2014 Tiguan 5n; RNS510 to RCD510; Trailer control module; Voice Recognition Language
Emzy
C?ID=310014
Hi everyone. I'm new to the forums and the vag-com world in general though I look forward to learning and becoming a contributor and resource for the VCDS community.
I figure I should list what I have modified and retrofitted to this vehicle, what problems I am observing directlty, and then explain away as much as I understand about each of the fault codes so you know where my thoughts are and what I've tried. Please bear with me, I'm sure my vocabulary will be off.
Modifications:
  • I replaced the stock RCD510 with an RNS510. The headunit appears to be in fully working order, the nav and map work fine and point me in the right direction.
  • I added the OEM trailer hitch and electronic module for the harmonic dampening functionality.
  • I installed a speaker system. Signal goes from Headunit line outputs -> DSP -> Amp -> crossovers -> speakers. It sounds fine and appears fully functional.
  • I replaced my diverter valve (was the old diaphragm type) with a GFB DV+.
That sums up the modifications.
Here's what isn't working proper:
  • Headunit is a bit slow (2 min boot time, unresponsive buttons - they work but slowly)
  • MFSW - the song forward and backward buttons on the left hand side of the wheel dont work for bluetooth audio anymore. They used to work. They still work for the SD card and my ipod plugged into the media in interface in the center console, just not for stuff streaming through bluetooth.
  • My voice recognition language is in something unrecognizable to me. This is the language the lady helper talks in when you push the button that looks like a microphone being hit by a sound wave that is located below the volume controls on the left hand side of the steering wheel
  • I cant get the trailer module coded correctly; I would very much like the harmonic dampening function to work.
Here's my take on the faults:
  • 19-CAN Gateway Malfunction 0010 & 1C-Position Sensing Not registered 0001
I read that this fault (19) can be from having modules that do not exist in the Installation List. I clicked on each and every module under the "Installed" and "Installed 2" tab and the only one that will not load is 1C-Position Sensing. This leads me to believe it is not installed. I have removed 1C from the installation list in 19-CAN Gateway but it still shows up under "Installed." From here I am not sure what to do.
Also, I cannot view the 1C fault in the autoscan results because the module will not load when clicked (regardless of it's status in the installation list in 19).
  • 37-Navigation Not registered 0011 & 56-Radio Malfunction 0010
Four of these codes I can directly account for, the Line Output Open Circuit faults. I cut the speaker wires going from the headunit to the speakers and routed those wires to an aftermarket DSP. The headunit and aftermarket speaker/amp/dsp installations I did are working just fine, and I imagine those fault codes are here to stay (different resistance from DSP than from the OEM speakers or something to that effect?). Regardless, I'm able to account for those faults so I'm not worried.
Also, Byte 2 Bit 0-7 in 56-Radio (long coding helper) I changed from 00 to 04. I did this so the headunit still gives me fader controls which gave back some functionality that was lost when I cut those wires. Fade and balance functions work fine as far as I can tell.
The 00856 Radio Antenna and 02635 Tuner Not Enabled/Activated faults confuse me. They appear in both 37-Navigation and 56-Radio modules.
My radio is working just fine. I get FM/AM. Not sure what is up here but like most people fault codes make me uneasy.
  • 69-Trailer Not registered 0001
When I click this fault from the autoscan gateway installation list the module is loaded and then says "No fault codes found."
I've messed around in the long coding helper and am not sure what to do.
Changes:
  1. Byte 0 bit 0-3 I changed from 00 (not coded) to 02 (North American Region)
  2. Byte 1 bit 0-7 from 00 (not coded) to 0D (Type/Swiveling Function)
  3. Byte 3 and 4 bit 0-7 from 00 (not active) to 02 (output enabled while trailer active)
Seemed like appropriate changes but I dont know enough to be sure.
When I try to enable the trailer in 01-Engine it gives me the Error 31 request out of range message. I read elsewhere on this forum to change the WSC and Improter number to non-zero values but those boxes are grey and unchangeable in the engine module (if I'm supposed to change the trailer module numbers those are all WSC12345 I#123 E#12345). Also, I'm not sure if non-zero meant there can be no zeroes or the total number must be greater than zero; ie my engine module WSC is 02069, which is about 2069 bigger than zero, but contains two zeroes.
  • 75-Telematics
I dont even know where to begin for the telematics fault.
Thanks in advance to each and every person who contributes. I'm pretty sure that I have a years worth of phone support from buying the Hex-net model but these problems are so minor that it seems rude or unnecessary to bother some very busy people (thanks Uwe, and also the ross-tech employees) who are spending that time making and perfecting awesome products for our vehicles. I'd much rather have these issues publicly solved and accessible than privately sorted.
Also, please, please believe me that I'm stalking and searching these forums and the wider internet looking for answers. If I'm asking a question it's because I didn't find the answer, most likely because I was not sure of what to search and searched for the wrong thing. Please feel free to redirect me if I overlooked important threads, I love reading.
Friday,16,June,2017,08:37:40:27218
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4341.4
VIN: WVGBV3AX6EW546390   License Plate:
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 22 25 2B 2E 37 42 44 46 4C
          52 53 56 62 69 72 75 77
VIN: WVGBV3AX6EW546390   Mileage: 34930km-21704miles
1C-Position Sensing -- Status: Not registered 0001
37-Navigation -- Status: Not registered 0011
69-Trailer -- Status: Not registered 0001
Address 01: Engine (CCT)       Labels: 06J-906-026-CCT.clb
   Part No SW: 06J 997 027 S    HW: 06J 907 309 A
   Component: MED17.5.2 TFSI 2 06 0402
   Revision: P3H07---    Serial number:
   Coding: 0423010A190F0160
   Shop #: WSC 02069 002 1048576
   VCID: 45C28BDC0CCBB4699A-8010
   Part No SW: 09G 927 750 NK    HW: 09G 927 750 NK
   Component: AQ 250 6F           2253
   Revision: 00H97000    Serial number:
   Coding: 0000840
   VCID: 075E41D476476679A8-8052
Address 03: ABS Brakes        Labels: 5N0-614-109-C6.clb
   Part No SW: 5N0 614 109 BD    HW: 5N0 614 109 BD
   Component: J104   C6 450M VD3A 0011
   Revision: --H07---    Serial number: 00000007510381
   Coding: 0005161
   VCID: 6E90147079FD57310B-803A
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Component: VWKESSYPQ35GP 086 1101
   Revision: 00086000    Serial number: 0194617684
   Coding: 030C0C
   ROD: EV_KESSYPQ35G_VW01.rod
   VCID: 3424C6189F513DE13D-8060
   Part No SW: 561 907 426 C    HW: 561 907 426 C
   Component: AC Manuell    H02 0202
   Revision: 00001K01
   Coding: 0010001002
   ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
   ROD: EV_ACManuaElectGen2BHTC_VW36.rod
   VCID: 1B760DA412CF92991C-804E
   Part No SW: 5K0 937 086 R    HW: 5K0 937 086 R
   Component: BCM PQ35 M    122 0173
   Revision: BJ122001
   Coding: EF180ABB80232EC4018800C11000854448010086564D8DF064804000A040
   VCID: 43C695C4C2FF8A59B4-8016
   Subsystem 1 - Part No SW: 5N1 955 119 B    HW: 5N1 955 119 B  Labels: 1KX-955-119.CLB
   Component: WWS316 120913  24  0664
   Coding: 009795
   Part No SW: 5N0 959 655 AD    HW: 5N0 959 655 AD
   Component: J234__207 VW10 HI   2318
   Revision: 27019000    Serial number: 003N4PJ70ZH4
   Coding: 0012343
   VCID: 7F4ED9342E972EB990-802A
   Subsystem 1 - Part No: 5N0 959 339 B
   Subsystem 2 - Serial number: 0000000000DYQA
   Subsystem 3 - Serial number: 0019.07.130000300000630105ÿ† 63
   Subsystem 4 - Serial number: 630105ÿ† 6332MTS638402523/ÿ† 63
   Subsystem 5 - Serial number: 02523/ÿ† 6342MTS6508226431ÿ† 63
   Subsystem 6 - Serial number: 226431ÿ† 6351HTS63O33ECKJLÿ† 63
   Subsystem 7 - Serial number: 3ECKJLÿ† 6361HTS6SMANBCKJQÿ† 63
   Subsystem 8 - Serial number: NBCKJQÿ† 63727TS67AF6BCKROÿ† 63
   Subsystem 9 - Serial number: 6BCKROÿ† 63827TS6U6GQBCKJEÿ
   Subsystem 10 - Serial number: QBCKJEÿ
   Part No SW: 5K0 953 501 BL    HW: 5K0 953 569 L
   Revision: FF010042    Serial number: 20130903201797
   Coding: 110A140000
   VCID: 75A23B1CD4AB64E9CA-8020
   Component: E221__MFL-TAS  H31 0037
   Coding: 820000
   Part No SW: 5N0 920 973 E    HW: 5N0 920 973 E
   Component: KOMBI         H04 0811
   Coding: 211F01
   VCID: 3620FC10892D2FF103-8062
   Part No SW: 7N0 907 530 AK    HW: 7N0 907 530 AK
   Component: J533  Gateway H57 1642
   Revision:   H57       Serial number: 071013F1001532
   Coding: 356002
   VCID: 79BA372CF0B30089AE-802C
                    Fault Frequency: 102
                    Mileage: 34567 km
                    Date: 2017.06.13
                    Time: 21:44:11
Address 1C: Position Sensing
   Part No SW: 0AY 907 554 E    HW: 0AY 907 554 E
   Component: Haldex 4Motion      0043
   Coding: 0000005
   VCID: 4DD2B3FCD4BB4C2952-8018
   Component: IMMO          H04 0811
   Coding: 000007
   VCID: 6A9818608D15BB1157-803E
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000214674002
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 302CCA086B4901C159-8064
Address 2E: Media Player 3
Address 37: Navigation (J0506)       Labels: 1T0-035-680.clb
   Part No SW: 3C0 035 684 C    HW: 3C0 035 684
   Component: RNS-MID       H17 1140
   Revision: AB001001    Serial number: VWZ6Z7H8271008
   Coding: 0C010440040000A200
   Shop #: WSC 12345 123 61029
   VCID: 2306354422BFAA59D4-8076
6 Faults Found:
00859 - Line-Output; Front Right
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
00823 - Line-Output; Front Left
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
00869 - Line Output; Rear Right
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
00860 - Line-Output; Rear Left
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
00856 - Radio Antenna
                    Fault Frequency: 53
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 29
                    Reset counter: 58
                    Mileage: 34560 km
   Part No SW: 5N0 959 701 F    HW: 3C0 959 793 B
   Component: TUER-SG FT    002 0503
   Revision: 13110009    Serial number: 0007513224
   Coding: 0004B4
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 383CF2288339D98111-806C
   Slave Driver:
   Subsystem 1 - Part No SW: 5N0 959 703 G    HW: 3C0 959 794 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  009 1504
   Serial number: 00000008275147
   Coding: 000490
   Part No SW: 5N1 909 144 R    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.286 1401
   Revision: 1BH04841    Serial number: 00132680051101
   Coding: 0000258
   VCID: 41CA9FCC18E39849A6-8014
   Part No SW: 5N0 959 702 F    HW: 3C0 959 792 B
   Component: TUER-SG BT    002 0503
   Revision: 15110009    Serial number: 0007557987
   Coding: 0004B4
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 393AF72CB833C089EE-806C
   Slave Passenger:
   Subsystem 1 - Part No SW: 5N0 959 704 G    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  009 1504
   Serial number: 00000008252721
   Coding: 000490
   Revision:   H19       Serial number: 00000001502175
   Coding: 0026156
   VCID: 3620FC10412D2FF103-8062
Address 56: Radio (J0506)       Labels: 1T0-035-680.clb
6 Faults Found:
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 53
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 29
                    Reset counter: 58
                    Mileage: 34560 km
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Component: Anhaenger     H12 0100
   Revision: 3A001001    Serial number: 00000426551056
   Coding: 420D000202000000
   VCID: 302CCA08634901C159-8064
Address 75: Telematics (J949)       Labels: 12E-035-284.clb
   Part No SW: 561 035 285     HW: 561 035 285
   Component: OCULowUSA     014 0102
   Serial number: 000003554140511
   Coding: 02130602C2161A107F1606C20000
   ROD: EV_OCULow_001.rod
   VCID: 53E6A5843A9F1AD904-8006
2103041 - Control Module
                    Fault Priority: 8
                    Reset counter: 58
                    Mileage: 34937 km
                    Date: 2017.06.16
                    Time: 11:32:59
Address 77: Telephone (J412)       Labels: 5N0-035-729.clb
   Component: TELEFON       H05 0315
   Revision: 1B001001    Serial number: 00007665336254
   Coding: 0A10030080010110
   ROD: EV_UHVUMI.rod
   VCID: 2E10D470717D17314B-807A
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
   Coding: 0000840
   Coding: 0005161
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
   Revision: BJ122001
   Coding: 009795
   Coding: 0012343
   Coding: 110A140000
   Coding: 820000
   Coding: 211F01
   Coding: 356002
                    Mileage: 34567 km
                    Date: 2017.06.13
                    Time: 21:44:11
   Coding: 0000005
   Coding: 000007
6 Faults Found:
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 53
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 29
                    Reset counter: 58
                    Mileage: 34560 km
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
6 Faults Found:
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 23
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 53
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Frequency: 29
                    Reset counter: 58
                    Mileage: 34560 km
                    Fault Priority: 8
                    Reset counter: 58
                    Mileage: 34937 km
                    Date: 2017.06.16
                    Time: 11:32:59
   ROD: EV_UHVUMI.rod
I can't address most of this, but the "fault" in 75-Telematics is not really a fault. We see that in most (if not all) of those modules and Priority 8 indicates it is just a "General Note". Fault Priority is explained toward the bottom of this page.
m87a
Bosnia and Herzegovina
C?ID=156900
1C-Position Sensing needed to be physically disconected for jetta it was in trunk and for golf it was under roof liner near hatch gate, don't know for Tiguan
you need to code 37 Navigation in gateway
also code 69 Trailer in gateway
after that scan again and post :)
Emzy
C?ID=310014
Thanks Uwe. I saw in another spot that priority 8 is the lowest so if you're not going to stress it I can overlook it with ease.
M87a, I'll get on that as soon as the wife gets home. It's her car, hell of a time explaining all the tinkering to her brand new vehicle lol
Emzy
C?ID=310014
Well, the CAN Gateway error went away when I registered the Nav and Trailer. Thanks for pointing that out m87a, I figured since they showed up in the installed list that they were already registered. Or more specifically I didnt understand or perceive a difference between installation and registration.
Still have the Error 31 out of range in the engine module.
Not sure where to poke around to change my voice recognition language. I think it's in Russian.
Saturday,17,June,2017,09:00:41:27218
Mileage: 34950km-21716mi   Repair Order:
VIN: WVGBV3AX6EW546390   Mileage: 34950km-21716miles
   Coding: 0000840
   Component: J104   C6 450M VD3B 0011
   Coding: 0005161
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
   Revision: BJ122001
   Coding: 009795
   Coding: 0012343
   Subsystem 3 - Serial number: 0019.07.130000300000630105ÿ†63
   Subsystem 4 - Serial number: 630105ÿ†6332MTS638402523/ÿ†63
   Subsystem 5 - Serial number: 02523/ÿ†6342MTS6508226431ÿ†63
   Subsystem 6 - Serial number: 226431ÿ†6351HTS63O33ECKJLÿ†63
   Subsystem 7 - Serial number: 3ECKJLÿ†6361HTS6SMANBCKJQÿ†63
   Subsystem 8 - Serial number: NBCKJQÿ†63727TS67AF6BCKROÿ†63
   Subsystem 9 - Serial number: 6BCKROÿ†63827TS6U6GQBCKJEÿ
   Coding: 110A140000
   Coding: 820000
   Coding: 211F01
   Coding: 356002
   Coding: 0000005
   Coding: 000007
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Reset counter: 59
                    Mileage: 34944 km
                    Fault Priority: 8
                    Reset counter: 59
                    Mileage: 34951 km
                    Date: 2017.06.17
                    Time: 11:49:47
   ROD: EV_UHVUMI.rod
End----------(Elapsed Time: 01:27, VBatt start/end: 11.9V/11.8V)-----------
Emzy
C?ID=310014
Woohoo, I solved something by myself.
Change voice recognition language, the problem of VWVortex thread Das Stupid (adding all that here so hopefully some googler in the future can find this), is solved by going into 77-Telephone, then adaptation, and then scrolling all the way down the list until the voice recognition languages are shown. Click on each language you do NOT want and change its value from "valid" to "invalid." I made everything except English and English (north america) invalid and voila!
If you cant tell the computer to do what you want, try telling it that it can't do anything you don't want.
What's worse though is how terrible and difficult to use the voice control system is; feels like a lot of troubleshooting for something I now know I will never use. I guess it was a cat in a box sort of situation.
Emzy
C?ID=310014
Another discovered tweak:
Make the Push to Talk button an audio mute button. Recently got my PTT working then decided it's junk (for me, ymmv), and wanted it to do something useful. If the computer doesnt think there is a PTT function the button becomes a mute.
16-Steering wheel -> coding -> long coding helper -> Byte 1 -> bit 3 -> deselect
Now your MFSW with PTT has a mute button. Huzzah.
Emzy
C?ID=310014
Video description of my MFSW Bluetooth control problem.
m87a
C?ID=156900
phone needs to be connected for those buttons to be active to control phone media player ;)
Emzy
C?ID=310014
That may be the case but those buttons also do not work when the phone is connected. We went on a rather long drive today, with phones connected, and they never worked.
I appreciate the attention though, I'm sure this will get sorted sooner or later :D
Emzy
C?ID=310014
Double posting from another thread but figure I'd leave this in here for anyone that uses Tiguan as a search keyword:
So, apparently the [bluetooth skip track and meta data issue] stems from the revision number of the RNS 510 and possibly the revision number of the bluetooth module.
This comes from BarryT82 on golfmkv forum:
"You have to have a version E or above RNS-510 and a 9w7 with SW 27xx or above to change songs. For voice command you need SW 2902 or above on the Bluetooth module. Did you buy the voice command Bluetooth harness or non voice command? It's a simple mode to make it work."
My bluetooth module meets these criteria but the RNS unit I bought does not. Not real happy with my purchase now
EDIT: bought a higher revision RNS510 today. Will be here Friday. We will see if this solves both my MFSW issue and the boot time issue.
Emzy
C?ID=310014
Installed the new rns unit today. Bluetooth works perfectly now. Firmware was definitely the problem, maybe also the revision number. Vasco from this forum seems to have had success just updating his firmware
Emzy
C?ID=310014
Strange things still:
1C-Position sensing
As far as I understand the 2014 tiguans dont have a copmass module installed in the vehicle like other vw's (golf/jetta, passat).
So I remove the module from the CAN gateway installation list.
This gives me a 19-CAN Gateway fault about position sensing.
Reenable the 1C module in the CAN gateway and the 1C gets a fault about not being reached.
Same problem applies to 46-Central Convenience (isn't reachable, remove it and get the 19 error, rinse and repeat)
The most major thing is that I cant get the engine module to accept that I have a trailer module installed. I'm not sure if this module must be coded/enabled or something to that effect by a VW dealer.
Wednesday,21,June,2017,19:10:41:27218
VIN: WVGBV3AX6EW546390   Mileage: 35460km-22033miles
   Coding: 0000840
   Component: J104   C6 450M VD42 0011
   Coding: 0005161
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
   Revision: BJ122001
   Coding: EF180ABB80232EC4018800C1100085444E010086564D8DF064804000A040
   Coding: 009795
   Coding: 0012343
   Coding: 1102140000
   Coding: 820000
   Coding: 211901
   Coding: 356002
            000 -  -  - Intermittent
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:54:09
   Coding: 0000005
   Coding: 000007
   Part No SW: 3C0 035 684 Q    HW: 3C0 035 684 L
   Component: RNS-MID       H23 5382
   Revision: AB001001    Serial number: VWZ6Z7P5006031
   Coding: 04010442040000AE000C
   Shop #: WSC 09003 957 00200
   VCID: 312ACF0C684308C956-8064
   Subsystem 1 - Part No: 7L6 919 859
   Component: NAR V11  8407
14 Faults Found:
                    Fault Status: 00101011
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
01523 - Microphone for Telephone (R38)
                    Reset counter: 66
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:53:26
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
14 Faults Found:
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 106
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Reset counter: 66
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:53:26
   Coding: 020D000202000000
                    Fault Priority: 8
                    Reset counter: 66
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:53:19
   Coding: 0211030080010100
   ROD: EV_UHVUMI.rod
9458195 - Control Module for Cellular Telephone
          B1052 13 [009] - Open Circuit
                    Reset counter: 66
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:53:19
End----------(Elapsed Time: 01:27, VBatt start/end: 11.8V/11.9V)-----------
m87a
C?ID=156900
i don't know about 1C position sensing much, in row it's not present
for 46 this module is not present physically as in passat but in golf/jetta/eos/tiguan its emulated in 09 bcm so it needs to be coded in gateway
Emzy
C?ID=310014
Thank you, I'll leave it coded in the gateway.
The faults don't really bother me much since everything I need is functioning.
I plan to take my wife's car to the dealership sometime in the next week to work on the error31 out of reach message in trailer coding in the engine module. That's really the last bit I'm concerned with before I call this car complete. Got a 2000 mile trailer equipped journey coming up soon.
Dana
Western PA, USA
Although all NAR 2009 2.0T Tiguan Engine modules accept Trailer installed coding we received several 2010+ reports that those part numbers refuse that particular coding modification. We have that in notes section on this page: http://wiki.ross-tech.com/wiki/index.php/Trailer_Hitch_Retrofitting_(5N)
If the dealer was able to enable that bit please do post the final scan so we can try to spot the changes.
Next, the 1C module would not be installed in a RNS-510 equipped vehicle but if you want to remove it from the [Installation List] function (without DTCs) it would also need to be unplugged. http://wiki.ross-tech.com/wiki/index.php/Navigation_System_(RNS510)_Retrofitting
If 1C isn't causing any functionality concerns with the dash display you could leave it as-is.
Lastly, although the speaker codes aren't going to affect functionality - I would try to get rid of them. See if the RNS will accept this coding: 0C010040010000A200
If that's accepted, clear codes and check the sound quality. Providing it sounds good I would leave it configured for a sound system/amp.
Emzy
C?ID=310014
Thanks Dana. My 2010+ has long coding for the engine module, significantly more numbers than the potentially problematic short-coding example given on the retrofitting page. I know that's not a certain. indication that the coding will be accepted though. Still have to go to the dealer, just haven't had the car available to me.
I'm led to believe that the 2010+ tiguans don't have a 1C module in any configuration, so there wouldn't be one to remove. That is why I posted about being baffled that removing it from the installation list leaves me with a DTC. Does the existence of a DTC for the 1C module in Can Gateway prove such a physical module does exist?
The dash still isn't quite as snappy as my oem RCD 510 but it's not bad either.
My wife comes home tomorrow and I will try the RNS coding in I'm guessing the Navigation or Radio module. I'm not sure if this is normal but Nav and Radio are identical, same codes and options and changes in one are mirrored exactly in the other module.
Thanks for help and time
Dana
Western PA, USA
I think that vehicle would have had a real 1C - but I'm beginning to question myself. Do you have a pre-modification scan saved on that PC that we can review? You may want to check both the Logs and Scans folders.
Emzy
C?ID=310014
I'm sorry but I do not have any pre-RNS510 installation scans. I did the RCD to RNS swap and installed the sound system weeks before I bought the VCDS :/
The Malfunction status at the beginning of the autoscan went away but the line output errors are still there if one clicks on the module.
Thursday,29,June,2017,08:17:11:27218
VIN: WVGBV3AX6EW546390   Mileage: 37710km-23431miles
008801 - Boost Pressure Control Valve (N249)
               P2261 - 000 - Mechanical Malfunction - Intermittent
                    Fault Frequency: 7
                    Mileage: 35599 km
                    Date: 2017.06.22
                    Time: 11:54:11
                    RPM: 1303 /min
                    Load: 6.3 %
                    Speed: 69.0 km/h
                    Temperature: 97.0°C
                    Temperature: 45.0°C
                    Absolute Pres.: 970.0 mbar
                    Voltage: 13.970 V
   Coding: 0000840
   Component: J104   C6 450M VD51 0011
   Coding: 0005161
   Coding: 030C0C
   Revision: 00001K01
   Coding: 0010001002
   Revision: BJ122001
   Coding: 009795
   Coding: 0012343
   Coding: 1102140000
   Coding: 820000
   Coding: 211901
   Coding: 356002
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:54:09
   Coding: 0000005
   Coding: 000007
   Coding: 0C010040010000A2000C
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
   Coding: 0004B4
   Slave Driver:
   Coding: 000490
   Coding: 0000258
   Coding: 0004B4
   Slave Passenger:
   Coding: 000490
   Coding: 0026156
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Reset counter: 81
                    Mileage: 37712 km
                    Fault Priority: 8
                    Reset counter: 81
                    Time: 00:00:00
   ROD: EV_UHVUMI.rod
                    Reset counter: 66
                    Mileage: 35464 km
                    Date: 2017.06.21
                    Time: 22:53:19
End----------(Elapsed Time: 01:26, VBatt start/end: 12.0V/11.9V)-----------
Emzy
C?ID=310014
the 77-Telephone fault 9458195 was resolved by removing the coding for a 3-button keypad in both the 77-telephone and 75-telematics module.
