2001 Audi allroad 2.7t airbag module: soft coding, seat occupancy, false crash signal
crazynorweegian
C?ID=201826
This is technically 3 different issues but they are on the same car and same system so I am making one thread.
1. Opened due to crash signal
I have been getting this code in my CCM:
01366 - Opened Due to Crash Signal 35-00
Which is accompanied by my doors unlocking and the dome lights activating. I believe it also disables my cruise control and disables the interior door lock button until the car power cycles. It does not activate the fuel cutoff.
I replaced the CCM, no change.
I unplugged the airbag module, no change.
2. Soft coding a replacement airbag module
I replaced the airbag module with a known good used one (same part number 4z7 959 655 C), problem still persists. In addition, I got these codes:
01044 - control module incorrectly coded 35-10
01215 - Seat Occupant Sensor, Driver Side Rear (G177) 35-00
Soft coding on both modules is 00407
Swapping the modules again results in the same errors, regardless of pulling the battery, clearing the codes, power cycling the car, or soft coding. Both modules now show the same errors.
The soft coding is being accepted because I can change it to 00406 and back to 00407 with no problem; the WSC also changes to my number.
3. Seat occupancy sensors
With either module, the advanced measuring blocks show that the seat occupancy sensors are either "too high" or "reversed polarity." All other blocks appear to register correctly/ normal.
So... is their a login code I need before I soft code? Do I need to run the car for a while to let it "register" or something?
The car is 2001 Audi Allroad 2.7t
Stage 3 mystery tune with immo delete, o2 delete, EGT delete, SAI delete
Front seats swapped with same seats from same year and model of car (symptoms persist between both sets of seats)
No record of a crash but there is evidence of left rear quarter body work
Please post an Auto-Scan so people can see all this in context.
I don't recall 2001 4B cars having with a seat occupied sensor. :confused:
crazynorweegian
C?ID=201826
Well even in the back seat, there is a momentary single pole switch on a lever directly in the center of each seat. The wires to that switch are routed into the yellow airbag plug, so I would say it does have occupancy sensors. Maybe the functionality was not built into the airbag module that year but the hardware is there and the module seems to be looking for it, since it throws a code for the sensor...
Jef
HQ
crazynorweegian
C?ID=201826
http://wiki.ross-tech.com/wiki/index.php/Airbag_Coding
When you post the Auto-Scan, be sure the VIN is listed as well.
I have to agree with Uwe, I'm not aware of any 2001 with a POD system in it. And looking at a wiring diagram for a 2001, I don't see any G177 listing as well.
Well, both modules have the same error codes, so let's just remove the used module from the equation. Getting my original module to function without these codes would be just fine with me.
As far as diagrams go, I don't think there is any mention in any of my diagrams with regards to my solar sunroof either, so my faith in their documentation of electrical features is weak, at best.
Attached is my autoscan and an image of the switch under my rear bench. Identical switches are present on either side. There is a sprung lever that actuates the switch when there is weight on the seat, I can hear it when I press on the seat... if that isn't an occupancy switch, it must be a "switch that is activated when the seat is... occupied."
I was pulling the battery cables a lot between scans, which is where some of those voltage errors are coming from.
Friday,18,November,2016,15:41:51:19790
VCDS Version: 16.8.3.1
Workshop Code: 000 12345 000000
VIN: WAUYP54B31N059018   License Plate:
Mileage: 153229   Repair Order:
          75 76 77
Address 01: Engine        Labels: 078-907-551-AZA.lbl
   Part No: 8D0 907 551 M
   Component: 2.7l V6/5VT     G   0002
   Coding: 06712
   Shop #: WSC 87119
   VCID: 346762A3047621E268-5122
Readiness: 0110 0100
Address 03: ABS Brakes        Labels: 8D0-907-389.lbl
   Part No: 4Z7 907 389
   Component: ABS/ESP allrad      D47
   Coding: 06395
   Shop #: WSC 02325
   VCID: 0919E35733740C0AEB-5140
   Part No: 4B0 959 760 C
   Component: Sitzmemory R1 BF    0103
   Coding: 00003
   VCID: 2D5177C7E75C702A27-4AE8
            07-00 - Signal too Low
Address 15: Airbags        Labels: 4B0-959-655-AI8.lbl
   Part No: 4Z7 959 655 C
   Component: Airbag Front+Kopf  1002
   Coding: 00407
   Shop #: WSC 66666
   VCID: 4FAD0D4F8D90623A75-515E
            35-00 -  -
01215 - Seat Occupant Sensor; Driver Side Rear (G177)
            35-00 -  -
Address 16: Steering wheel        Labels: 4B0-907-487.lbl
   Part No: 4B0 907 487 D
   Component: Lenkradelektronik    D02
   Coding: 00102
   Shop #: WSC 12345
   VCID: 2D5177C7E75C702A27-4F90
Address 17: Instruments        Labels: 4B0-920-xxx-17.lbl
   Part No: 4Z7 920 980 B
   Component: C5-KOMBIINSTR. VDO D13
   Coding: 02264
   Shop #: WSC 22102
   VCID: 4385317F51D8965AE1-5122
   WAUYP54B31N059018     AUZ7Z0Y1616155
            30-00 - Open or Short to Plus
01177 - Engine Control Unit
            49-00 - No Communications
Address 34: Level Control        Labels: 4Z7-907-553.lbl
   Part No: 4Z7 907 553 B
   Component:  - 2C1A1          X031
   Coding: 25500
   Shop #: WSC 12345
   VCID: 4487326354D69162D8-5106
Address 35: Centr. Locks        Labels: 4B0-962-258.lbl
   Part No: 4B0 962 258 J
   Component: Central Lock/Alarm  D33
   Coding: 16232
   Shop #: WSC 02325
   VCID: 306F6EB3F06E1DC20C-4EE8
01560 - Passenger Door
            59-00 - Can't Unlock
   Part No: 4B0 959 760 B
   Component: Sitzmemory R1 F     0102
   Coding: 00001
   VCID: 2C577AC3DC46792230-4AE8
Address 37: Navigation        Labels: 4B0-919-887-BNS3.lbl
   Part No: 4B0 919 887 B
   Component: Navigation     BNO 0001
   VCID: 326B64BBFE622FD27A-4ACE
65535 - Internal Control Module Memory Error
            00-00 -  -
Address 45: Inter. Monitor        Labels: 4B0-951-178.lbl
   Part No: 4B0 951 178 A
   Component: Innenraumueberw.    D04
   Coding: 00102
   Shop #: WSC 02325
   VCID: 264388EBC2AA4372E6-5122
01462 - Anti-theft alarm ultra sonic Sensor (G209)
            53-10 - Supply Voltage Too Low - Intermittent
   Part No: 4Z7 907 357
   Component: dynamische LWR       D04
   Coding: 00030
   Shop #: WSC 02325
   VCID: 0407F2631456516298-4B4C
00532 - Supply Voltage B+
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283
   Component: Parkingsyst. A6 RDW D08
   Coding: 00186
   Shop #: WSC 22197
   VCID: 020BF47B0E425F52AA-5122
End-------------------------(Elapsed Time: 05:15)--------------------------
https://drive.google.com/file/d/0B_jab3cyIYEFR1JGQldKZFRWSFk/view?usp=sharing
Well for starters id say you have an s4 engine ecu in an a6 allroad & that is just stupid FOD on top of the deleted smog components aforementioned.
Is the air bag controller the correct part #?
crazynorweegian
C?ID=201826
The ECU came with the car with those things tuned out. Thanks for the heads up on the ECU part number, I never thought to check on that. I will add that to the list of wonky crap from the previous owner that I need to replace.
The airbag module is the correct number. I got a replacement from the same year and model. I also verified the part number with my friend who has the exact same car.
crazynorweegian
C?ID=201826
Fixed the 01044 error by... spraying the harness with deoxit. What a silly overly sensitive system. That harness was sparkly clean to begin with.:banghead:
Now to figure out the 01366 code and the "too high" occupancy sensors.
crazynorweegian
C?ID=201826
For your crash signal problem, we've seen at least one other owner tripped up by a bad/wrong hazard light switch. As a diagnostic, try disconnecting it and see if the 01366 goes away.
Jason
100% correct.
I have been searching for this remedy for 2 years. ROSSTECH, please update your entry for this error code on your FAQ site.
01366 is FIXED!
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
Two instances make a pattern, so...
http://wiki.ross-tech.com/wiki/index.php/01366
Jason
jyoung8607
FoRT
Cincinnati, OH
C?ID=25607
A glance at PL24 for your VIN shows that your rear seats each have a pressure plate 4B0 885 363 A which actuates switch for seat heating 431 959 489 C. Presumably they're for disabling seat heating if nobody's there. Passenger occupancy detection is sort of a standard term for disabling airbags if nobody's there, which I think is why everyone is a bit confused. So for this purpose let's go with your fallback definition of "switch that is activated when the seat is... occupied" until we figure out what's going on. :D
You state these things are wired up to the yellow airbag harness... I can't explain that, or why the airbag module is coming up with those codes. I suggest double checking that, as well as the part numbers on those components. Maybe this thing legitimately has airbag POD, maybe not.
Jason
