Hello!
I have a Passat B6 MY2006 and i tried replacing the EPB module 3C0 907 801 B (Gen2) with 3C8 907 801 A (Gen3) module but some weird errors appeard on the EPB module preventing me to recode or to properly adapt the module.
I don't now if the module is either defective (it is salvaged from a passat CC) or it is not compatible with my ABS module/pump. I'm leaning towards defective because of the errors on the module.
If you guys could help me with some advice it will be very helpful.
I am posting a full scan with VCDS with the 03 ABS module partially coded.
I could not adapt the G251 lateral acceleration sensor from 03 Parking Brake module because it is not listed in the Basic Settings menu from VCDS.
Thank you!
Thank you!
Removed. Data from a clone/pirate copy of VCDS is not welcome here.
