It is set between 58-68, advanced timing on timing graph, at the top of the upper line. This is what was recommended by Kerma TDI because I have the Bosio 764 injector nozzles installed by VW dealership in St. Louis. I also have the upgraded Gerritt VNT-17 Turbo charger. The fuel trim was set from 2.9 /stream to 6.25 /stream. The car has great boost and good passing power, but lacks a bit when going up hills. I have yet to extend the glow plug time as right now, while it's still hot outside, the glow plugs go off in less than a second. Note: The glow plugs were installed about 2 yrs ago by myself. I bought them on
eBay. I have also changed the glow plug sensor and the 109 sensor for the glow plugs. Since the new injectors have been installed, I notice that the engine is much harder to start than when it's cold. Sometimes, I have to make two multi crank scenarios before engine starts, when it's warm. And when it does start, it sounds like a harsh start when a big diesel truck starts. Not to mention, the large cloud of dark (not black) smoke that comes out the back when I quickly accelerate from 0 - 40 mph. Any ideas what might be wrong here? Thanks Lawrence Mathon
