Cent Elec code 03302
Peirre
C?ID=277888
As a pre cursor to having the emissions mods done tomorrow I`ve scanned the car (R6 polo) for a before and after scan, but its thrown a fault code up on the door(s) and I`m wondering if anyone can shed some light as to what this new fault is/was (which I`ve now cleared). The only other thread I can find on this fault code has no replies
I`m also aware there is an old fault remaining on the HVAC which I`m disregarding for now. As its also going to have the aircon serviced tomorrow as well.
the full scan is:
Tuesday,14,March,2017,11:09:22:50070
VCDS Version: 17.1.3.0
VIN: WVWZZZ6RZAU008663   License Plate: *******
Mileage: 73400km-45608mi   Repair Order: Pre EA189 modification scan
Chassis Type: 6R (6N0)
Scan: 01 03 04 08 09 15 17 19 25 44 56
VIN: WVWZZZ6RZAU008663   Mileage: 73400km-45608miles
Address 01: Engine (J623-CAYA)       Labels: 03L-906-023-CAY.clb
   Part No SW: 03L 906 023 BL    HW: 03L 906 023 D
   Component: 1,6l R4 CR td H13 8821
   Revision: --H13---    Serial number: 00000000000000
   Coding: 00114014000500080000
   Shop #: WSC 31414 790 50316
   ASAM Dataset: EV_ECM16TDI02103L906023BL 003008
   ROD: EV_ECM16TDI02103L906023AH_003.rod
   VCID: 71E9AE62A06A8CC916-8024
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP82.clb
   Part No SW: 6R0 907 379 R    HW: 6R0 907 379 R
   Component: ESP8.2i front H04 0002
   Revision: --------
   Coding: 230224E3416D00BAC42B24E882D400821100
   Shop #: WSC 31414 790 31414
   VCID: 4D9112921012882952-8018
Address 08: Auto HVAC (J301)       Labels: 6R0-820-045-9AP.clb
   Part No SW: 6R0 820 045 A    HW: 6R0 820 045 A
   Component: Climatic       23 0500
   Revision: 00 09 23
   VCID: 2C577F164FC8A12165-8078
16372 - Control Module; Unspecified Internal Error
            014 - Defective
                    Fault Status: 01101110
                    Mileage: 34124 km
                    Date: 2013.02.11
                    Time: 06:38:24
Address 09: Cent. Elect. (J519)       Labels: 6R0-937-08x-09.clb
   Part No SW: 6R0 937 086 B    HW: 6R0 937 086 B
   Component: PQ25 BCM      H09 0029
   Revision: BD009001    Serial number: 9953A219090051
   Coding: 24B02BBF08A10000003000003D2B0CD00000410F600400002000
   Shop #: WSC 00389 210 91447
   VCID: 3B754C4ABAA63699FC-806E
   Subsystem 1 - Part No SW: 6R0 959 802 H    HW: 6R0 959 802 H  Labels: 6R0-959-802.CLB
   Component: J386__TSG_FT  004 0803
   Serial number: KU0-KU003.09.0911506
   Coding: 08BC30
   Subsystem 2 - Part No SW: 6R0 959 801 K    HW: 6R0 959 801 K  Labels: 6R0-959-801.CLB
   Component: J387__TSG_BT  003 0803
   Serial number: KU0-KU014.08.0911731
   Coding: 08BC30
   Subsystem 3 - Part No SW: 6R0 959 811 B    HW: 6R0 959 811 B
   Component: J388__TSG_HL  004 0803
   Serial number: KU0-KU020.08.0910419
   Coding: 08BC32
   Subsystem 4 - Part No SW: 6R0 959 812 B    HW: 6R0 959 812 B
   Component: J389__TSG_HR  004 0803
   Serial number: KU0-KU003.09.0910033
   Coding: 08BC32
03302 - Response Closing Status of Passenger's Door
                    Reset counter: 251
                    Mileage: 72906 km
                    Date: 2011.07.08
                    Time: 10:29:35
   Part No SW: 6R0 959 655 C    HW: 6R0 959 655 C
   Component: VW10Airbag00B H09 0018
   Revision: --------    Serial number: 003DW006LARQ
   Coding: 003042
   ROD: EV_AirbaVW10BPAVW250_VW25.rod
   VCID: 428B31AED54C4751BF-8016
   Serial number: 3572SRB400009A0549D8
   Serial number: 3582SRB400009A0D4A6B
   Serial number: 3516GRB401T9BR0F0K2F
   Serial number: 3526GRB401T9BR0ETS7E
   Part No SW: 6R0 920 961 B    HW: 6R0 920 961 B
   Component: KOMBI         H23 0110
   Coding: 440200
   ROD: EV_Kombi_UDS_VDD_RM09_A04_VW25.rod
   VCID: 35615A729482E0E90A-8060
Address 19: CAN Gateway (J533)       Labels: 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 6R0 937 086 B
   Component: GW-K-CAN TP20 0029
   Coding: 002300
   VCID: 70EFAB66A36085C119-8024
   Component: IMMO          H23 0110
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03004
   Part No: 6R0 423 156 A
   Component: LenkhilfeTRW        V275
   Coding: 10130
   Shop #: WSC 31414
   VCID: 2E53751EEDD4D3314B-807A
Address 56: Radio (J503)       Labels: 1K0-035-1xx-56.lbl
   Part No SW: 5M0 035 186 AA    HW: 5M0 035 186 AA
   Component: Radio RCD310  013 0036
   Revision: 01000000    Serial number: VWZ1Z2I6811079
   Coding: 0500040002
   VCID: 6BD5BC0A8A4666192C-803E
End-------------------------(Elapsed Time: 02:28)--------------------------
I`ll also post the before and after scans elsewhere for the diesel emissions work due to be carried out tomorrow to see if there`s any significant changes
Are you 100% sure you want to have the VW emissions "fix" done? It's not compulsory, you can say "thanks but no thanks".
Do some Googling and you'll find a significant number of owners having problems after the mods that didn't exist before - the worst I've read is someone (in the UK) who had the turbo oil seal fail and required a new turbo, fortunately VW stepped up to the plate and admitted it was caused by the mod (so much for it won't change anything and is safe???) and paid the full bill of approx £5,000.
Think long and hard before agreeing to the emissions mod....
Peirre
C?ID=277888
Any specific models affected?
Peirre
C?ID=277888
It's an R6 1.6 TDi polo
NZDubNurd
New Zealand
C?ID=230482
I'd at least get in writing that an EGR failure will be covered by VW for a decent period of time (maybe 3 or 6 months) after the update.
EGR failures seem pretty common after the update too. I thought there were 2 examples of Polos having failures, just on this forum??? A few Caddy guys have had it too.
Economy results vary afterwards too, from slightly better to about 15% worse.
Peirre
C?ID=277888
Due to personal reasons ATM the work is cancelled & on hold
Peirre
C?ID=277888
Pre & post emission mod scans
After cancelling the initial booking for the Diesel emissions due to a family tragedy, the car was returned to the dealer for the work to be carried out.
These are the before and after scans, there is a long standing fault on the HVAC which I`ve highlighted and discounted
Pre mod scan
Wednesday,03,May,2017,18:07:11:50070
Mileage: 74920km-46553mi   Repair Order: Pre Diesel recall scan
VIN: WVWZZZ6RZAU008663   Mileage: 74920km-46553miles
   Revision: --------
   Revision: 00 09 23
            014 - Defective
                    Mileage: 34124 km
                    Date: 2013.02.11
                    Time: 06:38:24
   Coding: 08BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003042
   Coding: 440200
   Coding: 002300
   Coding: 10130
   Shop #: WSC 31414
   Coding: 0500040002
Post Emissions mod scan
Tuesday,09,May,2017,19:58:54:50070
Mileage: 75120km-46677mi   Repair Order: Post Emmission recall scan
VIN: WVWZZZ6RZAU008663   Mileage: 75120km-46677miles
   Component: R4 1.6l TDI   H13 9979
   ASAM Dataset: EV_ECM16TDI02103L906023BL 003015
   Revision: --------
   Revision: 00 09 23
            014 - Defective
                    Mileage: 34124 km
                    Date: 2013.02.11
                    Time: 06:38:24
   Coding: 08BC30
   Coding: 08BC30
   Coding: 08BC32
   Coding: 08BC32
   Coding: 003042
   Coding: 440200
   Coding: 002300
   Coding: 10130
   Shop #: WSC 31414
   Coding: 0500040002
End-------------------------(Elapsed Time: 02:23)--------------------------
The 1st time I scanned it post mod it threw this fault up on the radio, which I`ve cleared
   Coding: 0500040002
                    Reset counter: 41
                    Mileage: 75019 km
                    Date: 2011.09.29
                    Time: 14:37:06
If anyone wants to analyse the scan(s) and pass comment
This is not as big a change as many of the emissions updates. Only the software version of the ECU changed:
Peirre
C?ID=277888
Thanks Uwe, that was the only thing I noticed when I compared them. There is apparently some kind of flow "straighter" fitted to the air intake pipe before the airflow sensor. The only difference in engine behaviour that I've noticed so far is a slight "rattling" sound at low rpm (1000-1500) as the engine labours to pull away from a standstill. A sound I'd describe as "pinking" on a petrol engine, but above 2000 rpm the power is there, but the car seems to require a few more gear changes than before, it that could be down to my driving style around town. This would indicate the mapping changes have altered the power delivery. The dealer did call me last night to enquire how it was, so I raised my concerns about this "rattling" to which they stated "give it a week or 2, and if it's still causing concern give us a call and we'll plug it into the diagnosistics and check it out"
Peirre
C?ID=277888
Update: I stopped by the dealers for a chat and to raise a few concerns since the mod.
Despite there being no warning lamps etc. The fuel consumption is taking a hit with around 50+ miles per tank less despite like for like useage, the DPF is cycling more frequently but not excessively, and there's a little less umph & the engine is sluggish when setting off from a standstill, it's as if the engine is taking a deep breath before it pulls away, and momentarily pauses which has led to a few interesting moments when pulling out of side streets into mainstream traffic, but above 1500rpm the power delivery seems ok. The gear indicator on the dash also seems to be asking me to change gear much lower down the rev range. My gut feeling is everything seems to point to the map update loaded during the mod.
If the engine was a petrol engine I'd say the timing was advanced and it was pinking. This pinking would also explain the symptoms I mentioned and may also explain the "rattling" up to 1500rpm I mentioned previously.
A mechanic from the dealer took a test drive and also hooked it up to read any possible fault codes (non found).
I stated that I'm due to go on vacation with the car in a few weeks, and the receptionist suggested that I (casually) bring it back in a week prior to departing to check it over again, the receptionist did try to suggest that the map installed prior to the mod wasn't the original and someone may have remapped the car in the 1st 3yrs prior to my ownership, but the previous owner was a senior citizen and the car was supplied to them via a government approved disability scheme, and routinely serviced by an approved dealer.
When I spoke to the head mechanic about the rattling, he decided that the car should be booked in and make the car available to them all day, and he would arrange for the injectors to be tested onsite, and should there be any issues it will allow them to discuss it with the VW techs and get a resolution
