- Oct 17, 2017
- 982
- 505
- Northwest UK
- C?ID=321059
Still having no success guys. I've tried non-zero values and still no success.
Any solutions??
Any solutions??
This started with Guided Functions in the VAS. Basically, VW tool the info that should (and used to be) in the repair manual and made it part of their scan tool, and now the repair manual just says: "Use our scan tool and do what it tells you".But basic settings are much better with ODIS. ODIS guides you through the complete process. For example, if you do brake bleeding, ODIS tells you what to do step-by-step. With VCDS you only hear pump ticking and then you need to guess what to do next.
I can't add the A5 camera into the PDC module but I know it's down to it being a 'e' revision. I think it might be possible with flashing the unit with software from say a H or a K version but I'm thinking of retrofitting PLA 3.0 so I might just try that module in in one go 5QA 919 298 C. A bloke on Ali express has it with the extra sensors and ABS sensors for about $250. I think my car already has PLA abs sensors as it has factory fitted ACC.
It's too close to Christmas to start that project so 1st thing in Jan ��
Unfortunately that didn't make a difference and my ABS is coded to exactly that coding string.
I have a question, what is your ACC coded to?? Mine is 00000300FE0739
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 5F A5
VIN: WVWZZZAUZFP100853 Mileage: 31843km-19786miles
Address 01: Engine (J623-CLHA) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 021 M HW: 04L 907 309 B
Component: R4 1,6L EDC X22 7635
Revision: 84X22---
Coding: 01110012034505092000
Shop #: WSC 00028 028 00028
ASAM Dataset: EV_ECM16TDI01104L906021M 002012
ROD: EV_ECM16TDI01104L906021P.rod
VCID: 2F6AAE9076139552153-807A
Part No SW: 3Q0 907 379 AF HW: 3Q0 907 379 F
Component: ESC H42 0625
Revision: 00000000 Serial number: 60825000001567
Coding: 01FA8AA11420096C077F060541C62580512890E06082A4F31440F078C082
Shop #: WSC 12345 123 12345
VCID: 7EF443D4E1F9ACDACE5-802A
Part No SW: 5G0 907 426 T HW: 5G0 907 426 T
Component: AC Manuell H02 1001
Revision: 00001K06
Coding: 00120104202100001000000000000000
Shop #: WSC 00028 028 00024
ROD: EV_ACManueBHBVW37X_003_VW37.rod
VCID: 3C7089DCB7657ECAA01-8068
Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AG HW: 5Q0 937 084 AG
Component: BCM MQBAB M H18 0137
Serial number: 01011507502417
Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
ROD: EV_BCMBOSCH_013.rod
VCID: 7DF644D8ECFFB7C2D7F-8028
Component: WWS 150304 042 0551
Serial number: 150312162128
Subsystem 2 - Part No SW: 5Q0 955 559 A HW: 5Q0 955 559 A Labels: 5Q0-955-547.CLB
Component: RLS 037 0059
Serial number: S5Y15M03D19H15M47S18
Coding: 90A8DD
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY150481FZR
Serial number: 00000000000061991997
Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb
Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0048
Revision: -------- Serial number: 39391507507581
Coding: 0071151001
ROD: EV_EPHVA18AU3700000_002_VW27.rod
VCID: 3D7684D8AC7F77C297F-8068
Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb
Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D
Component: ACC Bosch MQB H05 0304
Serial number: 07031503271652
Coding: 00000300FE0739
ASAM Dataset: EV_ACCMRRBoschVW372 001015
VCID: 387895CC835D52EA449-806C
Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA
Component: AirbagVW20 014 0386
Serial number: 003MLR0D9EUA
Shop #: WSC 00028 028 00013
VCID: 7F0ABED0E6F3A5D2C53-802A
Belt Pretensioner left:
Component: BeltPretRevFL H35 0341
Serial number: 34169677B17091450749
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H35 0341
Serial number: 34169676B18091450343
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 001 803 15
Serial number: 35767000000FE57C8317
Subsystem 4 - Part No SW: ----------- HW: 480 001 803 15
Serial number: 3586700000076C54731V
Subsystem 5 - Part No SW: ----------- HW: 480 402 003 15
Serial number: 3516502B119EFD22801D
Subsystem 6 - Part No SW: ----------- HW: 480 402 003 15
Serial number: 3526502C719EFD2472E.
Subsystem 7 - Part No SW: ----------- HW: 480 402 003 15
Serial number: 3556502B519EFD22438R
Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 20031504401200
Coding: 0C00
ROD: EV_SMLSKLOMQB_VW37.rod
VCID: 7BF24AC0F2EBB9F2E9B-802E
Part No SW: 5G1 920 941 HW: 5G1 920 941
Component: KOMBI 204 4270
Coding: 27A51A00678C2F0001887A0B1400000000000000
VCID: 66C40BB49969141A265-8032
Part No SW: 5Q0 907 530 AC HW: 5Q0 907 530 M
Component: GW MQB High 212 2203
Revision: -------- Serial number: 18031510800425
Coding: 030100040F087300FF00025C080F00010001050000000000000000000000
VCID: 72EC67E4A5A1F8BABAD-8026
Component: E221__MFL-DC1 H16 0038
Serial number: 29140002017020084377
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 G HW: 5Q0 915 181 G
Component: J367-BDMHella H04 8050
Serial number: 1306535903
Component: HRE_Master H12 0071
Serial number: 0400936029
Coding: 02031203
ROD: EV_HREntryHella_VW37.rod
Subsystem 1 - Part No SW: 5Q0 907 685 B HW: 5Q0 907 685 B
Component: HRE_Slave H12 0071
Serial number: 0400325995
Coding: 020312
338048 - Databus
Reset counter: 76
Mileage: 31843 km
Date: 2017.12.07
Time: 21:07:51
Part No SW: 5Q4 959 593 C HW: 5Q4 959 593 B
Component: TSG FS 009 0015
Serial number: 0000140168092
Coding: 00350220D001028000001000
VCID: 4586EC38C4AF3F02CFF-8010
Subsystem 1 - Part No SW: 5Q4 959 812 A HW: 5Q4 959 812 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000008327686
Coding: 0D0000
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 9102
VCID: 4382F220CA9B0132E1B-8016
Part No SW: 5Q4 959 592 C HW: 5Q4 959 592 B
Component: TSG BFS 009 0015
Serial number: 0000141936089
Coding: 00350020DE01028000801000
VCID: 4480F13CCF95060AD81-8010
Subsystem 1 - Part No SW: 5Q4 959 811 A HW: 5Q4 959 811 A Labels: 5QX-959-81X-V1.CLB
Serial number: 00000000000001049493
Coding: 050000
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH1.clb
Part No SW: 5G0 035 020 D HW: 5G0 035 020 D
Component: MU-H-ND-EU H43 0388
Serial number: A310G0EB003873
Coding: 02730001FF00000021111201008800101F010016010001007C
ASAM Dataset: EV_MUHig4CHBAS 001040
ROD: EV_MUHig4CHBAS_VW37.rod
VCID: 1A3C6F441D9160FA52D-804E
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H60 0030
Serial number: VWZ8Z9PS1007K6
Subsystem 2 - Part No SW: V03 959 801 DG HW: -----------
Component: ECE 2016/2017 --- 0153
Component: Gracenote --- 1010
1543 - Control Module Incorrectly Coded
U1014 00 [009] - -
Reset counter: 75
Mileage: 31818 km
Date: 2017.12.07
Time: 11:36:41
Voltage terminal 30: 12.1 V
Byte_Coding_Condition-byte_0_condition: OK
Byte_Coding_Condition-byte_1_condition: OK
Byte_Coding_Condition-byte_10_condition: ERROR
Byte_Coding_Condition-byte_11_condition: ERROR
Byte_Coding_Condition-byte_12_condition: ERROR
Byte_Coding_Condition-byte_13_condition: ERROR
Byte_Coding_Condition-byte_14_condition: ERROR
Byte_Coding_Condition-byte_15_condition: ERROR
Byte_Coding_Condition-byte_16_condition: ERROR
Byte_Coding_Condition-byte_17_condition: ERROR
Byte_Coding_Condition-byte_18_condition: ERROR
Byte_Coding_Condition-byte_19_condition: ERROR
Byte_Coding_Condition-byte_2_condition: OK
Byte_Coding_Condition-byte_20_condition: ERROR
Byte_Coding_Condition-byte_21_condition: ERROR
Byte_Coding_Condition-byte_22_condition: ERROR
Byte_Coding_Condition-byte_23_condition: ERROR
Byte_Coding_Condition-byte_24_condition: ERROR
Byte_Coding_Condition-byte_25_condition: ERROR
Byte_Coding_Condition-byte_26_condition: ERROR
Byte_Coding_Condition-byte_27_condition: ERROR
Byte_Coding_Condition-byte_3_condition: OK
Byte_Coding_Condition-byte_4_condition: OK
Byte_Coding_Condition-byte_5_condition: OK
Byte_Coding_Condition-byte_6_condition: OK
Byte_Coding_Condition-byte_7_condition: OK
Byte_Coding_Condition-byte_8_condition: OK
Byte_Coding_Condition-byte_9_condition: OK
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 5Q0-980-653.clb
Part No SW: 5Q0 980 653 G HW: 5Q0 980 653
Component: MQB_MFK H06 0060
Serial number: 10000102807
Coding: 0101000001020303000300010100010100
Shop #: WSC 01725 666 28888
ROD: EV_MFKBoschAU370.rod
6422533 - Databus
Reset counter: 76
Mileage: 31843 km
Date: 2017.12.07
Time: 21:07:06
Control Module temperature: 15 °C
Outside air temperature: 3.0 °C
Vehicle speed: 0.00 km/h
Voltage terminal 15: 12.0 V
Terminal 15 on: 15.4 s
