Passat 3C ABS coding after Engine Retrofit
abo hmzh
Jordan
C?ID=77823
hi all
i have coding abs j104 for passat b6 2009
vin nmber for car wvwzzz3cz9p028377
im replace ecu and Engines from 2000cc tsi to 2000ccfsi
Sunday,16,October,2016,17:52:30:50562
VCDS Version: 16.8.1.1 (x64)
Data version: 20160902 DS256
VIN: WVWZZZ1KZ6M828682   License Plate:
Chassis Type: 1K (3C0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 42 44 46 52 53 55 56 62
          72
VIN: WVWZZZ1KZ6M828682   Mileage: 58240km-36188miles
15-Airbags -- Status: Malfunction 1010
   Part No SW: 06F 906 056 EK    HW: Hardware No
   Component: MED9.5.10       G00 9150
   Revision: --H03---    Serial number: VWZ7Z0F3786172
   Coding: 0000075
   Shop #: WSC 00066 000 00000
   VCID: 76E805300102BFF282-8022
7 Faults Found:
050197 - Implausible Data Received from ABS Control Module
               U0415 - 008 -
                    Fault Status: 01101000
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:36:52
                    RPM: 720 /min
                    Load: 51.0 %
                    Temperature: 86.0°C
000152 - Intake Air Temperature Sensor 2 (G299)
               P0098 - 002 - Signal too Low
                    Fault Status: 01100010
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:36:52
                    RPM: 720 /min
                    Load: 51.0 %
                    Temperature: 86.0°C
005161 - Circuit for Brake Vacuum Pump
               P1429 - 004 - Open Circuit
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:36:52
                    RPM: 720 /min
                    Load: 48.6 %
                    Temperature: 86.0°C
006418 - Pressure Sensor for Brake Boost (G294)
               P1912 - 001 - Short to Plus
                    Fault Status: 01100001
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:36:52
                    RPM: 680 /min
                    Load: 49.0 %
                    Temperature: 86.0°C
000080 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
               P0050 - 004 - Malfunction / Open Circuit - MIL ON
                    Fault Status: 11100100
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:37:14
                    RPM: 720 /min
                    Load: 51.0 %
                    Temperature: 88.0°C
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit - MIL ON
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:37:14
                    RPM: 720 /min
                    Load: 51.0 %
                    Temperature: 88.0°C
000406 - Engine Oil Temp. Sensor (G8)
               P0196 - 004 - Implausible Signal
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:37:53
                    RPM: 720 /min
                    Load: 51.0 %
                    Temperature: 87.0°C
Readiness: 1110 0101
   Part No SW: 09G 927 750 HC    HW: 09G 927 750 HC
   Component: AQ 250 6F           1175
   Revision: 00H76000    Serial number:
   Coding: 0000072
   Shop #: WSC 00028 028 00001
   VCID: 79F20E0C301CD08AEF-802C
                    Fault Status: 00101101
                    Fault Frequency: 76
                    Reset counter: 0
01680 - ABS Wheel Speed Signal; Front Right
            013 - Check DTC Memory
                    Fault Frequency: 76
                    Reset counter: 0
   Part No SW: 3C0 614 109 P    HW: 3C0 614 109 P
   Component: J104    C4 440 V2   0011
   Revision: --025---    Serial number: 00000785935269
   Coding: 0000367
   VCID: 2B5EE4448AC0B21A2D-807E
            000 -  -
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:35:37
                    Speed: 1.0 km/h
                    Hex Value: 0x0024
                    Voltage: 14.00 V
                    Bin. Bits: 00011110
                    Count: 199
                    Hex Value: 0x0000
            000 -  -
                    Reset counter: 205
                    Hex Value: 0x0000
                    Voltage: 12.75 V
                    Bin. Bits: 00011110
                    Count: 149
                    Hex Value: 0x0000
00285 - ABS Wheel Speed Sensor; Front Right (G45)
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:35:45
                    Speed: 16.0 km/h
                    Hex Value: 0x0026
                    Voltage: 13.75 V
                    Bin. Bits: 00011110
                    Count: 17
                    Hex Value: 0x0000
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:35:45
Address 08: Auto HVAC        Labels: 3C0-907-044.lbl
   Part No SW: 3C0 907 044 DA    HW: 3C0 907 044 DA
   Component: ClimatronicPQ46 132 0811
   Revision: 00132023    Serial number: 00000000000000
   VCID: 63CE4C64A2903A5AD5-8036
8 Faults Found:
            009 - Open or Short to Ground
                    Fault Status: 01111001
                    Fault Frequency: 15
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 00:04:23
00538 - Reference Voltage
            002 - Lower Limit Exceeded
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:39:21
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 01:39:21
01809 - Actuating Motor for Temperature Flap; Left (V158)
            000 -  -
                    Fault Status: 01110000
                    Fault Frequency: 8
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 00:04:23
01810 - Actuating Motor for Temperature Flap; Right (V159)
            000 -  -
                    Fault Frequency: 8
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 00:04:23
01272 - Positioning Motor for Central Flap (V70)
            000 -  -
                    Fault Frequency: 8
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 00:04:23
00710 - Defroster Flap Positioning Motor (V107)
            000 -  -
                    Fault Frequency: 8
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 00:04:23
            000 -  -
                    Fault Frequency: 8
                    Reset counter: 205
                    Mileage: 58247 km
                    Date: 2016.08.29
                    Time: 00:04:23
Address 09: Cent. Elect.
Unable to communicate with address 09. Are you sure the doors are unlocked?
Monday,19,December,2016,06:28:49:50562
Mileage: 58240km-36188mi   Repair Order:
          72
03-ABS Brakes -- Status: Not registered 0011
15-Airbags -- Status: Sporadic communication error 1000
   Coding: 0000075
12 Faults Found:
               U0415 - 008 -
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:28:23
                    RPM: 720 /min
                    Load: 58.0 %
                    Temperature: 72.0°C
               P0098 - 002 - Signal too Low - MIL ON
                    Fault Status: 11100010
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:28:23
                    RPM: 720 /min
                    Load: 57.6 %
                    Temperature: 72.0°C
005668 - MIL Request Signal Active (Check TCM for errors too!)
               P1624 - 008 -  - Intermittent
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:28:24
                    RPM: 720 /min
                    Load: 57.2 %
                    Temperature: 72.0°C
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:28:24
                    RPM: 720 /min
                    Load: 58.0 %
                    Temperature: 72.0°C
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:28:24
                    RPM: 680 /min
                    Load: 58.8 %
                    Temperature: 72.0°C
049441 - No Communication with ABS Brake Control Module
               U0121 - 008 -  - Intermittent
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:29:26
                    Load: 0.0 %
                    Temperature: 76.0°C
001281 - Vehicle Speed Sensor
               P0501 - 004 - Implausible Signal
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 04:29:26
                    Load: 0.0 %
                    Temperature: 76.0°C
049489 - No Communications with Airbag Control Module
               U0151 - 008 -  - Intermittent
                    Load: 0.0 %
                    Temperature: 77.0°C
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:01:02
                    Load: 0.0 %
                    Temperature: 78.0°C
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:06:10
                    RPM: 720 /min
                    Load: 58.0 %
                    Temperature: 78.0°C
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:06:12
                    RPM: 720 /min
                    Load: 58.0 %
                    Temperature: 78.0°C
001393 - Brake Switch (F)
               P0571 - 008 - Implausible Signal
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:09:00
                    Load: 0.0 %
                    Temperature: 81.0°C
   Part No: 09G 927 750 FB
   Component: AQ 250 6F           0844
   Coding: 0000008
   Shop #: WSC 51060 981 63401
   Coding: 0000367
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
                    Hex Value: 0x0000
                    Voltage: 13.75 V
                    Bin. Bits: 00011110
                    Count: 199
                    Hex Value: 0x0000
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:12:23
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011110
                    Count: 149
                    Hex Value: 0x0000
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:12:23
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
                    Fault Status: 01101101
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:12:26
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
   Revision: 00H54000    Serial number: 00000005930235
   Coding: 03868F0700041000470A00000F000000000B5D435C000900000000000000
   VCID: 336EFC2452F0EADA65-8066
   Subsystem 1 - Part No: 3C1 955 419 A  Labels: 1KX-955-119.CLB
   Component: Wischer 300608 003  0205
   Coding: 00046997
   Shop #: WSC 00028
                    Fault Status: 01101100
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:07:00
                    Voltage: 13.95 V
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:07:00
                    Voltage: 13.95 V
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:08:00
                    Voltage: 12.60 V
            010 - Open or Short to Plus
                    Fault Status: 01101010
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:08:00
                    Voltage: 12.60 V
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:08:00
                    Voltage: 12.60 V
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475     HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0007
   Revision: --------    Serial number: 97530823101500
   Coding: 100102
   VCID: 71E2362CA86C98CA57-8024
16347 - Control Module - EEPROM Error
            014 - Defective
                    Fault Status: 01101110
                    Reset counter: 0
                    Mileage: 39391 km
                    Date: 2013.02.12
                    Time: 06:58:08
                    Temperature: 0.0°C
Address 15: Airbags        Labels: None
   VCID: 55AA62BCBCC4D4EAAB-8000
7 Faults Found:
01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257)
                    Fault Status: 11100101
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:13:56
01638 - Crash-Sensor for Side Airbag; Rear Drivers Side (G256)
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:13:56
01222 - Crash Sensor Side Airbag; Passenger Side (G180)
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:13:56
01221 - Crash Sensor Side Airbag; Driver Side (G179)
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:13:56
01656 - Crash Signal
            009 - Open or Short to Ground - MIL ON
                    Fault Status: 11101001
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:13:56
00003 - Control Module
            014 - Defective - MIL ON
                    Fault Status: 11101110
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:14:46
00149 - End of Line Programming not Completed
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:14:46
   Part No SW: 3C0 953 549 AC    HW: 3C0 953 549 AC
   Component: J0527               0020
   Revision: 00026000    Serial number: 3C5953507AR
   Coding: 0001111
   VCID: 6DDA2A5C74547C2A73-8038
   Part No SW: 3C0 920 871 D    HW: 3C0 920 871 D
   Component: KOMBIINSTRUMENT VD1 2416
   Revision: V0002000    Serial number: 00000000000000
   Coding: 0007605
   Shop #: WSC 00000 000 123456
   VCID: 254A127CEC24846AFB-8070
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:49
                    Reset counter: 246
Address 19: CAN Gateway        Labels: 3C0-907-530-V2.clb
   Part No SW: 3C0 907 530 H    HW: 3C0 907 951
   Component: J533__Gateway   H13 0142
   Revision:   H13       Serial number: 2600P087250571
   Coding: F5A1FF060002021000
   VCID: 2648157091228F72F2-8072
            000 -  -
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:08:16
                    Reset counter: 246
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:12:05
   Part No SW: 3C0 959 799 G    HW: 3C0 959 799 G
   Component:    IMMO         070 0383
   Revision: 00070000    Serial number: VWZCZ000000000
   VCID: 3D7ADA1C64B42CAA83-8068
   Component:    ELV          027 0380
   3C0905861G     ELV          027 0380
Address 36: Seat Mem. Drvr        Labels: 3C0-959-760.lbl
   Part No SW: 3C0 959 760 E    HW: 3C0 959 760 E
   Component: Sitzverstellung     1101
   Revision: 00005000    Serial number: 00000000000000
   VCID: 2F66F054BED8CE3A01-807A
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MAX3.lbl
   Part No SW: 1K0 959 701 AE    HW: 1K0 959 793 P
   Component: J386  TUER-SG FT    1517
   Revision: 71009005    Serial number: 00000017488715
   Coding: 0004535
   VCID: 71E2362C686C98CA57-8024
                    Fault Status: 01100101
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:49
   Part No SW: 5N1 909 144 G    HW: 5N1 909 148 F
   Component: J500__APA-BS KL.082 0401
   Revision: 1AH02234    Serial number: 00081470235702
   Coding: 0000258
   VCID: 3668C5304182FFF242-8062
02546 - Steering Limit Stop
                    Reset counter: 206
                        Term 15 On
                    (no units): 4.0
                    Voltage: 12.30 V
00566 - Steering Assistance Operation
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:50
                    Hex Value: 0x7301
                    Hex Value: 0x7601
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Hex Value: 0x0000
                    Reset counter: 206
                    (no units): 4.0
                    Steering Angle: 0.00°
                        Not OK
                    (no units): 0
Address 46: Central Conv.        Labels: 3C0-959-799-46.clb
   Component: 01 KESSY PQ46 R 070 0227
   Coding: 01910A0001C60E76300494157000CF0B60780103242480
   Shop #: WSC 08224 211 56823
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MAX3.lbl
   Part No SW: 1K0 959 702 AE    HW: 1K0 959 792 P
   Component: J387  TUER-SG BT    1517
   Revision: 71009005    Serial number: 00000533488724
   Coding: 0004534
   VCID: 72E039206D6AA3D2AE-8026
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:49
01735 - Potentiometer for Mirror Adj. Horizontal; Pass. Side
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:51
01737 - Potentiometer for Mirror Adj. Vertical; Pass. Side
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:04:51
   Part No SW: 3C8 907 801 A    HW: 3C8 907 801 A
   Component: J540 EPB3  VW-10498 0003
   Revision:   009       Serial number: 00000000112234
   Coding: 0000057
   VCID: 28541B489B369902C0-807C
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:14:52
                    Voltage: 11.80 V
                    Count: 76
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
            000 -  -  - MIL ON
                    Fault Status: 11110000
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 01:05:50
                    Voltage: 10.80 V
                    Count: 103
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:14:52
                    Voltage: 11.80 V
                    Count: 76
                    Hex Value: 0x1270
                    Hex Value: 0x0001
                    Hex Value: 0x0101
   Component: AFS-Steuergeraet    0133
   Coding: 2311169
   VCID: 346CFF3857FEEDE27C-8060
   Subsystem 1 - Part No: ID-L fehlt    Labels: ID-55-01.CLB
   Component: AFS-Lst.-Modul l    ....
   Coding: 00000255
   Subsystem 2 - Part No: 7L6 941 329 A  Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0002
   Coding: 00000035
02233 - Left Headlight Power Output Stage (J667)
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:10:22
                    Voltage: 12.21 V
                        ABS 1
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 206
                        Invalid
                        Invalid
                        Invalid
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 206
                        Invalid
                        Invalid
                        Invalid
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 206
                        Invalid
                        Invalid
                        Invalid
01539 - Headlights Not Adjusted
                    Reset counter: 206
                        Invalid
                        Invalid
                        Invalid
02628 - Sensor for Swivel Module Position; Right
            007 - Short to Ground - MIL ON
                    Fault Status: 10100111
                    Reset counter: 206
                    Mileage: 58249 km
                    Date: 2016.08.30
                    Time: 00:14:40
                    Voltage: 12.07 V
                        ABS 1
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  036 0130
   Revision: 00000001    Serial number: VWZ1Z3H3336090
   Coding: 0500040004
   VCID: 65CA527C6CA4446A3B-8030
   Part No SW: 1K0 959 703 AB    HW: 1K0 959 795 L
   Component: J388   TUER-SG HL   0308
   Revision: 41004101    Serial number: 00000000558602
   Coding: 0000144
   VCID: 70E43328636691C258-8024
   Part No SW: 1K0 959 704 AB    HW: 1K0 959 794 L
   Component: J389   TUER-SG HR   0308
   Revision: 41004101    Serial number: 00000000560510
   Coding: 0000144
End-------------------------(Elapsed Time: 02:22)--------------------------
Moved to Retrofits and changed title to be more descriptive.
dreke
Spain
C?ID=170515
I think for ABS 0000384 will do...
You have to recode your engine to 0000078 for use with DSG. The 0000075 is for manual gear.
Kind regards, dre
abo hmzh
Jordan
C?ID=77823
hi dreke
coding rejected
can any wan helpe my coding abs
golfi_vend
Tartu, Estonia
C?ID=195131
I use this method for ABS coding.
Your ABS extras code is 256. Start adding values to it, like 256, 257, 258 until no more "engine 000" faults.
Is your ECU modded?
