- Joined
- Mar 9, 2015
- Messages
- 476
- Reaction score
- 336
- Location
- Australia
- VCDS Serial number
- C?ID=241363
Hi All,
With a great deal of assistance from the one and only Golfi_vend, I am close to completing an Adaptive Cruise retrofit in my B6 Passat R36!
I have the new ABS and radar modules installed.
The sticking point now is an 'incompatible interface' error against the EPB module which causes a cascade of faults resulting in ESP/ABS/ACC/EPB not functioning.
The way that Golfi-Vend has resolved this in his installations has been to replace the dash mounted EPB switch from the B6 with the B7 rocker type switch in the centre console. This involves replacing and rewiring the whole centre console. Normally in this situation I would just buy the part and test it but this revision is rare and therefor expensive, more than the cost of a new centre console. And there is no SGO available to upgrade to sw 12 (I have a rev H with hw 19 already if this was possible)
Not the end of the world but I was just wanting to check if anyone had resolved this error with an upgrade of the EPB to 3AA907801J with sw 012, or any undocumented coding? The EPB works properly from the factory switch in the dash currently. If I change the coding to B7 style of course it no longer works.
There was a thread where someone had a similar error that was resolved by installing a 3AA907801J EPB, but also a new instrument cluster, however this was in a B7 so already had the correct switch: http://forums.ross-tech.com/showthr...S-ESP-coding&highlight=incompatible+interface
My EPB has been software upgraded to 3AA907801H sw 10 (not in the scan below, but it made no difference)
Monday,15,May,2017,18:17:09:02396
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
Workshop Code: 123 12345 000000
VIN: WVWZZZ3CZ9E08 License Plate: R36_NEW_ABS
Mileage: 105480km-65542mi Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 37 42 44 46 47 52
53 55 56 62 65 6C 6D 72 77
VIN: WVWZZZ3CZ9E083538 Mileage: 105480km-65542miles
Address 01: Engine (BWS) Labels: 03H-906-032-BLV.clb
Part No SW: 03H 906 032 AM HW: 03H 906 032 AB
Component: R3.6-FSI-EU4 3488
Revision: 5GH04--- Serial number: VWZCZ000000000
Coding: 0000175
Shop #: WSC 05311 000 00000
VCID: 6DDA3B177498A22FD7-8038
005715 - Please check DTC Memory of ABS Controller
P1653 - 001 -
Fault Status: 01100001
Mileage: 105476 km
Date: 2017.05.15
Time: 17:33:14
RPM: 1002 /min
Load: 18.8 %
Temperature: 84.0°C
Temperature: 48.0°C
Absolute Pres.: 990.0 mbar
Voltage: 13.843 V
005703 - Check Coding of ECUs on Powertrain Data Bus
P1647 - 008 -
Mileage: 105476 km
Date: 2017.05.15
Time: 17:33:14
RPM: 1002 /min
Load: 18.8 %
Temperature: 84.0°C
Temperature: 48.0°C
Voltage: 13.843 V
Readiness: 0110 0000
Part No SW: 02E 300 012 E HW: 02E 927 770 AJ
Component: GSG DSG AG6 440 1903
Revision: 04844002 Serial number: 00000810231260
Coding: 0000024
VCID: 122048EB0D66DDD7AA-8046
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 255
Reset counter: 1
Mileage: 105465 km
Date: 2017.05.15
Time: 15:59:31
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AJ HW: 3AA 614 109 AL
Component: J104 C2 450M VE51 0023
Revision: --H07--- Serial number: 00000007379684
Coding: 0103076
Shop #: WSC 12345 123 00000
VCID: 75EA13771CC86AEF2F-8020
03194 - Incompatible Interface
Reset counter: 81
Mileage: 105487 km
Date: 2017.05.15
Time: 18:01:16
Hex Value: 0x0000
Bin. Bits: 00000000 00000000
Voltage: 12.00 V
Bin. Bits: 00001111
Count: 284
Hex Value: 0x0000
00810 - Sensor 1/2 for Brake Pressure
Reset counter: 81
Mileage: 105487 km
Date: 2017.05.15
Time: 18:01:16
Address 08: Auto HVAC (J255) Labels: 5K0-907-044.clb
Part No SW: 5K0 907 044 ES HW: 5K0 907 044 ES
Component: Climatronic H18 1112
Revision: 00003001
Coding: 0001000002
VCID: 000472A39B0A5F470C-8054
Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl
Revision: 00H54000 Serial number: 00000009027172
Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
VCID: 336EED6F523C34DFC1-8066
Subsystem 1 - Part No: 3C2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer 100908 022 0601
Coding: 00046997
Shop #: WSC 12345
Component: RLS 121108 054 0402
Coding: 00471080
Shop #: WSC 12345
00061 - Footwell Lights
Fault Status: 00101100
Reset counter: 120
Mileage: 105465 km
Voltage: 11.70 V
Address 10: Park/Steer Assist (J446) Labels: 3C8-919-475.clb
Part No SW: 5K0 919 475 E HW: 5K0 919 475 E
Component: PARKHILFE 8K H01 0013
Revision: -------- Serial number: 97540830907185
Coding: 300102
Shop #: WSC 12345 123 61029
VCID: 3874DA438B5AD787F4-806C
Address 13: Auto Dist. Reg Labels: 3AA-907-567.clb
Part No SW: 3AA 907 567 A HW: 3AA 907 567
Component: AC201 RDW A 036 0170
Revision: 00036000 Serial number: 00000000569541
Coding: 0010000
Shop #: WSC 05311 000 08193
VCID: 3874DA434B5AD787F4-806C
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 81
Mileage: 105487 km
Date: 2017.05.15
Time: 18:05:05
Count: 4
Part No SW: 5N0 959 655 HW: 5N0 959 655
Component: J234__00S VW10 HI 1815
Revision: 19013000 Serial number: 0039BPMPB81T
Coding: 0012371
VCID: 7AF0004B35D6059742-802E
Subsystem 1 - Serial number: 6333FTS665962908
Subsystem 2 - Serial number: 6343FTS632552888
Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
Subsystem 4 - Serial number: 6363ETS640PKVVNR
Address 16: Steering wheel (J527) Labels: 3C0-953-569.clb
Part No SW: 3C5 953 501 BM HW: 5K0 953 569 T
Component: LENKS.MODUL 016 0140
Revision: FF010041 Serial number: 20160725000799
Coding: 1992A50003
VCID: 71E22767A0A046CFF3-8024
Subsystem 1 - Part No SW: 5K0 959 542 B HW: 5K0 959 542 B Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H30 0036
Coding: 830000
Address 17: Instruments (J285) Labels: 3C8-920-xxx-17.clb
Part No SW: 3AA 920 881 HW: 3AA 920 881
Component: KOMBI H03 0705
Coding: 711F01
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
12858113 - Invalid Data Received from Cruise Control Front Distance Range Sensor
U0433 00 [008] - -
Reset counter: 120
Mileage: 105465 km
Date: 2017.05.15
Time: 15:54:19
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 BL HW: 7N0 907 530 AN
Component: J533 Gateway H56 1682
Revision: H56 Serial number: 110114F2000857
Coding: 462007
VCID: 7BFE054FFAEC3C9F59-802E
Mileage: 105465 km
Date: 2017.05.15
Time: 15:44:09
Part No SW: 0BS 907 554 A HW: 0BS 907 554 A
Component: Haldex 4Motion 4013
Coding: 0000005
VCID: 448CBEB30792836768-8010
Part No SW: 3AA 959 433 B HW: 3AA 959 433 B
Component: IMMO 052 0407
Revision: 00052000 Serial number: VWZCZ000000000
Shop #: WSC 12345 123 2097151
Component: ELV 027 0380
3C0905861G ELV 027 0380
Address 36: Seat Mem. Drvr Labels: 3C0-959-760.lbl
Part No SW: 3C0 959 760 E HW: 3C0 959 760 E
Component: Sitzverstellung 1101
Revision: 00005000 Serial number: 00000000000000
VCID: 2F66E11FBE14103FA5-807A
Address 37: Navigation (J0506) Labels: 1T0-035-680.clb
Part No SW: 1T0 035 686 E HW: 1T0 035 686 E
Component: RNS-MID H30 6276
Revision: AB001001 Serial number: VWZ6Z7M5270061
Coding: 04050002010000910000
VCID: 3668D47B814E21F7E6-8062
Subsystem 1 - Part No: 7L6 919 859 G
Component: AUNZ V9 8333
02877 - Digital Radio Antenna (R183)
Fault Frequency: 9
Reset counter: 81
Mileage: 105464 km
Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.clb
Part No SW: 1K0 959 701 AE HW: 1K0 959 793 P
Component: J386 TUER-SG FT 1518
Revision: 71009005 Serial number: 00000691888917
Coding: 0005047
VCID: 71E2276768A046CFF3-8024
00131 - Outside Door Handle Illumination/mirror Light Driver Side
Reset counter: 120
Mileage: 105465 km
Date: 2017.05.15
Time: 15:59:30
Part No: 1K0 909 144 E
Component: EPS_ZFLS Kl. 143 2501
Revision: 00H15000
VCID: 2C5CF6138F026B2780-8078
Address 46: Central Conv. Labels: 3C0-959-433-46.clb
Component: KSG PQ47 ELV 052 0638
Coding: 00900A00D1034E7F000294157008DFCE607801
Component: Neigungssensor 004 0611
Address 47: Sound System (R184) Labels: 5K0-035-456.clb
Part No SW: 3AA 035 466 HW: 3AA 035 466
Component: KonzernAmp12K H03 6904
Revision: -------- Serial number: A1108A00010581
ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
ROD: EV_AudioVerst12KanalSTT1.rod
VCID: 6DDA3B17BC98A22FD7-8038
9461523 - Front Left Bass Speaker
B105F 13 [009] - Open Circuit
Reset counter: 80
Mileage: 105465 km
Date: 2017.05.15
Time: 15:44:10
9462035 - Front Left Treble Speaker
B1061 13 [009] - Open Circuit
Reset counter: 80
Mileage: 105465 km
Date: 2017.05.15
Time: 15:44:10
9463314 - Rear Left Treble Speaker
B1066 12 [009] - Short to Plus
Reset counter: 80
Mileage: 105465 km
Date: 2017.05.15
Time: 15:44:10
9463826 - Rear Right Treble Speaker
B1068 12 [009] - Short to Plus
Reset counter: 80
Mileage: 105465 km
Date: 2017.05.15
Time: 15:44:10
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.clb
Part No SW: 1K0 959 702 AE HW: 1K0 959 792 P
Component: J387 TUER-SG BT 1518
Revision: 71009005 Serial number: 00000649588929
Coding: 0005046
VCID: 72E0286B6DA67DD70A-8026
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
Reset counter: 120
Mileage: 105465 km
Date: 2017.05.15
Time: 15:59:30
Part No SW: 3AA 907 801 E HW: 3AA 907 801 E
Component: J540 EPB4 VW-55183 0007
Revision: H18 Serial number: 00000000155378
Coding: 0021057
Fault Status: 01110000
Reset counter: 81
Mileage: 105487 km
Date: 2017.05.15
Time: 17:59:49
Voltage: 12.10 V
Count: 95
Hex Value: 0x1260
Hex Value: 0x0001
Hex Value: 0x0101
Fault Status: 01111101
Fault Frequency: 10
Reset counter: 81
Mileage: 105465 km
Date: 2017.05.15
Time: 15:44:08
Voltage: 11.60 V
Count: 69
Hex Value: 0x1273
Hex Value: 0x0001
Hex Value: 0x1010
Component: AFS-Steuergeraet 0136
Coding: 2344193
VCID: 346CEE73573233E7D8-8060
Subsystem 1 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul l 0004
Coding: 00000035
Subsystem 2 - Part No: 7L6 941 329 A Labels: 3D0-941-329.CLB
Component: AFS-Lst.-Modul r 0004
Coding: 00000035
Address 56: Radio (J0506) Labels: 1T0-035-680.clb
Fault Frequency: 9
Reset counter: 81
Mileage: 105464 km
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.clb
Part No SW: 1K0 959 703 AB HW: 1K0 959 795 L
Component: J388 TUER-SG HL 0307
Revision: 41004101 Serial number: 00000000699648
Coding: 0000144
VCID: 70E4226363AA4FC7FC-8024
Address 65: Tire Pressure (J502) Labels: 3AA-907-273.clb
Part No SW: 3AA 907 273 F HW: 5Q0 907 273
Component: RDKBERU30 H04 0011
Serial number: 40000000055443
ASAM Dataset: EV_RDKBERU30 005005
ROD: EV_RDKBERU30.rod
VCID: 3776D97F8E44D8FFFD-8062
Address 6C: Back-up Cam. Labels: 5N0-907-441.clb
Part No SW: 3C0 907 441 HW: 3C0 907 441
Component: J772__Rearview 0042
Revision: 00H05000 Serial number: PA8 J890694
Coding: 0020007
VCID: 5FC651DF8E34C0BF55-800A
Part No SW: 3C9 827 383 F HW: 3C9 827 383 F
Component: J605 HECKDECKEL 0720
Revision: 00H27001
Subsystem 1 - Part No: 3C9 827 384 F
Component: J756 HECKDECKEL 0720
Subsystem 2 - Serial number: 0800H27001001B0148ÿ
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.clb
Part No SW: 1K0 959 704 AB HW: 1K0 959 794 L
Component: J389 TUER-SG HR 0307
Revision: 41004101 Serial number: 00000000693593
Coding: 0000144
Address 77: Telephone (J412) Labels: 3C8-035-730-A.clb
Part No SW: 3C8 035 730 E HW: 3C8 035 730 E
Component: Telefon 025 0983
Revision: -------- Serial number: 35502105271202
Coding: 020000010100110000000001
ASAM Dataset: EV_UHVPremi 002709
ROD: EV_UHVPremi.rod
VCID: 254A033724E85A6F5F-8070
End-------------------------(Elapsed Time: 03:30)--------------------------
