@iichel: Your understanding of Polos is unparalleled on this forum and I would always accept your words - but on other -ish vehicles, the connector for incandescent headlights is 10 x pin whereas non-halogen headlight connectors are 14 x pin. Given
@Johan1 says " retrofitting polo 6C from halogen to led " , doesn't this necessarily mean installing an interconnection facility of some type to make the 10 x pin car loom fit 14 x pin headlight ? What have I missed?
PS: love the banner at the bottom of your post - great minds think alike (let's forget the other part of the adage)!!
Well, you're both right ... and also wrong. You do need an adapter to easily swap back to halogen (eg. for an MOT inspection in case they didn't retrofit / Washers), but it is not required. O can easily do with as well as without it.
As you can see from
this to
this, you can pull the wiring out of the 10-pin connector,then re-orerder them into the 14-pin, to which you have extra wires for the (instead of headlight range motor) + FOG/CORNERING (this one comes in the bumper on halogen equipped cars).
my situation is i want to buy een adapter from kufatec and i neeed only the coding
Either way, there's still wiring work to be done, and this thread has the same exact steps you'd need to follow regardless of you adding Xenon or LED .
Aside the main beam as that's a separate bulb on LEDs, you still need to get the DRL up and running, as well as the fog/cornering lamps (into the headlights) if you don't want to keep them in the front bumper.
PS:
These are the headlamps he wants to install. Still, we'd need a scan plus admaps to see if your 6C even suports it. You will need a 387 version (highline) at the very least.
With a bit of initiative and some sweat, trust me, you'll get there. I had no clue about retrofitting in the beginning, nor I had any clue about reading wiring diagrams lol. But with help from people like downtime, iichel, DV52 and RT Staff, I gathered some decent knowledge
