2012 R8 Trans (R-Tronic) Adaptations
TheCzarofMexico
C?ID=314943
I'm trying to run the kiss point and fork position programs but VCDS says "not available". I have the car running, in N, parking brake on, brake depressed. The car does have a trans tune already.
Do you mean that the transmission ECU has been "chip tuned"? If so are you sure that the tuner hasn't disabled the kiss point and fork position calibrations?
TheCzarofMexico
C?ID=314943
Car is a 2012 R8 twin turbo R-Tronic
Yes the TCM has been tuned. No I'm not sure although I don't know why he would disable that or how to check or re-enable it as I'm very new to VCDS.
Below is the autoscan. Some interesting stuff (I have been having intermittent connection problems with the drivers side (B) ECU) but the auto trans section is A-Okay.
Tuesday,17,October,2017,19:21:20:61299
VCDS Version: 17.8.0.1 (x64)  HEX-V2 CB: 0.4401.4
VIN: WUAENAFG6CN001875   License Plate:
Chassis Type: FG-AU35 (7N0)
Scan: 01 02 03 08 09 0F 10 11 31 14 15 16 17 19 25 37 42 46 47 52
          56 61 65 6C 77 A6
VIN: WUAENAFG6CN001875   Mileage: 25590km-15900miles
11-Engine II -- Status: Sporadic communication error 1000
31-Engine other -- Status: Sporadic communication error 1000
A6-Microphone -- Status: Malfunction 0010
Address 01: Engine (BUJ)       Labels: None
   Part No SW: 424 910 552 M    HW: 420 907 552 B
   Component: 5.2L V10HDZ/4V F   ª0010
   Revision: F5H09---    Serial number: AUX7Z0KNFN90J4
   Coding: 011000091B0F0120
   Shop #: WSC 61656 001 1048576
   VCID: 1D64D1E2C1BF39DF50C-8048
005464 - Throttle Actuator (G186)
               P1558 - 002 - Electrical Malfunction - Intermittent
                    Mileage: 25589 km
                    Date: 2017.10.17
                    Time: 19:07:34
                    RPM: 730 /min
                    Load: 24.3 %
                    Temperature: 76.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 14.097 V
Readiness: 0110 1100
Address 02: Auto Trans        Labels: 420-910-156-V2.clb
   Part No SW: 420 910 156 M    HW: 420 927 156
   Component: SL600 5.2L FSI HDZ  0040
   Revision: SBH04001    Serial number: 9P2N113BL
   Coding: 0000001
   Shop #: WSC 02197 785 00200
   VCID: 196CC5F2D59745FFBC4-804C
   Subsystem 1 - Part No: 420 713 041 C
   Component: A11 C02  23.08.11   0A11
   Part No SW: 420 907 379     HW: 420 614 517 D
   Component: ESP8 quattro    H01 0200
   Coding: 0000271
   VCID: 59EC85F2951785FF7C4-800C
                    Fault Status: 00101101
                    Fault Frequency: 38
                    Reset counter: 169
                    Mileage: 25518 km
                    Date: 2017.10.11
                    Time: 12:34:16
                    Hex Value: 0x00C0
                    Hex Value: 0x6222
                    Hex Value: 0x0024
                    Hex Value: 0x0191
                    Hex Value: 0x0000
18265 - Load Signal
            P1857 - 000 - Error Message from ECU - Intermittent
                    Fault Frequency: 27
                    Reset counter: 169
                    Mileage: 25518 km
                    Date: 2017.10.11
                    Time: 14:00:10
                    Hex Value: 0x00C0
                    Hex Value: 0x6222
                    Hex Value: 0x0027
                    Hex Value: 0x0193
                    Hex Value: 0x0000
   Part No SW: 420 820 043 G    HW: 420 820 043 G
   Component: J255  Klima 1 Zone  0100
   Revision: 00H06007    Serial number: 00000001201216
   Coding: 1572906
   VCID: 0E46A6AE1C599247D96-805A
   Part No SW: 8P0 907 063 S    HW: 8P0 907 063 S
   Component: BCM PQ35  H   110 0667
   Revision: AG110667
   Coding: 6E000A00A893362420744CE00920004150F26A001120C92ADC080E1C0045
   Shop #: WSC 02391 823 56573
   VCID: 44D244860E9528173F2-8010
   Subsystem 1 - Part No SW: 423 955 113     HW: 423 955 113   Labels: 1KX-955-119.CLB
   Component: Wischer AudiR  H23 0040
   Coding: 005912
   Subsystem 2 - Part No SW: 8K0 910 557     HW: 8K0 955 559 A  Labels: 8K0-955-559.CLB
   Component: REGENLICHTSEN  H04 0003
   Coding: 025B32
   Part No SW: 8E0 035 593 P    HW: 8E0 035 593 P
   Component: SDAR SIRIUS     H07 0160
   Revision: 00000000    Serial number: AUZ4Z7L0607409
   Coding: 0000100
   VCID: 36362E4E44498A87B16-8062
            000 -  -
                    Reset counter: 244
                    Mileage: 22977 km
                    Date: 2017.02.05
                    Time: 13:18:25
Address 10: Park/Steer Assist (J446)       Labels:. 8P0-919-475-7X2.clb
   Part No SW: 8P0 919 475 N    HW: 8P0 919 475 N
   Component: PARKHILFE 8K  H01 0140
   Revision: 11001001    Serial number: 12501128400493
   Coding: 30010C
   VCID: 49CC55B229B7F57FCC4-801C
Address 11: Engine II        Labels: None
Address 14: Susp. Elect.        Labels: 8P0-907-376.lbl
   Part No SW: 420 910 376 A    HW: 420 907 376 A
   Component: J250 Raddaempfung   0170
   Revision: --H16---    Serial number: 190DPH 1269164
   Coding: 0000052
   VCID: 117CBDD20D678DBFC44-8044
01316 - ABS Control Module
                    Reset counter: 130
                    Mileage: 25578 km
                    Date: 2017.10.17
                    Time: 16:19:01
                    Voltage: 12.60 V
                    Speed: 2.6 km/h
                    Voltage: 4.99 V
Address 15: Airbags        Labels: 420-959-655.lbl
   Part No SW: 420 959 655     HW: 420 959 655
   Component: SN Airbag 9.43  H02 0020
   Revision: 93H02002    Serial number: 003B8000FHNY
   Coding: 0021326
   VCID: 5DE491E2813F79DF10C-8008
   Subsystem 1 - Part No: 8J0 910 339 A
   Component: BF-Gewichtsens. H02 0030
   Subsystem 2 - Serial number: 05PUT
   Subsystem 3 - Serial number: 0001.01.0000H0200000000000ÿ†63
   Subsystem 4 - Serial number: 000000ÿ†63328RB4065E86CD%ÿ†63
   Subsystem 5 - Serial number: E86CD%ÿ†63428RB406619C8AVÿ†63
   Subsystem 6 - Serial number: 19C8AVÿ†63747RB4067B77F70ÿ†63
   Subsystem 7 - Serial number: B77F70ÿ†63847RB4067B7D39/ÿ
   Subsystem 8 - Serial number: B7D39/ÿ
Address 16: Steering wheel        Labels: 8P0-953-549-F.lbl
   Part No SW: 8P0 953 549 F    HW: 8P0 953 549 F
   Component: J0527           H37 0070
   Coding: 0004141
   VCID: 41DC4D921D873D3F144-8014
   Component: E0221           H06 0030
Address 17: Instruments        Labels: 420-920-xxx-17.clb
   Part No SW: 420 920 981 K    HW: 420 920 981 K
   Component: KOMBIINSTR. VDO H02 0650
   Revision: D0H02002    Serial number: 224NK002000358
   Coding: 0081288
   Shop #: WSC 47389 001 1048576
   VCID: 1E66D6EECCB922C7496-804A
   Part No SW: 7N0 907 530 N    HW: 1K0 907 951
   Component: J533  Gateway H43 1623
   Revision:   H43       Serial number: 111111F1001090
   Coding: 354100
   VCID: 3B203F7A736B57EF4E8-806E
01342 - Engine Control Module 2 (Slave 1)
                    Fault Status: 00110100
                    Fault Frequency: 44
                    Reset counter: 163
                    Mileage: 25518 km
                    Date: 2017.10.11
                    Time: 12:34:24
   Revision: D0H02002    Serial number: AUX7Z0KNFN90J4
   Part No SW: 423 035 192 H    HW: 423 035 192 H
   Component: RNS-E PU US     H06 0210
   Revision: 0000013S    Serial number: AUZBZ7L7201361
   Coding: 0730677
   VCID: 1574C9C2398F619F98C-8040
Address 42: Door Elect, Driver        Labels: 8P0-959-801-MAX3.lbl
   Part No SW: 420 959 801 H    HW: 420 959 801 H
   Component: Tuer-SG         H04 0103
   Coding: 0005245
Address 47: Sound System        Labels: None
   Part No SW: 427 035 223     HW: 427 035 223
   Component: J525 Amp High   H04 0030
   Revision: 00H04001    Serial number: 94842000565704
   Coding: 0246111
   VCID: 4CC26CA62AC5E057F72-8018
   Part No SW: 420 959 802 H    HW: 420 959 802 H
   Coding: 0005245
   VCID: 1F18EBEACBB32BCF420-804A
   Coding: 0730677
   Component: Batt.regelung H43 1623
   Coding: F3260148
   VCID: 71BCDD5261A7EDBFA44-8024
   Subsystem 1 - Part No SW: 420 915 181     HW: 420 915 181
   Component: J367-BDM  H07 0140
   Serial number: 00000000005650785607
Address 65: Tire Pressure        Labels: None
   Part No SW: 420 910 273 A    HW: 4F0 907 273 A
   Component: Reifendruck 3   H05 0040
   Revision: 00050040    Serial number: 00000900008154
   Coding: 0462426
   VCID: 0D44A1A2115FA95F20C-8058
Address 6C: Back-up Cam.        Labels: 420-910-441.clb
   Part No SW: 420 910 441 A    HW: 7L6 907 441 C
   Component: J772__Rearview      0010
   Revision: --H13---    Serial number: 525PA8-J1Y600O
   Coding: 1020412
   VCID: 0A4EAABE6031BE6705E-805E
   Part No SW: 8P1 862 336 A    HW: 8P1 862 336
   Component: FSE_256x BT     H44 0660
   Revision: 00000000    Serial number: 00000005159387
   Coding: 0011477
   Shop #: WSC 02556 785 00200
Address A6: Microphone (J886)       Labels:. 420-907-394.clb
   Part No SW: 420 907 394     HW: 420 907 394
   Component: BELTMICBOX    H09 0060
   Coding: 0100010202
   Shop #: WSC 02197 785 00000
   ASAM Dataset: EV_BeltMicAU715 002011
   ROD: EV_BeltMicAU715_002.rod
   VCID: 56F68ECEE889AA87516-8002
0032 - Microphone 1 for Passenver Side
          B1206 13 [009] - Open Circuit
                    Fault Frequency: 29
0048 - Microphone 2 for Passenver Side
          B1207 13 [009] - Open Circuit
                    Fault Frequency: 29
0064 - Microphone 3 for Passenver Side
          B1208 13 [009] - Open Circuit
                    Fault Frequency: 28
0080 - Microphone 1 for Drivers Side
          B1203 13 [009] - Open Circuit
                    Fault Frequency: 16
                    Mileage: 23345 km
                    Date: 2017.02.26
                    Time: 08:19:34
0096 - Microphone 2 for Drivers Side
          B1204 13 [009] - Open Circuit
                    Fault Frequency: 16
                    Mileage: 23345 km
                    Date: 2017.02.26
                    Time: 08:19:34
0112 - Microphone 3 for Drivers Side
          B1205 13 [009] - Open Circuit
                    Fault Frequency: 17
End----------(Elapsed Time: 01:34, VBatt start/end: 12.5V/12.4V)-----------
You'll need to ask the tuner I reckon.
They have a strange tendency to be clueless or in denial when it comes to this kind of thing.
TheCzarofMexico
C?ID=314943
Presuming it was tuned via vcds and the kiss point test disabled, how would I check?
TheCzarofMexico
C?ID=314943
I was under the impression that albeit time consuming, the trans could be tuned via vcds
Not true, VCDS cannot be used for flashing firmware - it can change coding and adaptation values (where the original VAG firmware allows) but it cannot change the firmware.
