TPMS activation, reset, and disable coding with VCDS - mk6 VW
Welder75
Canada
C?ID=261654
How to activate, reset, or swap the TPMS system on your VW Jetta or Golf
difficulty: 1/5
Introduction
Some recent VW Golf and Jetta have the TPMS capability without having the button. This article shows how to reset or activate the hidden ABS based TPMS or swap from the direct to the indirect system
There are two basic types of tire pressure monitor systems installed in VW. The first type works off the ABS system and uses no additional sensors. If the wheel sensors detect that one wheel's diameter is smaller it assumes that the tire has lost air and trips the low pressure warning. The other type uses wireless sensors to directly measure air and temperature in the wheels and transmits the data to the car's computer.
The indirect system was installed starting in 2007 when it became mandatory in the US. Because it's not yet mandatory in Canada, many new Canadian VW don't have the TPMS. VW switched to the direct system but has switched back to the indirect system for model year 2011 in Golf and Jetta. More expensive models like the Touareg still use direct sensors.
The advantage of the direct sensors is that it's more accurate. The advantage of the indirect system is that it doesn't require a second set of sensors for winter wheels (unless you want to unmount the tires to remove the sensors) and because there are no sensors they don't need replacement when their battery dies. The battery life of TPMS sensors is about 6-9 years depending on use and it's non serviceable. While it's legal to have a TPMS which no longer detects tire pressure (except on a new car sale), it's not legal to disable the system or disable the light.
A direct type sensor sits inside the wheel with only the antenna/valve stem sticking out. If the tire valve stem is metal and stiff with the lock nut on the base, you have a direct sensor system. If the valve stems are flexible rubber you don't have these sensors. A valve stem is the piece of tire that sticks out and where you add air.
Warning: Never disable the TPMS light, disable the system, or disable the TPMS light if it's not legal where you live and/or operate the vehicle. In the US, a functional TPMS warning light is required under Federal requirement FMVSS 138. See the TOS Agreement for the full legal disclaimer.
If you have the direct system and have a compatible ABS control module, it might be possible to switch the indirect system for a second set of wheels or permanently switch to the indirect type system if you don't want to replace the sensors after their batteries die. You must have a compatible ABS control module to make the indirect type system to work. I tried it with a 2006 ABS control module and it didn't work. More on this below.
Parts
one ross tech VCDS cable and software
tire pressure gauge
How to reset the TPMS system and flashing TPMS light
If you have direct type sensors, just add air to the recommended tire pressure. Check all the tires with a tire gauge. Sometimes you have to slightly overfill the air and then let the pressure go back down to the correct level. Never go higher than the max cold pressure printed on the tire. Refer to your owner's manual or driver's side door panel for the correct air pressure.
If you have the indirect system, add air to the recommended tire pressure. Check all the tires with a tire gauge. Press and hold the TPMS reset button. This will reset the values that the ABS module looks for.
Procedure to activate the hidden TPMS system
First, if you don't have any TPMS or have the direct system and wish to switch to the indirect system, you should retrofit the reset button. You just have to add the button and a wiring harness to the car's electric module. These can be purchased from kufatec.com. Even if you don't have the reset button, you can still reset the light with a VCDS, you just won't have the button. If you don't have VCDS you just have to find someone to reset the light if the warning is ever tripped or add the reset button.
First plug in your VCDS cable and start the software. Make sure the green LED on the cable is lit. Click on "Select" to access the control modules.
Click on "ABS controller" and you'll see this screen. The module part number "VAG Number" is from a mk6 Golf. You should see "Long Coding" under the Software coding label in green. I'm pretty sure that if you see a number there it means you have a non-compatible module. Click on Coding.
Click on long coding helper. Write down your original code before changing anything!
It will open the long coding helper shown below.
Go to byte 16.
Click the checkbox for "Bit 2 - Tire pressure monitoring (TPMS/7K6) installed". Exit the long coding helper and the new code will already be under "New coding". Click "Do it!" to save and use the new code. Exit the module.
When you turn on the ignition, you should see the TPMS light briefly turn on. The system needs at least 1 hour of driving including on the highway to adapt. During that time the TPMS may not be reliable.
If you don't have a TPMS reset button, you have to manually reset it with VCDS. Go back to the ABS module and go to Basic settings. Go to "Group 042". Click Go! to reset it.
How to swap from the direct to the indirect TPMS system or disable the TPMS system
Since I don't believe anyone has done a swap from a working direct to an indirect system, I believe that you may have to first disable the direct system for the indirect system to work. See the warning at the top and the TOS Agreement for the full legal disclaimer. Do not operate the vehicle on public roads in the US without the Federally mandated TPMS system or if it's not legal where you live and/or operate the car.
Go back to the module screen and click on "CAN Gateway". Click on "long coding". Click on "long coding helper".
You'll see the screen below. Uncheck tire pressure monitoring. Close the long coding helper and it'll automatically cut/paste your new code under "new code". Click "Do it!" to save. Exit. It's now disabled. Make sure your TPMS system is functional before you go on public roads or highways.
Go back to the CECM. In Byte 8, uncheck the box for TPMS 7k3/7k4/7k5 installed/active. Exit and save.
Go to the ABS controller and you'll see the screen below. Click on Coding and enter the long coding helper. This module part number is from a mk5 2010 Jetta.
Go to Byte 16 and check the box for TPMS 7k6 installed.
You should see the TPMS warning light turn on. Reset it using basic settings group 42 as shown earlier.
Infiniteautotech
C?ID=56964
Hoping I could get some help here. I coded/activated a 2005 Canadian Rabbit via ABS control module to the 7K6 TMPS as the car is now in CA, USA. The TPMS light on the cluster now illuminates. However, when I tried to go reset it in the ABS module in the basic setting 042, I see a drop down that shows a line to reset TMPS. I select that line. But, there is no "Do it". After driving the car over a few days, the light persists. Is there something that I am missing? Any help would be appreciated.
Please post an Auto-Scan of this car so people can see what it's made of (specifically exactly what ABS system it has).
Once you do that, I'm going to split these messages into a new thread because a 2005 is definitely not an Mk.6 car.
Infiniteautotech
C?ID=56964
Thanks Uwe. I will get the car in again and grab an autoscan.
Infiniteautotech
C?ID=56964
OK, here is the autoscan of the vehicle. Again, after activating the TMPS function, I cannot reset the system using the VAG-COM. I see RESET in the drop down but no "DO IT." Any help would be appreciated...This is a Canadian 2008 Rabbit
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWDA71K78W260122   Mileage: 83240km-51722miles
02-Auto Trans -- Status: Sporadic communication error 1000
Address 01: Engine (CBT)       Labels: 06A-906-032-BGP.lbl
   Part No SW: 07K 906 032 BJ    HW: 07K 906 032 Q
   Component: 2,5l R5/4V      G   1567
   Revision: 1NH01---    Serial number: VWX7Z0H13ND81T
   Coding: 0000003
   Shop #: WSC 01279 785 00200
   VCID: F2E1FA8BED307BAEED-80A6
049409 - No Communication with Transmission Control Module
               U0101 - 008 -  - Intermittent
                    Mileage: 82843 km
                    Time: 10:04:21
                    RPM: 806 /min
                    Load: 23.5 %
                    Temperature: 58.0°C
                    Temperature: 31.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
   Part No SW: 09G 927 750 HE    HW: 09G 927 750 HE
   Component: AQ 250 6F           1090
   Revision: 00H69000    Serial number:
   Coding: 0000584
   Shop #: WSC 01269 785 00200
   VCID: FBFFD7AFBA7A3AE6BE-80AE
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0000641
   VCID: BF8763BFEEE2E6C6D2-80EA
            002 - Lower Limit Exceeded
   Part No SW: 1K0 820 047 HN    HW: 1K0 820 047 HN
   Component: Climatic PQ35   142 1111
   Revision: 00142031    Serial number: 00000000000000
   VCID: F7F7CB9F86521E86DA-80A2
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 00000007951251
   Coding: 108D8F214004150047140000001400000008730B5C000100000000000000
   Shop #: WSC 00000 785 00200
   VCID: EFE7F3FFFE02564602-80BA
   Component: Wischer 050208 021  0501
   Coding: 00038805
   Component: 6L AIRBAG VW8R  034 8000
   Revision: 05034000    Serial number: 003B6D0AH2X9
   Coding: 0013900
   VCID: ECDDE4F3CF14AD5E27-80B8
   Subsystem 1 - Serial number: 6332MSME337270654
   Subsystem 2 - Serial number: 6342MSME2E457914I
   Subsystem 3 - Serial number: 6352QSME526B5735L
   Subsystem 4 - Serial number: 6362QSME5B42235DN
   Subsystem 5 - Serial number: 63727SME13264650U
   Subsystem 6 - Serial number: 63827SME13355715Y
   Part No SW: 1K0 953 549 BF    HW: 1K0 953 549 BF
   Component: J0527           051 0100
   Coding: 0010022
   Part No SW: 1K0 920 854 T    HW: 1K0 920 854 T
   Component: KOMBIINSTRUMENT VDD 1212
   Revision: V0002000    Serial number: VWX7Z0H13ND81T
   Coding: 0007303
   Shop #: WSC 91449 999 58632
   VCID: BC7D14B3FFF4FDDEF7-80E8
                    Reset counter: 233
                    Mileage: 82843 km
                    Time: 10:04:21
Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
   Component: J533  Gateway   H07 0052
   Revision:   H07 01    Serial number: 130208F1001179
   Coding: ED807F060002020002
   VCID: B065308323BC09BE5B-80E4
                    Fault Status: 00110100
                    Reset counter: 233
                    Mileage: 82042 km
                    Time: 17:43:54
   Component: IMMO            VDD 1212
   Component: Tuer-SG         006 1219
   Coding: 0001205
   VCID: B87508A3CBCCD1FE13-80EC
   Part No: 1K1 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   Shop #: WSC 00000 028 00001
   VCID: B56B0197DCDE2C9608-80E0
   Part No SW: 1K0 959 433 CA    HW: 1K0 959 433 CA
   Coding: 939006885103281B0904058FB0080F0488FC80
   VCID: F1E3F587E83640B614-80A4
   Component: Tuer-SG         006 1203
   Coding: 0001204
   VCID: B9730DA7F0C6C8F6EC-80EC
Address 56: Radio        Labels: 1K0-035-161.lbl
   Part No SW: 1K0 035 161 C    HW: 1K0 035 161 C
   Component: Radio DE2       015 0019
   Revision: 00015000    Serial number: VWZ4Z7H6322588
   Coding: 0040401
   VCID: 9F47C33F4E2286C6F2-80CA
   Component: Tuer-SG         006 1302
   Coding: 0001168
   Shop #: WSC 01279 785 1012552
   Coding: 0001168
End-------------------------(Elapsed Time: 01:34)--------------------------
You may need to click the [ON/OFF/Next] button.
eden
Slovenia
C?ID=217860
Do you have coding for new Passat B8, 2015, MQB platform ?
I dont now how to disable TPMS over ABS. I have instaled direct TPMS with sensoren and antenna "65"
Tnx
type17volkswagen
C?ID=12115
Thank you for a great write-up Welder75. This thread is pretty close to what I'm looking for so I'm posting my question here.
I have a 2017 MQB Mk7 Golf, USA with indirect TPMS from the factory. What I'm looking for is the adaptation/setting/channel where the ABS stores the pressure value after resetting via the TPMS reset button/menu. Back when I had VWs with direct monitoring there was a field where you could set the value you wanted. I want to check the value on my car and be able to change it. First and foremost because I'm running different sized tires than it came with and second off when I had a nail in my tire recently the shop reset the button before all tires were filled to the correct pressure so I want to know what value it's set to.
PetrolDave
Westbury, UK
C?ID=1423
I think you're misunderstanding how indirect TPMS works - it doesn't have pressure sensors so it cannot measure/store any pressure values.
It measures the rotational speed of each wheel using the ABS sensors, and with some weird software compares that, with tolerances, against values of rotational speed for each wheel that get stored after you use the TPMS reset button/menu.
When you change wheel sizes or pressures all you have to do is set all the tyres to the correct pressures and reset TPMS. Since you can't see the pressures (as they're not measured) if you're unsure of the set values being used by indirect TPMS then just assume they're wrong and reset TPMS yourself when you know the pressures ARE correct.
type17volkswagen
C?ID=12115
Thanks for the reply PetrolDave. That makes complete sense, unlike what I was thinking. I knew it measured rotational speed (especially differences between tires) but had believed wrongly that it then used that data to calculate (estimate) a corresponding pressure to match to a stored value. I was too hung up on the word PRESSURE in tire pressure monitor system. :)
markdv77
C?ID=375497
What does the "Tire Pressure Monitoring (TPMS - PR-7K3/7K4/7K5) Installed/active" bit enable/disable exactly?
I ask because it's OFF in my 2012 Tig with direct TPMS, but it seems to be working just fine.
MFD has a Tyre Pressure menu in settings, and working pressure monitoring screen.
What am I missing, if anything, by having it OFF?
My full scan is here (on forum).
These are probably the most relevant bits:
   Part No SW: 5K0 937 086 M    HW: 5K0 937 086 M
   Component: BCM PQ35 M    021 0064
   Revision: BC021001
   Coding: 40180A3B88251AC0408800C8340011644B550008776D8DF0E4800000A048
   VCID: 3E253EA490712777F85-806A
   Part No SW: 5N0 920 882 B    HW: 5N0 920 882 B
   Component: KOMBI         H04 0417
   Coding: 111F01
   Shop #: WSC 00117 211 00000
   VCID: 323D1A9454A9F3170CD-8066
   Part No SW: 3AA 907 273 D    HW: 3AA 907 273 D
   Component: RDKBERU30     H09 0010
   Serial number: 10000000107439
   ASAM Dataset: EV_RDKBERU30 003012
   ROD: EV_RDKBERU30_003.rod
   VCID: 35372188A5C7E42F29F-8060
TIA,
Mark.
You're not missing anything. You have a direct system that uses actual pressure sensors in the wheels.
The rest of this thread is about an indirect system that uses some insane amount of signal processing of the pulses from the wheel speed sensors instead of actual pressure sensors.
There are benefits and drawbacks to both approaches. A direct system can show you actual pressures, but requires additional hardware (i.e. it adds cost to the vehicle when new) and some of that hardware (the sensors) will surely have to be replaced at least once during the lifetime of the vehicle.
An indirect system is really just software in the ABS module, so there's no incremental cost on a new vehicle, and nothing to wear out or need replacing, but it cannot show you actual pressures, and it will be somewhat slow to pick up a condition in which all four tires are equally under-inflated.
markdv77
C?ID=375497
Thanks Uwe, but I am familiar with the difference, had VAG mobiles with both systems, understand how both work.
What confuses - or raises a question with - me, is that the original post seem to indicate that the Direct system is enabled by the "TPMS 7k3/7k4/7k5 installed/active." bit in CECM.
Half way through starts to explain "How to swap from the direct to the indirect TPMS system or disable the TPMS system"
And the swapping instructions boil down to: disable 7k3/7k4/7k5 in CECM and enable 7K6 in ABS.
Thing is that I have BOTH disabled, yet my Direct system seems to work as intended.
Maybe I have another variant that's enabled/disabled in a different way?
Or that bit does something (subtly) different then just outright enable/disable?
karldietmann
C?ID=339222
@markdv77: the way I see it, there are not 2 but 3 possible tire pressure systems:
1. Indirect, via ABS
2. Direct, receiver antenna in TPMS controller
3. Direct, receiver antenna in BCM
gazayerly82
UAE
C?ID=523123
Hi , greetings. i need to ask a question supported by a photo but i am not able to upload the photo screen shot from VCDS. please advise how i can do it to explain my question properly.
i add here the full scan for reference:
Friday,29,July,2022,19:55:27:57643
VCDS Version: 22.3.1.4 (x64) HEX-V2 CB: 0.4615.4
Data version: 20220407 DS337.0
VIN: TMBAC6NE6G0083379 License Plate: 3379
Mileage: 88126 Repair Order: Kareem Saharara
Address 01: Engine Labels: 04E-907-309-V1.clb
Control Module Part Number: 04E 906 027 HD HW: 04E 907 309 BH
Component and/or Version: R4 1.4l TFS H22 2603
Software Coding: 01250032232419081000
Work Shop Code: WSC 73430 031 00000
ASAM Dataset: EV_ECM14TFS01104E906027HD 001006 (SK37)
ROD: EV_ECM14TFS01104E906027HD.rod
VCID: 6D87C4C6DD1FECD3149-8038
10203 - Random/Multiple Cylinder Misfire Detected
P0300 00 [096] - -
10591 - Cylinder 1
P0301 00 [096] - Misfire Detected
10593 - Cylinder 3
P0303 00 [096] - Misfire Detected
10594 - Cylinder 4
P0304 00 [096] - Misfire Detected
10592 - Cylinder 2
P0302 00 [096] - Misfire Detected
Address 02: Auto Trans Labels: 0CW-927-769.clb
Control Module Part Number: 0CW 300 048 L HW: 0AM 927 769 E
Component and/or Version: GSG DQ200G2_M H05 0610
Software Coding: 0014
Work Shop Code: WSC 04940 001 00001
ASAM Dataset: EV_TCMDQ200021 001001 (SK37)
ROD: EV_TCMDQ200021_VW26.rod
VCID: 45D75C66A52FF493BC9-8010
Address 03: ABS Brakes Labels: 5Q0-907-379-ESP-V1.clb
Control Module Part Number: 3Q0 907 379 T HW: 3Q0 907 379 C
Component and/or Version: ESC H32 0393
Software Coding: 1A076A912428116F007A060741CC245856248800608224F2002100004002
Work Shop Code: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 034033 (SK37)
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 4BC36A5E834B02E36AD-801E
Address 05: Acc/Start Auth. Labels: 5Q0-959-435.clb
Control Module Part Number: 5Q0 959 435 A HW: 5Q0 959 435
Component and/or Version: VWKESSYMQB 021 0604
Software Coding: 030C0C
Work Shop Code: WSC 73430 790 00000
ASAM Dataset: EV_KessyHellaMQBAB 002011 (SK37)
VCID: 3A2D3F9ADCD18B6BC1B-806E
Address 08: Auto HVAC Labels: 5G0-907-044.clb
Control Module Part Number: 5E0 907 044 Q HW: 5E0 907 044 Q
Component and/or Version: Climatronic H04 1002
Software Coding: 01010004000100011005000000101000
ASAM Dataset: EV_ACClimaBHBVW37X 004131 (SK37)
VCID: 333312BEFBBB7A2302D-8066
262659 - High Pressure Sensor
B10AE 04 [008] - Internal System Fault
Reset counter: 123
Mileage: 75057 km
Date: 2021.10.02
Time: 13:18:32
Outside temperature: 42.5 C
Engine RPM: 900 /min
Temperature downstream of evaporator: 26.0 C
System run time-Terminal 15 on: 0 s
Address 09: Cent. Elect. Labels: 5Q0-937-08X-HV1.clb
Control Module Part Number: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component and/or Version: BCM MQBAB H H24 0175
Software Coding: 0C111A42424722FB47E04000000C07080800000000000000000000000000
ASAM Dataset: EV_BCMMQB 015001 (SK37)
ROD: EV_BCMBOSCH_015.rod
VCID: 094F9056C9B750F3981-805C
Address 10: Park/Steer Assist Labels: 5Q0-919-294.clb
Control Module Part Number: 5Q0 919 294 K HW: 5Q0 919 294 A
Component and/or Version: PARKHILFE 8K H03 0054
Software Coding: 0031151051
Work Shop Code: WSC 73430 790 00063
ASAM Dataset: EV_EPHVA18AU3700000 002026 (SK37)
VCID: 43D3427EAB1BCAA392D-8016
Address 15: Airbags Labels: 5Q0-959-655.clb
Control Module Part Number: 3Q0 959 655 AT HW: 3Q0 959 655 AT
Component and/or Version: Airbag VW20 013 0200
Software Coding: 88CCC000000000005C5400CC000800000065
ASAM Dataset: EV_AirbaVW20TS6VW48X 001116 (SK37)
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 1079BD32AAED613B5FF-8044
Address 16: Steering wheel Labels: 5Q0-953-549.clb
Control Module Part Number: 5Q0 953 507 HQ HW: 5Q0 953 549 E
Component and/or Version: Lenks. Modul 003 0110
Software Coding: 1410
ASAM Dataset: EV_SMLSKLOMQB 017001 (SK37)
ROD: EV_SMLSKLOMQB_009_VW37.rod
VCID: 0C41A942C6C545DBA37-8058
Address 17: Instruments Labels: 5G0-920-XXX-17.clb-SRI3
Control Module Part Number: 5E0 920 780 B HW: 5E0 920 780 B
Component and/or Version: KOMBI 206 7640
Software Coding: 47A402182880000801082A001000000000000000
ASAM Dataset: EV_DashBoardJCIMQBAB 009005 (SK37)
ROD: EV_DashBoardJCIMQBAB_009_SK37.rod
VCID: 2615FBEA38691F8B953-8072
16777024 - Function Restricted due to Interrupted Communications
U1110 00 [008] - -
[BAP_BCME_0x23 keine Kommunikation]
Reset counter: 123
Mileage: 75057 km
Date: 2021.10.02
Time: 13:18:36
Address 19: CAN Gateway Labels: 5Q0-907-530-V1.clb
Control Module Part Number: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component and/or Version: GW MQB High 128 1223
Software Coding: 030100042F085700EB00024A1C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 013020 (SK37)
ROD: EV_GatewLear_013.rod
VCID: 75B7ECA6B54F2413EC9-8020
Address 2B: Steer. Col. Lock Labels: 5Q0-905-861.clb
Control Module Part Number: 5Q0 905 861 A HW: 5Q0 905 861 A
Component and/or Version: ELV-MQBA H01 0120
Software Coding: 5D00000000000000
ASAM Dataset: EV_ELVMarquMQB 004111 (SK37)
ROD: EV_ELVMarquMQB.rod
VCID: 343111A2FEB57D1B1B7-8060
Control Module Part Number: 5Q0 959 760 A HW: 5Q0 959 760 A
Component and/or Version: Sitzmemory H06 0009
Software Coding: 001000000000010001A081808080000000008181000000D4
ASAM Dataset: EV_SeatMemorDriveSide 001015 (SK37)
ROD: EV_SeatMemorDriveSide_001.rod
VCID: 3B233A9ED3EBB263DAD-806E
Address 42: Door Elect, Driver Labels: 5QX-959-X93-42.clb
Control Module Part Number: 5Q4 959 593 E HW: 5Q4 959 593 B
Component and/or Version: TSG FS 010 0031
Software Coding: 00150120DE00040000001100
ASAM Dataset: EV_DCUDriveSideEWMAXCONT 006001 (SK37)
VCID: 47CB566E9F23E6834E5-8012
Address 44: Steering Assist Labels: 5Q0-909-144.clb
Control Module Part Number: 5Q0 909 144 S HW: 5Q0 909 144 R
Component and/or Version: EPS_MQB_ZFLS 126 1063
Software Coding: 0103
ASAM Dataset: EV_SteerAssisMQB 012140 (SK37)
VCID: 44D14162AE15CD9BAB7-8010
Address 52: Door Elect, Pass. Labels: 5QX-959-X92-52.clb
Control Module Part Number: 5Q4 959 592 E HW: 5Q4 959 592 B
Component and/or Version: TSG BFS 010 0031
ASAM Dataset: EV_DCUPasseSideEWMAXCONT 006001 (SK37)
VCID: 46D55B6A9829FF8BB53-8012
Address 55: Headlight Range Labels: 7P6-907-357.clb
Control Module Part Number: 7P6 907 357 D HW: 7P6 907 357 A
Component and/or Version: AFS-ECU H07 0090
Software Coding: 03CA00003F000000
ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 (SK37)
VCID: 40D94D72BA0DD1BB8FF-8014
Address 5F: Information Electr. Labels: 3V0-035-MIB-STD2.clb
Control Module Part Number: 5Q0 035 840 A HW: 5Q0 035 840 A
Component and/or Version: MU-S--ER H24 0245
Software Coding: 03730100FF00000011110001001000002F0200D40120010002
ASAM Dataset: EV_MUStd4CTSAT 001022 (SK37)
ROD: EV_MUStd4CTSAT_VW37.rod
VCID: 2B030ADE238B22E34AD-807E
gazayerly82
UAE
C?ID=523123
This is the link to the photo (i hope it works).
It is related to UDS adaptation, ABS brakes, new value , channel 1B, IDE 07006 - tire pressure monitoring display: tire selection.
My questions are:
  1. What is the value i shall put in the New Value cell?
  2. Are there other adaptations/basic settings/coding i need to do further to activate the indirect TPMS on this car?
  3. Any steps i need to do after all the adaptations/coding/basic settings (besides driving the car for an hour or more including highway)?
Thanks in advance for your support.
