2010 Audi Q5 Park Assist Module Error -
ItemQ5
C?ID=298451
Hi All,
I have an Audi Q5 2010 Premium Plus that had a faulty parking assist module which I replaced with a second hand unit. Unfortunately the second unit came from a car with a trailer hitch and is now through up an error. See below:
Address 10: Park/Steer Assist (J446) Labels: 8K0-919-475.clb
Part No SW: 8K0 919 475 J HW: 8K0 919 475 A
Component: PARKHILFE 8K H06 0050
Revision: 11001001 Serial number: 39840920004289
Coding: 310105
Shop #: WSC 01814 444 54729
VCID: 40DA4901CA8CD0376D2-8014
01517 - Control Module for Trailer/Towing Sensor (J345)
Reset counter: 135
Mileage: 163482 km
Date: 2016.09.16
Time: 15:36:09
Temperature: 25.0°C
Would anyone have the instructions on how to remove the trailer hitch from this module or reprogram it? I am new to owning an Audi and using the VCDS software, so any instructions would be greatly appreciated.
Thanks in advance
MartinsX
Riga, Latvia
C?ID=268515
Post complete autoscan, please. It would allow others to see complete list of modules installed in Your car and a lot of other information needed to give You correct suggestions.
Is Your old module completely dead? Is it possible to connect it back and do an autoscan with old module connected?
ItemQ5
C?ID=298451
Thanks MartinX, I will run a complete auto scan with the old mobule and the replacement and post them both up tonight.
ItemQ5
C?ID=298451
Here is the full auto scan with the second hand module that faults due to a trailer hitch
 Chassis Type: FP (8T0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 42 46 47 52 53 55 56 5F
          62 6C 6D 72
VIN: WA1LKBFP8AA0XXXXX   Mileage: 167380km-104005miles
Address 01: Engine (J623-CALB)       Labels: 06E-907-559-CAL.clb
   Part No SW: 8R0 907 559 G    HW: 8F0 907 559 A
   Component: 3.2 SIMOS8.2  H06 0004
   Revision: --------
   Coding: 0121000A190F0121
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM32FSI0218R0907559G 001004
   ROD: EV_ECM32FSI.rod
   VCID: 44D24511DE14CC1749A-8010
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8R0 927 158 F    HW: 0B6 927 156
   Component: 0B6 32 FSIUSA H05 0005
   Revision: --H05---
   Coding: 001012
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 40DA4901CA0CD0376D2-8014
Address 03: ABS Brakes (J104)       Labels: 8R0-907-379-V1.clb
   Part No SW: 8R0 907 379 M    HW: 8R0 907 379 M
   Component: ESP8 quattro  H06 0020
   Coding: 041D18
   VCID: 4ACE6B29FCB01A67B36-801E
   Part No SW: 8K0 907 064 DS    HW: 8K0 907 064 DS
   Component: BCM2 1.1      H02 0326
   Coding: 090500
   VCID: 045285119E140C1709A-8050
   Serial number: 0509000048245013
   Serial number: 0209000068864010
   Part No SW: 8T1 820 043 AK    HW: 8T1 820 043 AK
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01021020090169
   Coding: 46112000
   VCID: 7AAEFBE9ECD04AE7636-802E
Address 09: Cent. Elect. (J519)       Labels: 8K0-907-063.clb
   Part No SW: 8K0 907 063 P    HW: 8K0 907 063 P
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000474265
   Coding: 26001091063CAF010000080300001D0D0F1C460802010161000000
   Shop #: WSC 45454 001 1048576
   VCID: 3C223DF1A664B4D731A-8068
   Subsystem 1 - Part No SW: 8R1 955 119 A    HW: 8R1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS416 090919  H10 0041
   Serial number: 90243014090915040356
   Coding: 01DD13
   Component: RLS  H04 0003
   Serial number: 10615855
   Coding: 024D25
   Subsystem 3 - Part No SW: 8K0 941 531 AL    HW: 8K0 941 531 AL
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002109090213
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
   Coding: 310105
                    Reset counter: 135
                    Mileage: 163482 km
                    Date: 2016.09.16
                    Time: 15:36:09
                    Temperature: 25.0°C
Address 15: Airbags (J234)       Labels: 8R0-959-655.clb
   Part No SW: 8R0 959 655 D    HW: 8R0 959 655 D
   Component: AirbagVW-AU10 H39 0560
   Serial number: 003FRD052MZ-
   Coding: 303333313432303030304A55304C38523053
   ROD: EV_AirbaAU10SMEAU416.rod
   VCID: 45D45815D52EF51F5E4-8010
   Subsystem 1 - Part No SW: 8R0 959 339     HW: 8R0 959 339
   Serial number: 5810000R0900003Q3H
   Serial number: 6334MSME4B255339F
   Serial number: 6344MSME4C340E15H
   Serial number: 6352QSME743B190AM
   Serial number: 6362QSME483B4326J
   Serial number: 63732SME2B3D0E324
   Serial number: 63832SME2B3D250C5
Address 16: Steering wheel (J527)       Labels: 8K0-953-568.clb
   Component: Lenks.Modul   H16 0014
   Revision: --------    Serial number: 90315IIT0005G
   Coding: 000017
   VCID: 3D2430F5BD7EBDDF064-8068
Address 17: Instruments (J285)       Labels: 8R0-920-xxx-17.clb
   Part No SW: 8R0 920 980 K    HW: 8R0 920 980 K
   Component: KOMBIINSTR.   H10 0255
   Revision: 00000000    Serial number: CJK2540A9
   Coding: 8B1622000300D705020000
   VCID: 41DC4C05C186D93F62C-8014
Address 19: CAN Gateway (J533)       Labels: 8T0-907-468.clb
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E099128144
   Coding: 00C303
   VCID: 52FE734914E052A7CB6-8006
   Subsystem 1 - Part No SW: 8R0 915 181     HW: 8R0 915 181
   Component: J367-BDM  H07 0107
   Serial number: 00000000004140093374
   Part No SW: 8R0 959 760 B    HW: 8R0 959 760 B
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001001349884
   Coding: 00581300000044440000
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009390892
   Coding: 011D03205E00440004
   VCID: 45D45815D5AEF51F5E4-8010
            008 - Implausible Signal
                    Fault Status: 01101000
                    Fault Frequency: 53
                    Reset counter: 63
                    Mileage: 166210 km
                    Date: 2016.11.30
                    Time: 18:51:42
Address 46: Central Conv. (J393)       Labels: 8K0-907-064-46.clb
   Revision: 00002001    Serial number: 0122042992
   Coding: 0126023A207A749404B0050000000000
   Component: GTO BF  H06 0050
   Serial number: 00000000000000173494
   Subsystem 3 - Part No SW: 8R0 959 591     HW: 8R0 959 591
   Component: J245EE16SKB10  H01 0180
   Subsystem 4 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J394EE19SKB12  H01 0220
02616 - Fuel Tank Cap; Unlock
                    Fault Status: 00101001
                    Reset counter: 88
                    Mileage: 167111 km
                    Date: 2017.01.25
                    Time: 07:55:14
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 H    HW: 8T0 035 223 H
   Component: DSP Prem      H04 0120
   Revision: 00004001    Serial number: 34880005725603
   VCID: 333016CD8B3A7BAFE00-8066
Address 52: Door Elect, Pass. (J387)       Labels: 8K0-959-792.clb
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Component: TSG BF        H11 0306
   Revision:             Serial number: 0000009366053
   VCID: 44D24511DE94CC1749A-8010
   Revision: 00000003    Serial number: 00000000459444
   VCID: 343215D18E347C97F9A-8060
   Part No: 8K0 907 357 B
   Component: Dynamische LWR  H01 0030
   Coding: 0000006
   Shop #: WSC 06334 000 00000
   VCID: 343215D182347C97F9A-8060
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335IU097531334
   Coding: 020000010000000001
   VCID: 1D64D0751DBEDDDF264-8048
Address 5F: Information Electr. (J794)       Labels: 4E0-035-6xx-5F.clb
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490I 097518812
   Coding: 010200060005A1EF41000B0E000000030000
   VCID: 36362FD998486E87C7E-8062
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466J$0A0233875
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: E0380 Bedient  H08 0100
   Serial number: 00000000368602
   Subsystem 4 - Part No: 8R0 906 961 A
   Component: CD-Database  1293
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 C    HW: 8K0 959 795 C
   Component: TSG HL        H10 0306
   Revision:             Serial number: 0000101997395
   Coding: 010C03204000240004
   VCID: 42DE4309C480C2277B6-8016
   Part No SW: 8R0 907 441 A    HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J98A1HS
   Coding: 1020010
   Part No SW: 8R0 827 851 B    HW: 8R0 827 851 B
   Component: J605  Master  H27 0300
   Revision: --------    Serial number: 8R0827851B
   VCID: 3B203EEDA36AB3EF380-806E
   Subsystem 1 - Part No SW: 8R0 827 852 B    HW: 8R0 827 852 B
   Component: J756  Slave  H27 0300
   Serial number: 8R0827852B
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H10 0306
   Revision:             Serial number: 0000101998623
End----------(Elapsed Time: 01:55, VBatt start/end: 11.7V/11.7V)-----------
Monday,06,February,2017,21:52:42:61747
VCDS Version: 17.1.2.1 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170131 DS267.1
VIN: WA1LKBFP8AA041182   License Plate:
Mileage: 167380km-104005mi   Repair Order:
          62 6C 6D 72
   Revision: --------
   Revision: --H05---
   Coding: 001012
   Coding: 041D18
   Coding: 090500
   Coding: 46112000
   Coding: 01DD13
   Coding: 024D25
   Coding: 310105
                    Reset counter: 135
                    Mileage: 163482 km
                    Date: 2016.09.16
                    Time: 15:36:09
                    Temperature: 25.0°C
   Coding: 000017
   Coding: 00C303
                    Fault Frequency: 53
                    Reset counter: 63
                    Mileage: 166210 km
                    Date: 2016.11.30
                    Time: 18:51:42
                    Reset counter: 88
                    Mileage: 167111 km
                    Date: 2017.01.25
                    Time: 07:55:14
   Coding: 0000006
   Coding: 1020010
End----------(Elapsed Time: 01:54, VBatt start/end: 11.7V/11.7V)-----------
Here is the Auto Scan with the original park assist module that couldn't be communicated to.
          62 6C 6D 72
10-Park/Steer Assist -- Status: Cannot be reached 1100
   Revision: --------
   Revision: --H05---
   Coding: 001012
   Coding: 041D18
   Coding: 090500
   Coding: 46112000
   Coding: 01DD13
   Coding: 024D25
   Coding: 000017
   Coding: 00C303
01327 - Control Module for Parking Aid (J446)
                    Reset counter: 65
                    Mileage: 167388 km
                    Date: 2017.02.09
                    Time: 21:44:06
                    Bin. Bits:    10111
                    Voltage: 11.30 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 0.40 s
                    Fault Frequency: 53
                    Reset counter: 63
                    Mileage: 166210 km
                    Date: 2016.11.30
                    Time: 18:51:42
                    Reset counter: 88
                    Mileage: 167111 km
                    Date: 2017.01.25
                    Time: 07:55:14
   Coding: 0000006
            000 -  -
                    Reset counter: 65
                    Mileage: 167388 km
                    Date: 2017.02.09
                    Time: 21:44:11
                    Bin. Bits: 00000100 00000000
                    Bin. Bits: 00000000 00000000
            000 -  -
                    Reset counter: 65
                    Mileage: 167388 km
                    Date: 2017.02.09
                    Time: 21:44:16
                    Bin. Bits: 00001000 00000000
   Coding: 1020010
                    Reset counter: 65
                    Mileage: 167388 km
                    Date: 2017.02.09
                    Time: 21:44:11
                        Term 15 On
                        Reverse OFF
                    Count: 3
End----------(Elapsed Time: 01:55, VBatt start/end: 11.6V/11.6V)-----------
Any advice on how to get rid of the trailer hitch error on the second hand module would be appreciated.
vagtuning
VCDS Super-User
C?ID=57100
Get the Trailer module correct communicating.Then it won´t be "missed"
NEtech
C?ID=56995
We cannot check what equipment your car has, because you removed VIN.
But you can try this Coding for [10-Park/Steer Assist]
300105
Use [Security Access-16] first.
ItemQ5
C?ID=298451
Hi NEtech, the VIN is WA1LKBFP8AA041182 for the Q5.
Hi Vagtuning, the Q5 doesn't have the physical trailer hitch installed on it. So I assumed that it wouldn't have the module installed on it. Would I be able to identify it?
NEtech
C?ID=56995
Yes, try the coding.
ItemQ5
C?ID=298451
Hi NEtech, I finally had the opportunity to try the coding last night and no the camera is working. Thank you very much for your help, i couldn't have done it without on my own.
