011
ROD: EV_VW526ParkiAssis2.rod
VCID: 42C8838FD5A85A3138B-8017
Part No SW: 7P0 959 655 B HW: 7P0 959 655 B
Component: VW10Airbag025 H05 0023
Revision: -------- Serial number: 003JX003ULWC
Coding: 000000000000000000000000000000003235
ROD: EV_AirbaVW10BPAVW526.rod
VCID: 40CC8987DBA448212EF-8015
Subsystem 1 - Part No SW: 7P6 959 339 HW: 7P6 959 339
Component: BF-Gewichtss. 003 0005
Serial number: 5850000R1160304PH3
Serial number: 3575LRB405F0N3MK28IR
Serial number: 3585LRB405J0N3MK6PTL
Serial number: 3515RRB40550LCOSAPB9
Serial number: 3525RRB40550LCOS6HL8
Serial number: 3555NRB404T0KSEGA9FD
Serial number: 3565NRB404P0KSEG2H2/
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4H0 953 568 F HW: 7P6 953 507 L
Component: Lenks.Modul H03 0005
Revision: -------- Serial number: 90815KHI000AK
Coding: 000015
VCID: 3620EF5F8160F691843-8063
Subsystem 1 - Part No SW: 7P6 959 542 HW: 7P6 959 542
Component: E221__MFL-TAS H03 0027
Address 17: Instruments (J285) Labels: 7P6-920-xxx-17.clb
Part No SW: 7P6 920 980 N HW: 7P6 920 980 N
Component: Kombi H13 0239
Revision: 11240062 Serial number: 658190811592032
Coding: 8B6733022B00CF05020004
ASAM Dataset: EV_KombiUDSRBVW526 001013
ROD: EV_KombiUDSRBVW526.rod
VCID: 47DE929BFE8A7F19EF5-8012
Part No SW: 7P6 907 530 C HW: 7P6 907 530 A
Component: GW-CAN-L-MOST H08 5202
Revision: -------- Serial number: 00000000226198
Coding: 0001037500
ASAM Dataset: EV_GatewVW526UDS 001006
ROD: EV_GatewUDS_VW52.rod
VCID: 383CE167837400E196F-806D
Subsystem 1 - Part No SW: 7P0 915 181 A HW: 7P0 915 181
Component: Batt_Sensor H07 0140
Serial number: 00000000005650315319
Part No SW: 4H0 959 793 N HW: 4H0 959 793 F
Component: TSG FA H07 0166
Revision: -------- Serial number: 0000118932626
Coding: 011D07200000453005080000
VCID: 44C48597C7BC54010A7-8011
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0156474884
Coding: 0186163A28B9500080A00620210000000000000000000000000000000000
Subsystem 1 - Part No SW: 7P6 959 719 HW: 7P6 959 719
Component: GTO BT H19 0059
Part No SW: 4H0 959 792 F HW: 4H0 959 792 F
Component: TSG BF H07 0166
Revision: -------- Serial number: 0000118742154
VCID: 3B36FE6BBA422BF97BD-806E
Address 53: Parking Brake (J540-) Labels: 7P0-907-801.clb
Part No SW: 7P0 907 801 F HW: 7P0 907 801 F
Component: EPB H51 1201
Revision: 00000000 Serial number: A11727008D5
Coding: 01040200
ROD: EV_ParkbA7.rod
Slave 3:
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 HW: 7L6 907 357 C
Component: AFS-ECU H04 0110
Coding: 010A00010F000400
VCID: 7CB43D77F7CCECC1327-8029
Subsystem 1 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo links H01 0002
Coding: 130000
Subsystem 2 - Part No SW: 8U0 941 329 HW: 8U0 941 329
Component: LeiMo rechts H01 0002
Coding: 130000
Part No SW: 4G0 035 082 B HW: 4G0 035 082
Component: Radio U SIRIU H52 0076
Revision: AB001007 Serial number: 156H10B7544845
Coding: 020007020100000001
VCID: 1F0E2AFB0E9A57D9775-804A
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 7P6 035 664 B HW: 7P6 035 664
Component: H-BN-NA H44 0319
Revision: -------- Serial number: 445HX0B7519130
Coding: 010200050040E1ED01022B0E00000003F0000101
Shop #: WSC 21026 444 84597
VCID: 373EE25B866A0F999F5-8062
Subsystem 1 - Part No: 8R0 060 884 AC
Component: NAR 2011 0503
Subsystem 2 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: DU8 SV Touch H26 0045
Subsystem 3 - Part No SW: 7P6 919 603 C HW: 7P6 919 603 C
Component: CD-Database 1886
Part No SW: 4H0 959 795 B HW: 4H0 959 795 B
Component: TSG HL H09 0162
Revision: -------- Serial number: 0000118941744
Coding: 011C07200000253005080000
VCID: 3A38FB6FB57812F160B-806F
Address 65: Tire Pressure (J502) Labels: 3Y0-907-273.clb
Part No SW: 7P6 907 273 F HW: 7P6 907 273 F
Component: RDKBERU25 H09 0008
Serial number: 10000000040574
ROD: EV_RDKBERU25_VW52.rod
VCID: 3FCE8A7BA65A37D9575-806A
Address 69: Trailer (J345) Labels: None
Part No SW: 7P0 907 383 F HW: 7P0 907 383 B
Component: Anhaenger H09 0110
Revision: 5A001001 Serial number: 00000155475646
Coding: 020D000000000000
Address 6D: Trunk Elect. (----) Labels: 7N0-959-107.clb
Part No SW: 7P6 959 107 HW: 7P6 959 107
Component: HDSG-Modul H10 0611
Revision: 22010001 Serial number: 213100681
Coding: 0533314003
ASAM Dataset: EV_HeckkTouar 202135
ROD: EV_HeckkTouar.rod
Component: TSG HR H09 0162
Revision: -------- Serial number: 0000118941553
End-------------------------(Elapsed Time: 02:39)--------------------------
