POLO 1.2 BLUE MOTION TPMS fault
audivwauto1
South Africa
C?ID=260881
ABS FAULT
stop start cant work tpms light on cant be cancelled
Monday,15,July,2019,13:50:39:16946
Dealer/Shop Name: AUDI VW AUTO CLINIC
Workshop Code: 996 02232 000010
VIN: WVWZZZ6RZDY156612   License Plate:
                Address 03: ABS Brakes       Labels: 6R0-907-37x-ESP90.clb
Control Module Part Number: 6R0 907 379 AS    HW: 6R0 907 379 AS
  Component and/or Version: ESP9.0i front H02 0002
           Software Coding: 23DD2485412800C6C41A246A825300920905
            Work Shop Code: WSC 01383 785 00200
              ASAM Dataset: EV_Brake1ESP90iBOSCH 003020 (VW25)
                       ROD: EV_Brake1ESP90iBOSCH_003_VW21.rod
                      VCID: 0F6E569FD61F5E3710-805A
0612 - TPMS Display
          C1146 F2 [008] - EEPROM Malfunction
                    Reset counter: 92
                    Mileage: 89294 km
                    Date: 2019.07.15
                    Time: 00:21:37
Monday,15,July,2019,11:26:52:16946
VIN: WVWZZZ6RZDY156612   License Plate: CA449445
Mileage: 89290km-55482mi   Repair Order: POLO 1.2 BLUE MOTION
Chassis Type: 6R-VW25 (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56 61
VIN: WVWZZZ6RZDY156612   Mileage: 89290km-55482miles
Address 01: Engine (J0000-CFWA)       Labels:. 03P-906-021-CFW.clb
   Part No SW: 03P 906 021 AH    HW: 03P 907 425
   Component: R3 1.2 DCM3.7 H09 3315
   Revision: 12005001    Serial number:
   Coding: 00114014032501080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM12TDI03103P906021AH 001004
   ROD: EV_ECM12TDI.rod
   VCID: 6E902B1BB1D5373F7B-803A
   Part No SW: 6R0 907 379 AS    HW: 6R0 907 379 AS
   Component: ESP9.0i front H02 0002
   Serial number: --------------
   Shop #: WSC 01383 785 00200
0612 - TPMS Display
          C1146 F2 [137] - EEPROM Malfunction
                    Fault Frequency: 34
                    Reset counter: 51
                    Mileage: 89159 km
                    Date: 2019.07.10
                    Time: 12:44:10
   Component: LENKW.SENSOR  H06 0060
   Serial number: 05121204650802
   Coding: 01
   ROD: EV_LWSKLOVW25X.rod
   VCID: 7EB01B5BE1B547BFEB-802A
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AB.clb
   Part No SW: 6R0 820 045 N    HW: 6R0 820 045 N
   Component: Man AC        H02 0202
   Revision: 0003SH02
   VCID: 393AC847B01BA0879E-806C
   Part No SW: 7H0 937 090     HW: 7H0 937 090
   Component: BCM PQ25 Max4 H72 0708
   Revision: B9072001    Serial number: 0531 332121645
   Coding: 25B42B3F08E12400923809B0262B0CD05F80412F7E840440A00020020000
   VCID: 6B96220F8AC7C2175C-803E
   Subsystem 1 - Part No SW: 6R0 959 802 AB    HW: 6R0 959 802 AB  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  008 1611
   Serial number: KU0KU012101200014318
   Coding: 58BC30
   Subsystem 2 - Part No SW: 6R0 959 801 AD    HW: 6R0 959 801 AD  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  008 1611
   Serial number: KU0KU011101200018039
   Coding: 58BC30
   Subsystem 3 - Part No: 1K8 951 171 A
   Component: DWA-Sensor 00  001 0103
   Subsystem 5 - Part No: 1K8 951 171 A
   Subsystem 6 - Part No SW: 5K0 959 542 C    HW: 5K0 959 542 C
   Component: E221__MFL-TAS  H31 0033
   Serial number: 0350169
   Coding: 020000
   Subsystem 7 - Part No SW: 6R0 959 811 N    HW: 6R0 959 811 N
   Component: J388__TSG_HL  003 8610
   Serial number: KU0KU010071441913090
   Coding: 0080A0
   Subsystem 8 - Part No SW: 6R0 959 812 G    HW: 6R0 959 812 G
   Component: J389__TSG_HR  008 1611
   Serial number: KU0KU005111200010527
   Coding: 58BC32
   Part No SW: 6R0 959 655 K    HW: 6R0 959 655 K
   Component: VW10Airbag028 H10 0020
   Revision: --------    Serial number: 003GX01H03K7
   Coding: 003238
   ROD: EV_AirbaVW10BPAVW250.rod
   VCID: 4AD8878BEDFD3B1F07-801E
   Serial number: 3575HRB40104UOB6F9GN
   Serial number: 3585HRB40024UNTCEGNI
   Serial number: 3515RRB40511NOT6IOON
   Serial number: 3525RRB40671O70U9G7J
   Part No SW: 6R0 920 861 K    HW: 6R0 920 861 K
   Component: KOMBI         H03 0306
   Serial number: 00000014179657
   Coding: 140801
   ASAM Dataset: EV_DashBoardUDSJCIPQ25 A01720
   ROD: EV_DashBoardUDSJCIPQ25_A01.rod
   VCID: 3D32DC57AC339CA7B2-8068
   Part No SW: 6N0 909 901     HW: 7H0 937 090
   Component: GW-K-CAN TP20 H72 0708
   Revision: B9072001
   Coding: 002300
   VCID: 70AC3563A3E121CF69-8024
Address 25: Immobilizer (J285)       Labels:. 5K0-920-xxx-25.clb
   Component: IMMO          H03 0015
   ASAM Dataset: EV_ImmobUDSJCIPQ25 A01003
   ROD: EV_ImmobUDSJCIPQ25.rod
   Part No: 6R0 423 156 C
   Component: LenkhilfeTRW        V278
   Coding: 11230
   Shop #: WSC 00788
   VCID: 302CF563F76161CF29-8064
   Part No SW: 5M0 035 156 D    HW: 5M0 035 156 D
   Component: Radio         553 0555
   Revision: R0553007    Serial number: VWZ5Z1M0791346
   Coding: 0500040002
   VCID: 2A18E70B45BD1B1FE7-807E
   Part No SW: 7H0 907 534     HW: 7H0 937 090
   Component: Batt.regelung H72 0708
   Coding: 03031A59
   Subsystem 1 - Part No SW: 6R0 915 181 E    HW: 6R0 915 181 E
   Component: J367-BDM  H08 0181
   Serial number: 00000000004970523755
End----------(Elapsed Time: 01:45, VBatt start/end: 13.1V/13.1V)-----------
RyMar
South Africa
C?ID=133909
Make sure all tyres are pumped to spec. Swith the switch in the cubby on and test drive. Should reset then.
Jef
HQ
From what I can tell, there is going to be a E492 "Tyre Pressure loss Indicator button" that goes to the ABS T38/4. The button looks to be a normally open circuit and when pushed, a battery voltage + signal from fuse SB9 passes through the switch and to the ABS module. Is that button shorted?
Are the powers and grounds for the ABS module to factory design... no voltage drop issues for the main powers/grounds at the ABS module?
If those things check out good, it would seem the ABS module has failed. :(
audivwauto1
South Africa
C?ID=260881
thanks for the imput ..will check and report back
