YAPAR - Yet Another Passat ACC Retrofit
kamold
Australia
C?ID=241363
Hi All,
With a great deal of assistance from the one and only Golfi_vend, I am close to completing an Adaptive Cruise retrofit in my B6 Passat R36! :)
I have the new ABS and radar modules installed.
The sticking point now is an 'incompatible interface' error against the EPB module which causes a cascade of faults resulting in ESP/ABS/ACC/EPB not functioning.
The way that Golfi-Vend has resolved this in his installations has been to replace the dash mounted EPB switch from the B6 with the B7 rocker type switch in the centre console. This involves replacing and rewiring the whole centre console. Normally in this situation I would just buy the part and test it but this revision is rare and therefor expensive, more than the cost of a new centre console. And there is no SGO available to upgrade to sw 12 (I have a rev H with hw 19 already if this was possible)
Not the end of the world but I was just wanting to check if anyone had resolved this error with an upgrade of the EPB to 3AA907801J with sw 012, or any undocumented coding? The EPB works properly from the factory switch in the dash currently. If I change the coding to B7 style of course it no longer works.
There was a thread where someone had a similar error that was resolved by installing a 3AA907801J EPB, but also a new instrument cluster, however this was in a B7 so already had the correct switch: http://forums.ross-tech.com/showthr...S-ESP-coding&highlight=incompatible+interface
My EPB has been software upgraded to 3AA907801H sw 10 (not in the scan below, but it made no difference)
Monday,15,May,2017,18:17:09:02396
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
Workshop Code: 123 12345 000000
VIN: WVWZZZ3CZ9E08   License Plate: R36_NEW_ABS
Mileage: 105480km-65542mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 25 36 37 42 44 46 47 52
          53 55 56 62 65 6C 6D 72 77
VIN: WVWZZZ3CZ9E083538   Mileage: 105480km-65542miles
Address 01: Engine (BWS)       Labels: 03H-906-032-BLV.clb
   Part No SW: 03H 906 032 AM    HW: 03H 906 032 AB
   Component: R3.6-FSI-EU4        3488
   Revision: 5GH04---    Serial number: VWZCZ000000000
   Coding: 0000175
   Shop #: WSC 05311 000 00000
   VCID: 6DDA3B177498A22FD7-8038
               P1653 - 001 -
                    Fault Status: 01100001
                    Mileage: 105476 km
                    Date: 2017.05.15
                    Time: 17:33:14
                    RPM: 1002 /min
                    Load: 18.8 %
                    Temperature: 84.0°C
                    Temperature: 48.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 13.843 V
005703 - Check Coding of ECUs on Powertrain Data Bus
               P1647 - 008 -
                    Fault Status: 01101000
                    Mileage: 105476 km
                    Date: 2017.05.15
                    Time: 17:33:14
                    RPM: 1002 /min
                    Load: 18.8 %
                    Temperature: 84.0°C
                    Temperature: 48.0°C
                    Voltage: 13.843 V
Readiness: 0110 0000
   Part No SW: 02E 300 012 E    HW: 02E 927 770 AJ
   Component: GSG DSG AG6     440 1903
   Revision: 04844002    Serial number: 00000810231260
   Coding: 0000024
   VCID: 122048EB0D66DDD7AA-8046
18255 - Please check DTC Memory of ABS Controller
            P1847 - 000 -  - Intermittent
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:59:31
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AL
   Component: J104   C2 450M VE51 0023
   Revision: --H07---    Serial number: 00000007379684
   Coding: 0103076
   Shop #: WSC 12345 123 00000
   VCID: 75EA13771CC86AEF2F-8020
03194 - Incompatible Interface
            000 -  -
                    Reset counter: 81
                    Mileage: 105487 km
                    Date: 2017.05.15
                    Time: 18:01:16
                    Hex Value: 0x0000
                    Bin. Bits: 00000000 00000000
                    Voltage: 12.00 V
                    Bin. Bits: 00001111
                    Count: 284
                    Hex Value: 0x0000
                    Reset counter: 81
                    Mileage: 105487 km
                    Date: 2017.05.15
                    Time: 18:01:16
   Part No SW: 5K0 907 044 ES    HW: 5K0 907 044 ES
   Component: Climatronic   H18 1112
   Revision: 00003001
   Coding: 0001000002
   VCID: 000472A39B0A5F470C-8054
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000009027172
   Coding: 668E8F0700041A00470000001E000000000B79435C400120000000000000
   VCID: 336EED6F523C34DFC1-8066
   Subsystem 1 - Part No: 3C2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 100908 022  0601
   Coding: 00046997
   Shop #: WSC 12345
   Component: RLS     121108 054  0402
   Coding: 00471080
   Shop #: WSC 12345
00061 - Footwell Lights
                    Fault Status: 00101100
                    Reset counter: 120
                    Mileage: 105465 km
                    Voltage: 11.70 V
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 5K0 919 475 E    HW: 5K0 919 475 E
   Component: PARKHILFE 8K  H01 0013
   Revision: --------    Serial number: 97540830907185
   Coding: 300102
   Shop #: WSC 12345 123 61029
   VCID: 3874DA438B5AD787F4-806C
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000569541
   Coding: 0010000
   Shop #: WSC 05311 000 08193
   VCID: 3874DA434B5AD787F4-806C
01316 - ABS Control Module
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Reset counter: 81
                    Mileage: 105487 km
                    Date: 2017.05.15
                    Time: 18:05:05
                    Count: 4
   Part No SW: 5N0 959 655     HW: 5N0 959 655
   Component: J234__00S VW10 HI   1815
   Revision: 19013000    Serial number: 0039BPMPB81T
   Coding: 0012371
   VCID: 7AF0004B35D6059742-802E
   Subsystem 1 - Serial number: 6333FTS665962908
   Subsystem 2 - Serial number: 6343FTS632552888
   Subsystem 3 - Serial number: 6353ETS6NTCKVVNR
   Subsystem 4 - Serial number: 6363ETS640PKVVNR
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BM    HW: 5K0 953 569 T
   Revision: FF010041    Serial number: 20160725000799
   Coding: 1992A50003
   VCID: 71E22767A0A046CFF3-8024
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 881     HW: 3AA 920 881
   Component: KOMBI         H03 0705
   Coding: 711F01
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A05729
12858113 - Invalid Data Received from Cruise Control Front Distance Range Sensor
          U0433 00 [008] - -
                    Reset counter: 120
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:54:19
   Part No SW: 7N0 907 530 BL    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1682
   Revision:   H56       Serial number: 110114F2000857
   Coding: 462007
   VCID: 7BFE054FFAEC3C9F59-802E
            000 -  -  - Intermittent
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:44:09
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   VCID: 448CBEB30792836768-8010
   Part No SW: 3AA 959 433 B    HW: 3AA 959 433 B
   Component:    IMMO         052 0407
   Revision: 00052000    Serial number: VWZCZ000000000
   Shop #: WSC 12345 123 2097151
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F66E11FBE14103FA5-807A
   Part No SW: 1T0 035 686 E    HW: 1T0 035 686 E
   Component: RNS-MID       H30 6276
   Revision: AB001001    Serial number: VWZ6Z7M5270061
   Coding: 04050002010000910000
   VCID: 3668D47B814E21F7E6-8062
   Subsystem 1 - Part No: 7L6 919 859 G
   Component: AUNZ V9  8333
02877 - Digital Radio Antenna (R183)
                    Fault Status: 01101011
                    Fault Frequency: 9
                    Reset counter: 81
                    Mileage: 105464 km
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.clb
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1518
   Revision: 71009005    Serial number: 00000691888917
   Coding: 0005047
   VCID: 71E2276768A046CFF3-8024
00131 - Outside Door Handle Illumination/mirror Light Driver Side
                    Reset counter: 120
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:59:30
   Part No: 1K0 909 144 E
   Component: EPS_ZFLS Kl. 143    2501
   Revision: 00H15000
   Shop #: WSC 02069 000 90108
   VCID: 2C5CF6138F026B2780-8078
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 052 0638
   Coding: 00900A00D1034E7F000294157008DFCE607801
Address 47: Sound System (R184)       Labels: 5K0-035-456.clb
   Part No SW: 3AA 035 466     HW: 3AA 035 466
   Component: KonzernAmp12K H03 6904
   Revision: --------    Serial number: A1108A00010581
   ASAM Dataset: EV_AudioVerst12KanalSTT1 001001
   ROD: EV_AudioVerst12KanalSTT1.rod
   VCID: 6DDA3B17BC98A22FD7-8038
9461523 - Front Left Bass Speaker
          B105F 13 [009] - Open Circuit
                    Reset counter: 80
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:44:10
9462035 - Front Left Treble Speaker
          B1061 13 [009] - Open Circuit
                    Reset counter: 80
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:44:10
9463314 - Rear Left Treble Speaker
          B1066 12 [009] - Short to Plus
                    Reset counter: 80
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:44:10
9463826 - Rear Right Treble Speaker
          B1068 12 [009] - Short to Plus
                    Reset counter: 80
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:44:10
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.clb
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1518
   Revision: 71009005    Serial number: 00000649588929
   Coding: 0005046
   VCID: 72E0286B6DA67DD70A-8026
00132 - Outside Door Handle Illumination/mirror Light Passenger Side
                    Reset counter: 120
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:59:30
   Part No SW: 3AA 907 801 E    HW: 3AA 907 801 E
   Component: J540 EPB4  VW-55183 0007
   Revision:   H18       Serial number: 00000000155378
   Coding: 0021057
            000 -  -
                    Fault Status: 01110000
                    Reset counter: 81
                    Mileage: 105487 km
                    Date: 2017.05.15
                    Time: 17:59:49
                    Voltage: 12.10 V
                    Count: 95
                    Hex Value: 0x1260
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Fault Status: 01111101
                    Fault Frequency: 10
                    Reset counter: 81
                    Mileage: 105465 km
                    Date: 2017.05.15
                    Time: 15:44:08
                    Voltage: 11.60 V
                    Count: 69
                    Hex Value: 0x1273
                    Hex Value: 0x0001
                    Hex Value: 0x1010
   Component: AFS-Steuergeraet    0136
   Coding: 2344193
   VCID: 346CEE73573233E7D8-8060
   Subsystem 1 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Coding: 00000035
                    Fault Frequency: 9
                    Reset counter: 81
                    Mileage: 105464 km
Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.clb
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0307
   Revision: 41004101    Serial number: 00000000699648
   Coding: 0000144
   VCID: 70E4226363AA4FC7FC-8024
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000055443
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30.rod
   VCID: 3776D97F8E44D8FFFD-8062
   Part No SW: 3C0 907 441     HW: 3C0 907 441
   Component: J772__Rearview      0042
   Revision: 00H05000    Serial number:    PA8 J890694
   Coding: 0020007
   VCID: 5FC651DF8E34C0BF55-800A
   Part No SW: 3C9 827 383 F    HW: 3C9 827 383 F
   Component: J605  HECKDECKEL    0720
   Revision: 00H27001
   Subsystem 1 - Part No: 3C9 827 384 F
   Component: J756  HECKDECKEL    0720
   Subsystem 2 - Serial number: 0800H27001001B0148ÿ
Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.clb
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0307
   Revision: 41004101    Serial number: 00000000693593
   Coding: 0000144
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 E    HW: 3C8 035 730 E
   Component: Telefon       025 0983
   Revision: --------    Serial number: 35502105271202
   Coding: 020000010100110000000001
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi.rod
   VCID: 254A033724E85A6F5F-8070
End-------------------------(Elapsed Time: 03:30)--------------------------
kamold
Australia
C?ID=241363
Well I managed to get a 3AA907801J EPB along with a centre console from a 2015 Passat.
thought I would at least try and just replace the EPB to see what happened - no luck unfortunately. Still had the same 'incompatible interface' error reported by the EPB module.
I also could no longer get the park brake to engage and disengage with the dashboard button, so that was a step backwards.
I tried randomly changing the coding for vehicle description in EPB but none of the values I tried made forward progress.
Interestingly with the rev J EPB module installed, Front Assist reports as available whereas with the previous module it would disengage on startup reporting Front Assist unavailable. Though I suspect this is just an anomaly given ABS and ESP are disengaged due to the fault on the ABS module.
I'll go down the path of replacing the centre console in a week or two when I have some time
kamold
Australia
C?ID=241363
I've now replaced the centre console and have adaptive cruise and front assist working :)
kamold
Australia
C?ID=241363
Just wanted to give a shout out to two members of this forum who have been very generous with their time and expertise all the way from the other side of the world.
I would not have been able to come close to completing this retrofit without the assistance of @Golfi_vend and @Spacewalker.
You guys are awesome!!
And of course to Rosstech for building their great product and this community of likeminded lunatic tinkerers :)
kamold
Australia
C?ID=241363
Please delete if this isn't appropriate...
I've done a little write up on my experience on a local forum if anyone is interested...
http://www.vwwatercooled.com.au/forums/showthread.php?t=118949
I'll also put a recent Autoscan in case it helps...
Tuesday,06,June,2017,13:06:08:02396
VIN: WVWZZZ3CZ9E083538   License Plate:
VIN: WVWZZZ3CZ9E0   Mileage: 106300km-66051miles
   Coding: 0000175
Readiness: 0110 0101
   Coding: 0000024
   Component: J104   C2 450M VE7D 0023
   Coding: 0103076
   Revision: 00003001
   Coding: 0001000002
   Coding: 00046997
   Shop #: WSC 12345
   Coding: 00471080
   Shop #: WSC 12345
   Coding: 300102
   Coding: 0010000
   Coding: 0012371
   Coding: 1992A50003
   Coding: 830000
   Coding: 711F01
   Coding: 462007
   Coding: 0000005
                    Reset counter: 124
                    Mileage: 106304 km
03138 - Input AUX IN
                    Reset counter: 125
                    Mileage: 106305 km
                    Date: 2017.06.06
                    Time: 13:03:53
   Coding: 0005047
   Revision: 00H15000
                    Reset counter: 125
                    Mileage: 106305 km
                    Date: 2017.06.06
                    Time: 12:47:19
                    Reset counter: 125
                    Mileage: 106305 km
                    Date: 2017.06.06
                    Time: 12:47:19
                    Reset counter: 125
                    Mileage: 106305 km
                    Date: 2017.06.06
                    Time: 12:47:19
                    Reset counter: 125
                    Mileage: 106305 km
                    Date: 2017.06.06
                    Time: 12:47:19
   Coding: 0005046
   Part No SW: 3AA 907 801 J    HW: 3AA 907 801 J
   Component: J540 EPB4  VW-63206 0012
   Revision:   H19       Serial number: 00000000248887
   Coding: 0022157
   Shop #: WSC 05311 000 00001
   Coding: 2344193
   Coding: 00000035
   Coding: 00000035
                    Reset counter: 124
                    Mileage: 106304 km
                    Reset counter: 125
                    Mileage: 106305 km
                    Date: 2017.06.06
                    Time: 13:03:53
   Coding: 0000144
   Coding: 0020007
   Revision: 00H27001
   Coding: 0000144
End-------------------------(Elapsed Time: 03:28)--------------------------
Unlike most forums, Ross-Tech doesn't operate this this one to generate advertising revenue, so we don't view links like that to be problematical in any way.
