Hi everyone. I'm new to the forums and the vag-com world in general though I look forward to learning and becoming a contributor and resource for the VCDS community.
I figure I should list what I have modified and retrofitted to this vehicle, what problems I am observing directlty, and then explain away as much as I understand about each of the fault codes so you know where my thoughts are and what I've tried. Please bear with me, I'm sure my vocabulary will be off.
Modifications:
Here's what isn't working proper:
Also, I cannot view the 1C fault in the autoscan results because the module will not load when clicked (regardless of it's status in the installation list in 19).
Also, Byte 2 Bit 0-7 in 56-Radio (long coding helper) I changed from 00 to 04. I did this so the headunit still gives me fader controls which gave back some functionality that was lost when I cut those wires. Fade and balance functions work fine as far as I can tell.
The 00856 Radio Antenna and 02635 Tuner Not Enabled/Activated faults confuse me. They appear in both 37-Navigation and 56-Radio modules.
My radio is working just fine. I get FM/AM. Not sure what is up here but like most people fault codes make me uneasy.
I've messed around in the long coding helper and am not sure what to do.
Changes:
When I try to enable the trailer in 01-Engine it gives me the Error 31 request out of range message. I read elsewhere on this forum to change the WSC and Improter number to non-zero values but those boxes are grey and unchangeable in the engine module (if I'm supposed to change the trailer module numbers those are all WSC12345 I#123 E#12345). Also, I'm not sure if non-zero meant there can be no zeroes or the total number must be greater than zero; ie my engine module WSC is 02069, which is about 2069 bigger than zero, but contains two zeroes.
Thanks in advance to each and every person who contributes. I'm pretty sure that I have a years worth of phone support from buying the Hex-net model but these problems are so minor that it seems rude or unnecessary to bother some very busy people (thanks Uwe, and also the ross-tech employees) who are spending that time making and perfecting awesome products for our vehicles. I'd much rather have these issues publicly solved and accessible than privately sorted.
Also, please, please believe me that I'm stalking and searching these forums and the wider internet looking for answers. If I'm asking a question it's because I didn't find the answer, most likely because I was not sure of what to search and searched for the wrong thing. Please feel free to redirect me if I overlooked important threads, I love reading.
Modifications:
- I replaced the stock RCD510 with an RNS510. The headunit appears to be in fully working order, the nav and map work fine and point me in the right direction.
- I added the OEM trailer hitch and electronic module for the harmonic dampening functionality.
- I installed a speaker system. Signal goes from Headunit line outputs -> DSP -> Amp -> crossovers -> speakers. It sounds fine and appears fully functional.
- I replaced my diverter valve (was the old diaphragm type) with a GFB DV+.
- Headunit is a bit slow (2 min boot time, unresponsive buttons - they work but slowly)
- MFSW - the song forward and backward buttons on the left hand side of the wheel dont work for bluetooth audio anymore. They used to work. They still work for the SD card and my ipod plugged into the media in interface in the center console, just not for stuff streaming through bluetooth.
- My voice recognition language is in something unrecognizable to me. This is the language the lady helper talks in when you push the button that looks like a microphone being hit by a sound wave that is located below the volume controls on the left hand side of the steering wheel
- I cant get the trailer module coded correctly; I would very much like the harmonic dampening function to work.
- 19-CAN Gateway Malfunction 0010 & 1C-Position Sensing Not registered 0001
- 37-Navigation Not registered 0011 & 56-Radio Malfunction 0010
- 69-Trailer Not registered 0001
Changes:
- Byte 0 bit 0-3 I changed from 00 (not coded) to 02 (North American Region)
- Byte 1 bit 0-7 from 00 (not coded) to 0D (Type/Swiveling Function)
- Byte 3 and 4 bit 0-7 from 00 (not active) to 02 (output enabled while trailer active)
- 75-Telematics
Friday,16,June,2017,08:37:40:27218
VCDS Version: 17.1.3.0 (x64) HEX-NET CB: 0.4341.4
VIN: WVGBV3AX6EW546390 License Plate:
Chassis Type: AX (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 1C 22 25 2B 2E 37 42 44 46 4C
52 53 56 62 69 72 75 77
VIN: WVGBV3AX6EW546390 Mileage: 34930km-21704miles
1C-Position Sensing -- Status: Not registered 0001
37-Navigation -- Status: Not registered 0011
69-Trailer -- Status: Not registered 0001
Address 01: Engine (CCT) Labels: 06J-906-026-CCT.clb
Part No SW: 06J 997 027 S HW: 06J 907 309 A
Component: MED17.5.2 TFSI 2 06 0402
Revision: P3H07--- Serial number:
Coding: 0423010A190F0160
Shop #: WSC 02069 002 1048576
VCID: 45C28BDC0CCBB4699A-8010
Part No SW: 09G 927 750 NK HW: 09G 927 750 NK
Component: AQ 250 6F 2253
Revision: 00H97000 Serial number:
Coding: 0000840
VCID: 075E41D476476679A8-8052
Address 03: ABS Brakes Labels: 5N0-614-109-C6.clb
Part No SW: 5N0 614 109 BD HW: 5N0 614 109 BD
Component: J104 C6 450M VD3A 0011
Revision: --H07--- Serial number: 00000007510381
Coding: 0005161
VCID: 6E90147079FD57310B-803A
Address 05: Acc/Start Auth. (J518) Labels: 5K0-959-434.clb
Part No SW: 5K0 959 434 B HW: 5K0 959 434
Component: VWKESSYPQ35GP 086 1101
Revision: 00086000 Serial number: 0194617684
Coding: 030C0C
ROD: EV_KESSYPQ35G_VW01.rod
VCID: 3424C6189F513DE13D-8060
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 561 907 426 C HW: 561 907 426 C
Component: AC Manuell H02 0202
Revision: 00001K01
Coding: 0010001002
ASAM Dataset: EV_ACManuaElectGen2BHTC 001002
ROD: EV_ACManuaElectGen2BHTC_VW36.rod
VCID: 1B760DA412CF92991C-804E
Part No SW: 5K0 937 086 R HW: 5K0 937 086 R
Component: BCM PQ35 M 122 0173
Revision: BJ122001
Coding: EF180ABB80232EC4018800C11000854448010086564D8DF064804000A040
VCID: 43C695C4C2FF8A59B4-8016
Subsystem 1 - Part No SW: 5N1 955 119 B HW: 5N1 955 119 B Labels: 1KX-955-119.CLB
Component: WWS316 120913 24 0664
Coding: 009795
Part No SW: 5N0 959 655 AD HW: 5N0 959 655 AD
Component: J234__207 VW10 HI 2318
Revision: 27019000 Serial number: 003N4PJ70ZH4
Coding: 0012343
VCID: 7F4ED9342E972EB990-802A
Subsystem 1 - Part No: 5N0 959 339 B
Component: BF-Gewichtsens. 003 0001
Subsystem 2 - Serial number: 0000000000DYQA
Subsystem 3 - Serial number: 0019.07.130000300000630105ÿ† 63
Subsystem 4 - Serial number: 630105ÿ† 6332MTS638402523/ÿ† 63
Subsystem 5 - Serial number: 02523/ÿ† 6342MTS6508226431ÿ† 63
Subsystem 6 - Serial number: 226431ÿ† 6351HTS63O33ECKJLÿ† 63
Subsystem 7 - Serial number: 3ECKJLÿ† 6361HTS6SMANBCKJQÿ† 63
Subsystem 8 - Serial number: NBCKJQÿ† 63727TS67AF6BCKROÿ† 63
Subsystem 9 - Serial number: 6BCKROÿ† 63827TS6U6GQBCKJEÿ
Subsystem 10 - Serial number: QBCKJEÿ
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 501 BL HW: 5K0 953 569 L
Revision: FF010042 Serial number: 20130903201797
Coding: 110A140000
VCID: 75A23B1CD4AB64E9CA-8020
Subsystem 1 - Part No SW: 5K0 959 542 C HW: 5K0 959 542 C Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H31 0037
Coding: 820000
Part No SW: 5N0 920 973 E HW: 5N0 920 973 E
Component: KOMBI H04 0811
Coding: 211F01
VCID: 3620FC10892D2FF103-8062
Part No SW: 7N0 907 530 AK HW: 7N0 907 530 AK
Component: J533 Gateway H57 1642
Revision: H57 Serial number: 071013F1001532
Coding: 356002
VCID: 79BA372CF0B30089AE-802C
Fault Frequency: 102
Mileage: 34567 km
Date: 2017.06.13
Time: 21:44:11
Address 1C: Position Sensing
Part No SW: 0AY 907 554 E HW: 0AY 907 554 E
Component: Haldex 4Motion 0043
Coding: 0000005
VCID: 4DD2B3FCD4BB4C2952-8018
Component: IMMO H04 0811
Coding: 000007
VCID: 6A9818608D15BB1157-803E
Address 2B: Steer. Col. Lock (J764) Labels: 5K0-905-861.clb
Part No SW: 5K0 905 861 C HW: 5K0 905 861 C
Component: ELV-PQ35 H21 0240
Revision: 00000000 Serial number: 13000214674002
Coding: 4900000000000000
ROD: EV_ELVMarquMPVW36X.rod
VCID: 302CCA086B4901C159-8064
Address 2E: Media Player 3
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 3C0 035 684 C HW: 3C0 035 684
Component: RNS-MID H17 1140
Revision: AB001001 Serial number: VWZ6Z7H8271008
Coding: 0C010440040000A200
Shop #: WSC 12345 123 61029
VCID: 2306354422BFAA59D4-8076
00859 - Line-Output; Front Right
Fault Status: 01101011
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
00823 - Line-Output; Front Left
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
00869 - Line Output; Rear Right
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
00860 - Line-Output; Rear Left
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
00856 - Radio Antenna
Fault Frequency: 53
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 29
Reset counter: 58
Mileage: 34560 km
Part No SW: 5N0 959 701 F HW: 3C0 959 793 B
Component: TUER-SG FT 002 0503
Revision: 13110009 Serial number: 0007513224
Coding: 0004B4
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 383CF2288339D98111-806C
Slave Driver:
Subsystem 1 - Part No SW: 5N0 959 703 G HW: 3C0 959 794 D Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 009 1504
Serial number: 00000008275147
Coding: 000490
Part No SW: 5N1 909 144 R HW: 5N1 909 148 J
Component: J500__APA-BS KL.286 1401
Revision: 1BH04841 Serial number: 00132680051101
Coding: 0000258
VCID: 41CA9FCC18E39849A6-8014
Part No SW: 5N0 959 702 F HW: 3C0 959 792 B
Component: TUER-SG BT 002 0503
Revision: 15110009 Serial number: 0007557987
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 393AF72CB833C089EE-806C
Slave Passenger:
Subsystem 1 - Part No SW: 5N0 959 704 G HW: 3C0 959 795 D Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 009 1504
Serial number: 00000008252721
Coding: 000490
Revision: H19 Serial number: 00000001502175
Coding: 0026156
VCID: 3620FC10412D2FF103-8062
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 53
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 29
Reset counter: 58
Mileage: 34560 km
Address 69: Trailer (J345) Labels: 1K0-907-383-V2.clb
Part No SW: 1K0 907 383 F HW: 1K0 907 383 F
Component: Anhaenger H12 0100
Revision: 3A001001 Serial number: 00000426551056
Coding: 420D000202000000
Shop #: WSC 12345 123 12345
VCID: 302CCA08634901C159-8064
Address 75: Telematics (J949) Labels: 12E-035-284.clb
Part No SW: 561 035 285 HW: 561 035 285
Component: OCULowUSA 014 0102
Serial number: 000003554140511
Coding: 02130602C2161A107F1606C20000
ROD: EV_OCULow_001.rod
VCID: 53E6A5843A9F1AD904-8006
2103041 - Control Module
Fault Priority: 8
Reset counter: 58
Mileage: 34937 km
Date: 2017.06.16
Time: 11:32:59
Address 77: Telephone (J412) Labels: 5N0-035-729.clb
Part No SW: 5N0 035 729 A HW: 5N0 035 729 A
Component: TELEFON H05 0315
Revision: 1B001001 Serial number: 00007665336254
Coding: 0A10030080010110
ROD: EV_UHVUMI.rod
VCID: 2E10D470717D17314B-807A
End----------(Elapsed Time: 01:26, VBatt start/end: 12.1V/12.1V)-----------
Coding: 0000840
Coding: 0005161
Coding: 030C0C
Revision: 00001K01
Coding: 0010001002
Revision: BJ122001
Coding: 009795
Coding: 0012343
Coding: 110A140000
Coding: 820000
Coding: 211F01
Coding: 356002
Mileage: 34567 km
Date: 2017.06.13
Time: 21:44:11
Coding: 0000005
Coding: 000007
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 53
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 29
Reset counter: 58
Mileage: 34560 km
Coding: 0004B4
Slave Driver:
Coding: 000490
Coding: 0000258
Coding: 0004B4
Slave Passenger:
Coding: 000490
Coding: 0026156
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 23
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 53
Reset counter: 58
Mileage: 34560 km
Fault Frequency: 29
Reset counter: 58
Mileage: 34560 km
Fault Priority: 8
Reset counter: 58
Mileage: 34937 km
Date: 2017.06.16
Time: 11:32:59
ROD: EV_UHVUMI.rod
