Finally joined (with Mk.2 Tiguan)
welshkaiboy
H11-2H
So does it look like my NOX sensor is duff? I hope it shows up on VW VAS scanner.
   #22
welshkaiboy
H11-2H
Just as an update dealer VAS is saying there is no NOX sensor error recorded.
   #23
Did you get an actual print-out or did they just clear it and tell you all is well? ;)
Is it still there in VCDS? If so, uncheck "Use Aggressive Mode" in VCDS and let us know if it's still there.
welshkaiboy
H11-2H
The guy came out and showed me the printouts (very helpful in fact) told me my alarm issue is still there and needs to be booked in for further diagnosis. I won't be able to scan the car until later today but I will try as suggested Uwe.
In fact if you look at 09 module in my latest scan there is no alarm error but it was clear on the VAS printout. If you look at my original scan when I joined the alarm error is present.
I will do an aggressive scan and AS unticked.
welshkaiboy
H11-2H
OK so as I had a recall ABS update so you will see 03 has changed and all errors are cleared after update. The NOX issue has gone but if you compare the above scan there is no alarm issue in 09 (this has been there since day one) so not sure why it wasn't picked up. Tonights scan is only showing 09 alarm issue.
AGG
Monday,29,May,2017,21:40:49:09667
VCDS Version: 17.4.2.3 (x64)
Data version: 20170505 DS270.4
License Plate: MK2TIGNONAGG
Mileage: 13380km-8313mi   Repair Order:
Chassis Type: 5N (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 42 44 52 5F A5
Mileage: 13380km-8313miles
Address 01: Engine (J623-DFGA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 026 EE    HW: 04L 907 309 M
   Component: R4 2.0l TDI   H23 2100
   Revision: B4H23---
   Coding: 0119001203251D082000
   ASAM Dataset: EV_ECM20TDI01104L906026EE 001003
   ROD: EV_ECM20TDI01104L906026HS_001_VW37.rod
   VCID: 71C70E52A08CD9CFF3-8024
   Part No SW: 5Q0 614 517 CE    HW: 5Q0 614 517 AC
   Component: ESC           H25 0413
   Revision: 00000000    Serial number: 60986000000722
   Coding: 0AEE929A34210B6D477B060462C64950492CD0E2604692713060F078C0224200002E64121A03102F35351919323200
   ROD: EV_Brake1UDSContiMK100IPB_036_VW27.rod
   VCID: 76CD3D4EC9E2FEF726-8022
Address 08: Auto HVAC (E87)       Labels: None
   Part No SW: 5NC 907 044     HW: 5NC 907 044
   Component: AC Automat    H34 3902
   Revision: 20K07000    Serial number: 00000B00101230
   Coding: 00120104202110011105104C00101102
   ASAM Dataset: EV_ACClimaPrehVW37X 002013
   VCID: 7EDD256EE1D2B6B77E-802A
   Subsystem 1 - Part No SW: 3G0 907 049 E    HW: 3G0 907 049 E
   Component: E265KlimaHeck  H02 0201
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 084 BP    HW: 5Q0 937 084 BP
   Component: BCM MQBAB M+  H32 0212
   Serial number: 00021524300004
   Coding: 03000946C24102FB0BA44080B11407081080000000000000000000000000
   ASAM Dataset: EV_BCMMQB 016001
   ROD: EV_BCMBOSCH_016_VW37.rod
   VCID: 0733408ABE08F77F4D-8052
   Subsystem 1 - Part No SW: 5NC 955 119     HW: 5NC 955 119   Labels: 1KX-955-119.CLB
   Component: 326 RL 160318  033 0372
   Serial number: 00000001603160301622
   Component: RLHS  037 0059
   Serial number: S3Y16M04D21H21M04S13
   Coding: 06A8DD
   Serial number: 000000000ZY160322AA5
   Component: Sirene, DWA  005 0313
   Serial number: 00000000000065024289
262912 - Sensor for Anti-Theft Alarm System
          U90EA55 F5 [008] - Alert Emergency Activation Stage 1
                    Fault Frequency: 18
                    Reset counter: 62
                    Mileage: 13200 km
                    Date: 2017.05.27
                    Time: 12:19:17
Address 10: Park/Steer Assist (J446)       Labels: 5Q0-919-294.clb
   Part No SW: 3Q0 919 294     HW: 3Q0 919 294
   Component: PDC 8 Kanal   H07 0152
   Serial number: 002203167478020
   Coding: 0071051001
   ASAM Dataset: EV_EPHBO18VW3260000 007013
   ROD: EV_EPHBO18VW3260000_007_VW37.rod
Address 13: Auto Dist. Reg (J428)       Labels: 2Q0-907-572.clb
   Part No SW: 2Q0 907 572 H    HW: 2Q0 907 572 B
   Component: ACCCONTIMQB   H01 0155
   Coding: 2A00404150FF8728749C806D004087
   ASAM Dataset: EV_ACCMRRCONTIVW376 001010
   ROD: EV_ACCMRRCONTIVW376_001_VW37.rod
   VCID: 3957F672B87C518F0B-806C
   Part No SW: 5Q0 959 655 AD    HW: 5Q0 959 655 AD
   Component: AirbagVW21    005 0130
   Serial number: 003NMR1NW0AC
   Coding: 98CCC0C00C0000005C5400CF00C800000065
   ASAM Dataset: EV_AirbaVW20SMEVW37X 002146
   VCID: 0225519E952AD2571A-8056
   Belt Pretensioner left:
   Serial number: 5NC857705C0111Q00025
   Coding: 80000D
   Belt Pretensioner right:
   Serial number: 5NC857706C0111Q00245
   Coding: 80000D
   Subsystem 3 - Part No SW: -----------    HW: 480 001 504 16
   Serial number: 3570000000095420E91G
   Subsystem 4 - Part No SW: -----------    HW: 480 002 004 16
   Serial number: 35800000000A329CBA1V
   Subsystem 5 - Part No SW: -----------    HW: 480 401 904 16
   Serial number: 3510001992080C22264N
   Subsystem 6 - Part No SW: -----------    HW: 480 401 904 16
   Serial number: 3520001992080C24E72.
   Subsystem 7 - Part No SW: -----------    HW: 480 401 304 16
   Serial number: 3550001C52080C26B42Z
   Pedestrian Protection Driver:
   Subsystem 8 - Part No SW: -----------    HW: 480 401 904 16
   Component: PedP_Sensor_D  000 6149
   Serial number: 2280001B52080C26054P
   Subsystem 9 - Part No SW: -----------    HW: 480 401 904 16
   Component: PedP_Sensor_P  000 6149
   Serial number: 2290001B92080C2326E/
   Pedestrian Protection Center:
   Subsystem 10 - Part No SW: -----------    HW: 480 401 904 16
   Component: PedP_Sensor_C  000 6149
   Serial number: 2300001B7209F106D49/
   Subsystem 11 - Part No SW: -----------    HW: 480 001 104 16
   Serial number: I0M0000000016638B91%
   Subsystem 12 - Part No SW: -----------    HW: 480 001 104 16
   Serial number: I0N0000000077638B917
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 FC    HW: 5Q0 953 569 B
   Component: Lenks.Modul   100 0205
   Revision: FF034034    Serial number: 20160303500912
   Coding: 0C00
   ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
   ROD: EV_SMLSVALEOMQBLRH_VW37.rod
   VCID: 78D13376C3F6888734-802C
   Part No SW: 5NA 920 951     HW: 5NA 920 951
   Component: KOMBI         308 6430
   Coding: 27A501006384260001886A031401000000000000
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1244
   Revision: --------    Serial number: 0004714076
   Coding: 030100041F087300FB00024C080F00010001050000000000000000000000
   ROD: EV_GatewLear_013_VW37.rod
   VCID: 79D73672F8FC918F4B-802C
   Subsystem 2 - Part No SW: 5TA 959 442 A    HW: 5TA 959 442 A  Labels: 3C8-959-537.CLB
   Serial number: 0831600260400045AM2B
   Coding: 2A0000
   Subsystem 3 - Part No SW: 5QA 915 181 B    HW: 5QA 915 181 B
   Component: J367-BDMHella  H10 9052
   Serial number: 8614749903
   Serial number: 220316ECG11866
   Coding: 00310220D001048000001000
   VCID: 43AB949ACAB01B5F51-8016
   Serial number: 00000000000009624994
   Coding: 0D0000
   Component: EPS_MQB_ZFLS  128 1072
   Coding: 1107
   ROD: EV_SteerAssisMQB_013_VW37.rod
   VCID: 45AF8A82C484256F7F-8010
   Serial number: 020416ED127785
   Coding: 00310020DE01048000001000
   VCID: 42A5919ED5AA12575A-8016
   Serial number: 00000000000009663057
   Coding: 050000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 874 A    HW: 3Q0 035 874 A
   Component: MU-S-ND-ER    820 0624
   Coding: 02730601FF00000051111101008808001F0100C6012001008F
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3041CB566B0690C7BC-8064
   Component: ABT_High  H63 0032
   Serial number: VWZ8Z9SKL00RE3
   Subsystem 2 - Part No SW: 3G0 919 866 AQ    HW: -----------
   Component: ECE1 2017  --- 0730
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3Q0-980-65X-A5.clb
   Part No SW: 3Q0 980 654 F    HW: 3Q0 980 654
   Component: MQB_B_MFK     H06 0220
   Serial number: 15041611P20577
   Coding: 0003070600000401000213448040A10094000E000020
   ROD: EV_MFKBoschMQBB_VW36.rod
   VCID: 3A55E97EBD7A5A9702-806E
End---------------------(Elapsed Time: 03:32, udsna)-----------------------
Non agg
   Revision: B4H23---
   Coding: 06A8DD
                    Fault Frequency: 18
                    Reset counter: 62
                    Mileage: 13200 km
                    Date: 2017.05.27
                    Time: 12:19:17
   Coding: 0071051001
   Coding: 80000D
   Coding: 80000D
   Coding: 0C00
   Coding: 2A0000
   Coding: 0D0000
   Coding: 1107
   Coding: 050000
   #26
welshkaiboy
H11-2H
I will give a couple of weeks and will rescan the car. Car has to go in for alarm to be fixed anyway. Just that bloody 09 SA now so I can add rain closing.
   #27
welshkaiboy
H11-2H
I have been informed that the software in my 09 is an early version (interim/beta) and will not work with the usual 31347 SA. So either I just accept I can't get in to make changes or I ask VW when they fix the alarm problem to update the BCM.
Anyone know what interim SA's have been used in the past?
   #28
Cmoyung
Hong Kong
Hi Welshkaiboy, did you finally find out the Sa code for module 9? Mine is Tiguan2 2016 which is also one of demo car. The access code 31347 doesn't work for mine.
   #29
Cmoyung
Hong Kong
   #30
welshkaiboy
H11-2H
Even VW tech cannot make changes, this is closely controlled by VW who in the future may flash with latest code but unknown if ever.
It means things I want change are on hold until such time.
The alarm issue is also known by VW and as it has a no impact on fit form or function again VW in the future may flash with latest code but unknown if ever.
The tech had VCDS, I had a quiet discussion on several points but the bottom line is VW hold all the keys.
