New member to the forum signing in!
So, the project I am currently workin on is to fit a MFSW steering wheel to my 2011 Jetta. The parts I have already acquired are the steering wheel itself (Mk6 Golf GTD), 2x repair wire (000 979 009 E) and the MFSW harness is on its way at this moment. So the only part I am lacking at this moment is the steering wheel control module.
So far I have been relying in these instructions: http://http://forums.vwvortex.com/showthread.php?7508946-Jetta-MK6-MFSW-Retrofit-DIY
Below you can see the auto-scan of my car, which seems to tell me that the module I have at the moment is 5K0 953 569. There is an extensive chart in the ross-tech website of the modules, which also tells me that this module is not compatible with the MFSW. The question is that which module should I buy to make this retrofit work?
Thank you in advance for helping out the newbie
Thursday,05,October,2017,17:28:36:10843
VCDS Version: 17.8.0.1 (x64) HEX-V2 CB: 0.4401.4
VIN: WVWZZZ16ZCM049136 License Plate: NIL-731
Mileage: 126240km-78441mi Repair Order:
Chassis Type: 16-VW32 (7N0)
VIN: WVWZZZ16ZCM049136 Mileage: 126240km-78441miles
Address 01: Engine (J623-CAXA) Labels:. 03C-906-016-CAX2.clb
Part No SW: 03C 906 016 BS HW: 03C 907 309 F
Component: MED17.5.5 H12 4772
Revision: LCH12--- Serial number: 00000000000000
Coding: 00190012002400000000
Shop #: WSC 36000 205 00000
ASAM Dataset: EV_ECM14TFS01103C906016BS 001010
ROD: EV_ECM14TFS01103C906016BS.rod
VCID: 71BCDC16512BBF3FA44-8024
Readiness: 1110 0101
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: A43B40F809260003250C02E7901F0040210000
Shop #: WSC 00066 000 00000
VCID: 7BA0FE3E03E7C56F0E8-802E
Part No SW: 7N0 907 426 AN HW: 7N0 907 426 AN
Component: AC Manuell H19 0304
Revision: 00001015
Coding: 0000004002
Shop #: WSC 00066 000 00120
ROD: EV_ACManueBHBVW36X_VW32.rod
VCID: 005A89D26A81A6B75BA-8054
Part No SW: 5K0 937 084 F HW: 5K0 937 084 F
Component: BCM PQ35 B 011 0048
Revision: BA011001
Coding: 00000A3A902D02C040080080000000E40300008870808D605CC000000040
VCID: 353428066543D31FB8C-8060
Part No SW: 5C0 959 655 C HW: 5C0 959 655 C
Component: AirbagVW10 013 0613
Serial number: 003G6M00RMHR
Coding: 00003242
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 323E131A94ADC4279DE-8066
Serial number: 3572MSME32021342ZZZA
Serial number: 3582MSME20031342ZZZ9
Serial number: 3516KSME492D2912ZZZV
Serial number: 3526KSME2B0A7112ZZZO
Part No SW: 1K5 953 521 AG HW: 5K0 953 569
Revision: FF010040 Serial number: 20110812200384
Coding: 4080140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGVOLWS.rod
VCID: 72BED31A542D84275DE-8026
Address 17: Instruments (J285) Labels:| 5K0-920-xxx-17.clb
Part No SW: 5C6 920 871 HW: 5C6 920 871
Component: KOMBI H04 0617
Coding: 171E01
VCID: 698CB47679FB47FFEC4-803C
Part No SW: 7N0 907 530 H HW: 1K0 907 951
Component: J533 Gateway H42 1620
Revision: H42 Serial number: 11091101270763
Coding: 351002
Component: IMMO H04 0617
VCID: 6A8ECB7A7CFD4CE7E5E-803E
Part No SW: 561 959 701 HW: 3C0 959 793 B
Component: TUER-SG FT 002 0515
Revision: 13110009 Serial number: 0003310477
Coding: 0000B5
Shop #: WSC 01383 790 50316
VCID: 5BE09EBEA3A7256F6E8-800E
Slave Driver:
Subsystem 1 - Part No SW: 3C0 959 703 B HW: 3C0 959 795 C Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1508
Serial number: 00000006025349
Coding: 000090
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 68 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 343215026239CA178F2-8060
Part No SW: 561 959 702 HW: 3C0 959 792 B
Component: TUER-SG BT 002 0515
Revision: 15110009 Serial number: 0003392657
Coding: 0000B4
VCID: 5CE29DA2A6A92257672-8008
Slave Passenger:
Subsystem 1 - Part No SW: 3C0 959 704 B HW: 3C0 959 794 C Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1508
Serial number: 00000006049112
Coding: 000090
Part No SW: 1K0 035 186 AN HW: 1K0 035 186 AN
Component: Radio RCD310 032 0079
Revision: 01000001 Serial number: VWZ1Z2L3156511
Coding: 05000400040006
VCID: 72BED31A54AD84275DE-8026
End----(Elapsed Time: 00:48, VBatt start/end: 11.9V/11.9V. VIgn 11.9V)-----
