Mk6 Jetta MFSW retrofit
Jukman
C?ID=308050
New member to the forum signing in!
So, the project I am currently workin on is to fit a MFSW steering wheel to my 2011 Jetta. The parts I have already acquired are the steering wheel itself (Mk6 Golf GTD), 2x repair wire (000 979 009 E) and the MFSW harness is on its way at this moment. So the only part I am lacking at this moment is the steering wheel control module.
So far I have been relying in these instructions: http://http://forums.vwvortex.com/showthread.php?7508946-Jetta-MK6-MFSW-Retrofit-DIY
Below you can see the auto-scan of my car, which seems to tell me that the module I have at the moment is 5K0 953 569. There is an extensive chart in the ross-tech website of the modules, which also tells me that this module is not compatible with the MFSW. The question is that which module should I buy to make this retrofit work?
Thursday,05,October,2017,17:28:36:10843
VIN: WVWZZZ16ZCM049136   License Plate: NIL-731
Mileage: 126240km-78441mi   Repair Order:
Chassis Type: 16-VW32 (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ16ZCM049136   Mileage: 126240km-78441miles
Address 01: Engine (J623-CAXA)       Labels:. 03C-906-016-CAX2.clb
   Part No SW: 03C 906 016 BS    HW: 03C 907 309 F
   Component: MED17.5.5     H12 4772
   Revision: LCH12---    Serial number: 00000000000000
   Coding: 00190012002400000000
   Shop #: WSC 36000 205 00000
   ASAM Dataset: EV_ECM14TFS01103C906016BS 001010
   ROD: EV_ECM14TFS01103C906016BS.rod
   VCID: 71BCDC16512BBF3FA44-8024
Readiness: 1110 0101
   Revision: 00H31001
   Coding: A43B40F809260003250C02E7901F0040210000
   VCID: 7BA0FE3E03E7C56F0E8-802E
   Part No SW: 7N0 907 426 AN    HW: 7N0 907 426 AN
   Component: AC Manuell    H19 0304
   Revision: 00001015
   Coding: 0000004002
   Shop #: WSC 00066 000 00120
   VCID: 005A89D26A81A6B75BA-8054
   Part No SW: 5K0 937 084 F    HW: 5K0 937 084 F
   Component: BCM PQ35 B    011 0048
   Revision: BA011001
   Coding: 00000A3A902D02C040080080000000E40300008870808D605CC000000040
   VCID: 353428066543D31FB8C-8060
   Part No SW: 5C0 959 655 C    HW: 5C0 959 655 C
   Serial number: 003G6M00RMHR
   Coding: 00003242
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 323E131A94ADC4279DE-8066
   Serial number: 3572MSME32021342ZZZA
   Serial number: 3582MSME20031342ZZZ9
   Serial number: 3516KSME492D2912ZZZV
   Serial number: 3526KSME2B0A7112ZZZO
   Part No SW: 1K5 953 521 AG    HW: 5K0 953 569
   Revision: FF010040    Serial number: 20110812200384
   Coding: 4080140000
   Shop #: WSC 00066 000 00185
   ROD: EV_SMLSNGVOLWS.rod
   VCID: 72BED31A542D84275DE-8026
   Part No SW: 5C6 920 871     HW: 5C6 920 871
   Coding: 171E01
   VCID: 698CB47679FB47FFEC4-803C
   Revision:   H42       Serial number: 11091101270763
   Coding: 351002
   VCID: 6A8ECB7A7CFD4CE7E5E-803E
   Revision: 13110009    Serial number: 0003310477
   Coding: 0000B5
   Shop #: WSC 01383 790 50316
   VCID: 5BE09EBEA3A7256F6E8-800E
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 B    HW: 3C0 959 795 C  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  006 1508
   Serial number: 00000006025349
   Coding: 000090
   Part No: 1K0 909 144 M
   Component: EPS_ZFLS Kl. 68     3201
   Revision: 00H20000
   VCID: 343215026239CA178F2-8060
   Revision: 15110009    Serial number: 0003392657
   Coding: 0000B4
   VCID: 5CE29DA2A6A92257672-8008
   Slave Passenger:
   Component: J389__TSG-HR  006 1508
   Serial number: 00000006049112
   Coding: 000090
   Part No SW: 1K0 035 186 AN    HW: 1K0 035 186 AN
   Component: Radio RCD310  032 0079
   Revision: 01000001    Serial number: VWZ1Z2L3156511
   Coding: 05000400040006
   VCID: 72BED31A54AD84275DE-8026
End----(Elapsed Time: 00:48, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
Thank you in advance for helping out the newbie :D
Christiank
C?ID=253485
Steering control module with revision "CH" will support the buttons on the MK6 mfsw. You should also change your cruise control stalk to a new one with revision "G".
You can problerly also use another control module, but these I don't know of. :)
Jukman
C?ID=308050
Thanks for the reply! So the correct module would be 1K0-953-549-CH and this will work even though the original module has a completely different part number?
And the cruise control stalk: wouldn't the correct part be 5K0054691D because of both MFI and MFSW? So replacing this part will remove the buttons on the right hand side switch, because the MFI will be operated from the steering wheel?
Christiank
C?ID=253485
Yes - this will work since your car share same electronics with the MK6 golf.
Part numbers for cruise control stalk 1K0953513G
Part number for wiper stalk is 1K0953519H
Jukman
C?ID=308050
Thank you for the part numbers! How about the wiper stalk, should it be replaced too or will the original work?
So these are the parts that have to be replaced:
-Steering wheel (duh...)
-Steering control module
-Wiring harness
-Cruise control stalk
-Wiper stalk (?)
Is there anything else that should be replaced, such as the slip ring?
Christiank
C?ID=253485
Wiper stalk will work without replacing. I did just replace mine to the one listed above to get rid of the buttons that will control the MFA. Don't like having stuff in the car with no function - your current wiper stalk buttons to control the MFA will not work once you install the MK6 multi function steering wheel.
Not sure what you have to replace the wire harness?
Your slipring should be fine :)
Jukman
C?ID=308050
Okay, will be replacing the wiper stalk then for the same reason.
From what I have understood, the wiring harness is required with the MFSW. The new steering wheel did not come with an airbag, so I will be using the airbag from my current SW and this one is missing one connector that plugs into the control module.
Jukman
C?ID=308050
Let's give this thread an update. The steering wheel control module I bought did not fit into my Jetta, it appears that mine has the module integrated into the slip ring. The module I bought did not therefore fit into my car.
So I am planning to buy a new control module, and so far I have three options: 5K0-953-569-L, 5K0-953-569-AL and 5K0-953-569-H. All of these are highline models and support the mfsw, but does all of these fit or are there differences between these units?
Jukman
C?ID=308050
Any help with this one? Thinking about pulling the trigger with 5K0-953-569-AL/H.
downtime
C?ID=280813
AL or AH should both be fine, both support MFSW buttons and cruise control. Only thing that is a little bothering is, that the Ross-Tech map does not show if your current control module has steering angle sensor in the module or not. It is TBD on Ross-Tech's site for your current module.
Also you have a new airbag wiring harness ordered for MFSW buttons? DO NOT use any repair wires and try to make it yourself. Buy a ready made wiring to be safe.
New wiper stalk is not mandatory as you can code the buttons on that out but of course for aesthetic reasons correct stalk is nice :)
Jukman
C?ID=308050
Thanks for the reply! Yes I do have the correct harness also waiting for the installation so that one is good to go.
Is it possible to check through VCDS if my car has the steering angle sensor, possibly from the "live data" section? I also have the wiper stalk without the buttons but the new stalk also has rear windscreen wiper option so I think I'll go with the current stalk. Unless somebody happens to know the right part number for the stalk without the buttons and the rear wiper?
iichel
Netherlands, eastern part
C?ID=284912
there's probably a measuring value block or advanced measurement value in the ABS for steering angle sensor (G85)
looks like your jetta is a AW1 (high, PQ35) so the stalk from a beetle won't work.
Jukman
C?ID=308050
I found that, thank you. Managed to get steering angle values from there, so that would mean that the original control module also has steering angle sensor, am I right? That there are no other parts where the car could get that information from?
Jukman
C?ID=308050
Alrighty, got my new control module and the plan is to give this a go during the weekend. Any advice on how to code the factory new controller, do I just use the original coding (4080140000) for the new module?
Dana
Western PA, USA
Yeah, start with the factory coding: 4080140000
After that's accepted go ahead and tweak the MFSW bits with the LCH. Please post the new scan even if you don't need further assistance.
Jukman
C?ID=308050
Thanks Dana, hopefully this will be a straight on project from now on.
I will post the new auto-scan if everything goes as planned.
Jukman
C?ID=308050
Good news, managed to install the MFSW almost succesfully, horn, css etc. work as they should. The original wiper stalk with buttons also work like before, so I think I can live with that.
However, the right hand side buttons function only partially: so far I have not noticed that the right-left -arrows do not operate at all, the up and down buttons function as they should. Any ideas on this one, perhaps this has something to do with the still functioning wiper stalk which I thought that it shouldn't work anymore? It also might be something as easy as tweaking with LCH, ran out of time at the moment...
The original steering wheel coding: 4080140000
The new coding: 4082140000
The difference was the result of tweaking with the LCH (MFSW installed).
The full auto-scan:
Saturday,10,February,2018,11:48:00:10843
VCDS Version: 17.8.1.0 (x64)  HEX-V2 CB: 0.4401.4
Mileage: 133950km-83232mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 56 62 72
VIN: WVWZZZ16ZCM049136   Mileage: 133950km-83232miles
   VCID: 71BCDC16512BBF3FA5F-8024
   Revision: 00H31001
   VCID: 7BA0FE3E03E7C56F0F3-802E
   Revision: 00001015
   Coding: 0000004002
   VCID: 005A89D26A81A6B75A1-8054
   Revision: BA011001
   Coding: 00000A3A982F02C040080080000000E40380008870808D205CC000000040
   Shop #: WSC 00066 123 12345
   VCID: 353428066543D31FB97-8060
   Coding: 00003242
   VCID: 323E131A94ADC4279C5-8066
   Part No SW: 5K0 953 569 AL    HW: 5K0 953 569 AL
   Revision: --X01---    Serial number: 20171101100167
   Coding: 4082140000
   Shop #: WSC 01286 386 08256
   VCID: 025E83DA648DB4A74C5-8056
   Component: E221__MFL-TAS  H07 0013
   Serial number: 0069722
   Coding: 820000
   Coding: 171E01
   VCID: 698CB47679FB47FFEDF-803C
   Coding: 351002
   VCID: 6A8ECB7A7CFD4CE7E45-803E
   Part No SW: 3C8 035 279 N    HW: 3C8 035 279 N
   Component: RNS315-EU   H70 0407
   Serial number: VWZAZ2N0424764
   Coding: 0600041104000F0000008000
   Shop #: WSC 00015 115 12345
   ROD: EV_RNS315EUV2UDS.rod
   VCID: 36362F0A78C5D807B0D-8062
   Component: EUR_W_V10  0070
1048630 - CD Changer
          B1101 31 [009] - No Signal
                    Reset counter: 121
                    Mileage: 133957 km
                    Date: 2018.02.10
                    Time: 00:16:25
1048652 - Telephone Microphone
          B1048 13 [009] - Open Circuit
                    Reset counter: 121
                    Mileage: 133957 km
                    Date: 2018.02.10
                    Time: 00:16:25
   Coding: 0000B5
   VCID: 5BE09EBEA3A7256F6F3-800E
   Slave Driver:
   Coding: 000090
   Revision: 00H20000
   VCID: 343215026239CA178E9-8060
   Coding: 0000B4
   VCID: 5CE29DA2A6A92257669-8008
   Slave Passenger:
   Coding: 000090
End----------(Elapsed Time: 00:50, VBatt start/end: 14.3V/14.4V)-----------
MasterTommy
Amsterdam
C?ID=295586
As far as I know, the left right buttons are for next/previous. Seems logical that the media player isn’t aware of the MFSW.
Jukman
C?ID=308050
The left hand side left-right -buttons work as they should, they change the song or the radio station depending on the media played. But the right hand side buttons should in my opinion operate the MFD. The up and down buttons work as they should.
Dana
Western PA, USA
If you still have the stalk controls connected that may be the conflict. For example, having both the factory MF stalk type -and- a retrofitted LIN 2.0 (12 button) Mk6 steering wheel caused issues on the early Mk6 Golf.
I'd try this coding: 008A140000
Even if you get an incorrectly coded DTC (i.e. due to the factory stalk instead of a plain/non MF stalk) the wheel buttons may work properly.
