VW Crafter scan abs errors
bagpipingandy
C?ID=74183
Hi, I am helping a friend with a vw crafter LT3, the abs light is on, along with traction control, I have tried to scan ABS module (03) but get a no communication error, so I suspect faulty abs, but changing it for another we get the same. I tried a full scan selecting crafter from the auto scan list and it scans the van ok, but there is no attempt to scan the ABS module 03, so my question is where is the abs module in vcds for the crafter? Can I scan the abs using vcds?
Any info greatly appreciated.
Best regards
Andy
bagpipingandy
C?ID=74183
Hi andy could you post your auto scan even if it doesnt scan the abs it still helps us with the details cheers
yes no problem, not sure how to attached but here is copy of text of 1st scan
Sunday,26,June,2016,14:51:13:05805
VCDS Version: 15.7.0.2
Data version: 20150820
VIN: WV1ZZZ2EZC6032361   License Plate:
                Address 01: Engine       Labels: 03L-906-012-CKT.clb
Control Module Part Number: 03L 906 012 Q    HW: 03L 906 012 A
  Component and/or Version: R4 2,0L EDC   H23 1860
           Software Coding: 0119401020040C080000
            Work Shop Code: WSC 00000 555 00117
              ASAM Dataset: EV_ECM20TDI01103L906012Q 001011 ()
                       ROD: EV_ECM20TDI01103L906012Q.rod
                      VCID: 32753F8F71865812AF24FCD-8066
4278 - Implausible Data Received from ABS Control Module
          U0415 00 [032] - -
4713 - No Communication with ABS Brake Control Module
          U0121 00 [032] - -
Readiness: 0 1 0 0 0
Address 01: DTCs clearedWednesday,03,August,2016,18:50:27:05805
Chassis Type: 2E (2E - VW Crafter (LT3 / 2006 >))
Scan: 01 91 92 93 94 95 96 97 98 99 9A 9B 9C 9D 9E 9F A0 A1 A2 A3
          B0 B1 B2 B3 B4 B5 B6 C1
Address 01: Engine (J623-CKTB)       Labels: 03L-906-012-CKT.clb
   Part No SW: 03L 906 012 Q    HW: 03L 906 012 A
   Component: R4 2,0L EDC   H23 1860
   Revision: 72H23---    Serial number: VWXDZ0L1001387
   Shop #: WSC 00000 555 00117
   VCID: 328EC24337BCF98568CA7F-8066
Readiness: 0 1 0 0 1
Address 93: LT3 Immo        Labels: 2E0-905-865-93.clb
   Part No SW: 2E0 909 052 HG    HW: 906 900 200 0
   Component: IMMO          0805  1006
   Revision: 00805000    Serial number: VWXDZ0L1001387
   VCID: 6F080B37E40E5C6D47649E-803A
Address 94: LT3 Airbag        Labels: None
   Part No HW: 9069014700
   Shop #: WSC 00117 555 00000
   ASAM Dataset: 3 3332
   ROD: CRFT_AB_3_3332.rod (*)
   VCID: 554459DF6692CEBDAD68FC-8000
Address 96: LT3 Instruments        Labels: None
   Part No SW: 9069021601    HW: 9069019800
   ASAM Dataset: 32 790
   ROD: CRFT_KOMBI_32_790.rod (*)
   VCID: 02EE5283C79C8905B82A4F-8056
9100 - Drivetrain CAN: No communication
            Test Complete - Stored
Address 99: LT3 Ign. Switch        Labels: None
   Part No HW: 9069002000
   ASAM Dataset: 67 257
   ROD: CRFT_EZS_67_257.rod (*)
900F - ABS Control Module (J104): Emergency opening canceled
            Test Complete - Active/Stored
900E - ABS Control Module (J104): Emergency opening performed
900D - ABS Control Module (J104): Emergency opening detected
Address 9A: LT3 Central Locks        Labels: 2E0-905-865-9A.clb
   Component: HF-FFB        0805  1006
   Revision: 00805000    Serial number: 12345678901234
   Shop #: WSC 00117 555 186459
Address 9B: LT3 Driver Door        Labels: None
   Part No HW: 9068204126
   ASAM Dataset: 33 773
   ROD: CRFT_FTUHR_33_773.rod (*)
9023 - Central locking; emergency opening activated: msg from elect. Ign./starter switch
Address B4: LT3 Central Elec.        Labels: None
   Part No SW: 9069021901    HW: 9069011500
   ASAM Dataset: 33 804
   ROD: CRFT_EZE_33_804.rod (*)
   VCID: 05E4499FD6B2BE3D9D086C-8050
90C1 - Emergency light activated; rotary light switch: implausible condition
90B2 - Control module: Faulty
9097 - Cent. locking - emerg. unlock activated: Sensor msg. from elect. Ign./start switch
903B - Back-up lights: Open circuit
900A - Bulb for right low beam headlamp (M31): Short to Plus
9099 - Terminal 54; brake pedal monitoring: Implausible signal
Address B6: LT3 Steering Wheel        Labels: None
   Part No SW: 9065402345    HW: 9065402345
   ASAM Dataset: 72 257
   ROD: CRFT_SML_72_257.rod (*)
   VCID: 06E64E93EBB4B525940213-8052
lewisbryant1992
C?ID=231472
If i was in your shoes id be getting my head into the fuse box and checking for any main abs controller fuses have blown and/or if its easy (get yourself a wiring to make it easier) test controller power and grounds, thats what i would do, if they all turn out good test CAN lines preferable with an oscilloscope, if there good then it can only be the controller, thats usually the approach i take.
I was working on a crafter last week and on my autoscan it contacted address 95 ESP
Hope ive been some help
bagpipingandy
C?ID=74183
I think it should be module 95, but my vcds wont connect to it??, it seems the crafter is a Mercedes and not a VW, I'm used to Audi VW models!! they make more sense :)
we fitted another (2nd hand) ABS module and still no connection in 3 or 95, what pins at the ABS controller can I check for power / grounds?
also looks like this central electric module B4 causes power issues and its the only module I cannot clear the error:
do we know if its linked to the ABS?
any info or ideas appreciated
regards
Andy
There could be a problem with ignition switch for the LT3.
If you have all power and grounds for the ABS module, it is most likely a bad weld joint within the module from pins to board.
There are dozens of videos on YouTube..........
bagpipingandy
C?ID=74183
ok update,
We tried a replacement abs, still no communication to module 95, tried a replavement LT3 Central Elec module- (address B4) this removed the 90B2 - Control module: Faulty error, but gave us 2 new ones
90EE - LIN bus: Timeout
90ED - LIN bus: Error
still no connection to ABS address 95,
I checked and get 2 x 12v and 2 x ground at the plug to the abs, not sure how to test CAN lines, any ideas?
I unplugged abs plug and scanned with vcds and engine module threw up abs no communication errors so the abs must be alive to some extent
the
I think his leads me back to the ABS module having a fault,
I'm thinking next step send pump away to get tested, any recommendations where to send it
or any other things to try feel free to suggest,
we still have ABS, ESP and 1 other error light on and MOT due!! :(
Tuesday,09,August,2016,19:30:37:05805
VCDS Version: 16.8.0.1
Data version: 20160801 DS254
VIN: WV1ZZZ2EZC6032361   License Plate: EBAY MODULE
   VCID: 326F53586539CCD264-8066
   VCID: 6FE99A2C7E8BA13A4B-803A
   VCID: 55A5C8C43417FBEAA1-8000
   VCID: 020FC3989519BC52B4-8056
00171 - Key 1 not learned
            000 -  -  - Intermittent
Address B0: LT3 Roof Display        Labels: None
   Part No SW: 9069021000    HW: 9069010900
   ASAM Dataset: 21 3
   ROD: CRFT_DBE_21_3.rod (*)
   VCID: 7BF1BE7CF2F3CD9AF7-802E
   VCID: 0505D88484378B6A91-8050
   VCID: 0607DF88B931807298-8052
End-------------------------(Elapsed Time: 03:14)--------------------------
I can clear all errors but they come back when the ignition is off and back on, the central locking tries to open the doors and this stores all the door emergency open errors
best regards
Andy
pembsv-dubs
C?ID=250431
what was the fix for this as we have the same issues on a crafter that come into us
ok update,
the
   ASAM Dataset: 21 3
best regards
Andy
Hi what was the fix for this abs fault as we have a customer come in today with the same issues
bagpipingandy
C?ID=74183
It went to abs specialist, he had oscilloscope on it and fixed it, not sure exactly what was done it, was a friends van but it was away for a while to get repaired, I think a brand new abs pump was fitted too
smirnoffrules
C?ID=269658
l love to know 100% what this was if you can find out friend , have one here the same , abs unit sent away and checked and returned saying its fine (ecu testing)
cheers
Keithuk
Stoke on Trent, England
C?ID=122432
Your using VCDS Version: 15.7.0.2 which is 16 versions out of date. http://www.ross-tech.com/vcds/download/current.php
I'm wondering why those VAG codes have letters in them, as far as I know EODB II codes start with a letter B, C, P or U.
It wasn't that far out of date on Sunday, 26 June, 2016 when the scan was done. ;)
The modules in that snippet are not emissions-related and thus of no concern to the generic OBD regulations. Moreover, those modules are MBZ (rather than VAG) and that's exactly how the factory scan too shows those codes -- in hexadecimal.
smirnoffrules
C?ID=269658
for some reason vcds wouldnt connect to abs ? but odis did and was a simple asb sensor
