A5 Lane Assist (Retrofit Mk.7 Golf)
myounus
Northwest UK
C?ID=321059
Still having no success guys. I've tried non-zero values and still no success.
Any solutions??
   #22
myounus
Northwest UK
C?ID=321059
Do you guys think I need to replace the rear ABS sensors? Do you think that's causing the issue?
   #23
myounus
Northwest UK
C?ID=321059
Update:
The ABS sensors are fine and I have managed to get it working. However, when I put the car into reverse I get errors on the dash and it switches off both blind spot assist and rear traffic alert. On VCDS I have databus errors in 3C and A5. It won't activate again until I delete the errors and switch off/back on the car.
I think it has something to do with the error I've been seeing where the PDC module won't allow me to select A5 camera in coding. What would you advise?
   #24
myounus
Northwest UK
C?ID=321059
Update: I think I 've worked out the issue. I've got a PDC Module of 5Q0 919 294 E.
In order for blind spot assist to work you have to have a module that is F or superior. So I'm going to scour the internet to see if I can update the software on this module, otherwise I'll have to purchase a new one.
   #25
myounus
Northwest UK
C?ID=321059
Final Update: I went along to the VW Dealership and spent some time with a master technician and had a play with their ODIS system. It could not update the software on this module and to be honest is poor in comparison to VCDS.
The master technician was impressed with VCDS and has said he's going to buy a lead himself as it can do more than what his system can. He told me that they have to contact VW UK for the binary coding as they're not told anything. They are told to
Follow a fault diagnosis plan and that's it.
Next mission to accomplish - new module!!
downtime
C?ID=280813
He's wrong. You cannot do more with VCDS than with ODIS. ODIS is very very good software but you need to know how to use it. It is a bit restricting as you need to follow Guided Functions for most of the things, but it is really easy to use.
VCDS you can do codings, adaptations easier. But basic settings are much better with ODIS. ODIS guides you through the complete process. For example, if you do brake bleeding, ODIS tells you what to do step-by-step. With VCDS you only hear pump ticking and then you need to guess what to do next.
But again, it's like comparing apples and oranges. Both tools are excellent tools but they have a different purpose.
   #27
myounus
Northwest UK
C?ID=321059
From what I've seen and read on these forums, what's plainly clear is that people like you and others are Far Far Far more educated, skilled and knowledged than what they teach the techs at the dealerships. I suppose it's down to the age old saying 'knowledge is power' and they probably don't want the techs to know more than they want
   #28
downtime
C?ID=280813
I think it's more than most of the techs have "just working here" -attitude. Techs who have genuine interest to what they are doing so that it expands to their spare time, well they are VERY rare :)
We are not working, or at least most of us are not working with these cars for their living, so we have time to grow a real interest. A little unfair positioning :)
Anyway, both are good tools, but from a slightly different angle each.
Can I ask what is the problem with your PDC module still? Are you not enable ACC in the PDC module or what? I can't do that either in my PDC 8 channel module but I haven't seen any negative in my ACC retrofit due to that.
I have to be honest that I've thought about getting a new PDC module but haven't got around to do that yet.
   #29
myounus
Northwest UK
C?ID=321059
I can't add the A5 camera into the PDC module but I know it's down to it being a 'e' revision. I think it might be possible with flashing the unit with software from say a H or a K version but I'm thinking of retrofitting PLA 3.0 so I might just try that module in in one go 5QA 919 298 C. A bloke on Ali express has it with the extra sensors and ABS sensors for about $250. I think my car already has PLA abs sensors as it has factory fitted ACC.
It's too close to Christmas to start that project so 1st thing in Jan ��
   #30
This started with Guided Functions in the VAS. Basically, VW tool the info that should (and used to be) in the repair manual and made it part of their scan tool, and now the repair manual just says: "Use our scan tool and do what it tells you".
myounus
Northwest UK
C?ID=321059
Is it possible to add guided functions onto VCDS? Have the cake and eat it!
   #32
downtime
C?ID=280813
I have factory fit A5 Front camera and I don't have anything in PDC module for that. Is it required to be coded there for Blind spot monitoring or what?
   #33
myounus
Northwest UK
C?ID=321059
Well it would seem so as I can't work out what else could be causing the Blindspot to de-activate once the car activates the PDC by putting car into reverse. I've ordered a PLA 3.0 module now so either I'll make a mountain out of a molehill or I might get both working properly!
   #34
downtime
C?ID=280813
Well have you tried disabling this from PDC?
Try this coding :
0031051001
It disables the PDC activation when car rolling back. It enables the PDC normally of course when gear on and moving forward low speed and when putting the car on reverse. See if that fixes the issue.
   #35
myounus
Northwest UK
C?ID=321059
I'll give it a whirl
   #36
downtime
C?ID=280813
And one more thing you could try as well.
In ABS module, there's possibility to code RCTA = Rear Cross Traffic Alert function when you have BSM modules and PDC.
So try this as your ABS coding :
01FA8AA11420096C077F060541C62580512890E06082A4F31440F078C082
This enables RCTA in ABS module. Maybe the problem is not in the PDC module but the ABS is not coded correctly?
   #37
myounus
Northwest UK
C?ID=321059
Unfortunately that didn't make a difference and my ABS is coded to exactly that coding string.
I have a question, what is your ACC coded to?? Mine is 00000300FE0739
   #38
downtime
C?ID=280813
I'll check that when I get home. I have automatic transmission so there's some small differences in coding.
   #39
downtime
C?ID=280813
One question, you have changed your ABS coding at some point? Because latest autoscan you pasted here has this ABS coding :
01FA8AA11420096C077F060541C62580512890E06082A4F31440F078C002
Which is not the same as what I proposed to change it to. The last byte is not the same.
Can you please do a fresh autoscan and post it here?
   #40
myounus
Northwest UK
C?ID=321059
Your wish is my command: Autoscan below:
Chassis Type: AU-VW37 (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 3C 42 44 52 5F A5
VIN: WVWZZZAUZFP100853   Mileage: 31843km-19786miles
Address 01: Engine (J623-CLHA)       Labels:. 04L-907-309-V1.clb
   Part No SW: 04L 906 021 M    HW: 04L 907 309 B
   Component: R4 1,6L EDC   X22 7635
   Revision: 84X22---
   Coding: 01110012034505092000
   Shop #: WSC 00028 028 00028
   ASAM Dataset: EV_ECM16TDI01104L906021M 002012
   ROD: EV_ECM16TDI01104L906021P.rod
   VCID: 2F6AAE9076139552153-807A
   Part No SW: 3Q0 907 379 AF    HW: 3Q0 907 379 F
   Component: ESC           H42 0625
   Revision: 00000000    Serial number: 60825000001567
   Coding: 01FA8AA11420096C077F060541C62580512890E06082A4F31440F078C082
   Shop #: WSC 12345 123 12345
   VCID: 7EF443D4E1F9ACDACE5-802A
   Part No SW: 5G0 907 426 T    HW: 5G0 907 426 T
   Revision: 00001K06
   Coding: 00120104202100001000000000000000
   Shop #: WSC 00028 028 00024
   ROD: EV_ACManueBHBVW37X_003_VW37.rod
   VCID: 3C7089DCB7657ECAA01-8068
   Part No SW: 5Q0 937 084 AG    HW: 5Q0 937 084 AG
   Component: BCM MQBAB M   H18 0137
   Serial number: 01011507502417
   Coding: 03000842C241027B0BA44080B10403281000000000000000000000000000
   ROD: EV_BCMBOSCH_013.rod
   VCID: 7DF644D8ECFFB7C2D7F-8028
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A  Labels: 5QX-955-119-V1.CLB
   Component: WWS    150304  042 0551
   Serial number:         150312162128
   Subsystem 2 - Part No SW: 5Q0 955 559 A    HW: 5Q0 955 559 A  Labels: 5Q0-955-547.CLB
   Component: RLS  037 0059
   Serial number: S5Y15M03D19H15M47S18
   Coding: 90A8DD
   Serial number: 000000000ZY150481FZR
   Serial number: 00000000000061991997
   Part No SW: 5Q0 919 294 E    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0048
   Revision: --------    Serial number: 39391507507581
   Coding: 0071151001
   ROD: EV_EPHVA18AU3700000_002_VW27.rod
   VCID: 3D7684D8AC7F77C297F-8068
Address 13: Auto Dist. Reg (J428)       Labels:| 5Q0-907-572-V1.clb
   Part No SW: 5Q0 907 572 D    HW: 5Q0 907 572 D
   Component: ACC Bosch MQB H05 0304
   Serial number: 07031503271652
   Coding: 00000300FE0739
   ASAM Dataset: EV_ACCMRRBoschVW372 001015
   VCID: 387895CC835D52EA449-806C
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0D9EUA
   Shop #: WSC 00028 028 00013
   VCID: 7F0ABED0E6F3A5D2C53-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0341
   Serial number: 34169677B17091450749
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0341
   Serial number: 34169676B18091450343
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 803 15
   Serial number: 35767000000FE57C8317
   Subsystem 4 - Part No SW: -----------    HW: 480 001 803 15
   Serial number: 3586700000076C54731V
   Subsystem 5 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3516502B119EFD22801D
   Subsystem 6 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3526502C719EFD2472E.
   Subsystem 7 - Part No SW: -----------    HW: 480 402 003 15
   Serial number: 3556502B519EFD22438R
   Part No SW: 5Q0 953 507 DD    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 20031504401200
   Coding: 0C00
   ROD: EV_SMLSKLOMQB_VW37.rod
   VCID: 7BF24AC0F2EBB9F2E9B-802E
   Part No SW: 5G1 920 941     HW: 5G1 920 941
   Component: KOMBI         204 4270
   Coding: 27A51A00678C2F0001887A0B1400000000000000
   VCID: 66C40BB49969141A265-8032
   Revision: --------    Serial number: 18031510800425
   Coding: 030100040F087300FF00025C080F00010001050000000000000000000000
   VCID: 72EC67E4A5A1F8BABAD-8026
   Component: E221__MFL-DC1  H16 0038
   Serial number: 29140002017020084377
   Coding: 2CFFFF
   Serial number: 1306535903
   Serial number: 0400936029
   Coding: 02031203
   ROD: EV_HREntryHella_VW37.rod
   Component: HRE_Slave  H12 0071
   Serial number: 0400325995
   Coding: 020312
338048 - Databus
                    Reset counter: 76
                    Mileage: 31843 km
                    Date: 2017.12.07
                    Time: 21:07:51
   Part No SW: 5Q4 959 593 C    HW: 5Q4 959 593 B
   Component: TSG FS        009 0015
   Serial number: 0000140168092
   Coding: 00350220D001028000001000
   VCID: 4586EC38C4AF3F02CFF-8010
   Serial number: 00000000000008327686
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  125 1061
   Coding: 9102
   VCID: 4382F220CA9B0132E1B-8016
   Part No SW: 5Q4 959 592 C    HW: 5Q4 959 592 B
   Component: TSG BFS       009 0015
   Serial number: 0000141936089
   Coding: 00350020DE01028000801000
   VCID: 4480F13CCF95060AD81-8010
   Serial number: 00000000000001049493
   Coding: 050000
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 020 D    HW: 5G0 035 020 D
   Component: MU-H-ND-EU    H43 0388
   Serial number: A310G0EB003873
   Coding: 02730001FF00000021111201008800101F010016010001007C
   ASAM Dataset: EV_MUHig4CHBAS 001040
   ROD: EV_MUHig4CHBAS_VW37.rod
   VCID: 1A3C6F441D9160FA52D-804E
   Component: ABT_High  H60 0030
   Serial number: VWZ8Z9PS1007K6
   Subsystem 2 - Part No SW: V03 959 801 DG    HW: -----------
   Component: ECE 2016/2017  --- 0153
   Component: Gracenote  --- 1010
1543 - Control Module Incorrectly Coded
          U1014 00 [009] - -
                    Reset counter: 75
                    Mileage: 31818 km
                    Date: 2017.12.07
                    Time: 11:36:41
                    Voltage terminal 30: 12.1 V
                    Byte_Coding_Condition-byte_0_condition: OK
                    Byte_Coding_Condition-byte_1_condition: OK
                    Byte_Coding_Condition-byte_10_condition: ERROR
                    Byte_Coding_Condition-byte_11_condition: ERROR
                    Byte_Coding_Condition-byte_12_condition: ERROR
                    Byte_Coding_Condition-byte_13_condition: ERROR
                    Byte_Coding_Condition-byte_14_condition: ERROR
                    Byte_Coding_Condition-byte_15_condition: ERROR
                    Byte_Coding_Condition-byte_16_condition: ERROR
                    Byte_Coding_Condition-byte_17_condition: ERROR
                    Byte_Coding_Condition-byte_18_condition: ERROR
                    Byte_Coding_Condition-byte_19_condition: ERROR
                    Byte_Coding_Condition-byte_2_condition: OK
                    Byte_Coding_Condition-byte_20_condition: ERROR
                    Byte_Coding_Condition-byte_21_condition: ERROR
                    Byte_Coding_Condition-byte_22_condition: ERROR
                    Byte_Coding_Condition-byte_23_condition: ERROR
                    Byte_Coding_Condition-byte_24_condition: ERROR
                    Byte_Coding_Condition-byte_25_condition: ERROR
                    Byte_Coding_Condition-byte_26_condition: ERROR
                    Byte_Coding_Condition-byte_27_condition: ERROR
                    Byte_Coding_Condition-byte_3_condition: OK
                    Byte_Coding_Condition-byte_4_condition: OK
                    Byte_Coding_Condition-byte_5_condition: OK
                    Byte_Coding_Condition-byte_6_condition: OK
                    Byte_Coding_Condition-byte_7_condition: OK
                    Byte_Coding_Condition-byte_8_condition: OK
                    Byte_Coding_Condition-byte_9_condition: OK
Address A5: Frt Sens. Drv. Assist (R242)       Labels:| 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 G    HW: 5Q0 980 653
   Component: MQB_MFK       H06 0060
   Serial number: 10000102807
   Coding: 0101000001020303000300010100010100
   Shop #: WSC 01725 666 28888
   ROD: EV_MFKBoschAU370.rod
6422533 - Databus
                    Reset counter: 76
                    Mileage: 31843 km
                    Date: 2017.12.07
                    Time: 21:07:06
                    Control Module temperature: 15 °C
                    Outside air temperature: 3.0 °C
                    Vehicle speed: 0.00 km/h
                    Voltage terminal 15: 12.0 V
                    Terminal 15 on: 15.4 s
