VW Passat B8 2017 Tweaks
   #41
DV52
C?ID=194404
NEtech: Thanks- now I understand (well...........not really, but I do see where the number "29" comes from). I suspect my error was the term "addressing" - I assumed that the full 29 Bits were purely intended as address location pointers.
I guess folk here are familiar with the type of bit stream pictures as in your link - I'm not. My very amateur (and extremely uninformed) observation is that it's a very inefficient way of carrying 8 Bits of data. But then I suspect that the overhead (i.e. additional 21 Bits) is the price that must be paid for using just two wires to talk to all the modules in the bus and for having these chats in such a noisy environment.
Anyhow, clearly the thing works - so kudos to Mr CAN for inventing the protocols !;)
Cheers
   #42
A CAN frame carries 8 bytes of data, not 8 bits.
In addition to noise resistance, it also gets you message prioritization and collision detection.
It works well enough that it's become a standard in the automotive industry world-wide.
   #43
DV52
C?ID=194404
Uwe: Clearly I need lots of remedial training to get even a rudimentary understanding of this stuff.
My confusion about Byte/Bits came from the following extract and my extrapolation of everything else - a clear case of a little knowledge is a dangerous thing:
Data frame
The data frame is the only frame for actual data transmission. There are two message formats:
Base frame format: with 11 identifier bits
Extended frame format: with 29 identifier bits (my bolding)
   #44
murmeltier
Switzerland
C?ID=260972
See my reply to Bruce.
Address 4B: Multifunc. Module (J745)       Labels:* None
The star indicates that the ROD file will give you coding info. Give it a try!
Thanks for the explanation. I will try it as soon as possible :-)
   #45
murmeltier
Switzerland
C?ID=260972
Hey guys
In the meantime I managed to activate the Dynamic Light Assist! :-)
I published a free instruction on the internet:
https://www.vcdsschweiz.ch/en/activating-dynamic-light-assist-dla/
(this is for MY 2017 and higher, but there is also one for the older MY).
Thanks everybody who helped me by finding the solution... :-)
Regards
mauriciospilere
Brazil
C?ID=313275
Hey Guys,
Just started making changes in my Passat b8 2018. Comes with ACC from factory, but not with lane assist, traffic jam and signal recognition.
Following some tutorials I got succeed activating the lane assist.
Does anybody tryed activating the Traffic Jam? There is any tutorial for Passat?
Another question. I activated the traffic signal recognition, but here, in Brazil, the system doesnt works properly. Sometimes it reads a signal, but less than 5% of them. There´s any configuration or region choice do gets it better?
I´m still interested activating Vídeo in Motion and Digital TV. Anyone got it? know if the discorevy pro 3gp (9´one) has digital tv inside or need another hardware?
That´s my scan:
Saturday,27,January,2018,21:44:47:01775
VCDS Version: 18.1.0.2 (x64)  HEX-V2 CB: 0.4411.4
VIN: WVWMV83C9JE047295   License Plate:
Chassis Type: 3C-VW48 (3Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 19 2B 36 42 44 4B 52 5F
          6C 6D A5 BB BC CA D6 D7
VIN: WVWMV83C9JE047295   Mileage: 4246km-2638miles
4B-Multifunc. Module -- Status: Malfunction 0010
CA-Sunroof -- Status: OK 0000
Address 01: Engine (J623-CHHB)       Labels:. 06K-907-425-V1.clb
   Part No SW: 3G0 906 259     HW: 06K 907 425 E
   Component: 2.0l R4 TFSI  H13 0004
   Revision: --H13---
   Coding: 091D00122464050B3000
   Shop #: WSC 05311 115 00319
   ASAM Dataset: EV_ECM20TFS0203G0906259 001007
   ROD: EV_ECM20TFS_VW48.rod
   VCID: 698CB5F1A9F98CBFDFB-803C
17176 - Databus
   Part No SW: 0D9 300 043 F    HW: 02E 927 770 AS
   Component: DQ250-6F MQB  H54 5202
   Revision: 06454104    Serial number: TFK01706282200
   Shop #: WSC 05311 115 00080
   ROD: EV_TCMDQ250021.rod
   VCID: 1D64D1212D31A01F633-8048
   Part No SW: 5Q0 614 517 CH    HW: 5Q0 614 517 AH
   Component: ESC           H62 0743
   Revision: 00000000    Serial number: 62097000001273
   Coding: 0EEC6A8F342423734779060940C84970562CC4E2600292753842F0B8C209420000000012121212B835351919323200
   Shop #: WSC 00015 115 08193
   ROD: EV_Brake1UDSContiMK100IPB_036.rod
   VCID: 79ACE5B1D9593C3F2FB-802C
   Part No SW: 3Q0 959 435 G    HW: 3Q0 959 435 G
   Component: VWKESSYMQB    037 0906
   Revision: 00037000    Serial number: 0448512768
   Coding: 1F20000723
   ROD: EV_KessyHellaMQBAB.rod
   VCID: 3E2636AD80F7DB075A9-806A
   Subsystem 1 - Part No SW: 3G0 962 243     HW: 3G0 962 243
   Component: GEB.F.Heckoef  H17 0812
   Serial number: ;8082872
   Part No SW: 5G0 907 044 DP    HW: 5G0 907 044 DP
   Component: Climatronic   H04 2001
   Revision: 00001K10
   Coding: 1102001420010001111550000010182A
   ASAM Dataset: EV_ACClimaBHBVW37X 006146
   ROD: EV_ACClimaBHBVW37X_006_VW27.rod
   VCID: 78AAE0B5E2532537505-802C
   Air quality sensor:
   Part No SW: 5Q0 937 086 BM    HW: 5Q0 937 086 BH
   Component: BCM PQ37BOSCH 034 0242
   Revision: --------    Serial number: 8658190717000C
   ROD: EV_BCMBOSCH_018.rod
   VCID: 06569E4D98A743C7529-8052
   Component: WWS    170630  042 0607
   Serial number:         170720040817
   Component: RLHS  042 0105
   Serial number: S9Y17M08D12H01M15S05
   Coding: 00A8DD
   Serial number: 20 04 2017  10000842
   Serial number: 000000000ZY1717013WM
   Serial number: 00000000000038729518
263442 - Siren / Alarm Horn for Anti-Theft Alarm System
          U90D757 F7 [008] - No Release by Immobilizer
527872 - Transport Mode Active
          U1105 00 [008] - -
   Part No SW: 5QA 919 294 B    HW: 5QA 919 294
   Serial number: 000308418617214
   Coding: 0471151811
   ROD: EV_EPHVA18AU3700000_009_VW48.rod
   VCID: 4BC06F79C3457EAFCD7-801E
   Part No SW: 3Q0 907 572 C    HW: 3Q0 907 572 C
   Component: ACC BOSCH MQB H04 0195
   Coding: 320067C259FFC428949C8045
   Shop #: WSC 05311 115 00414
   ROD: EV_ACCBOSCHVW48X.rod
   VCID: 35342981B5C1185F8B3-8060
   Serial number: 13071741350394
   ROD: EV_DRCONTITEMIC_VW27.rod
   VCID: 382A20B5A2D3E537905-806C
   Part No SW: 3Q0 959 655 BK    HW: 3Q0 959 655 BK
   Component: Airbag VW21   006 0703
   Revision: --------    Serial number: 003W6PF0Q87-
   Coding: 88CCC000000000005C5400CF000800000065
   Shop #: WSC 05314 000 00001
   ROD: EV_AirbaVW21TS6VW48X.rod
   VCID: 084A907592B355B7205-805C
   Belt Pretensioner left:
   Serial number: 3G1857705G0193R01259
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 3G1857706G0193R01068
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 454 002 707 17
   Serial number: 35700000000A502CA72K
   Subsystem 4 - Part No SW: -----------    HW: 454 002 707 17
   Serial number: 358000000003703CA72H
   Subsystem 5 - Part No SW: -----------    HW: 454 802 607 17
   Serial number: 3510047ECDC10000000T
   Subsystem 6 - Part No SW: -----------    HW: 454 802 507 17
   Serial number: 35200B315D4100000005
   Subsystem 7 - Part No SW: -----------    HW: 454 802 707 17
   Serial number: 35500BDEC9010000000U
   Part No SW: 5Q0 953 521 AF    HW: 5Q0 953 569 A
   Revision: FF033033    Serial number: 20170801100898
   Coding: 0010
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_SMLSVALEOMQB 001016
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 76B6EE8DE8475347429-8022
   Part No SW: 3G0 920 791 C    HW: 3G0 920 791 C
   Component: KOMBI         406 3193
   Coding: 07A401187F8C000801886B0B1001000080000000
   ROD: EV_DashBoardVDDMQBAB_VW48.rod
   VCID: 290CF5F169794CBF1FB-807C
16777008 - Function Restricted due to Interrupted Communications
          U1110 00 [009] - -
          [BAP_SWA_0x1A keine Kommunikation]
                    Reset counter: 132
                    Mileage: 3803 km
                    Date: 2018.01.21
                    Time: 16:09:17
16777010 - Function Restricted due to Interrupted Communications
          U1110 00 [008] - -
          [BAP_LDW_0x19 keine Kommunikation]
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 20:25:23
16776969 - Databus
          [LDW_02 keine Kommunikation]
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 20:22:51
16776982 - Databus
          [SWA_01 keine Kommunikation]
                    Reset counter: 132
                    Mileage: 3803 km
                    Date: 2018.01.21
                    Time: 16:10:52
   Part No SW: 3Q0 907 530 G    HW: 3Q0 907 530 C
   Component: GW MQB High   518 5304
   Serial number: 23071710803027
   Coding: 030300047F085900FB00025E9C0F00010001070000000000000000000000
   ROD: EV_GatewNF_VW48.rod
   VCID: 33301799BBB5066FA57-8066
   Serial number: 39170002047840047297
   Coding: 2DFFFF
   Serial number: 7588600000170728031B
   Analog clock:
   Serial number: 17000198431011
   Coding: 0800000000000000
   ROD: EV_ELVMarquMQBB.rod
   VCID: 71BCDD918129747F97B-8024
Address 36: Seat Mem. Drvr (J810)       Labels:* None
   Part No SW: 3Q0 959 760 B    HW: 3Q0 959 760 B
   Component: Sitzmemory    H05 0022
   Serial number: Y0006QGK25787
   Coding: 001000020000050081C280808080000000008181000000F400
   ASAM Dataset: EV_SeatMemorDriveSide 002021
   ROD: EV_SeatMemorDriveSide_002_VW48.rod
   VCID: 3A2E3ABD9CDFF727661-806E
   Serial number: 040717EG40809A
   Coding: 003F1A20D200028000000000
   VCID: 43D04759EB15B6EF357-8016
   Part No SW: 5Q0 909 143 P    HW: 5Q0 909 143 E
   Component: MQB_PP_APA    204 2051
   Revision: 00000000    Serial number: 0001892199
   Coding: 01000011004001
   Shop #: WSC 00015 115 00319
   ROD: EV_SteerAssisVWBSMQBA_009_VW48.rod
   VCID: 40DA4855FA03ADF7285-8014
3158336 - Databus
          [Ausfall der CAN-Botschaft "HCA_01" des Frontsensorik-SG (über GW)]
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 21:25:39
                    valid
   Part No SW: 3Q0 907 338     HW: 3Q0 907 338
   Component: FCM MQB Low   002 0286
   Serial number: 02081710522509
   Coding: 000000060100034A06004F01020000000000000000000000000000000000
   Shop #: WSC 05311 000 08193
   ROD: EV_MultiModulContiVW48X.rod
   VCID: 72BED29D842F4F676E1-8026
   Subsystem 1 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo links  H02 0003
   Coding: E02400
   Subsystem 2 - Part No SW: 3G0 941 329 _    HW: 3G0 941 329 _
   Component: Leimo rechts  H02 0003
   Coding: E02400
0033 - Left/Right Driving Switch-Over Active
          C1080 00 [009] -  -
                    Reset counter: 12
                    Mileage: 345 km
                    Date: 2017.11.11
                    Time: 12:02:44
   Serial number: 070717EG528109
   Coding: 003F1020DE00028200000000
   VCID: 42DE425DF40FBFE73E1-8016
Address 5F: Information Electr. (J794)       Labels:| 5G0-035-MIB-HGH2.clb
   Part No SW: 5NA 035 045 A    HW: 5NA 035 045
   Component: MU-H-N-RW     H54 1121
   Serial number: A849G0HS006223
   Coding: 02840103FF00000051220001001828001F0100E4012004009F
   ROD: EV_MUHig4CGen2HBAS_VW48.rod
   VCID: 36362E8DA8C71347829-8062
   Subsystem 1 - Part No SW: 5G6 919 606     HW: 5G6 919 606
   Component: ABT_High-2  H50 9130
   Serial number: VWZ6ZJT1945457
   Subsystem 2 - Part No SW: V03 959 801 EC    HW: -----------
   Component: ROW 2017  --- 0062
   Component: Gracenote2  --- 4012
7193 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Lane departure warning: heading control (0x19) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 21:04:02
                    Voltage terminal 30: 12.1 V
                    BAP-BAP_Function_ID: 02
7201 - Function Restricted due to Missing Message(s)
          U1111 00 [008] - -
          [Road sign display (0x21) - function restriction due to communication error - BapErr_retry not successful]
                    Reset counter: 188
                    Mileage: 4204 km
                    Date: 2018.01.27
                    Time: 13:29:15
                    Voltage terminal 30: 12.5 V
   Coding: 0184010162002017000040
   ROD: EV_CamSysRVRVCPANAMQBAB.rod
   VCID: 392C25B199D9FC3F6FB-806C
   Part No SW: 5Q0 959 107 K    HW: 5Q0 959 107 H
   Component: HDSG-Modul    H13 0261
   Revision: --------    Serial number: 31384133100000
   Coding: 0108
   ROD: EV_DeckLidCONTIAU736_VW27.rod
   Component: MQB_B_MFK     H08 0272
   Serial number: 27071711P10448
   Coding: 0004080100000101002223448156A90090000E300140
   ROD: EV_MFKBoschMQBB_VW27.rod
   VCID: 3C223CA596EBC91774D-8068
0659 - Steering
          U4E6652 F2 [008] - Lane-Holding Assistance Not Coded
          [HC_interface_at_the_steering_not_activated]
                    Reset counter: 169
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 20:26:25
                    Control Module temperature: 46 °C
                    Outside air temperature: 24.5 °C
                    Vehicle speed: 0.00 km/h
                    System run time: 2448.2 s
                    Voltage terminal 15: 11.9 V
                    mid: 02 A6
                    Status of camera: operational
                    Engine_Running_Info: 0
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
   Serial number: 190617EFJ18296
   Coding: 000E10200100028000000000
   VCID: 45D45941E52188DF1B3-8010
   Serial number: 190617EFJ1613A
   Part No SW: 4M0 907 594 K    HW: 4M0 907 594
   Coding: 608000748101
   ROD: EV_SunRoofCONTIAU736.rod
   Part No SW: 7PP 941 572 AB    HW: 7PP 941 572 A
   Component: LED1L         H09 0003
   ROD: EV_LEDModLeftMELCOAU736_VW48.rod
   VCID: 1676CE0DC807F347A29-8042
   Component: LED1R         H09 0003
End----------(Elapsed Time: 02:34, VBatt start/end: 12.3V/12.3V)-----------
hadez16
C?ID=289891
Video in Motion and Traffic Jam assist is not possible with VCDS
   #49
fschaeffer
Brazil
C?ID=320941
Hi Mauricio
I'm also from Brazil and managed to unlock Video in Motion on my 2018 Passat. But I used another device - OBD11.
If you are in Sao Paulo, I can help you or you can just buy the device abroad.
Cheers
   #50
TBAx
C?ID=287144
On a MY 2018 Passat? Lucky you, I heard from other people that OBD11 creates problems on those MIB2 units; having those devices reboot randomly.
Well, maybe they fixed that.
   #51
mauriciospilere
Brazil
C?ID=313275
Hi Mauricio
Cheers
I´m at Floripa and the tip helps a lot. Tks
   #52
mauriciospilere
Brazil
C?ID=313275
Hey Guys,
That´s my scan:
   Revision: --H13---
17176 - Databus
   Coding: 1F20000723
   Revision: 00001K10
   Air quality sensor:
   Coding: 00A8DD
          U1105 00 [008] - -
   Coding: 0471151811
   Coding: 80000D
   Coding: 80000D
   Coding: 0010
          U1110 00 [009] - -
                    Reset counter: 132
                    Mileage: 3803 km
                    Date: 2018.01.21
                    Time: 16:09:17
          U1110 00 [008] - -
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 20:25:23
16776969 - Databus
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 20:22:51
16776982 - Databus
                    Reset counter: 132
                    Mileage: 3803 km
                    Date: 2018.01.21
                    Time: 16:10:52
   Coding: 2DFFFF
   Analog clock:
3158336 - Databus
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 21:25:39
                    valid
   Coding: E02400
   Coding: E02400
          C1080 00 [009] -  -
                    Reset counter: 12
                    Mileage: 345 km
                    Date: 2017.11.11
                    Time: 12:02:44
          U1111 00 [008] - -
                    Reset counter: 171
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 21:04:02
          U1111 00 [008] - -
                    Reset counter: 188
                    Mileage: 4204 km
                    Date: 2018.01.27
                    Time: 13:29:15
   Coding: 0108
0659 - Steering
                    Reset counter: 169
                    Mileage: 3795 km
                    Date: 2018.01.20
                    Time: 20:26:25
                    mid: 02 A6
                    Software_Info_4: 2
                    Software_Info_3: 7
                    Software_Info_2: 2
                    Software_Info_1: 0
By the way, when activing the active lane assist i turned on the option of side assist at active display. Anyone can help me on where i can take out this option of the dashboard, cause my car dont have the side assist hardware.
   #53
PT_operator
Hungary
C?ID=118075
Hey Everyone
I just tried to activate DLA on my 2016 oct Passat B8 (Lane and front assist are OEM installed, also has LED II headlight with dynamic corner light) but according the following description (https://www.ascoding.ch/en/activate-dynamic-light-assist-dla-mj-2017/) but I faced some problems:
In modul 09 central electric I'm not allowed to change Byte 02 to hex 0E (no labeling) as it says it is out of range. I do it in long coding simply changing Byte 02 to 0E. How it should be done normally?
I could change the Fernlich Assistent (Menusteuerung Fernlichtassistent and Menusteuerung Fernlichtassistent Werkeinstellung) to present but the DLA menu did not pop up in CAR menu/Lighting.
I can manage to do all other changes except Modul 55 byte 04 bit 6 (Maskiertes Dauerfahrlicht MDF aktiv). There is no bit 6 avaible, only 5 bits I can see.
Do you may have any idea what do I do wrong?
THanks in advance guys!
   #54
TBAx
C?ID=287144
I always die a little inside, when someone says a bit is "not there". Just because VCDS does not have a label for this, it doesn't mean it is missing. You just have to set it manually using the binary field in LCode.
However, when the coding in 0x09 is all zeroes, just modify the adaption values using the default login:
> Fernlicht_Assistent-Erweiterte Fernlichtsteuerung > AFS: FLA: Fernlicht (GLW:MDF)
> Fernlicht_assistent-Assistenzfahrlicht: Empfindlichkeit per BAP einstellbar > present
> Fernlicht_Assistent-Menüsteuerung Fernlichtassistent > present
> Fernlicht_Assistent-Menüsteuerung Fernlichtassistent Werkseinstellung > present
PT_operator
Hungary
C?ID=118075
Thanks a lot for the quick respone. You're right, I'll try that way.
'However, when the coding in 0x09 is all zeroes, just modify the adaption values using the default login:'
What do you mean under '0x09 is all zeroes' - does this mean simply skip no labeling=changing byte 02 to hex0E?
hadez16
C?ID=289891
Right. Model year 17 upwards does not have any coding in Unit 09 anymore.
Everthing went to adaptation channels.
The instructions you linked also states "up to MY 17"! This does not include MY17.
For absolute correct statements, please post a full Auto-Scan.
PT_operator
Hungary
C?ID=118075
I will post full Auto-Scan however I have doubts my car would be MY17 as I have Modul 55 and cannot find modul 4B (however I have HEX-CAN cable not HEX-V2 type and I'm not sure if it can handle modul 4B) - furthermore first registration of my car is october 2016.
   #58
PT_operator
Hungary
C?ID=118075
Finally I succeed to activate DLA: you were right simply just switching on bit manually finally made the system work - thanks for your hint.
By the way: as a next challange I'd like to activate traffic jam assist but I could not find anything about it on forums. Did anyone try it?
   #59
hadez16
C?ID=289891
Yes but it's not possible with VCDS.
