Sticky Acronyms
Sticky
   #21
Keithuk
Stoke on Trent, England
C?ID=122432
I've noticed that Technical Service Bulletins (TSB) and Technical Product Information (TPI) don't show up.
   #22
Now they do.
golfi_vend
Tartu, Estonia
C?ID=195131
BAP already has info sticker on it, why not DDP?
   #24
It does now! :)
Added FPR and TPMS.
How about:
MOST
RLS
RLFS
RLHS (that was from a UDS PQ25 RoW Polo scan recently but I hadn't noticed it until 2014 scans)
DSG
TPI
Hey guys,
TPI made it already but any objections to the other ones?
   #27
I'm disinclined to do MOST because the software doesn't seem to be case sensitive and I really don't want it to jump on that word most of the time. ;)
I'm not sure how I missed the others; I've added 'em now.
jakematic
NC USA
C?ID=129085
GFF perhaps explaining the equivalent in VCDS
   #29
Added GFF. A failed attempt by VW to allow trained monkeys to fix cars instead of requiring intelligent technicians.
   #31
SBC Auto
C?ID=238403
Following on from the post Andyvee made in the MIB2 thread here is a list from 5f that is not in the main "common acronyms" list. Any ideas??
VPS
SWA
ENI
HCA (from LDW_HCA)
VPS
   #32
Eric
HC800000
From MLB gateway coding:
IVB, KL, HSP, AV, RWB, eBKV
AGK, VAQ, PreCrash
SAK, MO_StSt, AMB, AGA
Freilauf, MO, GE, ALR, MO_BZS, DR
AEB, FCWO, FCWP, QS, SCU, HAL, NR, MXB
I have a vague idea what Freilauf and Precrash might do, but the others :banghead:
   #34
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Freilauf = DSG's disengage the clutch when free-wheeling to save fuel
Won't add that one to the WIKI as it's not an actual Acronym. ;) You should find LDW/HCA, SWA/LCA, eBKV and a few other documented now. MXB is likely written MxB? If so, it's the combination of MQB & MLB platform.
   #36
hadez16
C?ID=289891
Anyone on FCWP?
   #37
NEtech
Denmark
C?ID=56995
Maybe: "Forward Collision Warning Pedestrian"
   #38
hadez16
C?ID=289891
Could make sense...thanks ;)
   #39
hadez16
C?ID=289891
(A)STA???
Camera coding: STA
Towing unit: ASTA
Whats that?
   #40
I'm not sure but in 69-Trailer the Selective Output Test shows ASTA_sensor_function_test as if that's a sensor.
Similar RODs show Adv MVBs such as:
[*IDE12009-IDE09554*] Anhängelast- und Stützlasterkennung: Werte - Spannungsversorgung [ASTA Trailer weight nose weight detection value - ASTA-Spannungversorgung]
[*IDE12009-MAS01561*] Anhängelast- und Stützlasterkennung: Werte - Einheit [ASTA Trailer weight nose weight detection value - Einheit]
Kilogramm (kg)
Pfund (lbs)
Fehler
nicht codiert / nicht verbaut
Messwert nicht verfügbar​
Do newer models have an optional trailer tongue weight sensor (or strategy built into the chassis control module that allows evaluation of the trailer load based on on the rear axle height and sensors)?
