saidfethi
New Member
- Joined
- Feb 21, 2018
- Messages
- 5
- Reaction score
- 1
- Location
- Morocco
- VCDS Serial number
- HC428168 (2nd hand?)
H to everyone
Very glad to be here with you in this nice space
I have iBIZA 2017 with problem of ABS coding
Any one can post the right coding will be very helpful
thank you in advance
VCDS Version: 18.1.0.2
VIN: VSSZZZ6JZHR037803 License Plate: IBIZA 2017
Mileage: 2326km-1445mi Repair Order:
Chassis Type: 6J-SE26 (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: VSSZZZ6JZHR037803 Mileage: 2326km-1445miles
03-ABS Brakes -- Status: Not registered 0011
Address 01: Engine (J000-CYZA) Labels:. 04B-907-445-V1.clb
Part No SW: 04B 906 027 AN HW: 04B 907 445 B
Component: R3 1.4l TDI H01 2765
Revision: 21005001
Coding: 01110112422400000000
Shop #: WSC 00049 770 00112
ASAM Dataset: EV_ECM14TDI03004B906027AN 001002
ROD: EV_ECM14TDI03004B906027M_001_VW26.rod
VCID: 6DDBC23FBCA2922D6E-8038
15652 - Coolant Fan Control Circuit 1
P0480 00 [035] - Electrical Malfunction
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
Coolant temperature: 13 °C
Intake air temperature: 17 °C
Voltage terminal 30: 11.390 V
Air mass at air mass meter 1: 0.0 kg/h
Mass airflow sensor 1 bank 1 airflow: raw value: 0.0 mg/stroke
Accelerator pedal travel: raw value: 0.00 %
Extern.temp.sens.1 bank 1: raw value: 14.0 °C
Coolant fan 1: activation: 0.00 %
Coolant fan 2: activation: 0.00 %
Fuel temp. sensor 1 bank 1: raw value: 15.2 °C
Fuel consumption: 0.00 l/h
Engine oil temperature: 13.1 °C
25126 - Databus
U1123 00 [035] - Received Error Message
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
Coolant temperature: 14 °C
Voltage terminal 30: 11.406 V
Drivetrain coordinator: brake fault status-ESP: no error
Drivetrain coordinator: brake fault status-Deceleration controller: Available
Drivetrain coordinator: brake fault status-TSK/ESP handshake: no error
Drivetrain coordinator: brake fault status-Bit 1: no error
Drivetrain coordinator: brake fault status-Bit 3: Not malfunction due to inaccurate engine torque
Drivetrain coordinator: brake fault status-Bit 4: No indication of TSK message consistency error
Drivetrain coordinator: brake fault status-Bit 6: Automatic engagement OK
Drivetrain coordinator: brake fault status: 4
Drivetrain coordinator: brake function status-Parking Brake: not active
Drivetrain coordinator: brake function status-ACC: Not braking
Drivetrain coordinator: brake function status-ESP: Not invoking TSK braking
Drivetrain coordinator: brake function status-Driver: Not braking
Drivetrain coordinator: brake function status-Hill descent control: passive
Drivetrain coordinator: brake function status-ASR: no intervention
Drivetrain coordinator: brake function status-MSR: no intervention
Drivetrain coordinator: brake function status-ADS: no intervention
Drivetrain coordinator: brake function status-ABS: no intervention
Drivetrain coordinator: brake function status-EDL: no intervention
Drivetrain coordinator: brake function status-ASP: no intervention
Drivetrain coordinator: brake function status-AWV2: No warning pressure
Drivetrain coordinator: brake function status-Bit 4: no intervention
Drivetrain coordinator: brake function status-Bit 11: not passively cycled
Drivetrain coordinator: brake function status-Bit 12: not passively cycled
Drivetrain coordinator: brake function status-Bit 13: Standstill not detected
Acceleration: 0.000 m/sІ
Readiness: N/A
Address 03: ABS Brakes (J104) Labels:. 6R0-907-37x-ESP90.clb
Part No SW: 6C0 907 379 K HW: 6R0 907 379 BA
Component: ESP9.0i H03 0004
Serial number: 08505343150703
Coding: 0000000000000000000000000000000000000000000000000000
Shop #: WSC 00049 770 00113
ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
VCID: 377720578E7EE8FD44-8062
0943 - ABS/ESP Control Module
U10C5 00 [137] - No or Incorrect Basic Setting
Reset counter: 73
Mileage: 39496 km
Date: 2017.07.28
Time: 00:00:04
1141 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
1149 - Implausible Data Received from Steering Angle Sensor Module (G85)
U0428 00 [137] - -
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
0887 - Control Module
U4E0450 F0 [024] - Incorrect VIN
Intermittent - Confirmed - Not Tested Since Memory Clear
Reset counter: 113
Mileage: 39496 km
Date: 2017.07.28
Time: 00:00:04
0883 - Control module not coded
U1013 00 [024] - -
Reset counter: 113
Time: 00:00:00
Address 08: Auto HVAC (J301) Labels:| 6C0-820-045.clb
Part No SW: 6P0 820 045 B HW: 6P0 820 045 B
Component: AC Manuell H01 0202
Serial number: 1505221B-1357
Coding: 001000001000200200
Shop #: WSC 00049 770 00139
ROD: EV_ACManueKMMValeoPQ26.rod
VCID: 2B5F0C2742365C1D30-807E
131074 - Supply voltage
U1011 00 [013] - Voltage too Low
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:39:17
Voltage terminal 30: 7.7 V
131076 - Function Restricted due to Insufficient Voltage
U1400 00 [012] - -
Reset counter: 181
Mileage: 2326 km
Date: 2017.01.16
Time: 13:36:46
Voltage terminal 30: 8.8 V
262914 - Refrigerant Pressure
U8E6550 F0 [013] - Too Low
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:48
590082 - Control Circuit for A/C Compressor
B10A9 15 [013] - Open or Short to Plus
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:48
Compressor shut-off requirement: A/C off or fan control switch in 0 position
Compressor current: actual value: 1.275 mA
Compressor current: specified value: 0.000 mA
Voltage terminal 30: 11.2 V
Address 09: Cent. Elect. (J519) Labels:| 6C0-937-089-V1.clb
Part No SW: 6C0 937 089 D HW: 6C0 937 089
Component: BCM PQ26 Hi4R H10 0094
Serial number: 006308112098
Coding: 080008404013405B4B844000400703000000690051010000000000000000
ASAM Dataset: EV_BCMA0 006002
ROD: EV_BCMA0_006_SE26.rod
VCID: 31631E4F601A36CD0A-8064
8202 - Bulb for Left DRL
B121D 15 [009] - Open or Short to Plus
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:52
8458 - Bulb for Right DRL
B121E 15 [009] - Open or Short to Plus
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:52
131330 - Supply voltage
U1011 00 [009] - Voltage too Low
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:35:54
131586 - Function Restricted due to Insufficient Voltage
U1400 00 [009] - -
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:33:45
558100 - Databus
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
Address 15: Airbags (J234) Labels:| 6C0-959-655.clb
Part No SW: 6C0 959 655 J HW: 6C0 959 655 J
Component: VW20Airbag006 002 0380
Revision: -------- Serial number: 003TH00001DK
Coding: 88C0C000000000005C000000000800000000
Shop #: WSC 19460 666 12345
ROD: EV_AirbaVW20BPAVW26X.rod
VCID: 3A713963BD6CF595BB-806E
8 Faults Found:
9443091 - Driver's Side Airbag Crash Sensor
B1017 13 [137] - Open Circuit
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
9451027 - Crash sensor side airbag; passenger side
B1036 13 [137] - Open Circuit
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
9682162 - Multiple collision brake
U917652 F2 [137] - No function
Mileage: 39496 km
Date: 2017.07.28
Time: 00:00:21
B1007 1B [137] - Resistance Too High
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:46
9440027 - Driver's side; side-airbag igniter
B100B 1B [137] - Resistance Too High
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:46
9439771 - Front Passenger's Side Airbag Igniter
B100A 1B [137] - Resistance Too High
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:46
9447189 - Seat Occupied Sensor; Passenger's Side
B1027 15 [137] - Open or Short to Plus
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:45
U1101 00 [137] - Active
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
Part No SW: 6P0 920 741 B HW: 6P0 920 741 B
Component: KOMBI 202 2310
Coding: 072409002080000800082A001000000000000000
ROD: EV_DashBoardVDDMQBAB_SE26.rod
VCID: 2F671837762E203D1C-807A
Address 19: CAN Gateway (J533) Labels:| 6C0-909-901-V1.clb
Part No SW: 6C0 909 901 A HW: 6C0 937 089
Component: GW MQB A0 H10 0094
Revision: -------- Serial number: 006308112098
Coding: 010100080008590070000000000000000001000000000000000000000000
ASAM Dataset: EV_GatewA0Lear 013020
ROD: EV_GatewA0Lear_013_VW26.rod
VCID: 2649FD1359D46175EF-8072
Subsystem 1 - Part No SW: 5F0 959 537 HW: 5F0 959 537 Labels: 3C8-959-537.CLB
Component: E221__MFL-PR6 H04 0130
Serial number: 000000000B1369250915
Coding: 001000
1282 - Supply voltage
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:37:30
Supply voltage: Terminal 30: 8.5 V
Terminal 15: On
66304 - Databus
U1124 00 [009] - Additional Installations Detected
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
Supply voltage: Terminal 30: 11.1 V
Terminal 15: On
U1101 00 [009] - Active
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
Supply voltage: Terminal 30: 11.2 V
Terminal 15: On
Address 44: Steering Assist (J792) Labels:| 6Rx-909-144-V2.clb
Part No SW: 6C1 909 144 AG HW: 6C1 909 144 D
Component: EPS_TRW_ALow 313 3232
Serial number: CG8V0279
Coding: 000700
ASAM Dataset: EV_SteerAssisUDSTRW 016026
ROD: EV_SteerAssisUDSTRW.rod
1055232 - Supply voltage
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:31:46
Engine speed: 0 /min
Vehicle speed: 0.00 km/h
Voltage terminal 30: 9.94 V
Power steering current consumption: 0.50 A
max.value: 0.50 A
End stage temperature: 17 °C
Steering assistance: engine output: 0.00 %
Engine angle: 0 °
Electric motor speed: 0 /min
Steering assistance: target engine torque: 0.00 Nm
Steering torque: 0.03 Nm
Status: OK
1094656 - Steering angle sensor
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:43
Address 5F: Information Electr. (J794) Labels:* Redir Fail!
Part No SW: 5F0 035 871 B HW: 5F0 035 871 B
Component: MU-E--ER 050 7060
Serial number: 06071600011601
Coding: 04520000BE00000011110001010108002F0000840000010000
ASAM Dataset: EV_MUEnt4CGen2LGE 001032
ROD: EV_MUEnt4CGen2LGE_VW26.rod
VCID: 254BFA1F24D26A6DE6-8070
8 Faults Found:
1537 - Supply voltage
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:36:32
Voltage terminal 30: 8.7 V
15360768 - Component Protection
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:42
Voltage terminal 30: 11.0 V
1539 - Function Restricted due to Insufficient Voltage
U1400 00 [009] - -
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:36:59
Voltage terminal 30: 8.5 V
0517 - Front Right Bass Speaker
B1062 13 [009] - Open Circuit
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
Voltage terminal 30: 10.9 V
B1064 13 [009] - Open Circuit
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
0522 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
B1061 13 [009] - Open Circuit
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:44
7206 - Function Restricted due to Missing Message(s)
U1111 00 [009] - -
Reset counter: 141
Mileage: 2326 km
Date: 2017.01.16
Time: 13:28:45
BAP-BAP_Function_ID: 00
End-------------------------(Elapsed Time: 02:06)--------------------------
