Thanks in advance for any help on this. I put a hazard switch in an 04 A6 for a flasher problem, fixed and all was good I thought, when the customer came to pick up her car she complained that her door locks didn't work any more. So, I noticed that they did work right up until you started the car, then if you locked with the power lock button all the doors would unlock, upon further investigation I found the 1366 code (open due to crash signal) in the central lock module. the door locks function normally when I have the controller open with the VCDS, and the code clears. a soon as I exit the module the locks start acting up again and the code returns. There are no codes in the airbag module. I left the battery disconnected over night in hopes of a miracle when I came back in the am, no such luck. Any ideas would be appreciated.
